[PATCH 2/6] Remove H8300 port
Joel Sherrill
joel at rtems.org
Mon Jan 4 02:15:16 UTC 2016
On Sun, Jan 3, 2016 at 8:03 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Instead of deleting the cpu supplement from the doc, it may be worth
> it to leave a stub that indicates when support was removed?
We haven't done that in the past. We have probably removed 6+ architectures
in the history. I honestly think no one will look here. The tools will be
gone, configure
will fail, etc,.
I would like to add a section to the release page/information for
Transition guidance.
4.11 needed that and I think the next few releases will need it as well.
> On Sun, Jan 3, 2016 at 4:27 PM, Joel Sherrill <joel at rtems.org> wrote:
> > From: Joel Sherrill <joel.sherrill at oarcorp.com>
> > updates #2452.
> > c/ACKNOWLEDGEMENTS | 9 +-
> > c/TOOL_TARGETS | 3 -
> > c/src/aclocal/check-networking.m4 | 2 +-
> > c/src/aclocal/rtems-cpu-subdirs.m4 | 1 -
> > c/src/lib/libbsp/h8300/Makefile.am | 7 -
> > c/src/lib/libbsp/h8300/acinclude.m4 | 8 -
> > c/src/lib/libbsp/h8300/configure.ac | 19 -
> > cpukit/aclocal/check-networking.m4 | 2 +-
> > cpukit/configure.ac | 4 -
> > cpukit/librpc/src/xdr/xdr_float.c | 1 -
> > cpukit/score/cpu/Makefile.am | 1 -
> > cpukit/score/cpu/h8300/Makefile.am | 19 -
> > cpukit/score/cpu/h8300/README | 27 -
> > cpukit/score/cpu/h8300/cpu.c | 134 ---
> > cpukit/score/cpu/h8300/cpu_asm.S | 221 ----
> > .../score/cpu/h8300/h8300-exception-frame-print.c | 24 -
> > cpukit/score/cpu/h8300/preinstall.am | 45 -
> > cpukit/score/cpu/h8300/rtems/asm.h | 118 --
> > cpukit/score/cpu/h8300/rtems/score/cpu.h | 1176
> > cpukit/score/cpu/h8300/rtems/score/cpuatomic.h | 14 -
> > cpukit/score/cpu/h8300/rtems/score/h8300.h | 44 -
> > cpukit/score/cpu/h8300/rtems/score/types.h | 47 -
> > doc/cpu_supplement/Makefile.am | 6 -
> > doc/cpu_supplement/cpu_supplement.texi | 2 -
> > doc/cpu_supplement/h8300.t | 11 -
> > testsuites/libtests/configure.ac | 3 -
> > testsuites/psxtests/psx04/task3.c | 2 +-
> > 27 files changed, 5 insertions(+), 1945 deletions(-)
> > delete mode 100644 c/src/lib/libbsp/h8300/Makefile.am
> > delete mode 100644 c/src/lib/libbsp/h8300/acinclude.m4
> > delete mode 100644 c/src/lib/libbsp/h8300/configure.ac
> > delete mode 100644 cpukit/score/cpu/h8300/Makefile.am
> > delete mode 100644 cpukit/score/cpu/h8300/README
> > delete mode 100644 cpukit/score/cpu/h8300/cpu.c
> > delete mode 100644 cpukit/score/cpu/h8300/cpu_asm.S
> > delete mode 100644 cpukit/score/cpu/h8300/h8300-exception-frame-print.c
> > delete mode 100644 cpukit/score/cpu/h8300/preinstall.am
> > delete mode 100644 cpukit/score/cpu/h8300/rtems/asm.h
> > delete mode 100644 cpukit/score/cpu/h8300/rtems/score/cpu.h
> > delete mode 100644 cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
> > delete mode 100644 cpukit/score/cpu/h8300/rtems/score/h8300.h
> > delete mode 100644 cpukit/score/cpu/h8300/rtems/score/types.h
> > delete mode 100644 doc/cpu_supplement/h8300.t
> > diff --git a/c/ACKNOWLEDGEMENTS b/c/ACKNOWLEDGEMENTS
> > index 76956fd..25d4a0b 100644
> > --- a/c/ACKNOWLEDGEMENTS
> > +++ b/c/ACKNOWLEDGEMENTS
> > @@ -150,9 +150,8 @@ The following persons/organizations have made
> contributions:
> > it easier to support external interrupt controllers.
