[PATCH 2/6] Remove H8300 port
Sun Jan 3 21:27:01 UTC 2016
updates #2452.
 c/ACKNOWLEDGEMENTS                                 |    9 +-
 c/TOOL_TARGETS                                     |    3 -
 c/src/aclocal/check-networking.m4                  |    2 +-
 c/src/aclocal/rtems-cpu-subdirs.m4                 |    1 -
 c/src/lib/libbsp/h8300/Makefile.am                 |    7 -
 c/src/lib/libbsp/h8300/acinclude.m4                |    8 -
 c/src/lib/libbsp/h8300/configure.ac                |   19 -
 cpukit/aclocal/check-networking.m4                 |    2 +-
 cpukit/configure.ac                                |    4 -
 cpukit/librpc/src/xdr/xdr_float.c                  |    1 -
 cpukit/score/cpu/Makefile.am                       |    1 -
 cpukit/score/cpu/h8300/Makefile.am                 |   19 -
 cpukit/score/cpu/h8300/README                      |   27 -
 cpukit/score/cpu/h8300/cpu.c                       |  134 ---
 cpukit/score/cpu/h8300/cpu_asm.S                   |  221 ----
 .../score/cpu/h8300/h8300-exception-frame-print.c  |   24 -
 cpukit/score/cpu/h8300/preinstall.am               |   45 -
 cpukit/score/cpu/h8300/rtems/asm.h                 |  118 --
 cpukit/score/cpu/h8300/rtems/score/cpu.h           | 1176 --------------------
 cpukit/score/cpu/h8300/rtems/score/cpuatomic.h     |   14 -
 cpukit/score/cpu/h8300/rtems/score/h8300.h         |   44 -
 cpukit/score/cpu/h8300/rtems/score/types.h         |   47 -
 doc/cpu_supplement/Makefile.am                     |    6 -
 doc/cpu_supplement/cpu_supplement.texi             |    2 -
 doc/cpu_supplement/h8300.t                         |   11 -
 testsuites/libtests/configure.ac                   |    3 -
 testsuites/psxtests/psx04/task3.c                  |    2 +-
 27 files changed, 5 insertions(+), 1945 deletions(-)
 delete mode 100644 c/src/lib/libbsp/h8300/Makefile.am
 delete mode 100644 c/src/lib/libbsp/h8300/acinclude.m4
 delete mode 100644 c/src/lib/libbsp/h8300/configure.ac
 delete mode 100644 cpukit/score/cpu/h8300/Makefile.am
 delete mode 100644 cpukit/score/cpu/h8300/README
 delete mode 100644 cpukit/score/cpu/h8300/cpu.c
 delete mode 100644 cpukit/score/cpu/h8300/cpu_asm.S
 delete mode 100644 cpukit/score/cpu/h8300/h8300-exception-frame-print.c
 delete mode 100644 cpukit/score/cpu/h8300/preinstall.am
 delete mode 100644 cpukit/score/cpu/h8300/rtems/asm.h
 delete mode 100644 cpukit/score/cpu/h8300/rtems/score/cpu.h
 delete mode 100644 cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/h8300/rtems/score/h8300.h
 delete mode 100644 cpukit/score/cpu/h8300/rtems/score/types.h
 delete mode 100644 doc/cpu_supplement/h8300.t
diff --git a/c/ACKNOWLEDGEMENTS b/c/ACKNOWLEDGEMENTS
index 76956fd..25d4a0b 100644
--- a/c/ACKNOWLEDGEMENTS
+++ b/c/ACKNOWLEDGEMENTS
@@ -150,9 +150,8 @@ The following persons/organizations have made contributions:
   it easier to support external interrupt controllers.
 + Joel Sherrill <joel at OARcorp.com> for the BSPs that work with
-  numerous simulators including psim, c4xsim, h8sim, armulator,
-  sim68000, and simcpu32.  Most of these BSPs work with instruction
-  set simulators in gdb.
+  numerous simulators. Many work with instruction set simulators
+  in gdb.
 + Darlene Stewart <Darlene.Stewart at nrc.ca> and Charles Gauthier
   <Charles.Gauthier at nrc.ca> of the Institute for Information Technology
@@ -165,10 +164,6 @@ The following persons/organizations have made contributions:
   Technology for the National Research Council of Canada
   submitted the RTEMS Cache Manager.
-+ Philip Quaife <philip at qs.co.nz> of Q Solutions ported
-  RTEMS to the Hitachi H8300H.  This effort was sponsored by
-  Comnet Technologies Ltd.
 + Joel Sherrill <joel at OARcorp.com> and Jennifer Averett <jennifer at OARcorp.com>
   for the Texas Instruments C3x/C4x port and c4xsim BSP that works
   with the C3x/C4X instruction set simulator in gdb.
diff --git a/c/TOOL_TARGETS b/c/TOOL_TARGETS
index 4811277..3b22d81 100644
--- a/c/TOOL_TARGETS
+++ b/c/TOOL_TARGETS
@@ -7,9 +7,6 @@ arm:
 c4x:
         c4x-rtems               COFF           Requires patches
-h8300:
-        h8300-rtems             COFF
 i386:
 	i386-rtems		ELF
diff --git a/c/src/aclocal/check-networking.m4 b/c/src/aclocal/check-networking.m4
index 53d2d36..69265ac 100644
--- a/c/src/aclocal/check-networking.m4
+++ b/c/src/aclocal/check-networking.m4
@@ -8,7 +8,7 @@ AC_CACHE_CHECK([whether BSP supports networking],
   [dnl
     case "$RTEMS_CPU" in
     # do not have address space to hold BSD TCP/IP stack
-    avr*|h8300*|m32c*)
+    avr*|m32c*)
       rtems_cv_HAS_NETWORKING="no"
diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4 b/c/src/aclocal/rtems-cpu-subdirs.m4
index 3cb28b1..5f10bda 100644
--- a/c/src/aclocal/rtems-cpu-subdirs.m4
+++ b/c/src/aclocal/rtems-cpu-subdirs.m4
@@ -14,7 +14,6 @@ _RTEMS_CPU_SUBDIR([arm],[$1]);;
 _RTEMS_CPU_SUBDIR([bfin],[$1]);;
 _RTEMS_CPU_SUBDIR([epiphany],[$1]);;
 _RTEMS_CPU_SUBDIR([avr],[$1]);;
-_RTEMS_CPU_SUBDIR([h8300],[$1]);;
 _RTEMS_CPU_SUBDIR([i386],[$1]);;
 _RTEMS_CPU_SUBDIR([lm32],[$1]);;
 _RTEMS_CPU_SUBDIR([m32c],[$1]);;
diff --git a/c/src/lib/libbsp/h8300/Makefile.am b/c/src/lib/libbsp/h8300/Makefile.am
deleted file mode 100644
index 140d76e..0000000
--- a/c/src/lib/libbsp/h8300/Makefile.am
+++ /dev/null
@@ -1,7 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../aclocal
-# Descend into the @RTEMS_BSP_FAMILY@ directory
-SUBDIRS = @RTEMS_BSP_FAMILY@
-include $(top_srcdir)/../../../automake/subdirs.am
-include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libbsp/h8300/acinclude.m4 b/c/src/lib/libbsp/h8300/acinclude.m4
index 296a6f7..0000000
--- a/c/src/lib/libbsp/h8300/acinclude.m4
