Participation in GSoC 2016
André Marques andre.lousa.marques at gmail.com
Mon Feb 29 21:37:35 UTC 2016
Hello Jan and Deval,
Às 20:24 de 29-02-2016, Jan Sommer escreveu:
> Hi,
> If you take a look here: https://devel.rtems.org/wiki/GSoC/2015#StudentsSummerofCodeTrackingTable you can find the links to the reports and repositories of the previous GSoC.
> Yurii Shevtsov was doing the work on the Ethernet/USB part for the pi.
> Andre Marques worked on the SPI and SD-Card driver.
I have updated a bit the Raspberry Open Projects page with the state of
the low level peripherals project, and provided links to the state of
each of the other projects (the wiki pages of the students working on
them last year, which also include their blogs and githubs).
https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveRaspberryPiBSP
  The other 3 raspberry projects I do not know exactly their current
state, but they already have some work done (just not in the RTEMS tree
yet).
It seems that only GPIO, I2C and SPI were merged last year.
> Cheers,
>     Jan
> Am Tuesday 01 March 2016, 01:15:24 schrieb Deval Shah:
>> It looks like there are more useful things in pipeline before raspberry pi
>> cam support.
>> Can anybody give me pointers/links to refer for porting ethernet support
>> and SD card support?
For the last year efforts on the SD card support you can refer to:
https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
>> On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
>> soja-lists at aries.uberspace.de> wrote:
>>> Am 2016-02-18 01:26, schrieb Joel Sherrill:
>>>> On Feb 17, 2016 6:17 PM, "André Marques" <andre.lousa.marques at gmail.com>
>>>> wrote:
>>>> Was i2c fully delivered for the new driver framework? I don't recall
>>>>> off-hand.
>>>>> Yes the i2c driver for the Pi uses the new (linux-based) i2c framework.
>>>> 10-bit addressing is untested because I had no compatible slave device.
>>>>> A detailed report of my last GSOC can be found here:
>>>>> SD card support was started but not completed last year, so it may be
>>>> included on a potential Raspberry project. I can help with that if needed.
>>>> Andres.. Thanks for speaking up. Can you update the project page and link
>>>> to your blog?
>>>> What else do you think needs find on the Pi and Pi2?
>>> Last year there was a GSoC to add ethernet support for the raspberry pi
>>> via rtems-libbsd, but I think it was never finished.
>>> Maybe that could be started again?
>>> I haven't researched it yet to know if it is feasible but I am curious if
>>>> the Arduino HW libraries have a clean porting layer which could provide
>>>> support for a lot of i2c devices. Is this a wikd goose chase or of
>>>> potential value?
>>> Sounds like an interesting idea, but isn't Arduino written in C++?
>>> Best regards,
>>>     Jan
>>>>> I very much look forward for any pointers on this.
>>>>>>> I am eager to work for RTEMS organization because I believe my skill
>>>>>>> set is best suited for this.
>>>>>>> Thanking you,
>>>>>>> Deval Shah
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> --André Marques
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>> devel mailing list
>>>> devel at rtems.org
>>> devel mailing list
>>> devel at rtems.org
> devel mailing list
> devel at rtems.org
--André Marques
