[PATCH 1/6] Remove M32R architecture
Joel Sherrill
joel at rtems.org
Mon Jan 4 02:11:48 UTC 2016
On Sun, Jan 3, 2016 at 8:02 PM, Gedare Bloom <gedare at rtems.org> wrote:
> The process should also (eventually) submit the removal of the tools
> from gcc upstream?
> Yep. Trying to sweep one thing at a time. These should only update the
tickets
not close them. I haven't looked but the new tcp/ip stack and some other
repos
may have references.
> On Sun, Jan 3, 2016 at 4:27 PM, Joel Sherrill <joel at rtems.org> wrote:
> > From: Joel Sherrill <joel.sherrill at oarcorp.com>
> > updates #2446.
> > c/src/aclocal/rtems-cpu-subdirs.m4 | 1 -
> > c/src/lib/libbsp/m32r/Makefile.am | 9 -
> > c/src/lib/libbsp/m32r/acinclude.m4 | 8 -
> > c/src/lib/libbsp/m32r/configure.ac | 20 -
> > cpukit/configure.ac | 4 +-
> > cpukit/libcsupport/src/newlibc_exit.c | 4 +-
> > .../libdl/include/arch/m32r/machine/elf_machdep.h | 39 -
> > cpukit/libdl/rtl-mdreloc-m32r.c | 156 ---
> > cpukit/libdl/rtl-shell.c | 2 +-
> > cpukit/librpc/src/xdr/xdr_float.c | 1 -
> > cpukit/score/cpu/Makefile.am | 1 -
> > cpukit/score/cpu/m32r/Makefile.am | 22 -
> > cpukit/score/cpu/m32r/context_init.c | 61 -
> > cpukit/score/cpu/m32r/context_switch.S | 67 -
> > cpukit/score/cpu/m32r/cpu.c | 125 --
> > cpukit/score/cpu/m32r/cpu_asm.c | 106 --
> > cpukit/score/cpu/m32r/m32r-exception-frame-print.c | 24 -
> > cpukit/score/cpu/m32r/preinstall.am | 54 -
> > cpukit/score/cpu/m32r/rtems/asm.h | 127 --
> > cpukit/score/cpu/m32r/rtems/score/cpu.h | 1272
> > cpukit/score/cpu/m32r/rtems/score/cpu_asm.h | 72 --
> > cpukit/score/cpu/m32r/rtems/score/cpuatomic.h | 14 -
> > cpukit/score/cpu/m32r/rtems/score/m32r.h | 70 --
> > cpukit/score/cpu/m32r/rtems/score/types.h | 52 -
> > cpukit/score/src/threadglobalconstruction.c | 4 +-
> > doc/cpu_supplement/Makefile.am | 8 +-
> > doc/cpu_supplement/cpu_supplement.texi | 2 -
> > doc/cpu_supplement/m32r.t | 11 -
> > doc/user/preface.texi | 3 +-
> > testsuites/libtests/configure.ac | 3 +-
> > 30 files changed, 7 insertions(+), 2335 deletions(-)
> > delete mode 100644 c/src/lib/libbsp/m32r/Makefile.am
> > delete mode 100644 c/src/lib/libbsp/m32r/acinclude.m4
> > delete mode 100644 c/src/lib/libbsp/m32r/configure.ac
> > delete mode 100644 cpukit/libdl/include/arch/m32r/machine/elf_machdep.h
> > delete mode 100644 cpukit/libdl/rtl-mdreloc-m32r.c
> > delete mode 100644 cpukit/score/cpu/m32r/Makefile.am
> > delete mode 100644 cpukit/score/cpu/m32r/context_init.c
> > delete mode 100644 cpukit/score/cpu/m32r/context_switch.S
> > delete mode 100644 cpukit/score/cpu/m32r/cpu.c
> > delete mode 100644 cpukit/score/cpu/m32r/cpu_asm.c
> > delete mode 100644 cpukit/score/cpu/m32r/m32r-exception-frame-print.c
> > delete mode 100644 cpukit/score/cpu/m32r/preinstall.am
> > delete mode 100644 cpukit/score/cpu/m32r/rtems/asm.h
> > delete mode 100644 cpukit/score/cpu/m32r/rtems/score/cpu.h
> > delete mode 100644 cpukit/score/cpu/m32r/rtems/score/cpu_asm.h
> > delete mode 100644 cpukit/score/cpu/m32r/rtems/score/cpuatomic.h
> > delete mode 100644 cpukit/score/cpu/m32r/rtems/score/m32r.h
> > delete mode 100644 cpukit/score/cpu/m32r/rtems/score/types.h
> > delete mode 100644 doc/cpu_supplement/m32r.t
> > diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4
> b/c/src/aclocal/rtems-cpu-subdirs.m4
> > index 524edac..3cb28b1 100644
> > --- a/c/src/aclocal/rtems-cpu-subdirs.m4
> > +++ b/c/src/aclocal/rtems-cpu-subdirs.m4
> > @@ -18,7 +18,6 @@ _RTEMS_CPU_SUBDIR([h8300],[$1]);;
> > _RTEMS_CPU_SUBDIR([i386],[$1]);;
> > _RTEMS_CPU_SUBDIR([lm32],[$1]);;
> > _RTEMS_CPU_SUBDIR([m32c],[$1]);;
> > -_RTEMS_CPU_SUBDIR([m32r],[$1]);;
> > _RTEMS_CPU_SUBDIR([m68k],[$1]);;
> > _RTEMS_CPU_SUBDIR([mips],[$1]);;
> > _RTEMS_CPU_SUBDIR([moxie],[$1]);;
> > diff --git a/c/src/lib/libbsp/m32r/Makefile.am
> b/c/src/lib/libbsp/m32r/Makefile.am
> > deleted file mode 100644
> > index f504c03..0000000
> > --- a/c/src/lib/libbsp/m32r/Makefile.am
> > +++ /dev/null
> > @@ -1,9 +0,0 @@
> > -ACLOCAL_AMFLAGS = -I ../../../aclocal
> > -## Descend into the @RTEMS_BSP_FAMILY@ directory
> > -SUBDIRS = @RTEMS_BSP_FAMILY@
> > -EXTRA_DIST =
> > -include $(top_srcdir)/../../../automake/subdirs.am
> > -include $(top_srcdir)/../../../automake/local.am
> > diff --git a/c/src/lib/libbsp/m32r/acinclude.m4
> b/c/src/lib/libbsp/m32r/acinclude.m4
> > index 296a6f7..0000000
> > --- a/c/src/lib/libbsp/m32r/acinclude.m4
> > +++ /dev/null
> > @@ -1,8 +0,0 @@
> > -# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
> > -AC_DEFUN([RTEMS_CHECK_BSPDIR],
> > - case "$1" in
> > - AC_MSG_ERROR([Invalid BSP]);;
> > - esac
> > diff --git a/c/src/lib/libbsp/m32r/configure.ac b/c/src/lib/libbsp/m32r/
> configure.ac
> > index 362e534..0000000
> > --- a/c/src/lib/libbsp/m32r/configure.ac
> > +++ /dev/null
> > @@ -1,20 +0,0 @@
> > -## Process this file with autoconf to produce a configure script.
> > -AC_PREREQ([2.69])
> > -AC_INIT([rtems-c-src-lib-libbsp-m32r],[_RTEMS_VERSION],[
> https://devel.rtems.org/newticket])
> > -AC_CONFIG_SRCDIR([Makefile.am])
> > -RTEMS_TOP(../../../../..)
