[PATCH 3/8] OR1k exception handling and start code
jakob.viketoft at gmail.com jakob.viketoft at gmail.com
Sat Feb 20 23:00:39 UTC 2016
From: Jakob Viketoft <jakob.viketoft at aacmicrotec.com>
- Correct start vector table.
- Add proper init of registers and caches
- Add more information on unhandled exceptions
- Use defines instead of hardcoded values for readability
Close #2598
 c/src/lib/libbsp/or1k/generic_or1k/start/start.S   | 258 ++++++++++++++++++---
 cpukit/score/cpu/or1k/or1k-exception-default.c     |   1 +
 cpukit/score/cpu/or1k/or1k-exception-frame-print.c |  11 +-
 cpukit/score/cpu/or1k/or1k-exception-handler-low.S | 220 +++++++++---------
 4 files changed, 343 insertions(+), 147 deletions(-)
diff --git a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
index 26991c8..7a182df 100644
--- a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
+++ b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
@@ -1,11 +1,16 @@
  * Copyright (c) 2014-2015 Hesham ALMatary <heshamelmatary at gmail.com>
+ * Copyright (c) 2014-2016 ÅAC Microtec AB <www.aacmicrotec.com>
+ *                         Jakob Viketoft <jakob.viketoft at aacmicrotec.com>
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE
+ * http://www.rtems.org/license/LICENSE
 #include <bsp/linker-symbols.h>
+#include <rtems/score/or1k-utility.h>
+  .extern _ISR_Handler
 /* The following macro defines the first instructions every exception
  * should execute before jumping to its handler function from the
@@ -16,34 +21,22 @@
 #define EXCEPTION_SETUP(vector) \
   l.nop   ;\
-  l.addi  r1, r1, -200 ;\
-  l.sw    0(r1), r3; \
+  /* Add space for redzone and make space on the current stack \
+   * (from the interrupted thread) */ \
+  l.addi  r1, r1, -(REDZONE_SIZE + EX_FRAME_SIZE); \
+  l.sw    OR1K_EC_GPR3(r1), r3; \
   l.addi  r3, r0, vector; \
   l.j     _ISR_Handler; \
   l.nop
   .extern boot_card
-  .extern bsp_section_bss_begin
-  .extern bsp_section_bss_end
-  .extern  bsp_start_vector_table_end
-  .extern  bsp_start_vector_table_size
-  .extern  bsp_vector_table_size
-  .extern  bsp_section_stack_begin
-  .extern exception_frame_save
-  .extern _OR1K_Exception_Process
   .extern _OR1K_Exception_default
-  .extern rtems_clock_tick
-  .extern _exit
-  .extern printk
-  .extern bsp_interrupt_handler_default
   /* Global symbols */
   .global  _start
   .global bsp_start_vector_table_begin
-/* Popualte HW vector table */
+/* Populate HW vector table */
 .section .vector, "ax"
@@ -61,7 +54,7 @@ _dPageFault:
   EXCEPTION_SETUP(3)
 .org 0x400
-_iPageFaule:
+_iPageFault:
   EXCEPTION_SETUP(4)
 .org 0x500
@@ -105,18 +98,74 @@ _trap:
   EXCEPTION_SETUP(14)
 .org 0xF00
-_undef1:
+_res_future1:
   EXCEPTION_SETUP(15)
-.org 0x1500
-_undef2:
+.org 0x1000
+_res_future2:
   EXCEPTION_SETUP(16)
-.org 0x1900
-_undef3:
+.org 0x1100
+_res_future3:
   EXCEPTION_SETUP(17)
+.org 0x1200
+_res_future4:
+  EXCEPTION_SETUP(18)
+.org 0x1300
+_res_future5:
+  EXCEPTION_SETUP(19)
+.org 0x1400
+_res_future6:
+  EXCEPTION_SETUP(20)
+.org 0x1500
+_res_impspec1:
+  EXCEPTION_SETUP(21)
+.org 0x1600
+_res_impspec2:
+  EXCEPTION_SETUP(22)
+.org 0x1700
+_res_impspec3:
+  EXCEPTION_SETUP(23)
+.org 0x1800
+_res_impspec4:
+  EXCEPTION_SETUP(24)
+.org 0x1900
+_res_custom1:
+  EXCEPTION_SETUP(25)
+.org 0x1A00
+_res_custom2:
+  EXCEPTION_SETUP(26)
+.org 0x1B00
+_res_custom3:
+  EXCEPTION_SETUP(27)
+.org 0x1C00
+_res_custom4:
+  EXCEPTION_SETUP(28)
+.org 0x1D00
+_res_custom5:
+  EXCEPTION_SETUP(29)
+.org 0x1E00
+_res_custom6:
+  EXCEPTION_SETUP(30)
 .org 0x1F00
+_res_custom7:
+  EXCEPTION_SETUP(31)
+.org 0x2000
 bsp_start_vector_table_begin:
@@ -127,7 +176,7 @@ bsp_start_vector_table_begin:
   .word _OR1K_Exception_default /* Instruction Page Fault */
   .word _OR1K_Exception_default /* Tick timer */
   .word _OR1K_Exception_default /* Alignment */
-  .word _OR1K_Exception_default /* Undefiend Instruction */
+  .word _OR1K_Exception_default /* Undefined Instruction */
   .word _OR1K_Exception_default /* External Interrupt */
   .word _OR1K_Exception_default /* Data TLB Miss */
   .word _OR1K_Exception_default /* Instruction TLB Miss */
@@ -135,8 +184,22 @@ bsp_start_vector_table_begin:
   .word _OR1K_Exception_default /* System Call */
   .word _OR1K_Exception_default /* Floating Point Exception */
   .word _OR1K_Exception_default /* Trap */
-  .word _OR1K_Exception_default /* Reserver for future use */
+  .word _OR1K_Exception_default /* Reserved for future use */
+  .word _OR1K_Exception_default /* Reserved for implementation-specific */
+  .word _OR1K_Exception_default /* Reserved for custom exceptions. */
 bsp_start_vector_table_end:
@@ -145,10 +208,145 @@ bsp_start_vector_table_end:
   .type _start, at function
 _start:
+  /* Clear r0 */
+  l.movhi r0, 0
   /* Set SR register to Supervision mode */
-  l.ori  r1, r0, 0x1
-  l.mtspr r0, r1, 17
+  l.ori   r1, r0, CPU_OR1K_SPR_SR_SM
+  l.mtspr r0, r1, CPU_OR1K_SPR_SR
+  /* Clear all registers */
+  l.movhi r1, 0
+  l.movhi r2, 0
+  l.movhi r3, 0
+  l.movhi r4, 0
+  l.movhi r5, 0
+  l.movhi r6, 0
+  l.movhi r7, 0
+  l.movhi r8, 0
+  l.movhi r9, 0
+  l.movhi r10, 0
+  l.movhi r11, 0
+  l.movhi r12, 0
+  l.movhi r13, 0
+  l.movhi r14, 0
+  l.movhi r15, 0
+  l.movhi r16, 0
+  l.movhi r17, 0
+  l.movhi r18, 0
+  l.movhi r19, 0
+  l.movhi r20, 0
+  l.movhi r21, 0
+  l.movhi r22, 0
+  l.movhi r23, 0
+  l.movhi r24, 0
+  l.movhi r25, 0
+  l.movhi r26, 0
+  l.movhi r27, 0
+  l.movhi r28, 0
+  l.movhi r29, 0
+  l.movhi r30, 0
+  l.movhi r31, 0
+  /* Disable all interrupts */
+  l.mtspr r0, r0, CPU_OR1K_SPR_PICMR
+  /* Clear all pending interrupts */
+  l.mtspr r0, r0, CPU_OR1K_SPR_PICSR
+  /* Disable Tick-Timer */
+  l.mtspr r0, r0, CPU_OR1K_SPR_TTMR
+  /* Zero the counter */
+  l.mtspr r0, r0, CPU_OR1K_SPR_TTCR
+  /* Check if IC present and skip otherwise */
+  l.mfspr r24, r0, CPU_OR1K_SPR_UPR
+  l.andi  r26, r24, CPU_OR1K_SPR_UPR_ICP
+  l.sfeq  r26, r0
+  l.bf    9f
+  l.nop
+  /* Disable I-Cache */
+  l.mfspr r13, r0, CPU_OR1K_SPR_SR