+++ /dev/null
@@ -1,8 +0,0 @@
-# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
-AC_DEFUN([RTEMS_CHECK_BSPDIR],
-  case "$1" in
-    AC_MSG_ERROR([Invalid BSP]);;
-  esac
diff --git a/c/src/lib/libbsp/h8300/configure.ac b/c/src/lib/libbsp/h8300/configure.ac
index e885460..0000000
--- a/c/src/lib/libbsp/h8300/configure.ac
+++ /dev/null
@@ -1,19 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-h8300],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([Makefile.am])
-RTEMS_TOP(../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_ENV_RTEMSBSP
-RTEMS_PROJECT_ROOT
-RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/cpukit/aclocal/check-networking.m4 b/cpukit/aclocal/check-networking.m4
index 06c94c0..50982f3 100644
--- a/cpukit/aclocal/check-networking.m4
+++ b/cpukit/aclocal/check-networking.m4
@@ -9,7 +9,7 @@ AC_CACHE_CHECK([whether CPU supports networking],
   [dnl
     case "$host" in
+    avr*|m32c*)
     *-*-rtems*)
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 8436c91..c5bbee8 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -393,9 +393,6 @@ case $RTEMS_CPU in
   # bfin has an issue to resolve with libdl. See ticket #2252
   bfin)
    HAVE_LIBDL=no ;;
-  # h8300 has an issue to resolve with libdl. See ticket #2284
-  h8300)
-   HAVE_LIBDL=no ;;
   # lm32 has an issue to resolve with libdl. See ticket #2283
   lm32)
    HAVE_LIBDL=no ;;
@@ -457,7 +454,6 @@ score/cpu/arm/Makefile
 score/cpu/bfin/Makefile
 score/cpu/avr/Makefile
 score/cpu/epiphany/Makefile
-score/cpu/h8300/Makefile
 score/cpu/i386/Makefile
 score/cpu/lm32/Makefile
 score/cpu/m68k/Makefile
diff --git a/cpukit/librpc/src/xdr/xdr_float.c b/cpukit/librpc/src/xdr/xdr_float.c
index 5d6b4ea..74d0bbc 100644
--- a/cpukit/librpc/src/xdr/xdr_float.c
+++ b/cpukit/librpc/src/xdr/xdr_float.c
@@ -62,7 +62,6 @@ static char *rcsid = "$FreeBSD: src/lib/libc/xdr/xdr_float.c,v 1.7 1999/08/28 00
     defined(_AM29K) || \
     defined(__arm__) || \
     defined(__epiphany__) ||  defined(__EPIPHANY__) || \
-    defined(__H8300__) || defined(__h8300__) || \
     defined(__hppa__) || \
     defined(__i386__) || \
     defined(__lm32__) || \
diff --git a/cpukit/score/cpu/Makefile.am b/cpukit/score/cpu/Makefile.am
index 4438e3f..a973a82 100644
--- a/cpukit/score/cpu/Makefile.am
+++ b/cpukit/score/cpu/Makefile.am
@@ -5,7 +5,6 @@ DIST_SUBDIRS += arm
 DIST_SUBDIRS += avr
 DIST_SUBDIRS += bfin
 DIST_SUBDIRS += epiphany
-DIST_SUBDIRS += h8300
 DIST_SUBDIRS += i386
 DIST_SUBDIRS += lm32
 DIST_SUBDIRS += m32c
diff --git a/cpukit/score/cpu/h8300/Makefile.am b/cpukit/score/cpu/h8300/Makefile.am
index 6a80409..0000000
--- a/cpukit/score/cpu/h8300/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-include_rtemsdir = $(includedir)/rtems
-include_rtems_HEADERS = rtems/asm.h
-include_rtems_scoredir = $(includedir)/rtems/score
-include_rtems_score_HEADERS = rtems/score/cpu.h
-include_rtems_score_HEADERS += rtems/score/h8300.h
-include_rtems_score_HEADERS += rtems/score/types.h
-include_rtems_score_HEADERS += rtems/score/cpuatomic.h
-noinst_LIBRARIES = libscorecpu.a
-libscorecpu_a_SOURCES = cpu.c cpu_asm.S
-libscorecpu_a_SOURCES += ../no_cpu/cpucounterread.c
-libscorecpu_a_SOURCES += h8300-exception-frame-print.c
-libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/score/cpu/h8300/README b/cpukit/score/cpu/h8300/README
index 1fed837..0000000
--- a/cpukit/score/cpu/h8300/README
+++ /dev/null
@@ -1,27 +0,0 @@
-This port was done by Philip Quaife <philip at qs.co.nz> of Q Solutions
-using RTEMS 3.5.1 under DOS and Hiview.   Philip used an H8300H
-to develop and test this port.
-It was updated to 4.5 and merged into the main development trunk
-by Joel Sherrill <joel at OARcorp.com>.  As part of the merger, the
-port was made to conditionally compile for the H8, H8300H, and H8300S
-series.
-The status of each CPU subfamily is as follows.
-H8  - Although RTEMS compiles with for these CPUs, it does not
-      truly support them.  All code that will not work on these
-      CPUs is conditionally disabled.  These CPUs have a 16-bit
-      address space.  Thus although a port is technically
-      feasible, some work will to be performed on RTEMS to
-      further minimize its footprint and address pointer
-      manipulation issues.
-H8H - Port was developed on this class of H8 so there should be
-      no problems.
-H8S - Port should work on this class of H8 but it is untested.
---joel
-28 June 2000
diff --git a/cpukit/score/cpu/h8300/cpu.c b/cpukit/score/cpu/h8300/cpu.c
index 36c41a2..0000000
--- a/cpukit/score/cpu/h8300/cpu.c
+++ /dev/null
@@ -1,134 +0,0 @@
- *  @file
- *  @brief H8300 CPU Dependent Source
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/wkspace.h>
-/*  _CPU_Initialize
- *  This routine performs processor dependent initialization.
- *  INPUT PARAMETERS: NONE
-void _CPU_Initialize(void)
-   *  If there is not an easy way to initialize the FP context
-   *  during Context_Initialize, then it is usually easier to
-   *  save an "uninitialized" FP context here and copy it to
-   *  the task's during Context_Initialize.
-  /* FP context initialization support goes here */
-uint32_t   _CPU_ISR_Get_level( void )
-  unsigned int _ccr;
-#if defined(__H8300__)
-#warning "How do we get ccr on base CPU models"
-#else
-  __asm__ volatile ( "stc ccr, %0" : "=m" (_ccr) : );
-#endif
-  if ( _ccr & 0x80 )
-    return 1;
-  return 0;
- *  _CPU_ISR_install_raw_handler
-void _CPU_ISR_install_raw_handler(
-  uint32_t    vector,
-  proc_ptr    new_handler,
-  proc_ptr   *old_handler
-   *  This is where we install the interrupt handler into the "raw" interrupt
-   *  table used by the CPU to dispatch interrupt handlers.