> > -RTEMS_CANONICAL_TARGET_CPU
> > -AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
> > -AM_MAINTAINER_MODE
> > -RTEMS_ENV_RTEMSBSP
> > -RTEMS_PROJECT_ROOT
> > -RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
> > -# Explicitly list all Makefiles here
> > -AC_CONFIG_FILES([Makefile])
> > -AC_OUTPUT
> > diff --git a/cpukit/configure.ac b/cpukit/configure.ac
> > index f1589a8..8436c91 100644
> > --- a/cpukit/configure.ac
> > +++ b/cpukit/configure.ac
> > @@ -388,8 +388,7 @@ AM_CONDITIONAL([RPCTOOLS],[test "$RPCGEN" = rpcgen \
> > # reloc backends
> > AC_MSG_CHECKING([whether CPU supports libdl])
> > case $RTEMS_CPU in
> > - arm | i386 | m32r | m68k | mips | \
> > - moxie | powerpc | sparc)
> > + arm | i386 | m68k | mips | moxie | powerpc | sparc)
> > HAVE_LIBDL=yes ;;
> > # bfin has an issue to resolve with libdl. See ticket #2252
> > bfin)
> > @@ -463,7 +462,6 @@ score/cpu/i386/Makefile
> > score/cpu/lm32/Makefile
> > score/cpu/m68k/Makefile
> > score/cpu/m32c/Makefile
> > -score/cpu/m32r/Makefile
> > score/cpu/mips/Makefile
> > score/cpu/moxie/Makefile
> > score/cpu/nios2/Makefile
> > diff --git a/cpukit/libcsupport/src/newlibc_exit.c
> b/cpukit/libcsupport/src/newlibc_exit.c
> > index fad7f76..c093bb2 100644
> > --- a/cpukit/libcsupport/src/newlibc_exit.c
> > +++ b/cpukit/libcsupport/src/newlibc_exit.c
> > @@ -22,9 +22,7 @@
> > /* FIXME: These defines are a blatant hack */
> > #if defined(__USE_INIT_FINI__)
> > - #if defined(__m32r__)
> > - #define FINI_SYMBOL __fini
> > - #elif defined(__ARM_EABI__)
> > + #if defined(__ARM_EABI__)
> > #define FINI_SYMBOL __libc_fini_array
> > #else
> > #define FINI_SYMBOL _fini
> > diff --git a/cpukit/libdl/include/arch/m32r/machine/elf_machdep.h
> b/cpukit/libdl/include/arch/m32r/machine/elf_machdep.h
> > index 3f531cf..0000000
> > --- a/cpukit/libdl/include/arch/m32r/machine/elf_machdep.h
> > +++ /dev/null
> > @@ -1,39 +0,0 @@
> > -#define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
> > -#define ELF32_MACHDEP_ID_CASES \
> > - case EM_M32R: \
> > - break;
> > -#define ELF32_MACHDEP_ID EM_M32R
> > -#define ARCH_ELFSIZE 32
> > -#define R_M32R_NONE 0
> > -/*-----------OLD TYPE-------------*/
> > -#define R_M32R_16 1
> > -#define R_M32R_32 2
> > -#define R_M32R_24 3
> > -#define R_M32R_10_PCREL 4
> > -#define R_M32R_18_PCREL 5
> > -#define R_M32R_26_PCREL 6
> > -#define R_M32R_HI16_ULO 7
> > -#define R_M32R_HI16_SLO 8
> > -#define R_M32R_LO16 9
> > -#define R_M32R_SDA16 10
> > -#define R_M32R_GNU_VTINHERIT 11
> > -#define R_M32R_GNU_VTENTRY 12
> > -#define R_M32R_16_RELA 33
> > -#define R_M32R_32_RELA 34
> > -#define R_M32R_24_RELA 35
> > -#define R_M32R_18_PCREL_RELA 37
> > -#define R_M32R_26_PCREL_RELA 38
> > -#define R_M32R_HI16_ULO_RELA 39
> > -#define R_M32R_HI16_SLO_RELA 40
> > -#define R_M32R_LO16_RELA 41
> > -#define R_M32R_SDA16_RELA 42
> > -#define R_M32R_RELA_GNU_VTINHERIT 43
> > -#define R_M32R_RELA_GNU_VTENTRY 44
> > -#define R_TYPE(name) __CONCAT(R_M32R_,name)
> > diff --git a/cpukit/libdl/rtl-mdreloc-m32r.c
> b/cpukit/libdl/rtl-mdreloc-m32r.c
> > index 265e9cb..0000000
> > --- a/cpukit/libdl/rtl-mdreloc-m32r.c
> > +++ /dev/null
> > @@ -1,156 +0,0 @@
> > -#include <sys/cdefs.h>
> > -#include <errno.h>
> > -#include <stdio.h>
> > -#include <sys/types.h>
> > -#include <sys/stat.h>
> > -#include <rtems/rtl/rtl.h>
> > -#include "rtl-elf.h"
> > -#include "rtl-error.h"
> > -#include "rtl-trace.h"
> > -static inline Elf_Addr
> > -load_ptr(void *where)
> > - Elf_Addr res;
> > - memcpy(&res, where, sizeof(res));
> > - return (res);
> > -static inline void
> > -store_ptr(void *where, Elf_Addr val)
> > - memcpy(where, &val, sizeof(val));
> > -bool
> > -rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
> > - return true;
> > -bool
> > -rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t* obj,
> > - const Elf_Rela* rela,
> > - const rtems_rtl_obj_sect_t* sect,
> > - const char* symname,
> > - const Elf_Byte syminfo,
> > - const Elf_Word symvalue)
> > - Elf_Addr *where;
> > - Elf_Word tmp;
> > - where = (Elf_Addr *)(sect->base + rela->r_offset);
> > - if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC)) {
> > - printf("relocated address 0x%08lx\n", (Elf_Addr)where);
> > - switch (ELF_R_TYPE(rela->r_info)) {
> > - case R_TYPE(NONE):
> > - break;
> > - case R_TYPE(16_RELA):
> > - * half16: S + A
> > - *(uint16_t *)where = (symvalue + rela->r_addend) & 0xffff;
> > - break;
> > - case R_TYPE(24_RELA):
> > - * imm24: (S + A) & 0xFFFFFF
> > - tmp = symvalue + rela->r_addend;
> > - if (((Elf_Sword)tmp > 0x7fffff) || ((Elf_Sword)tmp < -0x800000)) {
> > - printf("24_RELA Overflow\n");
> > - return false;
> > - *where = (*where & 0xff000000) | (tmp & 0xffffff);
> > - break;
> > - case R_TYPE(32_RELA):
> > - * word32: S + A
> > - *where += symvalue + rela->r_addend;
> > - break;
> > - case R_TYPE(26_PCREL_RELA):
> > - * disp24: ((S + A - P) >> 2) & 0xFFFFFF
> > - tmp = symvalue + rela->r_addend - (Elf_Addr)where;
> > - tmp = (Elf_Sword)tmp >> 2;
> > - printf("26_PCREL_RELA Overflow\n");
> > - return false;
> > - break;
> > - case R_TYPE(18_PCREL_RELA):
> > - * disp16: ((S + A - P) >> 2) & 0xFFFFFF
> > - if (((Elf_Sword)tmp > 0x7fff) || ((Elf_Sword)tmp < -0x8000)) {
> > - printf("18_PCREL_RELA Overflow\n");
> > - return false;
> > - *where = (*where & 0xffff0000) | (tmp & 0xffff);
> > - break;
> > - case R_TYPE(HI16_ULO_RELA):
> > - * imm16: ((S + A) >> 16)
> > - tmp = *where;
> > - tmp += ((symvalue + rela->r_addend) >> 16) & 0xffff;
> > - *where = tmp;
> > - break;
> > - case R_TYPE(HI16_SLO_RELA):
> > - * imm16: ((S + A) >> 16) or ((S + A + 0x10000) >> 16)
> > - if (tmp & 0x8000) tmp += 0x10000;
> > - tmp = (tmp >> 16) & 0xffff;
> > - *where += tmp;
> > - break;
> > - case R_TYPE(LO16_RELA):
> > - * imm16: (S + A) & 0xFFFF
> > - break;
> > - default:
> > - rtems_rtl_set_error (EINVAL, "rela type record not supported");
> > - printf("Unsupported rela reloc types\n");
> > - return false;
> > - return true;
> > -bool
> > -rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
> > - const Elf_Rel* rel,
> > - rtems_rtl_set_error (EINVAL, "rel type record not supported");
> > - return true;
> > diff --git a/cpukit/libdl/rtl-shell.c b/cpukit/libdl/rtl-shell.c
> > index 20a6aab..a10c931 100644
> > --- a/cpukit/libdl/rtl-shell.c
> > +++ b/cpukit/libdl/rtl-shell.c
> > @@ -25,7 +25,7 @@
> > * Flag the targets where off_t is 32 bits. This is not a compiler type
> > * so we can't rely on prerdefines.
> > -#if defined(__m32r__) || defined(__moxie__)
> > +#if defined(__moxie__)
> > #define PRIdoff_t PRIo32
> > #else
> > #define PRIdoff_t PRIo64
> > diff --git a/cpukit/librpc/src/xdr/xdr_float.c
> b/cpukit/librpc/src/xdr/xdr_float.c
> > index ac8c46d..5d6b4ea 100644
> > --- a/cpukit/librpc/src/xdr/xdr_float.c
> > +++ b/cpukit/librpc/src/xdr/xdr_float.c
> > @@ -77,7 +77,6 @@ static char *rcsid = "$FreeBSD:
> src/lib/libc/xdr/xdr_float.c,v 1.7 1999/08/28 00
> > defined(__AVR__) || \
> > defined(__BFIN__) || \
> > defined(__m32c__) || \
> > - defined(__M32R__) || \
> > defined(__v850)
> > #include <rtems/endian.h>
> > diff --git a/cpukit/score/cpu/Makefile.am b/cpukit/score/cpu/Makefile.am
> > index 7279d38..4438e3f 100644
> > --- a/cpukit/score/cpu/Makefile.am
> > +++ b/cpukit/score/cpu/Makefile.am
> > @@ -9,7 +9,6 @@ DIST_SUBDIRS += h8300
> > DIST_SUBDIRS += i386
> > DIST_SUBDIRS += lm32
> > DIST_SUBDIRS += m32c
> > -DIST_SUBDIRS += m32r
> > DIST_SUBDIRS += m68k
> > DIST_SUBDIRS += mips
> > DIST_SUBDIRS += moxie
> > diff --git a/cpukit/score/cpu/m32r/Makefile.am
> b/cpukit/score/cpu/m32r/Makefile.am
> > index dcf0871..0000000
> > --- a/cpukit/score/cpu/m32r/Makefile.am
> > +++ /dev/null
> > @@ -1,22 +0,0 @@
> > -include $(top_srcdir)/automake/compile.am
> > -include_HEADERS =
> > -include_rtemsdir = $(includedir)/rtems
> > -include_rtems_HEADERS = rtems/asm.h
> > -include_rtems_scoredir = $(includedir)/rtems/score
> > -include_rtems_score_HEADERS = rtems/score/cpu.h
> > -include_rtems_score_HEADERS += rtems/score/m32r.h
> > -include_rtems_score_HEADERS += rtems/score/cpu_asm.h
> > -include_rtems_score_HEADERS += rtems/score/types.h
> > -include_rtems_score_HEADERS += rtems/score/cpuatomic.h
> > -noinst_LIBRARIES = libscorecpu.a
> > -libscorecpu_a_SOURCES = cpu.c cpu_asm.c context_switch.S context_init.c
> > -libscorecpu_a_SOURCES += ../no_cpu/cpucounterread.c
> > -libscorecpu_a_SOURCES += m32r-exception-frame-print.c
> > -libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
> > -include $(srcdir)/preinstall.am
> > -include $(top_srcdir)/automake/local.am
> > diff --git a/cpukit/score/cpu/m32r/context_init.c
> b/cpukit/score/cpu/m32r/context_init.c
> > index 90f582a..0000000
> > --- a/cpukit/score/cpu/m32r/context_init.c
> > +++ /dev/null
> > @@ -1,61 +0,0 @@
> > - * @file
> > - * @brief M32R CPU Context Initialize
> > - * COPYRIGHT (c) 1989-2008.