> > + Joel Sherrill <joel at OARcorp.com> for the BSPs that work with
> > - numerous simulators including psim, c4xsim, h8sim, armulator,
> > - sim68000, and simcpu32. Most of these BSPs work with instruction
> > - set simulators in gdb.
> > + numerous simulators. Many work with instruction set simulators
> > + in gdb.
> > + Darlene Stewart <Darlene.Stewart at nrc.ca> and Charles Gauthier
> > <Charles.Gauthier at nrc.ca> of the Institute for Information Technology
> > @@ -165,10 +164,6 @@ The following persons/organizations have made
> contributions:
> > Technology for the National Research Council of Canada
> > submitted the RTEMS Cache Manager.
> > -+ Philip Quaife <philip at qs.co.nz> of Q Solutions ported
> > - RTEMS to the Hitachi H8300H. This effort was sponsored by
> > - Comnet Technologies Ltd.
> > + Joel Sherrill <joel at OARcorp.com> and Jennifer Averett
> <jennifer at OARcorp.com>
> > for the Texas Instruments C3x/C4x port and c4xsim BSP that works
> > with the C3x/C4X instruction set simulator in gdb.
> > diff --git a/c/TOOL_TARGETS b/c/TOOL_TARGETS
> > index 4811277..3b22d81 100644
> > --- a/c/TOOL_TARGETS
> > +++ b/c/TOOL_TARGETS
> > @@ -7,9 +7,6 @@ arm:
> > c4x:
> > c4x-rtems COFF Requires patches
> > -h8300:
> > - h8300-rtems COFF
> > i386:
> > i386-rtems ELF
> > diff --git a/c/src/aclocal/check-networking.m4
> b/c/src/aclocal/check-networking.m4
> > index 53d2d36..69265ac 100644
> > --- a/c/src/aclocal/check-networking.m4
> > +++ b/c/src/aclocal/check-networking.m4
> > @@ -8,7 +8,7 @@ AC_CACHE_CHECK([whether BSP supports networking],
> > [dnl
> > case "$RTEMS_CPU" in
> > # do not have address space to hold BSD TCP/IP stack
> > - avr*|h8300*|m32c*)
> > + avr*|m32c*)
> > rtems_cv_HAS_NETWORKING="no"
> > diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4
> b/c/src/aclocal/rtems-cpu-subdirs.m4
> > index 3cb28b1..5f10bda 100644
> > --- a/c/src/aclocal/rtems-cpu-subdirs.m4
> > +++ b/c/src/aclocal/rtems-cpu-subdirs.m4
> > @@ -14,7 +14,6 @@ _RTEMS_CPU_SUBDIR([arm],[$1]);;
> > _RTEMS_CPU_SUBDIR([bfin],[$1]);;
> > _RTEMS_CPU_SUBDIR([epiphany],[$1]);;
> > _RTEMS_CPU_SUBDIR([avr],[$1]);;
> > -_RTEMS_CPU_SUBDIR([h8300],[$1]);;
> > _RTEMS_CPU_SUBDIR([i386],[$1]);;
> > _RTEMS_CPU_SUBDIR([lm32],[$1]);;
> > _RTEMS_CPU_SUBDIR([m32c],[$1]);;
> > diff --git a/c/src/lib/libbsp/h8300/Makefile.am
> b/c/src/lib/libbsp/h8300/Makefile.am
> > deleted file mode 100644
> > index 140d76e..0000000
> > --- a/c/src/lib/libbsp/h8300/Makefile.am
> > +++ /dev/null
> > @@ -1,7 +0,0 @@
> > -ACLOCAL_AMFLAGS = -I ../../../aclocal
> > -# Descend into the @RTEMS_BSP_FAMILY@ directory
> > -SUBDIRS = @RTEMS_BSP_FAMILY@
> > -include $(top_srcdir)/../../../automake/subdirs.am
> > -include $(top_srcdir)/../../../automake/local.am
> > diff --git a/c/src/lib/libbsp/h8300/acinclude.m4
> b/c/src/lib/libbsp/h8300/acinclude.m4
> > index 296a6f7..0000000
> > --- a/c/src/lib/libbsp/h8300/acinclude.m4
> > +++ /dev/null
> > @@ -1,8 +0,0 @@
> > -# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
> > -AC_DEFUN([RTEMS_CHECK_BSPDIR],
> > - case "$1" in
> > - AC_MSG_ERROR([Invalid BSP]);;
> > - esac
> > diff --git a/c/src/lib/libbsp/h8300/configure.ac
> b/c/src/lib/libbsp/h8300/configure.ac
> > index e885460..0000000
> > --- a/c/src/lib/libbsp/h8300/configure.ac
> > +++ /dev/null
> > @@ -1,19 +0,0 @@
> > -## Process this file with autoconf to produce a configure script.
