[PATCH 1/8] or1k: Add further defines and helper functions in header file
jakob.viketoft at gmail.com
Sat Feb 20 22:58:42 UTC 2016
From: Jakob Viketoft <jakob.viketoft at aacmicrotec.com>
Close #2596.
cpukit/score/cpu/or1k/rtems/score/or1k-utility.h | 244 +++++++++++++++++++++--
1 file changed, 222 insertions(+), 22 deletions(-)
diff --git a/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h b/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
index 98bbe41..0eefd0a 100644
--- a/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
+++ b/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
@@ -4,6 +4,9 @@
* @brief OR1K utility
+ * COPYRIGHT (c) 2014-2015 ÅAC Microtec AB <www.aacmicrotec.com>
+ * Karol Gugala <kgugala at antmicro.com>
+ * Jakob Viketoft <jakob.viketoft at aacmicrotec.com>
* COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
* The license and distribution terms for this file may be
@@ -26,8 +29,8 @@
#define SPR_GRP7_PERF_CTR (7 << SPR_GRP_SHAMT)
#define SPR_GRP8_PWR_MNG (8 << SPR_GRP_SHAMT)
#define SPR_GRP9_PIC (9 << SPR_GRP_SHAMT)
-#define SPR_GPR10_TICK_TMR (10 << SPR_GRP_SHAMT)
-#define SPR_GPR11_FPU (11 << SPR_GRP_SHAMT)
+#define SPR_GRP10_TICK_TMR (10 << SPR_GRP_SHAMT)
+#define SPR_GRP11_FPU (11 << SPR_GRP_SHAMT)
/* SPR registers definitions */
@@ -196,8 +199,8 @@
#define CPU_OR1K_SPR_PICSR (SPR_GRP9_PIC + 2)
/* Group10: Tick Timer registers */
-#define CPU_OR1K_SPR_TTMR (SPR_GPR10_TICK_TMR + 0)
-#define CPU_OR1K_SPR_TTCR (SPR_GPR10_TICK_TMR + 1)
+#define CPU_OR1K_SPR_TTMR (SPR_GRP10_TICK_TMR + 0)
+#define CPU_OR1K_SPR_TTCR (SPR_GRP10_TICK_TMR + 1)
/* Shift amount macros for bits position in Supervision Register */
#define CPU_OR1K_SPR_SR_SHAMT_SM (0)
@@ -258,6 +261,114 @@
/*Context ID (Fast Context Switching) */
#define CPU_OR1K_SPR_SR_CID (F << CPU_OR1K_SPR_SR_SHAMT_CID)
+ * Bit definitions for the Version Register
+#define CPU_OR1K_SPR_VR_VER 0xff000000 /* Processor version */
+#define CPU_OR1K_SPR_VR_CFG 0x00ff0000 /* Processor configuration */
+#define CPU_OR1K_SPR_VR_RES 0x0000ffc0 /* Reserved */
+#define CPU_OR1K_SPR_VR_REV 0x0000003f /* Processor revision */
+#define CPU_OR1K_SPR_VR_VER_OFF 24
+#define CPU_OR1K_SPR_VR_CFG_OFF 16
+#define CPU_OR1K_SPR_VR_REV_OFF 0
+ * Bit definitions for the Unit Present Register
+#define CPU_OR1K_SPR_UPR_UP 0x00000001 /* UPR present */
+#define CPU_OR1K_SPR_UPR_DCP 0x00000002 /* Data cache present */
+#define CPU_OR1K_SPR_UPR_ICP 0x00000004 /* Instruction cache present */
+#define CPU_OR1K_SPR_UPR_DMP 0x00000008 /* Data MMU present */
+#define CPU_OR1K_SPR_UPR_IMP 0x00000010 /* Instruction MMU present */
+#define CPU_OR1K_SPR_UPR_MP 0x00000020 /* MAC present */
+#define CPU_OR1K_SPR_UPR_DUP 0x00000040 /* Debug unit present */
+#define CPU_OR1K_SPR_UPR_PCUP 0x00000080 /* Performance counters unit present */