-   *  Use Debug level IRQ Handlers
-  H8BD_Install_IRQ(vector,new_handler,old_handler);
-void _CPU_ISR_install_vector(
-  uint32_t    vector,
-   *old_handler = _ISR_Vector_table[ vector ];
-    *  If the interrupt vector table is a table of pointer to isr entry
-    *  points, then we need to install the appropriate RTEMS interrupt
-    *  handler for this vector number.
-   _CPU_ISR_install_raw_handler( vector, new_handler, old_handler );
-    *  We put the actual user ISR address in '_ISR_vector_table'.  This will
-    *  be used by the _ISR_Handler so the user gets control.
-    _ISR_Vector_table[ vector ] = new_handler;
- *  _CPU_Install_interrupt_stack
-void _CPU_Install_interrupt_stack( void )
- *  _CPU_Thread_Idle_body
- *  NOTES:
- *  1. This is the same as the regular CPU independent algorithm.
- *  2. If you implement this using a "halt", "idle", or "shutdown"
- *     instruction, then don't forget to put it in an infinite loop.
- *  3. Be warned. Some processors with onboard DMA have been known
- *     to stop the DMA if the CPU were put in IDLE mode.  This might
- *     also be a problem with other on-chip peripherals.  So use this
- *     hook with caution.
-#if 0
-void *_CPU_Thread_Idle_body( uintptr_t ignored )
-  for( ; ; )
-    IDLE_Monitor();
-	/* __asm__ ("	sleep	\n"); */
-    /* insert your "halt" instruction here */ ;
-#endif
diff --git a/cpukit/score/cpu/h8300/cpu_asm.S b/cpukit/score/cpu/h8300/cpu_asm.S
index e0fdf0a..0000000
--- a/cpukit/score/cpu/h8300/cpu_asm.S
+++ /dev/null
@@ -1,221 +0,0 @@
- * Hitachi H8 Score CPU functions
- *   Copyright Comnet Technologies Ltd 1999
- *  Based on example code and other ports with this copyright:
-#endif
-#include <rtems/asm.h>
-#include <rtems/score/percpu.h>
-;.equ	RUNCONTEXT_ARG,	 er0
-;.equ	HEIRCONTEXT_ARG, er1
- *  Make sure we tell the assembler what type of CPU model we are
- *  being compiled for.
-#if defined(__H8300H__)
-        .h8300h
-#endif
-#if defined(__H8300S__)
-        .h8300s
-#endif
-#if defined(__H8300SX__)
-        .h8300sx
-#endif
-        .text
-	.text
-	GCC Compiled with optimisations and Wimplicit decs to ensure
-    that stack from doesn't change
-	Supposedly R2 and R3 do not need to be saved but who knows
-	Arg1 = er0 	(not on stack)
-	Arg2 = er1	(not on stack)
-	.align 2
-	.global	SYM(_CPU_Context_switch)
-SYM(_CPU_Context_switch):
-	/* Save Context */
-#if defined(__H8300H__) || defined(__H8300S__) || defined(__H8300SX__)
-	stc.w	ccr,@(0:16,er0)
-	mov.l	er7,@(2:16,er0)
-	mov.l	er6,@(6:16,er0)
-	mov.l	er5,@(10:16,er0)
-	mov.l	er4,@(14:16,er0)
-	mov.l	er3,@(18:16,er0)
-	mov.l	er2,@(22:16,er0)
-	/* Install New context */
-restore:
-	mov.l	@(22:16,er1),er2
-	mov.l	@(18:16,er1),er3
-	mov.l	@(14:16,er1),er4
-	mov.l	@(10:16,er1),er5
-	mov.l	@(6:16,er1),er6
-	mov.l	@(2:16,er1),er7
-	ldc.w	@(0:16,er1),ccr
-#endif
-	rts
-	.align 2
-	.global	SYM(_CPU_Context_restore)
-SYM(_CPU_Context_restore):
-	mov.l	er0,er1
-	jmp		@restore:24
-#endif
-	VHandler for Vectored Interrupts
-	All IRQ's are vectored to routine _ISR_#vector_number
-	This routine stacks er0 and loads er0 with vector number
-	before transferring to here
-	.align 2
-	.global	SYM(_ISR_Handler)
-	.extern	SYM(_Vector_table)
-SYM(_ISR_Handler):
-	mov.l	er1, at -er7
-	mov.l	er2, at -er7
-	mov.l	er3, at -er7
-	mov.l	er4, at -er7
-	mov.l	er5, at -er7
-	mov.l	er6, at -er7
-/*  Set IRQ Stack */
-	orc		#0xc0,ccr
-	mov.l	er7,er6		; save stack pointer
-	mov.l	@ISR_NEST_LEVEL,er1
-	bne		nested
-	mov.l	@INTERRUPT_STACK_HIGH,er7
-nested:
-	mov.l	er6, at -er7	; save sp so pop regardless of nest level
-;; Inc  system counters
-	inc.l	#1,er1
-	mov.l	er1, at ISR_NEST_LEVEL
-	mov.l	@THREAD_DISPATCH_DISABLE_LEVEL,er1
-	inc.l	#1,er1
-	mov.l	er1, at THREAD_DISPATCH_DISABLE_LEVEL
-/* Vector to ISR */
-	mov		er0,er2	; copy vector
-	shll.l	er2
-	shll.l	er2		; vector = vector * 4 (sizeof(int))
-	mov.l	@(SYM(_ISR_Vector_table), er2),er1
-	jsr		@er1	; er0 = arg1 =vector
-	orc		#0xc0,ccr
-	dec.l	#1,er1
-	dec.l	#1,er1
-	bne	exit
-	mov.l	@DISPATCH_NEEDED,er1
-	beq	exit		; If no then exit
-	/* Context switch here through ISR_Dispatch */
-bframe:
-	orc	#0xc0,ccr
-/*	Pop Stack	*/
-	mov	@er7+,er6
-	mov	er6,er7
-	/* Set up IRQ stack frame and dispatch to _ISR_Dispatch */
-	mov.l	#0xc0000000,er2		/* Disable IRQ */
-	or.l	#SYM(_ISR_Dispatch),er2
-	rte
-/*	Inner IRQ Return, pop flags and return */
-exit:
-/*	Pop Stack	*/
-	orc		#0x80,ccr
-	mov		@er7+,er6
-	mov		er6,er7
-	mov		@er7+,er6
-	mov		@er7+,er5
-	mov		@er7+,er4
-	mov		@er7+,er3
-	mov		@er7+,er2
-	mov		@er7+,er1
-	mov		@er7+,er0
-#endif
-	rte
-	Called from ISR_Handler as a way of ending IRQ
-	but allowing dispatch to another task.
-	Must use RTE as CCR is still on stack but IRQ has been serviced.
-	CCR and PC occupy same word so rte can be used.