> > -AC_PREREQ([2.69])
> > -AC_INIT([rtems-c-src-lib-libbsp-h8300],[_RTEMS_VERSION],[
> https://devel.rtems.org/newticket])
> > -AC_CONFIG_SRCDIR([Makefile.am])
> > -RTEMS_TOP(../../../../..)
> > -RTEMS_CANONICAL_TARGET_CPU
> > -AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
> > -AM_MAINTAINER_MODE
> > -RTEMS_ENV_RTEMSBSP
> > -RTEMS_PROJECT_ROOT
> > -RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
> > -# Explicitly list all Makefiles here
> > -AC_CONFIG_FILES([Makefile])
> > -AC_OUTPUT
> > diff --git a/cpukit/aclocal/check-networking.m4
> b/cpukit/aclocal/check-networking.m4
> > index 06c94c0..50982f3 100644
> > --- a/cpukit/aclocal/check-networking.m4
> > +++ b/cpukit/aclocal/check-networking.m4
> > @@ -9,7 +9,7 @@ AC_CACHE_CHECK([whether CPU supports networking],
> > [dnl
> > case "$host" in
> > + avr*|m32c*)
> > *-*-rtems*)
> > diff --git a/cpukit/configure.ac b/cpukit/configure.ac
> > index 8436c91..c5bbee8 100644
> > --- a/cpukit/configure.ac
> > +++ b/cpukit/configure.ac
> > @@ -393,9 +393,6 @@ case $RTEMS_CPU in
> > # bfin has an issue to resolve with libdl. See ticket #2252
> > bfin)
> > HAVE_LIBDL=no ;;
> > - # h8300 has an issue to resolve with libdl. See ticket #2284
> > - h8300)
> > - HAVE_LIBDL=no ;;
> > # lm32 has an issue to resolve with libdl. See ticket #2283
> > lm32)
> > HAVE_LIBDL=no ;;
> > @@ -457,7 +454,6 @@ score/cpu/arm/Makefile
> > score/cpu/bfin/Makefile
> > score/cpu/avr/Makefile
> > score/cpu/epiphany/Makefile
> > -score/cpu/h8300/Makefile
> > score/cpu/i386/Makefile
> > score/cpu/lm32/Makefile
> > score/cpu/m68k/Makefile
> > diff --git a/cpukit/librpc/src/xdr/xdr_float.c
> b/cpukit/librpc/src/xdr/xdr_float.c
> > index 5d6b4ea..74d0bbc 100644
> > --- a/cpukit/librpc/src/xdr/xdr_float.c
> > +++ b/cpukit/librpc/src/xdr/xdr_float.c
> > @@ -62,7 +62,6 @@ static char *rcsid = "$FreeBSD:
> src/lib/libc/xdr/xdr_float.c,v 1.7 1999/08/28 00
> > defined(_AM29K) || \
> > defined(__arm__) || \
> > defined(__epiphany__) || defined(__EPIPHANY__) || \
> > - defined(__H8300__) || defined(__h8300__) || \
> > defined(__hppa__) || \
> > defined(__i386__) || \
> > defined(__lm32__) || \
> > diff --git a/cpukit/score/cpu/Makefile.am b/cpukit/score/cpu/Makefile.am
> > index 4438e3f..a973a82 100644
> > --- a/cpukit/score/cpu/Makefile.am
> > +++ b/cpukit/score/cpu/Makefile.am
> > @@ -5,7 +5,6 @@ DIST_SUBDIRS += arm
> > DIST_SUBDIRS += avr
> > DIST_SUBDIRS += bfin
> > DIST_SUBDIRS += epiphany
> > -DIST_SUBDIRS += h8300
> > DIST_SUBDIRS += i386
> > DIST_SUBDIRS += lm32
> > DIST_SUBDIRS += m32c
> > diff --git a/cpukit/score/cpu/h8300/Makefile.am
> b/cpukit/score/cpu/h8300/Makefile.am
> > index 6a80409..0000000
> > --- a/cpukit/score/cpu/h8300/Makefile.am
> > +++ /dev/null
> > @@ -1,19 +0,0 @@