> > - * On-Line Applications Research Corporation (OAR).
> > - * The license and distribution terms for this file may be
> > - * found in the file LICENSE in this distribution or at
> > - * http://www.rtems.org/license/LICENSE.
> > -#ifdef HAVE_CONFIG_H
> > -#include "config.h"
> > -#endif
> > -#include <stdint.h>
> > -#include <rtems/system.h>
> > -typedef struct {
> > - uint32_t marker;
> > -} Starting_Frame;
> > -#define _get_r12( _r12 ) \
> > - __asm__ volatile( "mv r12, %0" : "=r" (_r12))
> > -void _CPU_Context_Initialize(
> > - Context_Control *the_context,
> > - uint32_t *stack_base,
> > - uint32_t size,
> > - uint32_t new_level,
> > - void *entry_point,
> > - bool is_fp,
> > - void *tls_area
> > - void *stackEnd = stack_base;
> > - Starting_Frame *frame;
> > - uint32_t r12;
> > - stackEnd += size;
> > - frame = (Starting_Frame *)stackEnd;
> > - frame--;
> > - frame->marker = 0xa5a5a5a5;
> > - _get_r12( r12 );
> > - the_context->r8 = 0x88888888;
> > - the_context->r9 = 0x99999999;
> > - the_context->r10 = 0xaaaaaaaa;
> > - the_context->r11 = 0xbbbbbbbb;
> > - the_context->r12 = r12;
> > - the_context->r13_fp = 0;
> > - the_context->r14_lr = (uintptr_t) entry_point;
> > - the_context->r15_sp = (uintptr_t) frame;
> > diff --git a/cpukit/score/cpu/m32r/context_switch.S
> b/cpukit/score/cpu/m32r/context_switch.S
> > index 9f52090..0000000
> > --- a/cpukit/score/cpu/m32r/context_switch.S
> > +++ /dev/null
> > @@ -1,67 +0,0 @@
> > - * Context switch for the Reneas M32C
> > -#endif
> > -#define ARG_EXECUTING 8
> > -#define ARG_HEIR 12
> > -#define CONTEXT_R8 0x00
> > -#define CONTEXT_R9 0x04
> > -#define CONTEXT_R10 0x08
> > -#define CONTEXT_R11 0x0C
> > -#define CONTEXT_R12 0x10
> > -#define CONTEXT_R13_FP 0x14
> > -#define CONTEXT_R14_LR 0x18
> > -#define CONTEXT_R15_SP 0x1C
> > -#define CONTEXT_ACC_LOW 0x20
> > -#define CONTEXT_ACC_HIGH 0x24
> > - .file "context_switch.S"
> > - .text
> > - .global _CPU_Context_switch
> > - .type _CPU_Context_switch, @function
> > -_CPU_Context_switch:
> > - st r8, @(CONTEXT_R8,r0)
> > - st r9, @(CONTEXT_R9,r0)
> > - st r10, @(CONTEXT_R10,r0)
> > - st r11, @(CONTEXT_R11,r0)
> > - st r12, @(CONTEXT_R12,r0)
> > - st r13, @(CONTEXT_R13_FP,r0)
> > - st r14, @(CONTEXT_R14_LR,r0)
> > - st r15, @(CONTEXT_R15_SP,r0)
> > - mvfaclo r2
> > - st r2, @(CONTEXT_ACC_LOW,r0)
> > - mvfachi r2
> > - st r2, @(CONTEXT_ACC_HIGH,r0)
> > -restore:
> > - ld r8, @(CONTEXT_R8,r1)
> > - ld r9, @(CONTEXT_R9,r1)
> > - ld r10, @(CONTEXT_R10,r1)
> > - ld r11, @(CONTEXT_R11,r1)
> > - ld r12, @(CONTEXT_R12,r1)
> > - ld r13, @(CONTEXT_R13_FP,r1)
> > - ld r14, @(CONTEXT_R14_LR,r1)
> > - ld r15, @(CONTEXT_R15_SP,r1)
> > - ld r2, @(CONTEXT_ACC_LOW,r1)
> > - mvtaclo r2
> > - ld r2, @(CONTEXT_ACC_HIGH,r1)
> > - mvtachi r2
> > - jmp lr
> > - .global _CPU_Context_Restart_self
> > - .type _CPU_Context_Restart_self, @function
> > -_CPU_Context_Restart_self:
> > - mv r1, r0
> > - bra restore
> > diff --git a/cpukit/score/cpu/m32r/cpu.c b/cpukit/score/cpu/m32r/cpu.c
> > index 7bdf490..0000000
> > --- a/cpukit/score/cpu/m32r/cpu.c
> > +++ /dev/null
> > @@ -1,125 +0,0 @@
> > - * @file
> > - * @brief M32R CPU Support
> > -#endif
> > -#include <rtems/score/isr.h>
> > -/* _CPU_Initialize
> > - * This routine performs processor dependent initialization.
> > - * INPUT PARAMETERS: NONE
> > - * NO_CPU Specific Information:
> > - * XXX document implementation including references if appropriate
> > -void _CPU_Initialize(void)
> > - * This routine returns the current interrupt level.
> > -uint32_t _CPU_ISR_Get_level( void )
> > - return 0;
> > - * _CPU_ISR_install_raw_handler
> > -void _CPU_ISR_install_raw_handler(
> > - uint32_t vector,
> > - proc_ptr new_handler,
> > - proc_ptr *old_handler
> > - * This is where we install the interrupt handler into the "raw"
> interrupt
> > - * table used by the CPU to dispatch interrupt handlers.
> > - /* _set_var_vect(new_handler,vector); */
> > - * _CPU_ISR_install_vector
> > - * This kernel routine installs the RTEMS handler for the
> > - * specified vector.
> > - * Input parameters:
> > - * vector - interrupt vector number
> > - * old_handler - former ISR for this vector number
> > - * new_handler - replacement ISR for this vector number
> > - * Output parameters: NONE
> > -void _CPU_ISR_install_vector(
> > - uint32_t vector,
> > - *old_handler = _ISR_Vector_table[ vector ];
> > - * If the interrupt vector table is a table of pointer to isr entry
> > - * points, then we need to install the appropriate RTEMS interrupt
> > - * handler for this vector number.
> > - _CPU_ISR_install_raw_handler( vector, new_handler, old_handler );
> > - * We put the actual user ISR address in '_ISR_vector_table'. This
> will
> > - * be used by the _ISR_Handler so the user gets control.
> > - _ISR_Vector_table[ vector ] = new_handler;
> > - * _CPU_Install_interrupt_stack
> > -void _CPU_Install_interrupt_stack( void )
> > diff --git a/cpukit/score/cpu/m32r/cpu_asm.c
> b/cpukit/score/cpu/m32r/cpu_asm.c
> > index f808f42..0000000
> > --- a/cpukit/score/cpu/m32r/cpu_asm.c
> > +++ /dev/null
> > @@ -1,106 +0,0 @@
> > - * @file
> > - * @brief M32R ISR Handler
> > - * cpu_asm.c ===> cpu_asm.S or cpu_asm.s
> > - * @note This is supposed to be a .S or .s file NOT a C file.
> > - * M32R does not yet have interrupt support. When this functionality
> > - * is written, this file should become obsolete.
> > -#endif
> > -#include <rtems/score/cpu.h>
> > - * Prototypes
> > -void _ISR_Handler(void);
> > -/* void __ISR_Handler()
> > - * This routine provides the RTEMS interrupt management.
> > - * This discussion ignores a lot of the ugly details in a real
> > - * implementation such as saving enough registers/state to be
> > - * able to do something real. Keep in mind that the goal is
> > - * to invoke a user's ISR handler which is written in C and
> > - * uses a certain set of registers.
> > - * Also note that the exact order is to a large extent flexible.
> > - * Hardware will dictate a sequence for a certain subset of
> > - * _ISR_Handler while requirements for setting
> > - * At entry to "common" _ISR_Handler, the vector number must be
> > - * available. On some CPUs the hardware puts either the vector
> > - * number or the offset into the vector table for this ISR in a
> > - * known place. If the hardware does not give us this information,
> > - * then the assembly portion of RTEMS for this port will contain
> > - * a set of distinct interrupt entry points which somehow place
> > - * the vector number in a known place (which is safe if another
> > - * interrupt nests this one) and branches to _ISR_Handler.