-	now using task stack
-	.align 2
-	.global SYM(_ISR_Dispatch)
-SYM(_ISR_Dispatch):
-	jsr		@SYM(_Thread_Dispatch)
-	mov		@er7+,er6
-	mov		@er7+,er5
-	mov		@er7+,er4
-	mov		@er7+,er3
-	mov		@er7+,er2
-	mov		@er7+,er1
-	mov		@er7+,er0
-#endif
-	rte
-	.align 2
-	.global SYM(_CPU_Context_save_fp)
-SYM(_CPU_Context_save_fp):
-	rts
-	.align 2
-	.global SYM(_CPU_Context_restore_fp)
-SYM(_CPU_Context_restore_fp):
-	rts
diff --git a/cpukit/score/cpu/h8300/h8300-exception-frame-print.c b/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
index 71e7e1c..0000000
--- a/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
+++ /dev/null
@@ -1,24 +0,0 @@
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
-  #include "config.h"
-#endif
-#include <rtems/score/cpu.h>
-void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
-  /* TODO */
diff --git a/cpukit/score/cpu/h8300/preinstall.am b/cpukit/score/cpu/h8300/preinstall.am
index f3c1681..0000000
--- a/cpukit/score/cpu/h8300/preinstall.am
+++ /dev/null
@@ -1,45 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
-	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES = $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-$(PROJECT_INCLUDE)/rtems/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
-	@: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
-$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
-$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
-	@: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
-$(PROJECT_INCLUDE)/rtems/score/h8300.h: rtems/score/h8300.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/h8300.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/h8300.h
-$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
-$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
diff --git a/cpukit/score/cpu/h8300/rtems/asm.h b/cpukit/score/cpu/h8300/rtems/asm.h
index 6c1a643..0000000
--- a/cpukit/score/cpu/h8300/rtems/asm.h
+++ /dev/null
@@ -1,118 +0,0 @@
- * @file
- * @brief Address the Problems Caused by Incompatible Flavor of
- * Assemblers and Toolsets
- * This include file attempts to address the problems
- * caused by incompatible flavors of assemblers and
- * toolsets.  It primarily addresses variations in the
- * use of leading underscores on symbols and the requirement
- * that register names be preceded by a %.
- * NOTE: The spacing in the use of these macros
- *       is critical to them working as advertised.
- *  COPYRIGHT:
- *  This file is based on similar code found in newlib available
- *  from ftp.cygnus.com.  The file which was used had no copyright
- *  notice.  This file is freely distributable as long as the source
- *  of the file is noted.  This file is:
-#ifndef _RTEMS_ASM_H
-#define _RTEMS_ASM_H
- *  Indicate we are in an assembly file and get the basic CPU definitions.
-#include <rtems/score/h8300.h>
- *  Recent versions of GNU cpp define variables which indicate the
- *  need for underscores and percents.  If not using GNU cpp or
- *  the version does not support this, then you will obviously
- *  have to define these as appropriate.
-#ifndef __USER_LABEL_PREFIX__
-#define __USER_LABEL_PREFIX__ _
-#endif
-#ifndef __REGISTER_PREFIX__
-#define __REGISTER_PREFIX__
-#endif
-#include <rtems/concat.h>
-/* Use the right prefix for global labels.  */
-#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
-/* Use the right prefix for registers.  */
-#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
- *  define macros for all of the registers on this CPU
- *  EXAMPLE:     #define d0 REG (d0)
-#define	r0	REG(r0)
-#define r1	REG(r1)
-#define r2	REG(r2)
-#define r3	REG(r3)
-#define r4	REG(r4)
-#define r5	REG(r5)
-#define r6	REG(r6)
-#define r7	REG(r7)
-#define	er0	REG(er0)
-#define er1	REG(er1)
-#define er2	REG(er2)
-#define er3	REG(er3)
-#define er4	REG(er4)
-#define er5	REG(er5)
-#define er6	REG(er6)
-#define er7	REG(er7)
-#define sp	REG(sp)
- *  Define macros to handle section beginning and ends.
-#define BEGIN_CODE_DCL .text
-#define END_CODE_DCL
-#define BEGIN_DATA_DCL .data
-#define END_DATA_DCL
-#define BEGIN_CODE __asm__ ( ".text
-#define END_CODE ");
-#define BEGIN_DATA
-#define END_DATA
-#define BEGIN_BSS
-#define END_BSS
-#define END
- *  Following must be tailor for a particular flavor of the C compiler.
- *  They may need to put underscores in front of the symbols.
-#define PUBLIC(sym) .globl SYM (sym)
-#define EXTERN(sym) .globl SYM (sym)
-#endif
diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
index 8b34bb4..0000000
--- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
+++ /dev/null
@@ -1,1176 +0,0 @@
- * @file
- * @brief Hitachi H8300 CPU Department Source
- * This include file contains information pertaining to the H8300
- *  processor.
- *  COPYRIGHT (c) 1989-2006.
-#ifndef _RTEMS_SCORE_CPU_H
-#define _RTEMS_SCORE_CPU_H
-#ifdef __cplusplus
-extern "C" {
-#endif
-#include <rtems/score/types.h>
-#ifndef ASM
-  #include <rtems/bspIo.h>
-#endif
-/* conditional compilation parameters */
- *  Should the calls to _Thread_Enable_dispatch be inlined?
- *  If TRUE, then they are inlined.
- *  If FALSE, then a subroutine call is made.
- *  Basically this is an example of the classic trade-off of size
- *  versus speed.  Inlining the call (TRUE) typically increases the
- *  size of RTEMS while speeding up the enabling of dispatching.
- *  [NOTE: In general, the _Thread_Dispatch_disable_level will
- *  only be 0 or 1 unless you are in an interrupt handler and that
- *  interrupt handler invokes the executive.]  When not inlined
- *  something calls _Thread_Enable_dispatch which in turns calls
- *  _Thread_Dispatch.  If the enable dispatch is inlined, then
- *  one subroutine call is avoided entirely.]
- *  H8300 Specific Information:
- *  XXX
-#define CPU_INLINE_ENABLE_DISPATCH       FALSE
- *  Should this target use 16 or 32 bit object Ids?
-#define RTEMS_USE_16_BIT_OBJECT
- *  Does RTEMS manage a dedicated interrupt stack in software?
- *  If TRUE, then a stack is allocated in _ISR_Handler_initialization.
- *  If FALSE, nothing is done.
- *  If the CPU supports a dedicated interrupt stack in hardware,
- *  then it is generally the responsibility of the BSP to allocate it
- *  and set it up.
- *  If the CPU does not support a dedicated interrupt stack, then
- *  the porter has two options: (1) execute interrupts on the
- *  stack of the interrupted task, and (2) have RTEMS manage a dedicated
- *  interrupt stack.
- *  If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
- *  Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
- *  CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
- *  possible that both are FALSE for a particular CPU.  Although it
- *  is unclear what that would imply about the interrupt processing
- *  procedure on that CPU.
- *  XXX
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
- *  Does the CPU follow the simple vectored interrupt model?
- *  If TRUE, then RTEMS allocates the vector table it internally manages.
- *  If FALSE, then the BSP is assumed to allocate and manage the vector
- *  table
- *  XXX document implementation including references if appropriate
-#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
- *  Does this CPU have hardware support for a dedicated interrupt stack?
- *  If TRUE, then it must be installed during initialization.
- *  If FALSE, then no installation is performed.
- *  XXX
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
- *  Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
- *  If TRUE, then the memory is allocated during initialization.
- *  If FALSE, then the memory is allocated during initialization.
- *  This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
- *  XXX
-#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
- *  Does the CPU have hardware floating point?
- *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
- *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
- *  If there is a FP coprocessor such as the i387 or mc68881, then
- *  the answer is TRUE.
- *  The macro name "H8300_HAS_FPU" should be made CPU specific.