+  l.addi  r11, r0, -1
+  l.xori  r11, r11, CPU_OR1K_SPR_SR_ICE
+  l.and   r11, r13, r11
+  l.mtspr r0, r11, CPU_OR1K_SPR_SR
+  /* Establish cache block size
+     If BS=0, 16;
+     If BS=1, 32;
+     r14 contain block size
+  l.mfspr r24, r0, CPU_OR1K_SPR_ICCFGR
+  l.andi  r26, r24, CPU_OR1K_SPR_ICCFGR_CBS
+  l.srli  r28, r26, 7
+  l.ori   r30, r0, 16
+  l.sll   r14, r30, r28
+  /* Establish number of cache sets
+     r16 contains number of cache sets
+     r28 contains log(# of cache sets)
+  l.andi  r26, r24, CPU_OR1K_SPR_ICCFGR_NCS
+  l.srli  r28, r26, 3
+  l.ori   r30, r0, 1
+  l.sll   r16, r30, r28
+  /* Invalidate IC */
+  l.addi  r6, r0, 0
+  l.sll   r5, r14, r28
+1:
+  l.mtspr r0, r6, CPU_OR1K_SPR_ICBIR
+  l.sfne  r6, r5
+  l.bf    1b
+  l.add   r6, r6, r14
+9:
+  /* Check if DC present and skip otherwise */
+  l.andi  r26, r24, CPU_OR1K_SPR_UPR_DCP
+  l.sfeq  r26, r0
+  l.bf    9f
+  l.nop
+  /* Disable DC */
+  l.mfspr r6, r0, CPU_OR1K_SPR_SR
+  l.addi  r5, r0, -1
+  l.xori  r5, r5, CPU_OR1K_SPR_SR_DCE
+  l.and   r5, r6, r5
+  l.mtspr r0, r5, CPU_OR1K_SPR_SR
+     If BS=0, 16;
+     If BS=1, 32;
+  l.mfspr r24, r0,CPU_OR1K_SPR_DCCFGR
+  l.andi  r26, r24, CPU_OR1K_SPR_DCCFGR_CBS
+  l.ori   r30, r0, 16
+  l.andi  r26, r24, CPU_OR1K_SPR_DCCFGR_NCS
+  l.ori   r30, r0, 1
+  /* Invalidate DC */
+  l.addi  r6, r0, 0
+1:
+  l.mtspr r0, r6, CPU_OR1K_SPR_DCBIR
+  l.sfne  r6, r5
+  l.bf    1b
+  l.add   r6, r6, r14
+9:
   /* load stack and frame pointers */
   l.movhi r1, hi(bsp_section_stack_begin)
   l.ori   r1, r1, lo(bsp_section_stack_begin)
diff --git a/cpukit/score/cpu/or1k/or1k-exception-default.c b/cpukit/score/cpu/or1k/or1k-exception-default.c
index 037a169..a7b309a 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-default.c
+++ b/cpukit/score/cpu/or1k/or1k-exception-default.c
@@ -18,5 +18,6 @@ void _OR1K_Exception_default(uint32_t vector, CPU_Exception_frame *frame);
+  printk("Unhandled exception %u\n", vector);
   rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
diff --git a/cpukit/score/cpu/or1k/or1k-exception-frame-print.c b/cpukit/score/cpu/or1k/or1k-exception-frame-print.c
index 75e169c..0745089 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-frame-print.c
+++ b/cpukit/score/cpu/or1k/or1k-exception-frame-print.c
@@ -16,7 +16,14 @@
 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
   uint32_t i;
-  for ( i = 0; i < 32; ++i ) {
-      printk( "r%02i = 0x%016x\n",i, frame->r[i]);
+  /* r0 is a special case (always zero) */
+  printk( "r%02i = 0x%016x\n", 0, 0);
+  for ( i = 1; i < 32; ++i ) {
+      printk( "r%02i = 0x%016x\n", i, frame->r[i]);
+  printk( "EPCR = 0x%016x\n", frame->epcr);
+  printk( "EEAR = 0x%016x\n", frame->eear);
+  printk( "ESR  = 0x%016x\n", frame->esr);
diff --git a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
index 96d0c8e..5f61b00 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
+++ b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
@@ -13,6 +13,9 @@
  *  http://www.rtems.org/license/LICENSE.
