[PATCH] testsuits: Fixed typo in fileio.doc
punitvara punitvara at gmail.com
Sat Feb 20 19:26:54 UTC 2016
        This patch basically fixes some typo in document file.
 testsuites/samples/fileio/fileio.doc | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/testsuites/samples/fileio/fileio.doc b/testsuites/samples/fileio/fileio.doc
index 0a43601..95d50b1 100644
--- a/testsuites/samples/fileio/fileio.doc
+++ b/testsuites/samples/fileio/fileio.doc
@@ -22,17 +22,17 @@ A sample session might look like this:
 - start this system
 - select "p" (part_table_initialize) to read in the partition table of
-first harddisk, enter the device name "/dev/hda", when prompted
+first hard disk, enter the device name "/dev/hda", when prompted
 - select "f" (fsmount) to try to mount the partitions
-  /dev/hda1../dev/hdc4 to corresponding mount points. Non-existant
+  /dev/hda1../dev/hdc4 to corresponding mount points. Non-existent
   partitions will report an error, but will not abort the tests
 - select "w" (write file) to create a new file on the mounted disk (or
   in the IMFS). Enter the file name (e.g. "/mnt/hda1/test_1M.txt"),
   the file size (e.g. 64K or 2M) and the buffer size to use for the
   write calls (e.g. 32 or 4K). Then the sample will try to write the
-  corresponding file and print the time consumed and data rate achived.
+  corresponding file and print the time consumed and data rate achieved.
 - select "r" (read file) to read a file (without displaying the
   contents). It has similar parameters as "write file", but does not
2.7.1
