[PATCH] Beaglebone: Fix the IRQ handling code
Ben Gras beng at shrike-systems.com
Sat Feb 27 23:28:41 UTC 2016
All,
I tested this on current HEAD and verified it fixes a case I'd ran
into trouble with before, namely gpio-triggered irqs. Great to see. I
pushed your change with a commit message based on your original email,
Martin. I hope you like it.
Thank you!
On Sat, Feb 27, 2016 at 10:16 PM, Ben Gras <beng at shrike-systems.com> wrote:
> I'm doing a rebase & build right now, thanks for the reminder.
> On Fri, Feb 26, 2016 at 10:32 PM, Martin Galvan
> <martin.galvan at tallertechnologies.com> wrote:
>> Hi Ben! Sorry to bother, were you able to test my changes to the BBB
>> interrupt handler?
>> On Fri, Feb 12, 2016 at 11:09 AM, Martin Galvan
>>> Thanks Ben! Indeed, any further testing is more than welcome :)
>>> On Thu, Feb 11, 2016 at 7:55 PM, Ben Gras <beng at shrike-systems.com> wrote:
>>>> This looks like great work. Please let me test it (I'll try the GPIO
>>>> interrupt trigger) & I'll merge it as soon as I have time.
>>>> Thank you!
>>>> Cheers,
>>>> Ben
>>>> On Thu, Feb 11, 2016 at 3:27 PM, Martin Galvan
>>>>> This patch makes the following changes to the Beaglebone IRQ handling code:
>>>>> - Disable support for nested interrupts.
>>>>> - Detect spurious IRQs using the SPURIOUSIRQ field of the INTC_SIR_IRQ register.
>>>>> - Acknowledge spurious IRQs by setting the NewIRQAgr bit of the INTC_CONTROL
>>>>>   register. This cleans the SPURIOUSIRQ field and allows new interrupts
>>>>>   to be generated.
>>>>> - Improve the get_mir_reg function a bit.
>>>>> The Beaglebone bsp_interrupt_dispach function has been troublesome for a while now.
>>>>> We've seen it break the GPIO API (https://lists.rtems.org/pipermail/devel/2015-November/012995.html),
>>>>> the RTEMS interrupt server (https://lists.rtems.org/pipermail/devel/2015-July/011865.html),
>>>>> and now we've been getting spurious interrupts when trying to use the I2C module.
>>>>> We've done a lot of testing and concluded that the cause of most of these issues
>>>>> is the way nested interrupts are being handled. The AM335X manual states that
>>>>> the interrupt handling sequence should be as follows:
>>>>> 1. Identify the IRQ source by reading the ActiveIRQ field of the INTC_SIR_IRQ
>>>>>    register.
>>>>> 2. Jump to the corresponding IRQ handler, which should serve the IRQ and
>>>>>    deassert the interrupt condition at the peripheral side.
>>>>> 3. Enable the processing of new IRQs at the Interrupt Controller side by setting
>>>>>    the NewIRQAgr bit of the INTC_CONTROL register.
>>>>> 4. Finally, enable IRQs at the CPU side. This is done later in
>>>>>    _ARMV4_Exception_interrupt.
>>>>> Right now the Beaglebone bsp_interrupt_dispach enables IRQs at the INTC and CPU
>>>>> before jumping to the interrupt handler to allow for nested IRQs.
>>>>> Before doing so, it calls bsp_interrupt_disable to mask the IRQ source and avoid
>>>>> having it constantly fire new IRQs. After it's done it re-enables the IRQ
>>>>> by calling bsp_interrupt_enable. These calls break the GPIO API and the
>>>>> RTEMS interrupt server machinery, and we suspect it's also causing the spurious
>>>>> interrupts we saw with the I2C module.
