[PATCH 7/8] OR1k cache flush/invalidate additions
Jakob Viketoft jakob.viketoft at aacmicrotec.com
Wed Feb 24 22:15:02 UTC 2016
_______________________________________
From: devel [devel-bounces at rtems.org] on behalf of Hesham Almatary [heshamelmatary at gmail.com]
Sent: Wednesday, February 24, 2016 18:08
To: jakob.viketoft at gmail.com
Cc: rtems-devel at rtems.org
Subject: Re: [PATCH 7/8] OR1k cache flush/invalidate additions
>This definition conflicts with the prototype at
>ibcpu/include/cache.h. It produces a compilation error
Which only goes to show that I really shouldn't be doing stuff like this late Saturday evening. :)
Anyway, I inline and attach (since there was some stuff with encoding etc which played foul tricks on the previous version) a new version of the patch which _should_ work.
        /Jakob
>From 2c27d1b315c75c787ccbfa353a5757d52ea309ff Mon Sep 17 00:00:00 2001
From: Jakob Viketoft <jakob.viketoft at aacmicrotec.com>
Date: Sat, 20 Feb 2016 23:23:27 +0100
Subject: [PATCH 7/8] OR1k cache flush/invalidate additions
Close #2602
 c/src/lib/libcpu/or1k/shared/cache/cache.c | 113 ++++++++++++++++++++++-------
 1 file changed, 86 insertions(+), 27 deletions(-)
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
index d17fec2..ff28a61 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
@@ -4,9 +4,14 @@
  * COPYRIGHT (c) 1989-2006
  * On-Line Applications Research Corporation (OAR).
+ * Copyright (c) 2014 ÅAC Microtec AB <www.aacmicrotec.com>
+ * Contributor(s):
+ *  Karol Gugala <kgugala at antmicro.com>
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
  * http://www.rtems.org/license/LICENSE.
 #include <rtems/score/cpu.h>
@@ -14,13 +19,15 @@
 #include <rtems/score/or1k-utility.h>
 #include <libcpu/cache.h>
+#include <cache_.h>
 static inline void _CPU_OR1K_Cache_enable_data(void)
   uint32_t sr;
-   ISR_Level level;
+  ISR_Level level;
   _ISR_Disable (level);
   sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
   _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
@@ -30,7 +37,7 @@ static inline void _CPU_OR1K_Cache_enable_data(void)
 static inline void _CPU_OR1K_Cache_disable_data(void)
   uint32_t sr;
-   ISR_Level level;
+  ISR_Level level;
@@ -43,7 +50,7 @@ static inline void _CPU_OR1K_Cache_disable_data(void)
 static inline void _CPU_OR1K_Cache_enable_instruction(void)
   uint32_t sr;
-   ISR_Level level;
+  ISR_Level level;
@@ -66,7 +73,8 @@ static inline void _CPU_OR1K_Cache_disable_instruction(void)
   _ISR_Enable(level);
-static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
+static inline void _CPU_OR1K_Cache_data_block_prefetch
+(const void *d_addr)
   ISR_Level level;
@@ -77,9 +85,11 @@ static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
   _ISR_Enable(level);
-static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
+static inline void _CPU_OR1K_Cache_data_block_flush
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
@@ -87,9 +97,11 @@ static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
   _ISR_Enable(level);
-static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
+static inline void _CPU_OR1K_Cache_data_block_invalidate
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
@@ -97,9 +109,11 @@ static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
   _ISR_Enable(level);
-static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
+static inline void _CPU_OR1K_Cache_data_block_writeback
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uintptr_t) d_addr);
@@ -107,9 +121,11 @@ static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
   _ISR_Enable(level);
-static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
+static inline void _CPU_OR1K_Cache_data_block_lock
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uintptr_t) d_addr);
@@ -120,7 +136,8 @@ static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
 static inline void _CPU_OR1K_Cache_instruction_block_prefetch
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uintptr_t) d_addr);
@@ -131,7 +148,8 @@ static inline void _CPU_OR1K_Cache_instruction_block_prefetch
 static inline void _CPU_OR1K_Cache_instruction_block_invalidate
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
@@ -142,7 +160,8 @@ static inline void _CPU_OR1K_Cache_instruction_block_invalidate
 static inline void _CPU_OR1K_Cache_instruction_block_lock
-   ISR_Level level;
+  ISR_Level level;
   _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uintptr_t) d_addr);
@@ -152,24 +171,28 @@ static inline void _CPU_OR1K_Cache_instruction_block_lock
 /* Implement RTEMS cache manager functions */
-void _CPU_cache_flush_1_data_line(const void *d_addr)
+void _CPU_cache_flush_1_data_line
-   ISR_Level level;
+  ISR_Level level;
-  _CPU_OR1K_Cache_data_block_flush(d_addr);
+  _CPU_OR1K_Cache_data_block_flush((uintptr_t) d_addr);
   //asm volatile("l.csync");
   _ISR_Enable(level);
-void _CPU_cache_invalidate_1_data_line(const void *d_addr)
+void _CPU_cache_invalidate_1_data_line
-   ISR_Level level;
+  ISR_Level level;
-  _CPU_OR1K_Cache_data_block_invalidate(d_addr);
+  _CPU_OR1K_Cache_data_block_invalidate((uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -184,12 +207,14 @@ void _CPU_cache_unfreeze_data(void)
   /* Do nothing */
-void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
+void _CPU_cache_invalidate_1_instruction_line
-   ISR_Level level;
+  ISR_Level level;
-  _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
+  _CPU_OR1K_Cache_instruction_block_invalidate((uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -206,17 +231,51 @@ void _CPU_cache_unfreeze_instruction(void)
 void _CPU_cache_flush_entire_data(void)
+  int addr;
+  /* We have only 0 level cache so we do not need to invalidate others */
+  for (
+    addr = _CPU_cache_get_data_cache_size(0);
+    addr > 0;
+    addr -= CPU_DATA_CACHE_ALIGNMENT
+    _CPU_OR1K_Cache_data_block_flush((void*) addr);
 void _CPU_cache_invalidate_entire_data(void)
+  int addr;
+  for (
+    addr > 0;
+    _CPU_cache_invalidate_1_data_line((void*) addr);
 void _CPU_cache_invalidate_entire_instruction(void)
+  int addr;
+  for (
+    addr = _CPU_cache_get_instruction_cache_size(0);
+    addr > 0;
+    addr -= CPU_INSTRUCTION_CACHE_ALIGNMENT
+    _CPU_cache_invalidate_1_instruction_line((void*) addr);
+  /* Flush instructions out of instruction buffer */
+  asm volatile("l.nop");
 void _CPU_cache_enable_data(void)
2.1.4
Jakob Viketoft
Senior Engineer in RTL and embedded software
ÅAC Microtec AB
Dag Hammarskjölds väg 48
SE-751 83 Uppsala, Sweden
T: +46 702 80 95 97
http://www.aacmicrotec.com
Type: text/x-patch
Desc: 0007-OR1k-cache-flush-invalidate-additions.patch
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160224/53f8a3df/attachment-0002.bin>