+ *  Contributor(s):
+ *   COPYRIGHT (c) 2016 ÅAC Microtec AB
 #ifdef HAVE_CONFIG_H
@@ -21,7 +24,7 @@
 #include <rtems/asm.h>
-#include "rtems/score/or1k-utility.h"
 .align 4
 .text
@@ -30,96 +33,88 @@ PUBLIC(_ISR_Handler)
  SYM(_ISR_Handler):
-  l.addi  r1, r1, -140
-  l.sw  8(r1),r2
-  /* r3 is saved by BSP exception handler */
-  l.sw  16(r1),r4
-  l.sw  20(r1),r5
-  l.sw  24(r1),r6
-  l.sw  28(r1),r7
-  l.sw  32(r1),r8
-  l.sw  36(r1),r9
-  l.sw  40(r1),r10
-  l.sw  44(r1),r11
-  l.sw  48(r1),r12
-  l.sw  52(r1),r13
-  l.sw  56(r1),r14
-  l.sw  60(r1),r15
-  l.sw  64(r1),r16
-  l.sw  68(r1),r17
-  l.sw  72(r1),r18
-  l.sw  76(r1),r19
-  l.sw  80(r1),r20
-  l.sw  84(r1),r21
-  l.sw  88(r1),r22
-  l.sw  92(r1),r23
-  l.sw  96(r1),r24
-  l.sw  100(r1),r25
-  l.sw  104(r1),r26
-  l.sw  108(r1),r27
-  l.sw  112(r1),r28
-  l.sw  116(r1),r29
-  l.sw  120(r1),r30
-  l.sw  124(r1),r31
-  /* Exception level related registers */
+  /* Store the registers (leave space for r0 although it isn't stored) */
+  l.sw    OR1K_EC_GPR2(r1), r2
+  /* r3 is saved by BSP exception setup */
+  l.sw    OR1K_EC_GPR4(r1), r4
+  l.sw    OR1K_EC_GPR5(r1), r5
+  l.sw    OR1K_EC_GPR6(r1), r6
+  l.sw    OR1K_EC_GPR7(r1), r7
+  l.sw    OR1K_EC_GPR8(r1), r8
+  l.sw    OR1K_EC_GPR9(r1), r9
+  l.sw    OR1K_EC_GPR10(r1), r10
+  l.sw    OR1K_EC_GPR11(r1), r11
+  l.sw    OR1K_EC_GPR12(r1), r12
+  l.sw    OR1K_EC_GPR13(r1), r13
+  l.sw    OR1K_EC_GPR14(r1), r14
+  l.sw    OR1K_EC_GPR15(r1), r15
+  l.sw    OR1K_EC_GPR16(r1), r16
+  l.sw    OR1K_EC_GPR17(r1), r17
+  l.sw    OR1K_EC_GPR18(r1), r18
+  l.sw    OR1K_EC_GPR19(r1), r19
+  l.sw    OR1K_EC_GPR20(r1), r20
+  l.sw    OR1K_EC_GPR21(r1), r21
+  l.sw    OR1K_EC_GPR22(r1), r22
+  l.sw    OR1K_EC_GPR23(r1), r23
+  l.sw    OR1K_EC_GPR24(r1), r24
+  l.sw    OR1K_EC_GPR25(r1), r25
+  l.sw    OR1K_EC_GPR26(r1), r26
+  l.sw    OR1K_EC_GPR27(r1), r27
+  l.sw    OR1K_EC_GPR28(r1), r28
+  l.sw    OR1K_EC_GPR29(r1), r29
+  l.sw    OR1K_EC_GPR30(r1), r30
+  l.sw    OR1K_EC_GPR31(r1), r31
   /* EPCR */
   l.mfspr r13, r0, CPU_OR1K_SPR_EPCR0
-  l.sw  128(r1), r13 /* epcr */
+  l.sw    OR1K_EC_EPCR0(r1), r13
   /* EEAR */
   l.mfspr r13, r0, CPU_OR1K_SPR_EEAR0
-  l.sw  132(r1), r13 /* eear */
+  l.sw    OR1K_EC_EEAR0(r1), r13
   /* ESR */
   l.mfspr r13, r0, CPU_OR1K_SPR_ESR0
-  l.sw  136(r1), r13  /* esr */
+  l.sw    OR1K_EC_ESR0(r1), r13
   /* Increment nesting level */
   l.movhi r6, hi(ISR_NEST_LEVEL)
   l.ori   r6, r6, lo(ISR_NEST_LEVEL)