> > - * save some or all context on stack
> > - * may need to save some special interrupt information for exit
> > - * #if ( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE )
> > - * if ( _ISR_Nest_level == 0 )
> > - * switch to software interrupt stack
> > - * #endif
> > - * _ISR_Nest_level++;
> > - * _Thread_Dispatch_disable_level++;
> > - * (*_ISR_Vector_table[ vector ])( vector );
> > - * _Thread_Dispatch_disable_level--;
> > - * --_ISR_Nest_level;
> > - * if ( _ISR_Nest_level )
> > - * goto the label "exit interrupt (simple case)"
> > - * if ( _Thread_Dispatch_disable_level )
> > - * if ( _Thread_Dispatch_necessary ) {
> > - * call _Thread_Dispatch() or prepare to return to _ISR_Dispatch
> > - * prepare to get out of interrupt
> > - * return from interrupt (maybe to _ISR_Dispatch)
> > - * LABEL "exit interrupt (simple case):
> > - * if outermost interrupt
> > - * restore stack
> > - * #endif
> > diff --git a/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
> b/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
> > index 71e7e1c..0000000
> > --- a/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
> > +++ /dev/null
> > @@ -1,24 +0,0 @@
> > - * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
> > - * embedded brains GmbH
> > - * Obere Lagerstr. 30
> > - * 82178 Puchheim
> > - * Germany
> > - * <rtems at embedded-brains.de>
> > - #include "config.h"
> > -#endif
> > -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> > - /* TODO */
> > diff --git a/cpukit/score/cpu/m32r/preinstall.am
> b/cpukit/score/cpu/m32r/preinstall.am
> > index 3d76b74..0000000
> > --- a/cpukit/score/cpu/m32r/preinstall.am
> > +++ /dev/null
> > @@ -1,54 +0,0 @@
> > -## Automatically generated by ampolish3 - Do not edit
> > -if AMPOLISH3
> > -$(srcdir)/preinstall.am: Makefile.am
> > - $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> > -endif
> > -PREINSTALL_DIRS =
> > -DISTCLEANFILES = $(PREINSTALL_DIRS)
> > -all-am: $(PREINSTALL_FILES)
> > -PREINSTALL_FILES =
> > -CLEANFILES = $(PREINSTALL_FILES)
> > -$(PROJECT_INCLUDE)/$(dirstamp):
> > - @$(MKDIR_P) $(PROJECT_INCLUDE)
> > - @: > $(PROJECT_INCLUDE)/$(dirstamp)
> > -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
> > -$(PROJECT_INCLUDE)/rtems/$(dirstamp):
> > - @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
> > - @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> > -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> > -$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
> > -$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
> > - @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
> > - @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> > -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> > -$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
> > -$(PROJECT_INCLUDE)/rtems/score/m32r.h: rtems/score/m32r.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/m32r.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/m32r.h
> > -$(PROJECT_INCLUDE)/rtems/score/cpu_asm.h: rtems/score/cpu_asm.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
> > -$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
> > -$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> > diff --git a/cpukit/score/cpu/m32r/rtems/asm.h
> b/cpukit/score/cpu/m32r/rtems/asm.h
> > index 11f5b87..0000000
> > --- a/cpukit/score/cpu/m32r/rtems/asm.h
> > +++ /dev/null
> > @@ -1,127 +0,0 @@
> > - * @file
> > - * @brief Address the Problems Caused by Incompatible Flavor of
> > - * Assemblers and Toolsets
> > - * This include file attempts to address the problems
> > - * caused by incompatible flavors of assemblers and
> > - * toolsets. It primarily addresses variations in the
> > - * use of leading underscores on symbols and the requirement
> > - * that register names be preceded by a %.
> > - * NOTE: The spacing in the use of these macros
> > - * is critical to them working as advertised.
> > - * COPYRIGHT:
> > - * This file is based on similar code found in newlib available
> > - * from ftp.cygnus.com. The file which was used had no copyright
> > - * notice. This file is freely distributable as long as the source
> > - * of the file is noted. This file is:
> > - * COPYRIGHT (c) 1994-2006.
> > -#ifndef _RTEMS_ASM_H
> > -#define _RTEMS_ASM_H
> > - * Indicate we are in an assembly file and get the basic CPU
> definitions.
> > -#ifndef ASM
> > -#define ASM
> > -#endif
> > -#include <rtems/score/cpuopts.h>
> > -#include <rtems/score/m32r.h>
> > -#ifndef __USER_LABEL_PREFIX__
> > - * Recent versions of GNU cpp define variables which indicate the
> > - * need for underscores and percents. If not using GNU cpp or
> > - * the version does not support this, then you will obviously
> > - * have to define these as appropriate.
> > - * This symbol is prefixed to all C program symbols.
> > -#define __USER_LABEL_PREFIX__ _
> > -#endif
> > -#ifndef __REGISTER_PREFIX__
> > - * This symbol is prefixed to all register names.
> > -#define __REGISTER_PREFIX__
> > -#endif
> > -#include <rtems/concat.h>
> > -/** Use the right prefix for global labels. */
> > -#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
> > -/** Use the right prefix for registers. */
> > -#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
> > - * define macros for all of the registers on this CPU
> > - * EXAMPLE: #define d0 REG (d0)
> > - * Define macros to handle section beginning and ends.
> > -/** This macro is used to denote the beginning of a code declaration. */
> > -#define BEGIN_CODE_DCL .text
> > -/** This macro is used to denote the end of a code declaration. */
> > -#define END_CODE_DCL
> > -/** This macro is used to denote the beginning of a data declaration
> section. */
> > -#define BEGIN_DATA_DCL .data
> > -/** This macro is used to denote the end of a data declaration section.
> > -#define END_DATA_DCL
> > -/** This macro is used to denote the beginning of a code section. */
> > -#define BEGIN_CODE .text
> > -/** This macro is used to denote the end of a code section. */
> > -#define END_CODE
> > -/** This macro is used to denote the beginning of a data section. */
> > -#define BEGIN_DATA
> > -/** This macro is used to denote the end of a data section. */
> > -#define END_DATA
> > - * This macro is used to denote the beginning of the
> > - * unitialized data section.
> > -#define BEGIN_BSS
> > -/** This macro is used to denote the end of the unitialized data
> section. */
> > -#define END_BSS
> > -/** This macro is used to denote the end of the assembly file. */
> > -#define END
> > - * This macro is used to declare a public global symbol.
> > - * NOTE: This must be tailored for a particular flavor of the C
> compiler.
> > - * They may need to put underscores in front of the symbols.
> > -#define PUBLIC(sym) .globl SYM (sym)
> > - * This macro is used to prototype a public global symbol.
> compiler.
> > -#define EXTERN(sym) .globl SYM (sym)
> > -#endif
> > diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h
> b/cpukit/score/cpu/m32r/rtems/score/cpu.h
> > index 9ad41cd..0000000
> > --- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
> > +++ /dev/null
> > @@ -1,1272 +0,0 @@
> > - * @file
> > - * @brief Intel M32R CPU Dependent Source
> > - * This include file contains information pertaining to the XXX
> > - * processor.
> > - * NOTE: This file is part of a porting template that is intended
> > - * to be used as the starting point when porting RTEMS to a new
> > - * CPU family. The following needs to be done when using this as
> > - * the starting point for a new port:
> > - * + Anywhere there is an XXX, it should be replaced
> > - * with information about the CPU family being ported to.
> > - * + At the end of each comment section, there is a heading which
> > - * says "Port Specific Information:". When porting to RTEMS,
> > - * add CPU family specific information in this section
> > -#ifndef _RTEMS_SCORE_CPU_H
> > -#define _RTEMS_SCORE_CPU_H
> > -#ifdef __cplusplus
> > -extern "C" {
> > -#endif
> > -#include <rtems/score/types.h>
> > -/* conditional compilation parameters */
> > - * Should the calls to @ref _Thread_Enable_dispatch be inlined?
> > - * If TRUE, then they are inlined.
> > - * If FALSE, then a subroutine call is made.
> > - * This conditional is an example of the classic trade-off of size
> > - * versus speed. Inlining the call (TRUE) typically increases the
> > - * size of RTEMS while speeding up the enabling of dispatching.
> > - * NOTE: In general, the @ref _Thread_Dispatch_disable_level will
> > - * only be 0 or 1 unless you are in an interrupt handler and that
> > - * interrupt handler invokes the executive.] When not inlined
> > - * something calls @ref _Thread_Enable_dispatch which in turns calls
> > - * @ref _Thread_Dispatch. If the enable dispatch is inlined, then
> > - * one subroutine call is avoided entirely.
> > - * Port Specific Information:
> > -#define CPU_INLINE_ENABLE_DISPATCH FALSE
> > - * Does RTEMS manage a dedicated interrupt stack in software?
> > - * If TRUE, then a stack is allocated in @ref
> _ISR_Handler_initialization.
> > - * If FALSE, nothing is done.
> > - * If the CPU supports a dedicated interrupt stack in hardware,
> > - * then it is generally the responsibility of the BSP to allocate it
> > - * and set it up.
> > - * If the CPU does not support a dedicated interrupt stack, then
> > - * the porter has two options: (1) execute interrupts on the
> > - * stack of the interrupted task, and (2) have RTEMS manage a dedicated
> > - * interrupt stack.
> > - * If this is TRUE, @ref CPU_ALLOCATE_INTERRUPT_STACK should also be
> TRUE.
> > - * Only one of @ref CPU_HAS_SOFTWARE_INTERRUPT_STACK and
> > - * @ref CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE. It is
> > - * possible that both are FALSE for a particular CPU. Although it
> > - * is unclear what that would imply about the interrupt processing
> > - * procedure on that CPU.
> > -#define CPU_HAS_SOFTWARE_INTERRUPT_STACK FALSE
> > - * Does the CPU follow the simple vectored interrupt model?
> > - * If TRUE, then RTEMS allocates the vector table it internally manages.
> > - * If FALSE, then the BSP is assumed to allocate and manage the vector
> > - * table
> > -#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
> > - * Does this CPU have hardware support for a dedicated interrupt stack?
> > - * If TRUE, then it must be installed during initialization.
> > - * If FALSE, then no installation is performed.
> TRUE.
> > -#define CPU_HAS_HARDWARE_INTERRUPT_STACK TRUE
> > - * Does RTEMS allocate a dedicated interrupt stack in the Interrupt
> Manager?
> > - * If TRUE, then the memory is allocated during initialization.
> > - * If FALSE, then the memory is allocated during initialization.