- *  It indicates whether or not this CPU model has FP support.  For
- *  example, it would be possible to have an i386_nofp CPU model
- *  which set this to false to indicate that you have an i386 without
- *  an i387 and wish to leave floating point support out of RTEMS.
- *  XXX
-#define CPU_HARDWARE_FP     FALSE
- *  Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
- *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
- *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
- *  If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
- *  XXX
-#define CPU_ALL_TASKS_ARE_FP     FALSE
- *  Should the IDLE task have a floating point context?
- *  If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
- *  and it has a floating point context which is switched in and out.
- *  If FALSE, then the IDLE task does not have a floating point context.
- *  Setting this to TRUE negatively impacts the time required to preempt
- *  the IDLE task from an interrupt because the floating point context
- *  must be saved as part of the preemption.
- *  XXX
-#define CPU_IDLE_TASK_IS_FP      FALSE
- *  Should the saving of the floating point registers be deferred
- *  until a context switch is made to another different floating point
- *  task?
- *  If TRUE, then the floating point context will not be stored until
- *  necessary.  It will remain in the floating point registers and not
- *  disturned until another floating point task is switched to.
- *  If FALSE, then the floating point context is saved when a floating
- *  point task is switched out and restored when the next floating point
- *  task is restored.  The state of the floating point registers between
- *  those two operations is not specified.
- *  If the floating point context does NOT have to be saved as part of
- *  interrupt dispatching, then it should be safe to set this to TRUE.
- *  Setting this flag to TRUE results in using a different algorithm
- *  for deciding when to save and restore the floating point context.
- *  The deferred FP switch algorithm minimizes the number of times
- *  the FP context is saved and restored.  The FP context is not saved
- *  until a context switch is made to another, different FP task.
- *  Thus in a system with only one FP task, the FP context will never
- *  be saved or restored.
- *  XXX
-#define CPU_USE_DEFERRED_FP_SWITCH       TRUE
- *  Does this port provide a CPU dependent IDLE task implementation?
- *  If TRUE, then the routine _CPU_Internal_threads_Idle_thread_body
- *  must be provided and is the default IDLE thread body instead of
- *  _Internal_threads_Idle_thread_body.
- *  If FALSE, then use the generic IDLE thread body if the BSP does
- *  not provide one.
- *  This is intended to allow for supporting processors which have
- *  a low power or idle mode.  When the IDLE thread is executed, then
- *  the CPU can be powered down.
- *  The order of precedence for selecting the IDLE thread body is:
- *    1.  BSP provided
- *    2.  CPU dependent (if provided)
- *    3.  generic (if no BSP and no CPU dependent)
- *  XXX
- *  The port initially called a BSP dependent routine called
- *  IDLE_Monitor.  The idle task body can be overridden by
- *  the BSP in newer versions of RTEMS.
-#define CPU_PROVIDES_IDLE_THREAD_BODY    FALSE
- *  Does the stack grow up (toward higher addresses) or down
- *  (toward lower addresses)?
- *  If TRUE, then the grows upward.
- *  If FALSE, then the grows toward smaller addresses.
- *  XXX
-#define CPU_STACK_GROWS_UP               FALSE
- *  The following is the variable attribute used to force alignment
- *  of critical RTEMS structures.  On some processors it may make
- *  sense to have these aligned on tighter boundaries than
- *  the minimum requirements of the compiler in order to have as
- *  much of the critical data area as possible in a cache line.
- *  The placement of this macro in the declaration of the variables
- *  is based on the syntactically requirements of the GNU C
- *  "__attribute__" extension.  For example with GNU C, use
- *  the following to force a structures to a 32 byte boundary.
- *      __attribute__ ((aligned (32)))
- *  NOTE:  Currently only the Priority Bit Map table uses this feature.
- *         To benefit from using this, the data must be heavily
- *         used so it will stay in the cache and used frequently enough
- *         in the executive to justify turning this on.
- *  XXX
-#define CPU_STRUCTURE_ALIGNMENT
-#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
- *  Define what is required to specify how the network to host conversion
- *  routines are handled.
-#define CPU_BIG_ENDIAN                           TRUE
-#define CPU_LITTLE_ENDIAN                        FALSE
- *  The following defines the number of bits actually used in the
- *  interrupt field of the task mode.  How those bits map to the
- *  CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
- *  XXX
-#define CPU_MODES_INTERRUPT_MASK   0x00000001
-#define CPU_PER_CPU_CONTROL_SIZE 0
- *  Processor defined structures required for cpukit/score.
- *  XXX
-/* may need to put some structures here.  */
- * Contexts
- *  Generally there are 2 types of context to save.
- *     1. Interrupt registers to save
- *     2. Task level registers to save
- *  This means we have the following 3 context items:
- *     1. task level context stuff::  Context_Control
- *     2. floating point task stuff:: Context_Control_fp
- *     3. special interrupt level context :: Context_Control_interrupt
- *  On some processors, it is cost-effective to save only the callee
- *  preserved registers during a task context switch.  This means
- *  that the ISR code needs to save those registers which do not
- *  persist across function calls.  It is not mandatory to make this
- *  distinctions between the caller/callee saves registers for the
- *  purpose of minimizing context saved during task switch and on interrupts.
- *  If the cost of saving extra registers is minimal, simplicity is the
- *  choice.  Save the same context on interrupt entry as for tasks in
- *  this case.
- *  Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
- *  care should be used in designing the context area.
- *  On some CPUs with hardware floating point support, the Context_Control_fp
- *  structure will not be used or it simply consist of an array of a
- *  fixed number of bytes.   This is done when the floating point context
- *  is dumped by a "FP save context" type instruction and the format
- *  is not really defined by the CPU.  In this case, there is no need
- *  to figure out the exact format -- only the size.  Of course, although
- *  this is enough information for RTEMS, it is probably not enough for
- *  a debugger such as gdb.  But that is another problem.
- *  XXX
-#ifndef ASM
-typedef struct {
-  /* There is no CPU specific per-CPU state */
-} CPU_Per_CPU_control;
-#define nogap __attribute__ ((packed))
-typedef struct {
-    uint16_t    ccr nogap;
-    void	*er7 nogap;
-    void 	*er6 nogap;
-    uint32_t    er5 nogap;
-    uint32_t  	er4 nogap;
-    uint32_t    er3 nogap;
-    uint32_t  	er2 nogap;
-    uint32_t    er1 nogap;
-    uint32_t  	er0 nogap;
-    uint32_t    xxx nogap;
-} Context_Control;
-#define _CPU_Context_Get_SP( _context ) \
-  (_context)->er7
-typedef struct {
-    double      some_float_register[2];
-} Context_Control_fp;
-typedef struct {
-    uint32_t   special_interrupt_register;
-} CPU_Interrupt_frame;
- *  This variable is optional.  It is used on CPUs on which it is difficult
- *  to generate an "uninitialized" FP context.  It is filled in by
- *  _CPU_Initialize and copied into the task's FP context area during
- *  _CPU_Context_Initialize.
- *  XXX
-SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
- *  Nothing prevents the porter from declaring more CPU specific variables.
- *  XXX
-/* XXX: if needed, put more variables here */
- *  The size of the floating point context area.  On some CPUs this
- *  will not be a "sizeof" because the format of the floating point
- *  area is not defined -- only the size is.  This is usually on
- *  CPUs with a "floating point save context" instruction.