+#define CPU_OR1K_SPR_UPR_PMP 0x00000100 /* Power management present */
+#define CPU_OR1K_SPR_UPR_PICP 0x00000200 /* PIC present */
+#define CPU_OR1K_SPR_UPR_TTP 0x00000400 /* Tick timer present */
+#define CPU_OR1K_SPR_UPR_RES 0x00fe0000 /* Reserved */
+#define CPU_OR1K_SPR_UPR_CUP 0xff000000 /* Context units present */
+ * Bit definitions for the CPU configuration register
+#define CPU_OR1K_SPR_CPUCFGR_NSGF 0x0000000f /* Number of shadow GPR files */
+#define CPU_OR1K_SPR_CPUCFGR_CGF 0x00000010 /* Custom GPR file */
+#define CPU_OR1K_SPR_CPUCFGR_OB32S 0x00000020 /* ORBIS32 supported */
+#define CPU_OR1K_SPR_CPUCFGR_OB64S 0x00000040 /* ORBIS64 supported */
+#define CPU_OR1K_SPR_CPUCFGR_OF32S 0x00000080 /* ORFPX32 supported */
+#define CPU_OR1K_SPR_CPUCFGR_OF64S 0x00000100 /* ORFPX64 supported */
+#define CPU_OR1K_SPR_CPUCFGR_OV64S 0x00000200 /* ORVDX64 supported */
+#define CPU_OR1K_SPR_CPUCFGR_RES 0xfffffc00 /* Reserved */
+ * Bit definitions for the Debug configuration register and other
+ * constants.
+#define CPU_OR1K_SPR_DCFGR_NDP 0x00000007 /* Number of matchpoints mask */
+#define CPU_OR1K_SPR_DCFGR_NDP1 0x00000000 /* One matchpoint supported */
+#define CPU_OR1K_SPR_DCFGR_NDP2 0x00000001 /* Two matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_NDP3 0x00000002 /* Three matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_NDP4 0x00000003 /* Four matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_NDP5 0x00000004 /* Five matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_NDP6 0x00000005 /* Six matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_NDP7 0x00000006 /* Seven matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_NDP8 0x00000007 /* Eight matchpoints supported */
+#define CPU_OR1K_SPR_DCFGR_WPCI 0x00000008 /* Watchpoint counters implemented */
+ * Bit definitions for Data Cache Control register
+#define CPU_OR1K_SPR_DCCR_EW 0x000000ff /* Enable ways */
+ * Bit definitions for Insn Cache Control register
+#define CPU_OR1K_SPR_ICCR_EW 0x000000ff /* Enable ways */
+ * Bit definitions for Data Cache Configuration Register
+#define CPU_OR1K_SPR_DCCFGR_NCW 0x00000007
+#define CPU_OR1K_SPR_DCCFGR_NCS 0x00000078
+#define CPU_OR1K_SPR_DCCFGR_CBS 0x00000080
+#define CPU_OR1K_SPR_DCCFGR_CWS 0x00000100
+#define CPU_OR1K_SPR_DCCFGR_CCRI 0x00000200
+#define CPU_OR1K_SPR_DCCFGR_CBIRI 0x00000400
+#define CPU_OR1K_SPR_DCCFGR_CBPRI 0x00000800
+#define CPU_OR1K_SPR_DCCFGR_CBLRI 0x00001000
+#define CPU_OR1K_SPR_DCCFGR_CBFRI 0x00002000
+#define CPU_OR1K_SPR_DCCFGR_CBWBRI 0x00004000
+#define CPU_OR1K_SPR_DCCFGR_NCW_OFF 0
+#define CPU_OR1K_SPR_DCCFGR_NCS_OFF 3
+#define CPU_OR1K_SPR_DCCFGR_CBS_OFF 7
+ * Bit definitions for Instruction Cache Configuration Register
+#define CPU_OR1K_SPR_ICCFGR_NCW 0x00000007
+#define CPU_OR1K_SPR_ICCFGR_NCS 0x00000078
+#define CPU_OR1K_SPR_ICCFGR_CBS 0x00000080
