[PATCH 3/6] avr/avrtest/configure.ac: Correct typo
Joel Sherrill
joel at rtems.org
Mon Jan 4 02:13:07 UTC 2016
On Sun, Jan 3, 2016 at 8:03 PM, Gedare Bloom <gedare at rtems.org> wrote:
> why is this adding back avrtest/configure.ac?
> p
To make git happy? I couldn't figure out why I needed it either.
I can try applying the patches one at a time and see if the need goes away.
> On Sun, Jan 3, 2016 at 4:27 PM, Joel Sherrill <joel at rtems.org> wrote:
> > From: Joel Sherrill <joel.sherrill at oarcorp.com>
> > c/src/lib/libbsp/avr/avrtest/configure.ac | 20 ++++++++++++++++++++
> > c/src/lib/libbsp/avr/configure.ac | 1 -
> > 2 files changed, 20 insertions(+), 1 deletions(-)
> > create mode 100644 c/src/lib/libbsp/avr/avrtest/configure.ac
> > diff --git a/c/src/lib/libbsp/avr/avrtest/configure.ac
> b/c/src/lib/libbsp/avr/avrtest/configure.ac
> > new file mode 100644
> > index 0000000..f9c0b5c
> > --- /dev/null
> > +++ b/c/src/lib/libbsp/avr/avrtest/configure.ac
> > @@ -0,0 +1,20 @@
> > +## Process this file with autoconf to produce a configure script.
> > +AC_PREREQ([2.69])
> > +AC_INIT([rtems-c-src-lib-libbsp-avr-avrtest],[_RTEMS_VERSION],[
> https://devel.rtems.org/newticket])
> > +AC_CONFIG_SRCDIR([bsp_specs])
> > +RTEMS_TOP(../../../../../..)
> > +RTEMS_CANONICAL_TARGET_CPU
> > +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> > +RTEMS_BSP_CONFIGURE
> > +RTEMS_PROG_CC_FOR_TARGET
> > +RTEMS_CANONICALIZE_TOOLS
> > +RTEMS_PROG_CCAS
> > +RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
> > +# Explicitly list all Makefiles here
> > +AC_CONFIG_FILES([Makefile])
> > +AC_OUTPUT
> > diff --git a/c/src/lib/libbsp/avr/configure.ac b/c/src/lib/libbsp/avr/
> configure.ac
> > index eebd8b5..32ecf2e 100644
> > --- a/c/src/lib/libbsp/avr/configure.ac
> > +++ b/c/src/lib/libbsp/avr/configure.ac
> > @@ -2,7 +2,6 @@
> > AC_PREREQ([2.69])
> > AC_INIT([rtems-c-src-lib-libbsp-avr],[_RTEMS_VERSION],[
> > -AC_CONFIG_SRCDIR([avrtest])
> > RTEMS_TOP(../../../../..)
> > 1.7.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160103/a8e7c4cd/attachment.html>
