[PATCH 6/7] i386 ..score/cpu.h: Fix spacing
Gedare Bloom
gedare at rtems.org
Mon Feb 15 19:05:43 UTC 2016
cpukit/score/cpu/i386/rtems/score/cpu.h | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 34845b0..18b63af 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -408,10 +408,10 @@ SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
else __asm__ volatile ( "sti" ); \
#else
-#define _CPU_ISR_Disable( _level ) _level = i386_disable_interrupts( )
+#define _CPU_ISR_Disable( _level ) _level = i386_disable_interrupts()
#define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
#define _CPU_ISR_Flash( _level ) i386_flash_interrupts( _level )
-#define _CPU_ISR_Set_level( _new_level ) i386_set_interrupt_level( _new_level)
+#define _CPU_ISR_Set_level( _new_level ) i386_set_interrupt_level(_new_level)
#endif
uint32_t _CPU_ISR_Get_level( void );
1.9.1