+#define CPU_OR1K_SPR_ICCFGR_CCRI 0x00000200
+#define CPU_OR1K_SPR_ICCFGR_CBIRI 0x00000400
+#define CPU_OR1K_SPR_ICCFGR_CBPRI 0x00000800
+#define CPU_OR1K_SPR_ICCFGR_CBLRI 0x00001000
+#define CPU_OR1K_SPR_ICCFGR_NCW_OFF 0
+#define CPU_OR1K_SPR_ICCFGR_NCS_OFF 3
+#define CPU_OR1K_SPR_ICCFGR_CBS_OFF 7
/* Tick timer configuration bits */
#define CPU_OR1K_SPR_TTMR_SHAMT_IP 28
#define CPU_OR1K_SPR_TTMR_SHAMT_IE 29
@@ -285,6 +396,84 @@
#define CPU_OR1K_SPR_PMR_DCGE (1 << CPU_OR1K_SPR_PMR_SHAMT_DCGE)
#define CPU_OR1K_SPR_PMR_SUME (1 << CPU_OR1K_SPR_PMR_SHAMT_SUME)
+#define REDZONE_SIZE (128)
+#define EX_FRAME_SIZE (140)
+/* Define the different offsets in a Control Context struct for a more
+ * controlled assembler manipulation */
+#define OR1K_CC_GPR1 (0)
+#define OR1K_CC_GPR2 (4)
+#define OR1K_CC_GPR3 (8)
+#define OR1K_CC_GPR4 (12)
+#define OR1K_CC_GPR5 (16)
+#define OR1K_CC_GPR6 (20)
+#define OR1K_CC_GPR7 (24)
+#define OR1K_CC_GPR8 (28)
+#define OR1K_CC_GPR9 (32)
+#define OR1K_CC_GPR10 (36)
+#define OR1K_CC_GPR11 (40)
+#define OR1K_CC_GPR12 (44)
+#define OR1K_CC_GPR13 (48)
+#define OR1K_CC_GPR14 (52)
+#define OR1K_CC_GPR15 (56)
+#define OR1K_CC_GPR16 (60)
+#define OR1K_CC_GPR17 (64)
+#define OR1K_CC_GPR18 (68)
+#define OR1K_CC_GPR19 (72)
+#define OR1K_CC_GPR20 (76)
+#define OR1K_CC_GPR21 (80)
+#define OR1K_CC_GPR22 (84)
+#define OR1K_CC_GPR23 (88)
+#define OR1K_CC_GPR24 (92)
+#define OR1K_CC_GPR25 (96)
+#define OR1K_CC_GPR26 (100)
+#define OR1K_CC_GPR27 (104)
+#define OR1K_CC_GPR28 (108)
+#define OR1K_CC_GPR29 (112)
+#define OR1K_CC_GPR30 (116)
+#define OR1K_CC_GPR31 (120)
+#define OR1K_CC_SR (124)
+#define OR1K_CC_EPCR0 (128)
+#define OR1K_CC_EEAR0 (132)
+#define OR1K_CC_ESR0 (136)
+/* Define the different offsets in an ExceptionContext struct for a more
+#define OR1K_EC_GPR1 (4)
+#define OR1K_EC_GPR2 (8)
+#define OR1K_EC_GPR3 (12)
+#define OR1K_EC_GPR4 (16)
+#define OR1K_EC_GPR5 (20)
+#define OR1K_EC_GPR6 (24)
+#define OR1K_EC_GPR7 (28)
+#define OR1K_EC_GPR8 (32)
+#define OR1K_EC_GPR9 (36)
+#define OR1K_EC_GPR10 (40)
+#define OR1K_EC_GPR11 (44)
+#define OR1K_EC_GPR12 (48)
+#define OR1K_EC_GPR13 (52)
+#define OR1K_EC_GPR14 (56)
+#define OR1K_EC_GPR15 (60)
+#define OR1K_EC_GPR16 (64)
+#define OR1K_EC_GPR17 (68)
+#define OR1K_EC_GPR18 (72)
+#define OR1K_EC_GPR19 (76)
+#define OR1K_EC_GPR20 (80)
+#define OR1K_EC_GPR21 (84)
+#define OR1K_EC_GPR22 (88)
+#define OR1K_EC_GPR23 (92)
+#define OR1K_EC_GPR24 (96)
+#define OR1K_EC_GPR25 (100)
+#define OR1K_EC_GPR26 (104)
+#define OR1K_EC_GPR27 (108)
+#define OR1K_EC_GPR28 (112)
+#define OR1K_EC_GPR29 (116)
+#define OR1K_EC_GPR30 (120)
+#define OR1K_EC_GPR31 (124)
+#define OR1K_EC_EPCR0 (128)
+#define OR1K_EC_EEAR0 (132)
+#define OR1K_EC_ESR0 (136)
#ifndef ASM
#include <stddef.h>
@@ -301,24 +490,24 @@ extern "C" {
* @see OpenRISC architecture manual - revision 0.
