[PATCH 3/6] avr/avrtest/configure.ac: Correct typo
Sun Jan 3 21:27:02 UTC 2016
 c/src/lib/libbsp/avr/avrtest/configure.ac |   20 ++++++++++++++++++++
 c/src/lib/libbsp/avr/configure.ac         |    1 -
 2 files changed, 20 insertions(+), 1 deletions(-)
 create mode 100644 c/src/lib/libbsp/avr/avrtest/configure.ac
diff --git a/c/src/lib/libbsp/avr/avrtest/configure.ac b/c/src/lib/libbsp/avr/avrtest/configure.ac
new file mode 100644
index 0000000..f9c0b5c
--- /dev/null
+++ b/c/src/lib/libbsp/avr/avrtest/configure.ac
@@ -0,0 +1,20 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-avr-avrtest],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+AC_CONFIG_SRCDIR([bsp_specs])
+RTEMS_TOP(../../../../../..)
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_PROG_CC_FOR_TARGET
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_PROG_CCAS
+RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile])
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/avr/configure.ac b/c/src/lib/libbsp/avr/configure.ac
index eebd8b5..32ecf2e 100644
--- a/c/src/lib/libbsp/avr/configure.ac
+++ b/c/src/lib/libbsp/avr/configure.ac
@@ -2,7 +2,6 @@
 AC_PREREQ([2.69])
 AC_INIT([rtems-c-src-lib-libbsp-avr],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([avrtest])
 RTEMS_TOP(../../../../..)
1.7.1