+  l.lwz   r5, 0(r6)
+  l.addi  r5, r5, 1
+  l.sw    0(r6), r5
-  /* Disable multitasking */
+  /* Disable multitasking / thread dispatching */
   l.movhi r8, hi(THREAD_DISPATCH_DISABLE_LEVEL)
   l.ori   r8, r8, lo(THREAD_DISPATCH_DISABLE_LEVEL)
-  l.lwz   r5, 0(r6)
   l.lwz   r7, 0(r8)
-  l.addi  r5, r5, 1
   l.addi  r7, r7, 1
-  l.sw    0(r6), r5
   l.sw    0(r8), r7
-  /* Save interrupted task stack pointer */
-  l.addi r4, r1, 340
-  l.sw   4(r1), r4
+  /* Find installed handler */
+  l.add  r11, r3, r0
+  l.slli r11, r11, 2
+  l.addi r11, r11, lo(bsp_start_vector_table_begin)
+  l.lwz  r11, 0(r11)
-  /* Save interrupted task r3 (first arg) value */
-  l.addi r4, r1, 140
-  l.lwz  r4, 0(r4)
-  l.sw  12(r1), r4
+  /* Save interrupted task stack pointer for exception frame diagnostics */
+  l.addi  r8, r1, REDZONE_SIZE
+  l.addi  r8, r8, EX_FRAME_SIZE
+  l.sw   4(r1), r8
-  /* Keep r1 (Exception frame address) in r14 */
-  l.add   r14, r1, r0
-  /* Call the exception handler from vector table */
-  /* First function arg for C handler is vector number,
-   * and the second is a pointer to exception frame.
+  /* First function arg for C handler is vector number (already there),
+   * and the second is a pointer to the exception frame.
-  l.add  r13, r3, r0
-  l.add  r4, r1, r0
-  l.slli r13, r13, 2
-  l.addi r13, r13, lo(bsp_start_vector_table_begin)
-  l.lwz  r13, 0(r13)
+  l.add   r4, r1, r0
+  /* Keep r1 (exception frame address) in r14 */
+  l.add   r14, r1, r0
   /* Do not switch stacks if we are in a nested interrupt. At
    * this point r5 should be holding ISR_NEST_LEVEL value.
   l.sfgtui r5, 1
-  l.bf jump_to_c_handler
+  l.bf    jump_to_c_handler
   l.nop
    /* Switch to RTEMS dedicated interrupt stack */
@@ -128,35 +123,35 @@ PUBLIC(_ISR_Handler)
   l.lwz   r1, 0(r1)
 jump_to_c_handler:
-  l.jalr r13
+  /* Call the exception handler from vector table */
+  l.jalr r11
   l.nop
-  /* Switch back to the interrupted task stack */
-  l.add r1, r14, r0
+  /* Switch back to the interrupted task stack (if changed) */
+  l.add   r1, r14, r0
   /* Decrement nesting level */
+  l.lwz   r5, 0(r6)
+  l.addi  r5, r5, -1
+  l.sw    0(r6), r5
   /* Enable multitasking */
-  l.lwz   r5, 0(r6)
   l.lwz   r7, 0(r8)
-  l.addi  r5, r5, -1
   l.addi  r7, r7, -1
-  l.sw    0(r6), r5
   l.sw    0(r8), r7
   /* Check if _ISR_Nest_level > 0 */
   l.sfgtui r5, 0
-  l.bf exception_frame_restore
+  l.bf    exception_frame_restore
   l.nop