> > - * This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
> > -#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
> > - * Does the RTEMS invoke the user's ISR with the vector number and
> > - * a pointer to the saved interrupt frame (1) or just the vector
> > - * number (0)?
> > -#define CPU_ISR_PASSES_FRAME_POINTER 0
> > - * @def CPU_HARDWARE_FP
> > - * Does the CPU have hardware floating point?
> > - * If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
> > - * If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
> > - * If there is a FP coprocessor such as the i387 or mc68881, then
> > - * the answer is TRUE.
> > - * The macro name "M32R_HAS_FPU" should be made CPU specific.
> > - * It indicates whether or not this CPU model has FP support. For
> > - * example, it would be possible to have an i386_nofp CPU model
> > - * which set this to false to indicate that you have an i386 without
> > - * an i387 and wish to leave floating point support out of RTEMS.
> > - * @def CPU_SOFTWARE_FP
> > - * Does the CPU have no hardware floating point and GCC provides a
> > - * software floating point implementation which must be context
> > - * switched?
> > - * This feature conditional is used to indicate whether or not there
> > - * is software implemented floating point that must be context
> > - * switched. The determination of whether or not this applies
> > - * is very tool specific and the state saved/restored is also
> > - * compiler specific.
> > -#if ( M32R_HAS_FPU == 1 )
> > -#define CPU_HARDWARE_FP TRUE
> > -#else
> > -#define CPU_HARDWARE_FP FALSE
> > -#endif
> > -#define CPU_SOFTWARE_FP FALSE
> > - * Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
> > - * If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
> > - * If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
> > - * So far, the only CPUs in which this option has been used are the
> > - * HP PA-RISC and PowerPC. On the PA-RISC, The HP C compiler and
> > - * gcc both implicitly used the floating point registers to perform
> > - * integer multiplies. Similarly, the PowerPC port of gcc has been
> > - * seen to allocate floating point local variables and touch the FPU
> > - * even when the flow through a subroutine (like vfprintf()) might
> > - * not use floating point formats.
> > - * If a function which you would not think utilize the FP unit DOES,
> > - * then one can not easily predict which tasks will use the FP hardware.
> > - * In this case, this option should be TRUE.
> > - * If @ref CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
> > -#define CPU_ALL_TASKS_ARE_FP TRUE
> > - * Should the IDLE task have a floating point context?
> > - * If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
> > - * and it has a floating point context which is switched in and out.
> > - * If FALSE, then the IDLE task does not have a floating point context.
> > - * Setting this to TRUE negatively impacts the time required to preempt
> > - * the IDLE task from an interrupt because the floating point context
> > - * must be saved as part of the preemption.
> > -#define CPU_IDLE_TASK_IS_FP FALSE
> > - * Should the saving of the floating point registers be deferred
> > - * until a context switch is made to another different floating point
> > - * task?
> > - * If TRUE, then the floating point context will not be stored until
> > - * necessary. It will remain in the floating point registers and not
> > - * disturned until another floating point task is switched to.
> > - * If FALSE, then the floating point context is saved when a floating
> > - * point task is switched out and restored when the next floating point
> > - * task is restored. The state of the floating point registers between
> > - * those two operations is not specified.
> > - * If the floating point context does NOT have to be saved as part of
> > - * interrupt dispatching, then it should be safe to set this to TRUE.
> > - * Setting this flag to TRUE results in using a different algorithm
> > - * for deciding when to save and restore the floating point context.
> > - * The deferred FP switch algorithm minimizes the number of times
> > - * the FP context is saved and restored. The FP context is not saved
> > - * until a context switch is made to another, different FP task.
> > - * Thus in a system with only one FP task, the FP context will never
> > - * be saved or restored.
> > -#define CPU_USE_DEFERRED_FP_SWITCH TRUE
> > - * Does this port provide a CPU dependent IDLE task implementation?
> > - * If TRUE, then the routine @ref _CPU_Thread_Idle_body
> > - * must be provided and is the default IDLE thread body instead of
> > - * @ref _CPU_Thread_Idle_body.
> > - * If FALSE, then use the generic IDLE thread body if the BSP does
> > - * not provide one.
> > - * This is intended to allow for supporting processors which have
> > - * a low power or idle mode. When the IDLE thread is executed, then
> > - * the CPU can be powered down.
> > - * The order of precedence for selecting the IDLE thread body is:
> > - * -# BSP provided
> > - * -# CPU dependent (if provided)
> > - * -# generic (if no BSP and no CPU dependent)
> > -#define CPU_PROVIDES_IDLE_THREAD_BODY FALSE
> > - * Does the stack grow up (toward higher addresses) or down
> > - * (toward lower addresses)?
> > - * If TRUE, then the grows upward.
> > - * If FALSE, then the grows toward smaller addresses.
> > -#define CPU_STACK_GROWS_UP TRUE
> > - * The following is the variable attribute used to force alignment
> > - * of critical RTEMS structures. On some processors it may make
> > - * sense to have these aligned on tighter boundaries than
> > - * the minimum requirements of the compiler in order to have as
> > - * much of the critical data area as possible in a cache line.
> > - * The placement of this macro in the declaration of the variables
> > - * is based on the syntactically requirements of the GNU C
> > - * "__attribute__" extension. For example with GNU C, use
> > - * the following to force a structures to a 32 byte boundary.
> > - * __attribute__ ((aligned (32)))
> > - * NOTE: Currently only the Priority Bit Map table uses this feature.
> > - * To benefit from using this, the data must be heavily
> > - * used so it will stay in the cache and used frequently enough
> > - * in the executive to justify turning this on.
> > -#define CPU_STRUCTURE_ALIGNMENT
> > -#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
> > - * @defgroup CPUEndian Processor Dependent Endianness Support
> > - * This group assists in issues related to processor endianness.
> > - * Define what is required to specify how the network to host conversion
> > - * routines are handled.
> > - * NOTE: @a CPU_BIG_ENDIAN and @a CPU_LITTLE_ENDIAN should NOT have the
> > - * same values.
> > - * @see CPU_LITTLE_ENDIAN
> > -#define CPU_BIG_ENDIAN TRUE
> > - * NOTE: @ref CPU_BIG_ENDIAN and @ref CPU_LITTLE_ENDIAN should NOT have
> the
> > - * same values.
> > - * @see CPU_BIG_ENDIAN
> > -#define CPU_LITTLE_ENDIAN FALSE
> > - * @ingroup CPUInterrupt
> > - * The following defines the number of bits actually used in the
> > - * interrupt field of the task mode. How those bits map to the
> > - * CPU interrupt levels is defined by the routine @ref
> _CPU_ISR_Set_level.
> > -#define CPU_MODES_INTERRUPT_MASK 0x00000001
> > -#define CPU_PER_CPU_CONTROL_SIZE 0
> > - * Processor defined structures required for cpukit/score.
> > -/* may need to put some structures here. */
> > -typedef struct {
> > - /* There is no CPU specific per-CPU state */
> > -} CPU_Per_CPU_control;
> > - * @defgroup CPUContext Processor Dependent Context Management
> > - * From the highest level viewpoint, there are 2 types of context to
> save.
> > - * -# Interrupt registers to save
> > - * -# Task level registers to save
> > - * Since RTEMS handles integer and floating point contexts separately,
> this
> > - * means we have the following 3 context items:
> > - * -# task level context stuff:: Context_Control
> > - * -# floating point task stuff:: Context_Control_fp
> > - * -# special interrupt level context :: CPU_Interrupt_frame
> > - * On some processors, it is cost-effective to save only the callee
> > - * preserved registers during a task context switch. This means
> > - * that the ISR code needs to save those registers which do not
> > - * persist across function calls. It is not mandatory to make this
> > - * distinctions between the caller/callee saves registers for the
> > - * purpose of minimizing context saved during task switch and on
> interrupts.
> > - * If the cost of saving extra registers is minimal, simplicity is the
> > - * choice. Save the same context on interrupt entry as for tasks in
> > - * this case.
> > - * Additionally, if gdb is to be made aware of RTEMS tasks for this
> CPU, then
> > - * care should be used in designing the context area.
> > - * On some CPUs with hardware floating point support, the
> Context_Control_fp
> > - * structure will not be used or it simply consist of an array of a
> > - * fixed number of bytes. This is done when the floating point context
> > - * is dumped by a "FP save context" type instruction and the format
> > - * is not really defined by the CPU. In this case, there is no need
> > - * to figure out the exact format -- only the size. Of course, although
> > - * this is enough information for RTEMS, it is probably not enough for
> > - * a debugger such as gdb. But that is another problem.
> > - * This defines the minimal set of integer and processor state registers
> > - * that must be saved during a voluntary context switch from one thread
> > - * to another.
> > -typedef struct {
> > - /** r8 -- temporary register */
> > - uint32_t r8;
> > - /** r9 -- temporary register */
> > - uint32_t r9;
> > - /** r10 -- temporary register */
> > - uint32_t r10;
> > - /** r11 -- temporary register */
> > - uint32_t r11;
> > - /** r12 -- may be global pointer */
> > - uint32_t r12;
> > - /** r13 -- frame pointer */
> > - uint32_t r13_fp;
> > - /** r14 -- link register (aka return pointer */
> > - uint32_t r14_lr;
> > - /** r15 -- stack pointer */
> > - uint32_t r15_sp;
> > - /** dsp accumulator low order 32-bits */
> > - uint32_t acc_low;
> > - /** dsp accumulator high order 32-bits */
> > - uint32_t acc_high;
> > -} Context_Control;
> > - * This macro returns the stack pointer associated with @a _context.
> > - * @param[in] _context is the thread context area to access
> > - * @return This method returns the stack pointer.
