[PATCH 3/6] avr/avrtest/configure.ac: Correct typo
Mon Jan 4 02:03:05 UTC 2016
why is this adding back avrtest/configure.ac?
On Sun, Jan 3, 2016 at 4:27 PM, Joel Sherrill <joel at rtems.org> wrote:
> From: Joel Sherrill <joel.sherrill at oarcorp.com>
>  c/src/lib/libbsp/avr/avrtest/configure.ac |   20 ++++++++++++++++++++
>  c/src/lib/libbsp/avr/configure.ac         |    1 -
>  2 files changed, 20 insertions(+), 1 deletions(-)
>  create mode 100644 c/src/lib/libbsp/avr/avrtest/configure.ac
> diff --git a/c/src/lib/libbsp/avr/avrtest/configure.ac b/c/src/lib/libbsp/avr/avrtest/configure.ac
> new file mode 100644
> index 0000000..f9c0b5c
> --- /dev/null
> +++ b/c/src/lib/libbsp/avr/avrtest/configure.ac
> @@ -0,0 +1,20 @@
> +## Process this file with autoconf to produce a configure script.
> +AC_PREREQ([2.69])
> +AC_INIT([rtems-c-src-lib-libbsp-avr-avrtest],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
> +AC_CONFIG_SRCDIR([bsp_specs])
> +RTEMS_TOP(../../../../../..)
> +RTEMS_CANONICAL_TARGET_CPU
> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> +RTEMS_BSP_CONFIGURE
> +RTEMS_PROG_CC_FOR_TARGET
> +RTEMS_CANONICALIZE_TOOLS
> +RTEMS_PROG_CCAS
> +RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
> +# Explicitly list all Makefiles here
> +AC_CONFIG_FILES([Makefile])
> +AC_OUTPUT
> diff --git a/c/src/lib/libbsp/avr/configure.ac b/c/src/lib/libbsp/avr/configure.ac
> index eebd8b5..32ecf2e 100644
> --- a/c/src/lib/libbsp/avr/configure.ac
> +++ b/c/src/lib/libbsp/avr/configure.ac
> @@ -2,7 +2,6 @@
>  AC_PREREQ([2.69])
>  AC_INIT([rtems-c-src-lib-libbsp-avr],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
> -AC_CONFIG_SRCDIR([avrtest])
>  RTEMS_TOP(../../../../..)
> 1.7.1
> devel mailing list
> devel at rtems.org
