RTEMS 4.12 tool chain update required
Joel Sherrill
joel at rtems.org
Wed Feb 24 16:43:38 UTC 2016
We will need to bump again once the next newlib snapshot comes out. I added
methods missing methods to pthread.h and need it before I can submit patches
to add those methods to RTEMS.
I suppose we could bump to a git snapshot but I would rather avoid that
since
it seems to cause users with draconian firewalls problems.
--joel
On Wed, Feb 24, 2016 at 10:28 AM, Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> Thanks for the heads up.
> This is sorted out in the latest RSB patch I submitted.
> On Mon, Jan 18, 2016 at 2:01 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > I updated the RTEMS 4.12 tool chain to use the
> > * current Binutils 2.26 branch (the Binutils 2.26 release is close),
> > * Newlib 2.3.0.20160104 snapshot, and
> > * the GCC 6-20160117 snapshot.
> > The non-FSF based tool chains (or1k and epiphany) are now probably out of
> > sync.
> > RTEMS uses now the <sys/select.h> provided by Newlib, thus all users of
> the
> > RTEMS master branch must update their tool chain now. See also
> > https://lists.rtems.org/pipermail/devel/2015-December/013145.html.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Hesham
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160224/4ef9aa47/attachment.html>