- *  XXX
-#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
-#endif /* ASM */
- *  Amount of extra stack (above minimum stack size) required by
- *  system initialization thread.  Remember that in a multiprocessor
- *  system the system intialization thread becomes the MP server thread.
- *  It is highly unlikely the H8300 will get used in a multiprocessor system.
-#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
- *  This defines the number of entries in the ISR_Vector_table managed
- *  by RTEMS.
- *  XXX
-#define CPU_INTERRUPT_NUMBER_OF_VECTORS      64
-#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER  (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
- *  This is defined if the port has a special way to report the ISR nesting
- *  level.  Most ports maintain the variable _ISR_Nest_level.
-#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
- *  Should be large enough to run all RTEMS tests.  This ensures
- *  that a "reasonable" small application should not have any problems.
- *  XXX
-#define CPU_STACK_MINIMUM_SIZE          (1536)
-  #define CPU_SIZEOF_POINTER 4
-#else
-  #define CPU_SIZEOF_POINTER 2
-#endif
- *  CPU's worst alignment requirement for data types on a byte boundary.  This
- *  alignment does not take into account the requirements for the stack.
- *  XXX
-#define CPU_ALIGNMENT              8
- *  This number corresponds to the byte alignment requirement for the
- *  heap handler.  This alignment requirement may be stricter than that
- *  for the data types alignment specified by CPU_ALIGNMENT.  It is
- *  common for the heap to follow the same alignment requirement as
- *  CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict enough for the heap,
- *  then this should be set to CPU_ALIGNMENT.
- *  NOTE:  This does not have to be a power of 2.  It does have to
- *         be greater or equal to than CPU_ALIGNMENT.
- *  XXX
-#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
- *  This number corresponds to the byte alignment requirement for memory
- *  buffers allocated by the partition manager.  This alignment requirement
- *  may be stricter than that for the data types alignment specified by
- *  CPU_ALIGNMENT.  It is common for the partition to follow the same
- *  alignment requirement as CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict
- *  enough for the partition, then this should be set to CPU_ALIGNMENT.
- *  XXX
-#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
- *  stack.  This alignment requirement may be stricter than that for the
- *  data types alignment specified by CPU_ALIGNMENT.  If the CPU_ALIGNMENT
- *  is strict enough for the stack, then this should be set to 0.
- *  NOTE:  This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
- *  XXX
-#define CPU_STACK_ALIGNMENT        2
- *  ISR handler macros
- *  Support routine to initialize the RTEMS vector table after it is allocated.
-#define _CPU_Initialize_vectors()
-/* COPE With Brain dead version of GCC distributed with Hitachi HIView Tools.
-   Note requires ISR_Level be uint16_t or assembler croaks.
-#if (__GNUC__ == 2 && __GNUC_MINOR__ == 7 )
- *  Disable all interrupts for an RTEMS critical section.  The previous
- *  level is returned in _level.
-#define _CPU_ISR_Disable( _isr_cookie ) \
-  do { \
-    __asm__ volatile( "stc.w ccr, @-er7 ;\n orc #0xC0,ccr ;\n mov.w @er7+,%0" :  : "r" (_isr_cookie) ); \
-  } while (0)
- *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
- *  This indicates the end of an RTEMS critical section.  The parameter
- *  _level is not modified.
-#define _CPU_ISR_Enable( _isr_cookie )  \
-  do { \
-    __asm__ volatile( "mov.w %0, at -er7 ;\n ldc.w @er7+, ccr" :  : "r" (_isr_cookie) ); \
-  } while (0)
- *  This temporarily restores the interrupt to _level before immediately
- *  disabling them again.  This is used to divide long RTEMS critical
- *  sections into two or more parts.  The parameter _level is not
- * modified.
-#define _CPU_ISR_Flash( _isr_cookie ) \
-  do { \
-    __asm__ volatile( "mov.w %0, at -er7 ;\n ldc.w @er7+, ccr ;\n orc #0xC0,ccr" :  : "r" (_isr_cookie) ); \
-  } while (0)
-/* end of ISR handler macros */
-#else /* modern gcc version */
- *  TODO: As of 8 October 2014, this method is not implemented for the SX.
-  do { \
-    unsigned char __ccr; \
-    __asm__ volatile( "stc ccr, %0 ; orc #0x80,ccr " \
-             : "=m" (__ccr) /* : "0" (__ccr) */ ); \
-    (_isr_cookie) = __ccr; \
-  } while (0)
-#else
-  do { \
-    (_isr_cookie) = 0; \
-  } while (0)
-#endif
-  do { \
-    unsigned char __ccr = (unsigned char) (_isr_cookie); \
-    __asm__ volatile( "ldc %0, ccr" :  : "m" (__ccr) ); \
-  } while (0)
-#else
-  do { \
-    (_isr_cookie) = (_isr_cookie); \
-  } while (0)
-#endif
- *  modified.
-  do { \
-    __asm__ volatile( "ldc %0, ccr ; orc #0x80,ccr " :  : "m" (__ccr) ); \
-  } while (0)
-#else
-  do { \
-    _CPU_ISR_Enable( _isr_cookie ); \
-    _CPU_ISR_Disable( _isr_cookie ); \
-  } while (0)
-#endif
-#endif /* end of old gcc */
- *  Map interrupt level in task mode onto the hardware that the CPU
- *  actually provides.  Currently, interrupt levels which do not
- *  map onto the CPU in a generic fashion are undefined.  Someday,
- *  it would be nice if these were "mapped" by the application
- *  via a callout.  For example, m68k has 8 levels 0 - 7, levels
- *  8 - 255 would be available for bsp/application specific meaning.
- *  This could be used to manage a programmable interrupt controller
- *  via the rtems_task_mode directive.
- *  XXX
-#define _CPU_ISR_Set_level( _new_level ) \
-    if ( _new_level ) __asm__ volatile ( "orc #0x80,ccr\n" ); \
-    else              __asm__ volatile ( "andc #0x7f,ccr\n" ); \
-#ifndef ASM
-uint32_t   _CPU_ISR_Get_level( void );
-/* Context handler macros */
- *  Initialize the context to a state suitable for starting a
- *  task after a context restore operation.  Generally, this
- *  involves:
- *     - setting a starting address
- *     - preparing the stack
- *     - preparing the stack and frame pointers
- *     - setting the proper interrupt level in the context
- *     - initializing the floating point context
- *  This routine generally does not set any unnecessary register
- *  in the context.  The state of the "general data" registers is
- *  undefined at task start time.
- *  NOTE: This is_fp parameter is TRUE if the thread is to be a floating
- *        point thread.  This is typically only used on CPUs where the
- *        FPU may be easily disabled by software such as on the SPARC
- *        where the PSR contains an enable FPU bit.