> > -#define _CPU_Context_Get_SP( _context ) \
> > - (_context)->r15_sp
> > - * This defines the complete set of floating point registers that must
> > - * be saved during any context switch from one thread to another.
> > -typedef struct {
> > - /** FPU registers are listed here */
> > - double some_float_register;
> > -} Context_Control_fp;
> > - * This defines the set of integer and processor state registers that
> must
> > - * be saved during an interrupt. This set does not include any which
> are
> > - * in @ref Context_Control.
> > -typedef struct {
> > - /** This field is a hint that a port will have a number of integer
> > - * registers that need to be saved when an interrupt occurs or
> > - * when a context switch occurs at the end of an ISR.
> > - uint32_t special_interrupt_register;
> > -} CPU_Interrupt_frame;
> > - * This variable is optional. It is used on CPUs on which it is
> difficult
> > - * to generate an "uninitialized" FP context. It is filled in by
> > - * @ref _CPU_Initialize and copied into the task's FP context area
> during
> > - * @ref _CPU_Context_Initialize.
> > -SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
> > - * @defgroup CPUInterrupt Processor Dependent Interrupt Management
> > - * On some CPUs, RTEMS supports a software managed interrupt stack.
> > - * This stack is allocated by the Interrupt Manager and the switch
> > - * is performed in @ref _ISR_Handler. These variables contain pointers
> > - * to the lowest and highest addresses in the chunk of memory allocated
> > - * for the interrupt stack. Since it is unknown whether the stack
> > - * grows up or down (in general), this give the CPU dependent
> > - * code the option of picking the version it wants to use.
> > - * NOTE: These two variables are required if the macro
> > - * @ref CPU_HAS_SOFTWARE_INTERRUPT_STACK is defined as TRUE.
> > - * Nothing prevents the porter from declaring more CPU specific
> variables.
> > -/* XXX: if needed, put more variables here */
> > - * @ingroup CPUContext
> > - * The size of the floating point context area. On some CPUs this
> > - * will not be a "sizeof" because the format of the floating point
> > - * area is not defined -- only the size is. This is usually on
> > - * CPUs with a "floating point save context" instruction.
> > -#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
> > - * Amount of extra stack (above minimum stack size) required by
> > - * MPCI receive server thread. Remember that in a multiprocessor
> > - * system this thread must exist and be able to process all directives.
> > -#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
> > - * This defines the number of entries in the @ref _ISR_Vector_table
> managed
> > - * by RTEMS.
> > -#define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
> > - * This defines the highest interrupt vector number for this port.
> > -#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER
> (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
> > - * This is defined if the port has a special way to report the ISR
> nesting
> > - * level. Most ports maintain the variable @a _ISR_Nest_level.
> > -#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
> > - * Should be large enough to run all RTEMS tests. This ensures
> > - * that a "reasonable" small application should not have any problems.
> > -#define CPU_STACK_MINIMUM_SIZE (1024)
> > -#define CPU_SIZEOF_POINTER 4
> > - * CPU's worst alignment requirement for data types on a byte
> boundary. This
> > - * alignment does not take into account the requirements for the stack.
> > -#define CPU_ALIGNMENT 8
> > - * This number corresponds to the byte alignment requirement for the
> > - * heap handler. This alignment requirement may be stricter than that
> > - * for the data types alignment specified by @ref CPU_ALIGNMENT. It is
> > - * common for the heap to follow the same alignment requirement as
> > - * @ref CPU_ALIGNMENT. If the @ref CPU_ALIGNMENT is strict enough for
> > - * the heap, then this should be set to @ref CPU_ALIGNMENT.
> > - * NOTE: This does not have to be a power of 2 although it should be
> > - * a multiple of 2 greater than or equal to 2. The requirement
> > - * to be a multiple of 2 is because the heap uses the least
> > - * significant field of the front and back flags to indicate
> > - * that a block is in use or free. So you do not want any odd
> > - * length blocks really putting length data in that bit.
> > - * On byte oriented architectures, @ref CPU_HEAP_ALIGNMENT
> normally will
> > - * have to be greater or equal to than @ref CPU_ALIGNMENT to
> ensure that
> > - * elements allocated from the heap meet all restrictions.
> > -#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
> > - * This number corresponds to the byte alignment requirement for memory
> > - * buffers allocated by the partition manager. This alignment
> requirement
> > - * may be stricter than that for the data types alignment specified by
> > - * @ref CPU_ALIGNMENT. It is common for the partition to follow the
> same
> > - * alignment requirement as @ref CPU_ALIGNMENT. If the @ref
> CPU_ALIGNMENT is
> > - * strict enough for the partition, then this should be set to
> > - * NOTE: This does not have to be a power of 2. It does have to
> > - * be greater or equal to than @ref CPU_ALIGNMENT.
> > -#define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT
> > - * stack. This alignment requirement may be stricter than that for the
> > - * data types alignment specified by @ref CPU_ALIGNMENT. If the
> > - * @ref CPU_ALIGNMENT is strict enough for the stack, then this should
> be
> > - * set to 0.
> > - * NOTE: This must be a power of 2 either 0 or greater than @ref
> CPU_ALIGNMENT.
> > -#define CPU_STACK_ALIGNMENT 0
> > - * ISR handler macros
> > - * @addtogroup CPUInterrupt
> > - * Support routine to initialize the RTEMS vector table after it is
> allocated.
> > -#define _CPU_Initialize_vectors()
> > - * Disable all interrupts for an RTEMS critical section. The previous
> > - * level is returned in @a _isr_cookie.
> > - * @param[out] _isr_cookie will contain the previous level cookie
> > - * TODO: As of 8 October 2014, this method is not implemented.
> > -#define _CPU_ISR_Disable( _isr_cookie ) \
> > - do { \
> > - (_isr_cookie) = 0; \
> > - } while (0)
> > - * Enable interrupts to the previous level (returned by
> _CPU_ISR_Disable).
> > - * This indicates the end of an RTEMS critical section. The parameter
> > - * @a _isr_cookie is not modified.
> > - * @param[in] _isr_cookie contain the previous level cookie
> > -#define _CPU_ISR_Enable( _isr_cookie ) \
> > - do { \
> > - (_isr_cookie) = (_isr_cookie); \
> > - } while (0)
> > - * This temporarily restores the interrupt to @a _isr_cookie before
> immediately
> > - * disabling them again. This is used to divide long RTEMS critical
> > - * sections into two or more parts. The parameter @a _isr_cookie is not
> > - * modified.
> > -#define _CPU_ISR_Flash( _isr_cookie ) \
> > - do { \
> > - _CPU_ISR_Enable( _isr_cookie ); \
> > - _CPU_ISR_Disable( _isr_cookie ); \
> > - } while (0)
> > - * This routine and @ref _CPU_ISR_Get_level
> > - * Map the interrupt level in task mode onto the hardware that the CPU
> > - * actually provides. Currently, interrupt levels which do not
> > - * map onto the CPU in a generic fashion are undefined. Someday,
> > - * it would be nice if these were "mapped" by the application
> > - * via a callout. For example, m68k has 8 levels 0 - 7, levels
> > - * 8 - 255 would be available for bsp/application specific meaning.
> > - * This could be used to manage a programmable interrupt controller
> > - * via the rtems_task_mode directive.
> > -static inline void _CPU_ISR_Set_level( unsigned int new_level )
> > - * Return the current interrupt disable level for this task in
> > - * the format used by the interrupt level portion of the task mode.
> > - * NOTE: This routine usually must be implemented as a subroutine.
> > -uint32_t _CPU_ISR_Get_level( void );
> > -/* end of ISR handler macros */
> > -/* Context handler macros */
> > - * @brief Initialize CPU context.
> > - * Initialize the context to a state suitable for starting a
> > - * task after a context restore operation. Generally, this
> > - * involves:
> > - * - setting a starting address
> > - * - preparing the stack
> > - * - preparing the stack and frame pointers
> > - * - setting the proper interrupt level in the context
> > - * - initializing the floating point context
> > - * This routine generally does not set any unnecessary register
> > - * in the context. The state of the "general data" registers is
> > - * undefined at task start time.
> > - * @param[in] _the_context is the context structure to be initialized
> > - * @param[in] _stack_base is the lowest physical address of this task's
> stack
> > - * @param[in] _size is the size of this task's stack
> > - * @param[in] _isr is the interrupt disable level
> > - * @param[in] _entry_point is the thread's entry point. This is
> > - * always @a _Thread_Handler
> > - * @param[in] _is_fp is TRUE if the thread is to be a floating
> > - * point thread. This is typically only used on CPUs where the
> > - * FPU may be easily disabled by software such as on the SPARC
> > - * where the PSR contains an enable FPU bit.
> > - * @param[in] tls_area is the thread-local storage (TLS) area
> > - size_t size,
> > - bool is_fp,
> > - void *tls_area
> > - * This routine is responsible for somehow restarting the currently
> > - * executing task. If you are lucky, then all that is necessary
> > - * is restoring the context. Otherwise, there will need to be
> > - * a special assembly routine which does something special in this
> > - * case. For many ports, simply adding a label to the restore path
> > - * of @ref _CPU_Context_switch will work. On other ports, it may be
> > - * possibly to load a few arguments and jump to the restore path. It
> will
> > - * not work if restarting self conflicts with the stack frame
> > - * assumptions of restoring a context.
> > -void _CPU_Context_Restart_self(
> > -) RTEMS_NO_RETURN;
> > - * The purpose of this macro is to allow the initial pointer into
> > - * a floating point context area (used to save the floating point
> > - * context) to be at an arbitrary place in the floating point
> > - * context area.
> > - * This is necessary because some FP units are designed to have
> > - * their context saved as a stack which grows into lower addresses.