   /* Check if _Thread_Dispatch_disable_level > 0 */
   l.sfgtui r7, 0
   l.nop
   /* Check if dispatch needed */
@@ -172,58 +167,53 @@ jump_to_c_handler:
   l.jalr  r13
   l.nop
- SYM(exception_frame_restore):
+SYM(exception_frame_restore):
   /* EPCR */
-  l.lwz  r13,  128(r1)
+  l.lwz   r13,  OR1K_EC_EPCR0(r1)
   l.mtspr r0, r13, CPU_OR1K_SPR_EPCR0
   /* EEAR */
-  l.lwz  r13,  132(r1)
+  l.lwz   r13,  OR1K_EC_EEAR0(r1)
   l.mtspr r0, r13, CPU_OR1K_SPR_EEAR0
   /* ESR */
-  l.lwz  r13,  136(r1)
+  l.lwz   r13,  OR1K_EC_ESR0(r1)
   l.mtspr r0, r13, CPU_OR1K_SPR_ESR0
-  l.lwz  r2,  8(r1)
-  l.lwz  r3,  12(r1)
-  l.lwz  r4,  16(r1)
-  l.lwz  r5,  20(r1)
-  l.lwz  r6,  24(r1)
-  l.lwz  r7,  28(r1)
-  l.lwz  r8,  32(r1)
-  l.lwz  r9,  36(r1)
-  l.lwz  r10, 40(r1)
-  l.lwz  r11, 44(r1)
-  l.lwz  r12, 48(r1)
-  l.lwz  r13, 52(r1)
-  l.lwz  r14, 56(r1)
-  l.lwz  r15, 60(r1)
-  l.lwz  r16, 64(r1)
-  l.lwz  r17, 68(r1)
-  l.lwz  r18, 72(r1)
-  l.lwz  r19, 76(r1)
-  l.lwz  r20, 80(r1)
-  l.lwz  r21, 84(r1)
-  l.lwz  r22, 88(r1)
-  l.lwz  r23, 92(r1)
-  l.lwz  r24, 96(r1)
-  l.lwz  r25, 100(r1)
-  l.lwz  r26, 104(r1)
-  l.lwz  r27, 108(r1)
-  l.lwz  r28, 112(r1)
-  l.lwz  r29, 116(r1)
-  l.lwz  r30, 120(r1)
-  l.lwz  r31, 124(r1)
-  /* Unwind exception frame */
-  l.addi r1, r1, 140
-  /* Red-zone */
-  l.addi r1, r1, 200
+  /* Restore GPRs */
+  l.lwz   r2,  OR1K_EC_GPR2(r1)
+  l.lwz   r3,  OR1K_EC_GPR3(r1)
+  l.lwz   r4,  OR1K_EC_GPR4(r1)
+  l.lwz   r5,  OR1K_EC_GPR5(r1)
+  l.lwz   r6,  OR1K_EC_GPR6(r1)
+  l.lwz   r7,  OR1K_EC_GPR7(r1)
+  l.lwz   r8,  OR1K_EC_GPR8(r1)
+  l.lwz   r9,  OR1K_EC_GPR9(r1)
+  l.lwz   r10, OR1K_EC_GPR10(r1)
+  l.lwz   r11, OR1K_EC_GPR11(r1)
+  l.lwz   r12, OR1K_EC_GPR12(r1)
+  l.lwz   r13, OR1K_EC_GPR13(r1)
+  l.lwz   r14, OR1K_EC_GPR14(r1)
+  l.lwz   r15, OR1K_EC_GPR15(r1)
+  l.lwz   r16, OR1K_EC_GPR16(r1)
+  l.lwz   r17, OR1K_EC_GPR17(r1)
+  l.lwz   r18, OR1K_EC_GPR18(r1)
+  l.lwz   r19, OR1K_EC_GPR19(r1)
+  l.lwz   r20, OR1K_EC_GPR20(r1)
+  l.lwz   r21, OR1K_EC_GPR21(r1)
+  l.lwz   r22, OR1K_EC_GPR22(r1)
+  l.lwz   r23, OR1K_EC_GPR23(r1)
+  l.lwz   r24, OR1K_EC_GPR24(r1)
+  l.lwz   r25, OR1K_EC_GPR25(r1)
+  l.lwz   r26, OR1K_EC_GPR26(r1)
+  l.lwz   r27, OR1K_EC_GPR27(r1)
+  l.lwz   r28, OR1K_EC_GPR28(r1)
+  l.lwz   r29, OR1K_EC_GPR29(r1)
+  l.lwz   r30, OR1K_EC_GPR30(r1)
+  l.lwz   r31, OR1K_EC_GPR31(r1)
+  /* Unwind exception frame and redzone */
+  l.addi  r1, r1, (EX_FRAME_SIZE + REDZONE_SIZE)
   l.rfe
   l.nop
2.1.4