>>>>> The correct way to enable interrupt nesting according to both the manual and
>>>>> the AM335X StarterWare code is to allow only interrupts of a higher priority
>>>>> to preempt the current one. This can be achieved by setting the INTC_THRESHOLD
>>>>> register to the priority of the current IRQ. However, in our case this isn't
>>>>> necessary since all the interrupt priorities are set to 0 (the highest possible)
>>>>> in bsp_interrupt_facility_initialize. We may implement this in a future patch,
>>>>> if required.
>>>>> We've tested this quite extensively on a number of different applications, and
>>>>> it's working fine.
>>>>> Closes #2580.
>>>>>  c/src/lib/libbsp/arm/beagle/irq.c           | 82 +++++++++++++++--------------
>>>>>  c/src/lib/libcpu/arm/shared/include/omap3.h |  3 +-
>>>>>  2 files changed, 44 insertions(+), 41 deletions(-)
>>>>> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
>>>>> index c6485cd..d080a5e 100644
>>>>> --- a/c/src/lib/libbsp/arm/beagle/irq.c
>>>>> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
>>>>> @@ -18,6 +18,7 @@
>>>>>  #include <bsp.h>
>>>>>  #include <bsp/irq-generic.h>
>>>>>  #include <bsp/linker-symbols.h>
>>>>> +#include <bsp/fatal.h>
>>>>>  #include <rtems/score/armv4.h>
>>>>> @@ -43,77 +44,78 @@ static struct omap_intr omap_intr = {
>>>>>  #endif
>>>>> -static int irqs_enabled[BSP_INTERRUPT_VECTOR_MAX+1];
>>>>> +/* Enables interrupts at the Interrupt Controller side. */
>>>>> +static inline void omap_irq_ack(void)
>>>>> +  mmio_write(omap_intr.base + OMAP3_INTCPS_CONTROL, OMAP3_INTR_NEWIRQAGR);
>>>>> -volatile static int level = 0;
>>>>> +  /* Flush data cache to make sure all the previous writes are done
>>>>> +     before re-enabling interrupts. */
>>>>> +  flush_data_cache();
>>>>>  void bsp_interrupt_dispatch(void)
>>>>> -  /* get irq */
>>>>> -  uint32_t reg = mmio_read(omap_intr.base + OMAP3_INTCPS_SIR_IRQ);
>>>>> -  int irq;
>>>>> -  irq = reg & OMAP3_INTR_ACTIVEIRQ_MASK;
>>>>> +  const uint32_t reg = mmio_read(omap_intr.base + OMAP3_INTCPS_SIR_IRQ);
>>>>> -  if(!irqs_enabled[irq]) {
>>>>> -       /* Ignore spurious interrupt */
>>>>> -  } else {
>>>>> -    bsp_interrupt_vector_disable(irq);
>>>>> -    /* enable new interrupts, and flush data cache to make sure
>>>>> -     * it hits the intc
>>>>> -    mmio_write(omap_intr.base + OMAP3_INTCPS_CONTROL, OMAP3_INTR_NEWIRQAGR);
>>>>> -    flush_data_cache();
>>>>> -    mmio_read(omap_intr.base + OMAP3_INTCPS_SIR_IRQ);
>>>>> -    /* keep current irq masked but enable unmasked ones */
>>>>> -    uint32_t psr = _ARMV4_Status_irq_enable();
>>>>> -    bsp_interrupt_handler_dispatch(irq);
>>>>> -    _ARMV4_Status_restore(psr);
>>>>> +  if ((reg & OMAP3_INTR_SPURIOUSIRQ_MASK) != OMAP3_INTR_SPURIOUSIRQ_MASK) {
>>>>> +    const rtems_vector_number irq = reg & OMAP3_INTR_ACTIVEIRQ_MASK;
>>>>> -    bsp_interrupt_vector_enable(irq);
>>>>> +    bsp_interrupt_handler_dispatch(irq);
>>>>> +  } else {
>>>>> +    /* Ignore spurious interrupts. We'll still ACK it so new interrupts
>>>>> +       can be generated. */
>>>>> +  omap_irq_ack();
>>>>> -static uint32_t get_mir_reg(int vector, uint32_t *mask)
>>>>> +/* There are 4 32-bit interrupt mask registers for a total of 128 interrupts.