> > -include $(top_srcdir)/automake/compile.am
> > -include_rtemsdir = $(includedir)/rtems
> > -include_rtems_HEADERS = rtems/asm.h
> > -include_rtems_scoredir = $(includedir)/rtems/score
> > -include_rtems_score_HEADERS = rtems/score/cpu.h
> > -include_rtems_score_HEADERS += rtems/score/h8300.h
> > -include_rtems_score_HEADERS += rtems/score/types.h
> > -include_rtems_score_HEADERS += rtems/score/cpuatomic.h
> > -noinst_LIBRARIES = libscorecpu.a
> > -libscorecpu_a_SOURCES = cpu.c cpu_asm.S
> > -libscorecpu_a_SOURCES += ../no_cpu/cpucounterread.c
> > -libscorecpu_a_SOURCES += h8300-exception-frame-print.c
> > -libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
> > -include $(srcdir)/preinstall.am
> > -include $(top_srcdir)/automake/local.am
> > diff --git a/cpukit/score/cpu/h8300/README
> b/cpukit/score/cpu/h8300/README
> > index 1fed837..0000000
> > --- a/cpukit/score/cpu/h8300/README
> > +++ /dev/null
> > @@ -1,27 +0,0 @@
> > -This port was done by Philip Quaife <philip at qs.co.nz> of Q Solutions
> > -using RTEMS 3.5.1 under DOS and Hiview. Philip used an H8300H
> > -to develop and test this port.
> > -It was updated to 4.5 and merged into the main development trunk
> > -by Joel Sherrill <joel at OARcorp.com>. As part of the merger, the
> > -port was made to conditionally compile for the H8, H8300H, and H8300S
> > -series.
> > -The status of each CPU subfamily is as follows.
> > -H8 - Although RTEMS compiles with for these CPUs, it does not
> > - truly support them. All code that will not work on these
> > - CPUs is conditionally disabled. These CPUs have a 16-bit
> > - address space. Thus although a port is technically
> > - feasible, some work will to be performed on RTEMS to
> > - further minimize its footprint and address pointer
> > - manipulation issues.
> > -H8H - Port was developed on this class of H8 so there should be
> > - no problems.
> > -H8S - Port should work on this class of H8 but it is untested.
> > ---joel
> > -28 June 2000
> > diff --git a/cpukit/score/cpu/h8300/cpu.c b/cpukit/score/cpu/h8300/cpu.c
> > index 36c41a2..0000000
> > --- a/cpukit/score/cpu/h8300/cpu.c
> > +++ /dev/null
> > @@ -1,134 +0,0 @@
> > - * @file
> > - * @brief H8300 CPU Dependent Source
> > - * COPYRIGHT (c) 1989-1999.
> > - * On-Line Applications Research Corporation (OAR).
> > - * The license and distribution terms for this file may be
> > - * found in the file LICENSE in this distribution or at
> > - * http://www.rtems.org/license/LICENSE.
> > -#ifdef HAVE_CONFIG_H
> > -#include "config.h"
> > -#endif
> > -#include <rtems/system.h>
> > -#include <rtems/score/isr.h>
> > -#include <rtems/score/wkspace.h>
> > -/* _CPU_Initialize
> > - * This routine performs processor dependent initialization.