> > - * Other FP units can be saved by simply moving registers into offsets
> > - * from the base of the context area. Finally some FP units provide
> > - * a "dump context" instruction which could fill in from high to low
> > - * or low to high based on the whim of the CPU designers.
> > - * @param[in] _base is the lowest physical address of the floating point
> > - * context area
> > - * @param[in] _offset is the offset into the floating point area
> > -#define _CPU_Context_Fp_start( _base, _offset ) \
> > - ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
> > - * This routine initializes the FP context area passed to it to.
> > - * There are a few standard ways in which to initialize the
> > - * floating point context. The code included for this macro assumes
> > - * that this is a CPU in which a "initial" FP context was saved into
> > - * @a _CPU_Null_fp_context and it simply copies it to the destination
> > - * context passed to it.
> > - * Other floating point context save/restore models include:
> > - * -# not doing anything, and
> > - * -# putting a "null FP status word" in the correct place in the FP
> context.
> > - * @param[in] _destination is the floating point context area
> > -#define _CPU_Context_Initialize_fp( _destination ) \
> > - *(*(_destination)) = _CPU_Null_fp_context; \
> > -/* end of Context handler macros */
> > -/* Fatal Error manager macros */
> > - * This routine copies _error into a known place -- typically a stack
> > - * location or a register, optionally disables interrupts, and
> > - * halts/stops the CPU.
> > -#define _CPU_Fatal_halt( _source, _error ) \
> > -/* end of Fatal Error manager macros */
> > -/* Bitfield handler macros */
> > - * @defgroup CPUBitfield Processor Dependent Bitfield Manipulation
> > - * This set of routines are used to implement fast searches for
> > - * the most important ready task.
> > - * This definition is set to TRUE if the port uses the generic bitfield
> > - * manipulation implementation.
> > -#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> > - * This definition is set to TRUE if the port uses the data tables
> provided
> > - * by the generic bitfield manipulation implementation.
> > - * This can occur when actually using the generic bitfield manipulation
> > - * implementation or when implementing the same algorithm in assembly
> > - * language for improved performance. It is unlikely that a port will
> use
> > - * the data if it has a bitfield scan instruction.
> > -#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> > - * This routine sets @a _output to the bit number of the first bit
> > - * set in @a _value. @a _value is of CPU dependent type
> > - * @a Priority_bit_map_Word. This type may be either 16 or 32 bits
> > - * wide although only the 16 least significant bits will be used.
> > - * There are a number of variables in using a "find first bit" type
> > - * instruction.
> > - * -# What happens when run on a value of zero?
> > - * -# Bits may be numbered from MSB to LSB or vice-versa.
> > - * -# The numbering may be zero or one based.
> > - * -# The "find first bit" instruction may search from MSB or LSB.
> > - * RTEMS guarantees that (1) will never happen so it is not a concern.
> > - * (2),(3), (4) are handled by the macros @ref _CPU_Priority_Mask and
> > - * @ref _CPU_Priority_bits_index. These three form a set of routines
> > - * which must logically operate together. Bits in the _value are
> > - * set and cleared based on masks built by @ref _CPU_Priority_Mask.
> > - * The basic major and minor values calculated by @ref _Priority_Major
> > - * and @ref _Priority_Minor are "massaged" by @ref
> > - * to properly range between the values returned by the "find first bit"
> > - * instruction. This makes it possible for @ref _Priority_Get_highest
> to
> > - * calculate the major and directly index into the minor table.
> > - * This mapping is necessary to ensure that 0 (a high priority
> major/minor)
> > - * is the first bit found.
> > - * This entire "find first bit" and mapping process depends heavily
> > - * on the manner in which a priority is broken into a major and minor
> > - * components with the major being the 4 MSB of a priority and minor
> > - * the 4 LSB. Thus (0 << 4) + 0 corresponds to priority 0 -- the
> highest
> > - * priority. And (15 << 4) + 14 corresponds to priority 254 -- the next
> > - * to the lowest priority.
> > - * If your CPU does not have a "find first bit" instruction, then
> > - * there are ways to make do without it. Here are a handful of ways
> > - * to implement this in software:
> > - at verbatim
> > - - a series of 16 bit test instructions
> > - - a "binary search using if's"
> > - - _number = 0
> > - if _value > 0x00ff
> > - _value >>=8
> > - _number = 8;
> > - if _value > 0x0000f
> > - _value >=8
> > - _number += 4
> > - _number += bit_set_table[ _value ]
> > - at endverbatim
> > - * where bit_set_table[ 16 ] has values which indicate the first
> > - * bit set
> > - * @param[in] _value is the value to be scanned
> > - * @param[in] _output is the first bit set
> > -#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
> > -#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> > - (_output) = 0; /* do something to prevent warnings */ \
> > -#endif
> > -/* end of Bitfield handler macros */
> > - * This routine builds the mask which corresponds to the bit fields
> > - * as searched by @ref _CPU_Bitfield_Find_first_bit. See the discussion
> > - * for that routine.
> > -#define _CPU_Priority_Mask( _bit_number ) \
> > - ( 1 << (_bit_number) )
> > -#endif
> > - * This routine translates the bit numbers returned by
> > - * @ref _CPU_Bitfield_Find_first_bit into something suitable for use as
> > - * a major or minor component of a priority. See the discussion
> > - * @param[in] _priority is the major or minor number to translate
> > -#define _CPU_Priority_bits_index( _priority ) \
> > - (_priority)
> > -#endif
> > -/* end of Priority handler macros */
> > -/* functions */
> > - * @brief CPU initialization.
> > - * This routine performs CPU dependent initialization.
> > -void _CPU_Initialize(void);
> > - * This routine installs a "raw" interrupt handler directly into the
> > - * processor's vector table.
> > - * @param[in] vector is the vector number
> > - * @param[in] new_handler is the raw ISR handler to install
> > - * @param[in] old_handler is the previously installed ISR Handler
> > - uint32_t vector,
> > - * This routine installs an interrupt vector.
> > - * @param[in] new_handler is the RTEMS ISR handler to install
> > - uint32_t vector,
> > - * This routine installs the hardware interrupt stack pointer.
> > - * NOTE: It need only be provided if @ref
> > - * is TRUE.
> > -void _CPU_Install_interrupt_stack( void );
> > - * This routine switches from the run context to the heir context.
> > - * @param[in] run points to the context of the currently executing task
> > - * @param[in] heir points to the context of the heir task
> > -void _CPU_Context_switch(
> > - Context_Control *run,
> > - Context_Control *heir
> > - * @addtogroup CPUContext
> > - * This routine is generally used only to restart self in an
> > - * efficient manner. It may simply be a label in @ref
> _CPU_Context_switch.
> > - * @param[in] new_context points to the context to be restored.
> > - * NOTE: May be unnecessary to reload some registers.
> > -void _CPU_Context_restore(
> > - Context_Control *new_context
> > -) RTEMS_NO_RETURN;
> > - * This routine saves the floating point context passed to it.
> > - * @param[in] fp_context_ptr is a pointer to a pointer to a floating
> > - * point context area
> > - * @return on output @a *fp_context_ptr will contain the address that
> > - * should be used with @ref _CPU_Context_restore_fp to restore this
> context.
> > -void _CPU_Context_save_fp(
> > - Context_Control_fp **fp_context_ptr
> > - * This routine restores the floating point context passed to it.
> > - * point context area to restore
> > - * should be used with @ref _CPU_Context_save_fp to save this context.
> > -void _CPU_Context_restore_fp(
> > -static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
> > - /* TODO */
> > -static inline void _CPU_Context_validate( uintptr_t pattern )
> > - while (1) {
> > - /* TODO */
> > -/* FIXME */
> > -typedef CPU_Interrupt_frame CPU_Exception_frame;
> > -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> > - * @ingroup CPUEndian
> > - * The following routine swaps the endian format of an unsigned int.
> > - * It must be static because it is referenced indirectly.
> > - * This version will work on any processor, but if there is a better
> > - * way for your CPU PLEASE use it. The most common way to do this is
> to:
> > - * swap least significant two bytes with 16-bit rotate
> > - * swap upper and lower 16-bits
> > - * swap most significant two bytes with 16-bit rotate
> > - * Some CPUs have special instructions which swap a 32-bit quantity in
> > - * a single instruction (e.g. i486). It is probably best to avoid
> > - * an "endian swapping control bit" in the CPU. One good reason is
> > - * that interrupts would probably have to be disabled to ensure that
> > - * an interrupt does not try to access the same "chunk" with the wrong
> > - * endian. Another good reason is that on some CPUs, the endian bit
> > - * endianness for ALL fetches -- both code and data -- so the code
> > - * will be fetched incorrectly.
> > - * @param[in] value is the value to be swapped
> > - * @return the value after being endian swapped
> > -static inline uint32_t CPU_swap_u32(
> > - uint32_t value
> > - uint32_t byte1, byte2, byte3, byte4, swapped;
> > - byte4 = (value >> 24) & 0xff;
> > - byte3 = (value >> 16) & 0xff;
> > - byte2 = (value >> 8) & 0xff;
> > - byte1 = value & 0xff;
> > - swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
> > - return swapped;
> > - * This routine swaps a 16 bir quantity.
> > -#define CPU_swap_u16( value ) \
> > - (((value&0xff) << 8) | ((value >> 8)&0xff))
> > -typedef uint32_t CPU_Counter_ticks;
> > -CPU_Counter_ticks _CPU_Counter_read( void );
> > -static inline CPU_Counter_ticks _CPU_Counter_difference(
> > - CPU_Counter_ticks second,
> > - CPU_Counter_ticks first
> > - return second - first;
> > -#ifdef __cplusplus
> > -#endif
> > -#endif
> > diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu_asm.h
> b/cpukit/score/cpu/m32r/rtems/score/cpu_asm.h
> > index ac6aac4..0000000
> > --- a/cpukit/score/cpu/m32r/rtems/score/cpu_asm.h
> > +++ /dev/null
> > @@ -1,72 +0,0 @@
> > - * @file
> > - * @brief Intel M32R Assembly File
> > - * Very loose template for an include file for the cpu_asm.? file
> > - * if it is implemented as a ".S" file (preprocessed by cpp) instead
> > - * of a ".s" file (preprocessed by gm4 or gasp).