>>>>> +   The IRQ number tells us which register to use. */
>>>>> +static uint32_t omap_get_mir_reg(rtems_vector_number vector, uint32_t *const mask)
>>>>> -  *mask = 1UL << (vector % 32);
>>>>> -  if(vector <   0) while(1) ;
>>>>> -  if(vector <  32) return OMAP3_INTCPS_MIR0;
>>>>> -  if(vector <  64) return OMAP3_INTCPS_MIR1;
>>>>> -  if(vector <  96) return OMAP3_INTCPS_MIR2;
>>>>> -  if(vector < 128) return OMAP3_INTCPS_MIR3;
>>>>> -  while(1) ;
>>>>> +  uint32_t mir_reg;
>>>>> +  /* Select which bit to set/clear in the MIR register. */
>>>>> +  *mask = 1ul << (vector % 32u);
>>>>> +  if (vector < 32u) {
>>>>> +    mir_reg = OMAP3_INTCPS_MIR0;
>>>>> +  } else if (vector < 64u) {
>>>>> +    mir_reg = OMAP3_INTCPS_MIR1;
>>>>> +  } else if (vector < 96u) {
>>>>> +    mir_reg = OMAP3_INTCPS_MIR2;
>>>>> +  } else if (vector < 128u) {
>>>>> +    mir_reg = OMAP3_INTCPS_MIR3;
>>>>> +  } else {
>>>>> +    /* Invalid IRQ number. This should never happen. */
>>>>> +    bsp_fatal(0);
>>>>> +  return mir_reg;
>>>>>  rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>>>>>    uint32_t mask, cur;
>>>>> -  uint32_t mir_reg = get_mir_reg(vector, &mask);
>>>>> +  uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
>>>>>    cur = mmio_read(omap_intr.base + mir_reg);
>>>>>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>>>>>    flush_data_cache();
>>>>> -  irqs_enabled[vector] = 1;
>>>>>    return RTEMS_SUCCESSFUL;
>>>>>  rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>>>>>    uint32_t mask, cur;
>>>>>    mmio_write(omap_intr.base + mir_reg, cur | mask);
>>>>>    flush_data_cache();
>>>>> -  irqs_enabled[vector] = 0;
>>>>> diff --git a/c/src/lib/libcpu/arm/shared/include/omap3.h b/c/src/lib/libcpu/arm/shared/include/omap3.h
>>>>> index f28e5e5..0cc43d6 100644
>>>>> --- a/c/src/lib/libcpu/arm/shared/include/omap3.h
>>>>> +++ b/c/src/lib/libcpu/arm/shared/include/omap3.h
>>>>> @@ -72,7 +72,8 @@
>>>>>  #define OMAP3_INTR_ILR(base,m) \
>>>>>      (base + OMAP3_INTCPS_ILR0 + 0x4 * (m))
>>>>> -#define OMAP3_INTR_ACTIVEIRQ_MASK 0x7f /* Active IRQ mask for SIR_IRQ */
>>>>> +#define OMAP3_INTR_SPURIOUSIRQ_MASK (0x1FFFFFF << 7) /* Spurious IRQ mask for SIR_IRQ */
>>>>> +#define OMAP3_INTR_ACTIVEIRQ_MASK 0x7F /* Active IRQ mask for SIR_IRQ */
>>>>>  #define OMAP3_INTR_NEWIRQAGR      0x1  /* New IRQ Generation */
>>>>>  #define OMAP3_DM337X_NR_IRQ_VECTORS    96
>>>>> 2.7.1
>>> Martin Galvan
>>> Software Engineer
>>> Taller Technologies Argentina
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Córdoba, Argentina
>>> Phone: 54 351 4217888 / +54 351 4218211
>> Martin Galvan
>> Software Engineer
>> Córdoba, Argentina
