Error in building
Hesham Almatary heshamelmatary at gmail.com
Sun Feb 28 09:32:45 UTC 2016
Hi Animesh,
The RTEMS master branch assumes you are using the 4.12 RSB release (so
you have to replace your 4.11 built tools with a 4.12 build).
Regards,
Hesham
On Sun, Feb 28, 2016 at 4:46 AM, animesh pathak <animesh2049 at gmail.com> wrote:
> Hi, I am new to RTEMS. I am trying to setup the environment but getting
> error.
> I followed the instruction from the rtems website. Firstly I installed RSB
> as instructed by this link https://devel.rtems.org/wiki/Developer/Tools/RSB
> (../source-builder/sb-set-builder --prefix=$HOME/development/rtems/4.11
> 4.11/rtems-sparc).
> Then I followed the instruction from this link to install RTEMS
> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start. I cloned from this
> link git://git.rtems.org/rtems.git. And now I am getting the errror fatal
> error: sys/select.h: No such file or directory.
> But sys/select.h is there when I tried locating that.
> can someone help me out ?
> Regards
> Animesh
> devel mailing list
> devel at rtems.org
Hesham