typedef enum {
- OR1K_EXCEPTION_RESET = 1,
- OR1K_EXCEPTION_BUS_ERR = 2,
- OR1K_EXCEPTION_D_PF = 3, /* Data Page Fault */
- OR1K_EXCEPTION_I_PF = 4, /* Instruction Page Fault */
- OR1K_EXCEPTION_TICK_TIMER = 5,
- OR1K_EXCEPTION_ALIGNMENT = 6,
- OR1K_EXCEPTION_I_UNDEF= 7, /* Undefiend instruction */
- OR1K_EXCEPTION_IRQ = 8, /* External interrupt */
- OR1K_EXCPETION_D_TLB = 9, /* Data TLB miss */
- OR1K_EXCPETION_I_TLB = 10, /* Instruction TLB miss */
- OR1K_EXCPETION_RANGE = 11, /* Range exception */
- OR1K_EXCPETION_SYS_CALL = 12,
- OR1K_EXCPETION_FP = 13, /* Floating point exception */
- OR1K_EXCPETION_TRAP = 14, /* Caused by l.trap instruction or by debug unit */
- OR1K_EXCPETION_RESERVED1 = 15,
- OR1K_EXCPETION_RESERVED2 = 16,
- OR1K_EXCPETION_RESERVED3 = 17,
- MAX_EXCEPTIONS = 17,
+ OR1K_EXCEPTION_RESET = 1,
+ OR1K_EXCEPTION_BUS_ERR = 2,
+ OR1K_EXCEPTION_D_PF = 3, /* Data Page Fault */
+ OR1K_EXCEPTION_I_PF = 4, /* Instruction Page Fault */
+ OR1K_EXCEPTION_TICK_TIMER = 5,
+ OR1K_EXCEPTION_ALIGNMENT = 6,
+ OR1K_EXCEPTION_I_UNDEF = 7, /* Undefined instruction */
+ OR1K_EXCEPTION_IRQ = 8, /* External interrupt */
+ OR1K_EXCEPTION_D_TLB = 9, /* Data TLB miss */
+ OR1K_EXCEPTION_I_TLB = 10, /* Instruction TLB miss */
+ OR1K_EXCEPTION_RANGE = 11, /* Range exception */
+ OR1K_EXCEPTION_SYS_CALL = 12,
+ OR1K_EXCEPTION_FP = 13, /* Floating point exception */
+ OR1K_EXCEPTION_TRAP = 14, /* Caused by l.trap instruction or by debug unit */
+ OR1K_EXCEPTION_RESERVED1 = 15,
+ OR1K_EXCEPTION_RESERVED2 = 16,
+ OR1K_EXCEPTION_RESERVED3 = 17,
+ MAX_EXCEPTIONS = 17,
OR1K_EXCEPTION_MAKE_ENUM_32_BIT = 0xffffffff
} OR1K_Symbolic_exception_name;
@@ -385,6 +574,17 @@ static inline void _OR1K_Sync_pipeline( void )
#define _OR1KSIM_CPU_Halt() \
asm volatile ("l.nop 0xc")
+static inline uint32_t _OR1K_Find_first_one(uint32_t value)
+ uint32_t position;
+ asm volatile(
+ "l.ff1 %0, %1;\n\t"
+ : "=r" (position) : "r" (value));
+ return position;
#ifdef __cplusplus
#endif
2.1.4