> > - * COPYRIGHT (c) 1989-1999.
> > -#ifndef _RTEMS_SCORE_CPU_ASM_H
> > -#define _RTEMS_SCORE_CPU_ASM_H
> > -/* pull in the generated offsets */
> > -#include <rtems/score/offsets.h>
> > - * Hardware General Registers
> > -/* put something here */
> > - * Hardware Floating Point Registers
> > - * Hardware Control Registers
> > - * Calling Convention
> > - * Temporary registers
> > - * Floating Point Registers - SW Conventions
> > - * Temporary floating point registers
> > -#endif
> > -/* end of file */
> > diff --git a/cpukit/score/cpu/m32r/rtems/score/cpuatomic.h
> b/cpukit/score/cpu/m32r/rtems/score/cpuatomic.h
> > index 598ee76..0000000
> > --- a/cpukit/score/cpu/m32r/rtems/score/cpuatomic.h
> > +++ /dev/null
> > @@ -1,14 +0,0 @@
> > - * COPYRIGHT (c) 2012-2013 Deng Hengyi.
> > -#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
> > -#define _RTEMS_SCORE_ATOMIC_CPU_H
> > -#include <rtems/score/cpustdatomic.h>
> > -#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
> > diff --git a/cpukit/score/cpu/m32r/rtems/score/m32r.h
> b/cpukit/score/cpu/m32r/rtems/score/m32r.h
> > index cd91134..0000000
> > --- a/cpukit/score/cpu/m32r/rtems/score/m32r.h
> > +++ /dev/null
> > @@ -1,70 +0,0 @@
> > - * @file
> > - * @brief Set up Basic CPU Dependency Settings Based on Compiler
> Settings
> > - * This file sets up basic CPU dependency settings based on
> > - * compiler settings. For example, it can determine if
> > - * floating point is available. This particular implementation
> > - * is specified to the NO CPU port.
> > -#ifndef _RTEMS_SCORE_NO_CPU_H
> > -#define _RTEMS_SCORE_NO_CPU_H
> > -#ifdef __cplusplus
> > -extern "C" {
> > -#endif
> > - * This file contains the information required to build
> > - * RTEMS for a particular member of the NO CPU family.
> > - * It does this by setting variables to indicate which
> > - * implementation dependent features are present in a particular
> > - * member of the family.
> > - * This is a good place to list all the known CPU models
> > - * that this port supports and which RTEMS CPU model they correspond
> > - * to.
> > -#if defined(rtems_multilib)
> > - * Figure out all CPU Model Feature Flags based upon compiler
> > - * predefines.
> > -#define CPU_MODEL_NAME "rtems_multilib"
> > -#define NOCPU_HAS_FPU 1
> > -#elif defined(__m32r__)
> > -#define CPU_MODEL_NAME "m32r"
> > -#else
> > -#error "Unsupported CPU Model"
> > -#endif
> > - * Define the name of the CPU family.
> > -#define CPU_NAME "NO CPU"
> > -#ifdef __cplusplus
> > -#endif
> > -#endif /* _RTEMS_SCORE_NO_CPU_H */
> > diff --git a/cpukit/score/cpu/m32r/rtems/score/types.h
> b/cpukit/score/cpu/m32r/rtems/score/types.h
> > index 3ee57f2..0000000
> > --- a/cpukit/score/cpu/m32r/rtems/score/types.h
> > +++ /dev/null
> > @@ -1,52 +0,0 @@
> > - * @file
> > - * @brief Intel M32R CPU Type Definitions
> > - * This include file contains type definitions pertaining to the Intel
> > - * m32r processor family.
> > - * COPYRIGHT (c) 1989-2006.
> > -#ifndef _RTEMS_SCORE_TYPES_H
> > -#define _RTEMS_SCORE_TYPES_H
> > -#include <rtems/score/basedefs.h>
> > -#ifndef ASM
> > -#ifdef __cplusplus
> > -extern "C" {
> > -#endif
> > - * This section defines the basic types for this processor.
> > -/** Type that can store a 32-bit integer or a pointer. */
> > -typedef uintptr_t CPU_Uint32ptr;
> > -/** This defines the type for a priority bit map entry. */
> > -typedef uint16_t Priority_bit_map_Word;
> > -/** This defines the return type for an ISR entry point. */
> > -typedef void m32r_isr;
> > -/** This defines the prototype for an ISR entry point. */
> > -typedef m32r_isr ( *m32r_isr_entry )( void );
> > -#ifdef __cplusplus
> > -#endif
> > -#endif /* !ASM */
> > -#endif
> > diff --git a/cpukit/score/src/threadglobalconstruction.c
> b/cpukit/score/src/threadglobalconstruction.c
> > index 05a8613..c7c10d9 100644
> > --- a/cpukit/score/src/threadglobalconstruction.c
> > +++ b/cpukit/score/src/threadglobalconstruction.c
> > @@ -28,9 +28,7 @@
> > * initialization this target and compiler version uses.
> > - #if defined(__M32R__)
> > - #define INIT_NAME __init
> > #define INIT_NAME __libc_init_array
> > #else
> > #define INIT_NAME _init
> > diff --git a/doc/cpu_supplement/Makefile.am
> b/doc/cpu_supplement/Makefile.am
> > index 06ebf48..f27cc6a 100644
> > --- a/doc/cpu_supplement/Makefile.am
> > +++ b/doc/cpu_supplement/Makefile.am
> > @@ -1,5 +1,5 @@
> > -# COPYRIGHT (c) 1988-2012.
> > +# COPYRIGHT (c) 1988-2015.
> > # On-Line Applications Research Corporation (OAR).
> > # All rights reserved.
> > @@ -20,7 +20,6 @@ GENERATED_FILES += h8300.texi
> > GENERATED_FILES += i386.texi
> > GENERATED_FILES += lm32.texi
> > GENERATED_FILES += m32c.texi
> > -GENERATED_FILES += m32r.texi
> > GENERATED_FILES += m68k.texi
> > GENERATED_FILES += microblaze.texi
> > GENERATED_FILES += mips.texi
> > @@ -83,11 +82,6 @@ m32c.texi: m32c.t
> > -u "Top" \
> > -n "" < $< > $@
> > -m32r.texi: m32r.t
> > - $(BMENU2) -p "" \
> > - -u "Top" \
> > - -n "" < $< > $@
> > lm32.texi: lm32.t
> > $(BMENU2) -p "" \
> > -u "Top" \
> > diff --git a/doc/cpu_supplement/cpu_supplement.texi
> b/doc/cpu_supplement/cpu_supplement.texi
> > index 105a54e..2fcdfa0 100644
> > --- a/doc/cpu_supplement/cpu_supplement.texi
> > +++ b/doc/cpu_supplement/cpu_supplement.texi
> > @@ -70,7 +70,6 @@
> > * Intel/AMD x86 Specific Information::
> > * Lattice Mico32 Specific Information::
> > * Renesas M32C Specific Information::
> > -* Renesas M32R Specific Information::
> > * M68xxx and Coldfire Specific Information::
> > * Xilinx MicroBlaze Specific Information::
> > * MIPS Specific Information::
> > @@ -95,7 +94,6 @@
> > @include i386.texi
> > @include lm32.texi
> > @include m32c.texi
> > - at include m32r.texi
> > @include m68k.texi
> > @include microblaze.texi
> > @include mips.texi
> > diff --git a/doc/cpu_supplement/m32r.t b/doc/cpu_supplement/m32r.t
> > index 951bf94..0000000
> > --- a/doc/cpu_supplement/m32r.t
> > +++ /dev/null
> > @@ -1,11 +0,0 @@
> > - at c Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> > - at chapter Renesas M32R Specific Information
> > - at section Symmetric Multiprocessing
> > -SMP is not supported.
> > - at section Thread-Local Storage
> > -Thread-local storage is not implemented.
> > diff --git a/doc/user/preface.texi b/doc/user/preface.texi
> > index e47f18e..f8c0728 100644
> > --- a/doc/user/preface.texi
> > +++ b/doc/user/preface.texi
> > @@ -1,5 +1,5 @@
> > @c
> > - at c COPYRIGHT (c) 1989-2011.
> > + at c COPYRIGHT (c) 1989-2015.
> > @c On-Line Applications Research Corporation (OAR).
> > @c All rights reserved.
> > @@ -161,7 +161,6 @@ It has been ported to the following processor
> families:
> > @item Renesas (formerly Hitachi) SuperH
> > @item Renesas (formerly Hitachi) H8/300
> > @item Renesas M32C
> > - at item Renesas M32R
> > @item SPARC v7, v8, and V9
> > @end itemize
> > diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/
> configure.ac
> > index a34bbb2..4941c51 100644
> > --- a/testsuites/libtests/configure.ac
> > +++ b/testsuites/libtests/configure.ac
> > @@ -48,8 +48,7 @@ AM_CONDITIONAL(HAS_POSIX,test
> x"${rtems_cv_RTEMS_POSIX_API}" = x"yes")
> > # Must match the list in cpukit.
> > case $RTEMS_CPU in
> > TEST_LIBDL=yes ;;
> > bfin)
> > 1.7.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160103/8b0891cb/attachment-0001.html>