- *  XXX
-#define CPU_CCR_INTERRUPTS_ON  0x80
-#define CPU_CCR_INTERRUPTS_OFF 0x00
-#define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
-                                   _isr, _entry_point, _is_fp, _tls_area ) \
-  /* Locate Me */ \
-  do { \
-    uintptr_t   _stack; \
-    if ( (_isr) ) (_the_context)->ccr = CPU_CCR_INTERRUPTS_OFF; \
-    else          (_the_context)->ccr = CPU_CCR_INTERRUPTS_ON; \
-    (void) _is_fp; /* to eliminate set but not used warning */ \
-    _stack = ((uintptr_t)(_stack_base)) + (_size) - 4; \
-    *((proc_ptr *)(_stack)) = (_entry_point); \
-     (_the_context)->er7     = (void *) _stack; \
-     (_the_context)->er6     = (void *) _stack; \
-     (_the_context)->er5     = 0; \
-     (_the_context)->er4     = 1; \
-     (_the_context)->er3     = 2; \
-  } while (0)
- *  This routine is responsible for somehow restarting the currently
- *  executing task.  If you are lucky, then all that is necessary
- *  is restoring the context.  Otherwise, there will need to be
- *  a special assembly routine which does something special in this
- *  case.  Context_Restore should work most of the time.  It will
- *  not work if restarting self conflicts with the stack frame
- *  assumptions of restoring a context.
- *  XXX
-#define _CPU_Context_Restart_self( _the_context ) \
-   _CPU_Context_restore( (_the_context) );
- *  The purpose of this macro is to allow the initial pointer into
- *  a floating point context area (used to save the floating point
- *  context) to be at an arbitrary place in the floating point
- *  context area.
- *  This is necessary because some FP units are designed to have
- *  their context saved as a stack which grows into lower addresses.
- *  Other FP units can be saved by simply moving registers into offsets
- *  from the base of the context area.  Finally some FP units provide
- *  a "dump context" instruction which could fill in from high to low
- *  or low to high based on the whim of the CPU designers.
- *  XXX
-#define _CPU_Context_Fp_start( _base, _offset ) \
-   ( (void *) (_base) + (_offset) )
- *  This routine initializes the FP context area passed to it to.
- *  There are a few standard ways in which to initialize the
- *  floating point context.  The code included for this macro assumes
- *  that this is a CPU in which a "initial" FP context was saved into
- *  _CPU_Null_fp_context and it simply copies it to the destination
- *  context passed to it.
- *  Other models include (1) not doing anything, and (2) putting
- *  a "null FP status word" in the correct place in the FP context.
- *  XXX
-#define _CPU_Context_Initialize_fp( _destination ) \
-   *(*(_destination)) = _CPU_Null_fp_context; \
-/* end of Context handler macros */
-/* Fatal Error manager macros */
- *  This routine copies _error into a known place -- typically a stack
- *  location or a register, optionally disables interrupts, and
- *  halts/stops the CPU.
- *  XXX
-#define _CPU_Fatal_halt( _source, _error ) \
- 	printk("Fatal Error %d.%d Halted\n",_source, _error); \
-	for(;;)
-/* end of Fatal Error manager macros */
-/* Bitfield handler macros */
- *  This routine sets _output to the bit number of the first bit
- *  set in _value.  _value is of CPU dependent type Priority_bit_map_Word.
- *  This type may be either 16 or 32 bits wide although only the 16
- *  least significant bits will be used.
- *  There are a number of variables in using a "find first bit" type
- *  instruction.
- *    (1) What happens when run on a value of zero?
- *    (2) Bits may be numbered from MSB to LSB or vice-versa.
- *    (3) The numbering may be zero or one based.
- *    (4) The "find first bit" instruction may search from MSB or LSB.
- *  RTEMS guarantees that (1) will never happen so it is not a concern.
- *  (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
- *  _CPU_Priority_bits_index().  These three form a set of routines
- *  which must logically operate together.  Bits in the _value are
- *  set and cleared based on masks built by _CPU_Priority_mask().
- *  The basic major and minor values calculated by _Priority_Major()
- *  and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
- *  to properly range between the values returned by the "find first bit"
- *  instruction.  This makes it possible for _Priority_Get_highest() to
- *  calculate the major and directly index into the minor table.
- *  This mapping is necessary to ensure that 0 (a high priority major/minor)
- *  is the first bit found.
- *  This entire "find first bit" and mapping process depends heavily
- *  on the manner in which a priority is broken into a major and minor
- *  components with the major being the 4 MSB of a priority and minor
- *  the 4 LSB.  Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
- *  priority.  And (15 << 4) + 14 corresponds to priority 254 -- the next
- *  to the lowest priority.
- *  If your CPU does not have a "find first bit" instruction, then
- *  there are ways to make do without it.  Here are a handful of ways
- *  to implement this in software:
- *    - a series of 16 bit test instructions
- *    - a "binary search using if's"
- *    - _number = 0
- *      if _value > 0x00ff
- *        _value >>=8
- *        _number = 8;
- *      if _value > 0x0000f
- *        _value >=8
- *        _number += 4
- *      _number += bit_set_table[ _value ]
- *    where bit_set_table[ 16 ] has values which indicate the first
- *      bit set
- *  XXX
-#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
-#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
-#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
-#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
-    (_output) = 0;   /* do something to prevent warnings */ \
-#endif
-/* end of Bitfield handler macros */
- *  This routine builds the mask which corresponds to the bit fields
- *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
- *  for that routine.
- *  XXX
-#define _CPU_Priority_Mask( _bit_number ) \
-  ( 1 << (_bit_number) )
-#endif
- *  This routine translates the bit numbers returned by
- *  _CPU_Bitfield_Find_first_bit() into something suitable for use as
- *  a major or minor component of a priority.  See the discussion
- *  XXX
-#define _CPU_Priority_bits_index( _priority ) \
-  (_priority)
-#endif
-/* end of Priority handler macros */
-/* functions */
- *  _CPU_Initialize
- *  This routine performs CPU dependent initialization.
- *  XXX
-void _CPU_Initialize(void);
- *  This routine installs a "raw" interrupt handler directly into the
- *  processor's vector table.
- *  XXX
-  uint32_t    vector,
- *  _CPU_ISR_install_vector
- *  This routine installs an interrupt vector.
- *  XXX
-  uint32_t    vector,
- *  This routine installs the hardware interrupt stack pointer.
- *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
- *         is TRUE.
- *  XXX
-void _CPU_Install_interrupt_stack( void );
- *  _CPU_Internal_threads_Idle_thread_body
- *  This routine is the CPU dependent IDLE thread body.
- *  NOTE:  It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
- *         is TRUE.
- *  XXX
-void *_CPU_Thread_Idle_body( uint32_t );
- *  _CPU_Context_switch
- *  This routine switches from the run context to the heir context.
- *  XXX
-void _CPU_Context_switch(
-  Context_Control  *run,
-  Context_Control  *heir
- *  _CPU_Context_restore
- *  This routine is generallu used only to restart self in an
- *  efficient manner.  It may simply be a label in _CPU_Context_switch.
- *  NOTE: May be unnecessary to reload some registers.
- *  XXX
-void _CPU_Context_restore(
-  Context_Control *new_context
-) RTEMS_NO_RETURN;
- *  _CPU_Context_save_fp
- *  This routine saves the floating point context passed to it.
- *  XXX
-void _CPU_Context_save_fp(
-  Context_Control_fp **fp_context_ptr
- *  _CPU_Context_restore_fp
- *  This routine restores the floating point context passed to it.
