Participation in GSoC 2016
Deval Shah
deval.maker at gmail.com
Mon Feb 29 19:45:24 UTC 2016
It looks like there are more useful things in pipeline before raspberry pi
cam support.
Can anybody give me pointers/links to refer for porting ethernet support
and SD card support?
On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
soja-lists at aries.uberspace.de> wrote:
> Am 2016-02-18 01:26, schrieb Joel Sherrill:
>> On Feb 17, 2016 6:17 PM, "André Marques" <andre.lousa.marques at gmail.com>
>> wrote:
>> Was i2c fully delivered for the new driver framework? I don't recall
>>> off-hand.
>>> Yes the i2c driver for the Pi uses the new (linux-based) i2c framework.
>> 10-bit addressing is untested because I had no compatible slave device.
>>> A detailed report of my last GSOC can be found here:
>>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card
>>> SD card support was started but not completed last year, so it may be
>> included on a potential Raspberry project. I can help with that if needed.
>> Andres.. Thanks for speaking up. Can you update the project page and link
>> to your blog?
>> What else do you think needs find on the Pi and Pi2?
> Last year there was a GSoC to add ethernet support for the raspberry pi
> via rtems-libbsd, but I think it was never finished.
> Maybe that could be started again?
> I haven't researched it yet to know if it is feasible but I am curious if
>> the Arduino HW libraries have a clean porting layer which could provide
>> support for a lot of i2c devices. Is this a wikd goose chase or of
>> potential value?
> Sounds like an interesting idea, but isn't Arduino written in C++?
> Best regards,
> Jan
>>> I very much look forward for any pointers on this.
>>>>> I am eager to work for RTEMS organization because I believe my skill
>>>>> set is best suited for this.
>>>>> Thanking you,
>>>>> Deval Shah
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> --André Marques
>>> devel mailing list
>>> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160301/b3594de7/attachment.html>
