[PATCH 6/6] OR1k cache invalidate additions
Gedare Bloom
gedare at rtems.org
Sat Feb 20 13:35:08 UTC 2016
On Sat, Feb 20, 2016 at 3:34 AM, <jakob.viketoft at gmail.com> wrote:
> From: Jakob Viketoft <jakob.viketoft at aacmicrotec.com>
> c/src/lib/libcpu/or1k/shared/cache/cache.c | 86 ++++++++++++++++++++++------
> 1 file changed, 67 insertions(+), 19 deletions(-)
> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
> index d17fec2..49f5ca9 100644
> --- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
> @@ -4,9 +4,14 @@
> * COPYRIGHT (c) 1989-2006
> * On-Line Applications Research Corporation (OAR).
> + * Copyright (c) 2014 ÅAC Microtec AB <www.aacmicrotec.com>
> + * Contributor(s):
> + * Karol Gugala <kgugala at antmicro.com>
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> * http://www.rtems.org/license/LICENSE.
> #include <rtems/score/cpu.h>
> @@ -14,13 +19,15 @@
> #include <rtems/score/or1k-utility.h>
> #include <rtems/score/percpu.h>
> #include <libcpu/cache.h>
> +#include <cache_.h>
> static inline void _CPU_OR1K_Cache_enable_data(void)
> uint32_t sr;
> - ISR_Level level;
> + ISR_Level level;
> _ISR_Disable (level);
> sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
> _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
> @@ -30,7 +37,7 @@ static inline void _CPU_OR1K_Cache_enable_data(void)
> static inline void _CPU_OR1K_Cache_disable_data(void)
> uint32_t sr;
> - ISR_Level level;
> + ISR_Level level;
> @@ -43,7 +50,7 @@ static inline void _CPU_OR1K_Cache_disable_data(void)
> static inline void _CPU_OR1K_Cache_enable_instruction(void)
> uint32_t sr;
> - ISR_Level level;
> + ISR_Level level;
> @@ -79,7 +86,8 @@ static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
> static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
> @@ -89,7 +97,8 @@ static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
> static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
> @@ -99,7 +108,8 @@ static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
> static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uintptr_t) d_addr);
> @@ -109,7 +119,8 @@ static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
> static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uintptr_t) d_addr);
> @@ -120,7 +131,8 @@ static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
> static inline void _CPU_OR1K_Cache_instruction_block_prefetch
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uintptr_t) d_addr);
> @@ -131,7 +143,8 @@ static inline void _CPU_OR1K_Cache_instruction_block_prefetch
> static inline void _CPU_OR1K_Cache_instruction_block_invalidate
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
> @@ -142,7 +155,8 @@ static inline void _CPU_OR1K_Cache_instruction_block_invalidate
> static inline void _CPU_OR1K_Cache_instruction_block_lock
> - ISR_Level level;
> + ISR_Level level;
> _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uintptr_t) d_addr);
> @@ -152,9 +166,11 @@ static inline void _CPU_OR1K_Cache_instruction_block_lock
> /* Implement RTEMS cache manager functions */
> -void _CPU_cache_flush_1_data_line(const void *d_addr)
> +void _CPU_cache_flush_1_data_line
> +(const void *d_addr)
> - ISR_Level level;
> + ISR_Level level;
> _CPU_OR1K_Cache_data_block_flush(d_addr);
> @@ -164,9 +180,11 @@ void _CPU_cache_flush_1_data_line(const void *d_addr)
> _ISR_Enable(level);
> -void _CPU_cache_invalidate_1_data_line(const void *d_addr)
> +void _CPU_cache_invalidate_1_data_line
> - ISR_Level level;
> + ISR_Level level;
> _CPU_OR1K_Cache_data_block_invalidate(d_addr);
> @@ -184,9 +202,11 @@ void _CPU_cache_unfreeze_data(void)
> /* Do nothing */
> -void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
> +void _CPU_cache_invalidate_1_instruction_line
> - ISR_Level level;
> + ISR_Level level;
> _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
> @@ -206,17 +226,45 @@ void _CPU_cache_unfreeze_instruction(void)
> void _CPU_cache_flush_entire_data(void)
> + int addr;
> + /* We have only 0 level cache so we do not need to invalidate others */
> + for (addr = _CPU_cache_get_data_cache_size(0);
> + addr > 0;
> + addr -= CPU_DATA_CACHE_ALIGNMENT) {
When breaking lines in expressions, leave the first and last line empty,
for (
addr = ...();
addr > 0;
addr -= ...
> + _CPU_OR1K_Cache_data_block_flush((void*) addr);
Casting int to void* is not a great idea. Consider using uintptr_t instead.
> void _CPU_cache_invalidate_entire_data(void)
> + int addr;
> + addr > 0;
> + _CPU_cache_invalidate_1_data_line((void*) addr);
> void _CPU_cache_invalidate_entire_instruction(void)
> + int addr;
> + for (addr = _CPU_cache_get_instruction_cache_size(0);
> + addr > 0;
> + addr -= CPU_INSTRUCTION_CACHE_ALIGNMENT) {
> + _CPU_cache_invalidate_1_instruction_line((void*) addr);
> + /* Flush instructions out of instruction buffer */
> + asm volatile("l.nop");
> void _CPU_cache_enable_data(void)
> 1.7.10.4
> devel mailing list
> devel at rtems.org