- *  XXX
-void _CPU_Context_restore_fp(
-static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
-  /* TODO */
-static inline void _CPU_Context_validate( uintptr_t pattern )
-  while (1) {
-    /* TODO */
-/* FIXME */
-typedef CPU_Interrupt_frame CPU_Exception_frame;
-void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
-/*  The following routine swaps the endian format of an unsigned int.
- *  It must be static because it is referenced indirectly.
- *  This version will work on any processor, but if there is a better
- *  way for your CPU PLEASE use it.  The most common way to do this is to:
- *     swap least significant two bytes with 16-bit rotate
- *     swap upper and lower 16-bits
- *     swap most significant two bytes with 16-bit rotate
- *  Some CPUs have special instructions which swap a 32-bit quantity in
- *  a single instruction (e.g. i486).  It is probably best to avoid
- *  an "endian swapping control bit" in the CPU.  One good reason is
- *  that interrupts would probably have to be disabled to ensure that
- *  an interrupt does not try to access the same "chunk" with the wrong
- *  endian.  Another good reason is that on some CPUs, the endian bit
- *  endianness for ALL fetches -- both code and data -- so the code
- *  will be fetched incorrectly.
- *  This is the generic implementation.
-static inline uint32_t   CPU_swap_u32(
-  uint32_t   value
-  uint32_t   byte1, byte2, byte3, byte4, swapped;
-  byte4 = (value >> 24) & 0xff;
-  byte3 = (value >> 16) & 0xff;
-  byte2 = (value >> 8)  & 0xff;
-  byte1 =  value        & 0xff;
-  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
-  return( swapped );
-#define CPU_swap_u16( value ) \
-  (((value&0xff) << 8) | ((value >> 8)&0xff))
-typedef uint32_t CPU_Counter_ticks;
-CPU_Counter_ticks _CPU_Counter_read( void );
-static inline CPU_Counter_ticks _CPU_Counter_difference(
-  CPU_Counter_ticks second,
-  CPU_Counter_ticks first
-  return second - first;
-/* to be provided by the BSP */
-extern void H8BD_Install_IRQ(
-  uint32_t  	vector,
-  proc_ptr	*old_handler );
-#endif /* ASM */
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/cpu/h8300/rtems/score/cpuatomic.h b/cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
index 598ee76..0000000
--- a/cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,14 +0,0 @@
- * COPYRIGHT (c) 2012-2013 Deng Hengyi.
-#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
-#define _RTEMS_SCORE_ATOMIC_CPU_H
-#include <rtems/score/cpustdatomic.h>
-#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/h8300/rtems/score/h8300.h b/cpukit/score/cpu/h8300/rtems/score/h8300.h
index e30343c..0000000
--- a/cpukit/score/cpu/h8300/rtems/score/h8300.h
+++ /dev/null
@@ -1,44 +0,0 @@
- * @file
- * @brief Information Required to Build RTEMS for a Particular Member
- * of the Hitachi H8/300 Family
- * This file contains information pertaining to the Hitachi H8/300
- * processor family.
-#ifndef _RTEMS_SCORE_H8300_H
-#define _RTEMS_SCORE_H8300_H
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This file contains the information required to build
- *  RTEMS for a particular member of the "h8300"
- *  family when executing in protected mode.  It does
- *  this by setting variables to indicate which implementation
- *  dependent features are present in a particular member
- *  of the family.
-#define CPU_NAME  "Hitachi H8300"
-#define CPU_MODEL_NAME  "h8300"
-#define H8300_HAS_FPU     0
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/cpu/h8300/rtems/score/types.h b/cpukit/score/cpu/h8300/rtems/score/types.h
index 7fcac8b..0000000
--- a/cpukit/score/cpu/h8300/rtems/score/types.h
+++ /dev/null
@@ -1,47 +0,0 @@
- * @file
- * @brief Hitachi H8300 CPU Type Definitions
- * This include file contains type definitions pertaining to the Hitachi
- * h8300 processor family.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef unsigned long CPU_Uint32ptr;
-typedef uint16_t     Priority_bit_map_Word;
-typedef void h8300_isr;
-typedef void ( *h8300_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
diff --git a/doc/cpu_supplement/Makefile.am b/doc/cpu_supplement/Makefile.am
index f27cc6a..4d8ac98 100644
--- a/doc/cpu_supplement/Makefile.am
+++ b/doc/cpu_supplement/Makefile.am
@@ -16,7 +16,6 @@ GENERATED_FILES += arm.texi
 GENERATED_FILES += avr.texi
 GENERATED_FILES += bfin.texi
 GENERATED_FILES += epiphany.texi
-GENERATED_FILES += h8300.texi
 GENERATED_FILES += i386.texi
 GENERATED_FILES += lm32.texi
 GENERATED_FILES += m32c.texi
@@ -67,11 +66,6 @@ epiphany.texi: epiphany.t
 	    -u "Top" \
 	    -n "" < $< > $@
-h8300.texi: h8300.t
-	$(BMENU2) -p "" \
-	    -u "Top" \
-	    -n "" < $< > $@
 i386.texi: i386.t
 	$(BMENU2) -p "" \
 	    -u "Top" \
diff --git a/doc/cpu_supplement/cpu_supplement.texi b/doc/cpu_supplement/cpu_supplement.texi
index 2fcdfa0..52c1a6f 100644
--- a/doc/cpu_supplement/cpu_supplement.texi
+++ b/doc/cpu_supplement/cpu_supplement.texi
@@ -66,7 +66,6 @@
 * Atmel AVR Specific Information::
 * Blackfin Specific Information::
 * Epiphany Specific Information::
-* Renesas H8/300 Specific Information::
 * Intel/AMD x86 Specific Information::
 * Lattice Mico32 Specific Information::
 * Renesas M32C Specific Information::
@@ -90,7 +89,6 @@
 @include avr.texi
 @include bfin.texi
 @include epiphany.texi
- at include h8300.texi
 @include i386.texi
 @include lm32.texi
 @include m32c.texi
diff --git a/doc/cpu_supplement/h8300.t b/doc/cpu_supplement/h8300.t
index 8c50ffb..0000000
--- a/doc/cpu_supplement/h8300.t
+++ /dev/null
@@ -1,11 +0,0 @@
- at c Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
- at chapter Renesas H8/300 Specific Information
- at section Symmetric Multiprocessing
-SMP is not supported.
- at section Thread-Local Storage
-Thread-local storage is not implemented.
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 4941c51..5ac2dfd 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -53,9 +53,6 @@ case $RTEMS_CPU in
   bfin)
    HAVE_LIBDL=no ;;
-  h8300)
-   HAVE_LIBDL=no ;;
   lm32)
    HAVE_LIBDL=no ;;
diff --git a/testsuites/psxtests/psx04/task3.c b/testsuites/psxtests/psx04/task3.c
index 71ac39f..5d4172c 100644
--- a/testsuites/psxtests/psx04/task3.c
+++ b/testsuites/psxtests/psx04/task3.c
@@ -29,7 +29,7 @@ void *Task_3(
   unsigned int  remaining;
   int           status;
   int           sig;
-  volatile union sigval  value; /* should be removed once the H8300 target is fixed */
+  volatile union sigval  value;
   sigset_t      mask;
   siginfo_t     info;
1.7.1