> > - * INPUT PARAMETERS: NONE
> > -void _CPU_Initialize(void)
> > - * If there is not an easy way to initialize the FP context
> > - * during Context_Initialize, then it is usually easier to
> > - * save an "uninitialized" FP context here and copy it to
> > - * the task's during Context_Initialize.
> > - /* FP context initialization support goes here */
> > -uint32_t _CPU_ISR_Get_level( void )
> > - unsigned int _ccr;
> > -#if defined(__H8300__)
> > -#warning "How do we get ccr on base CPU models"
> > -#else
> > - __asm__ volatile ( "stc ccr, %0" : "=m" (_ccr) : );
> > -#endif
> > - if ( _ccr & 0x80 )
> > - return 1;
> > - return 0;
> > - * _CPU_ISR_install_raw_handler
> > -void _CPU_ISR_install_raw_handler(
> > - uint32_t vector,
> > - proc_ptr new_handler,
> > - proc_ptr *old_handler
> > - * This is where we install the interrupt handler into the "raw"
> interrupt
> > - * table used by the CPU to dispatch interrupt handlers.
> > - * Use Debug level IRQ Handlers
> > - H8BD_Install_IRQ(vector,new_handler,old_handler);
> > -void _CPU_ISR_install_vector(
> > - uint32_t vector,
> > - *old_handler = _ISR_Vector_table[ vector ];
> > - * If the interrupt vector table is a table of pointer to isr entry
> > - * points, then we need to install the appropriate RTEMS interrupt
> > - * handler for this vector number.
> > - _CPU_ISR_install_raw_handler( vector, new_handler, old_handler );
> > - * We put the actual user ISR address in '_ISR_vector_table'. This
> will
> > - * be used by the _ISR_Handler so the user gets control.
> > - _ISR_Vector_table[ vector ] = new_handler;
> > - * _CPU_Install_interrupt_stack
> > -void _CPU_Install_interrupt_stack( void )
> > - * _CPU_Thread_Idle_body
> > - * NOTES:
> > - * 1. This is the same as the regular CPU independent algorithm.
> > - * 2. If you implement this using a "halt", "idle", or "shutdown"
> > - * instruction, then don't forget to put it in an infinite loop.
> > - * 3. Be warned. Some processors with onboard DMA have been known
> > - * to stop the DMA if the CPU were put in IDLE mode. This might
> > - * also be a problem with other on-chip peripherals. So use this
> > - * hook with caution.
> > -#if 0
> > -void *_CPU_Thread_Idle_body( uintptr_t ignored )
> > - for( ; ; )
> > - IDLE_Monitor();
> > - /* __asm__ (" sleep \n"); */
> > - /* insert your "halt" instruction here */ ;
> > -#endif
> > diff --git a/cpukit/score/cpu/h8300/cpu_asm.S
> b/cpukit/score/cpu/h8300/cpu_asm.S
> > index e0fdf0a..0000000
> > --- a/cpukit/score/cpu/h8300/cpu_asm.S
> > +++ /dev/null
> > @@ -1,221 +0,0 @@
> > - * Hitachi H8 Score CPU functions
> > - * Copyright Comnet Technologies Ltd 1999
> > - * Based on example code and other ports with this copyright:
> > -#endif
> > -#include <rtems/asm.h>
> > -#include <rtems/score/percpu.h>
> > -;.equ RUNCONTEXT_ARG, er0
> > -;.equ HEIRCONTEXT_ARG, er1
> > - * Make sure we tell the assembler what type of CPU model we are
> > - * being compiled for.
> > -#if defined(__H8300H__)
> > - .h8300h
> > -#endif
> > -#if defined(__H8300S__)
> > - .h8300s
> > -#endif
> > -#if defined(__H8300SX__)
> > - .h8300sx
> > -#endif
> > - .text
> > - .text
> > - GCC Compiled with optimisations and Wimplicit decs to ensure
> > - that stack from doesn't change
> > - Supposedly R2 and R3 do not need to be saved but who knows
> > - Arg1 = er0 (not on stack)
> > - Arg2 = er1 (not on stack)
> > - .align 2
> > - .global SYM(_CPU_Context_switch)
> > -SYM(_CPU_Context_switch):
> > - /* Save Context */
> > -#if defined(__H8300H__) || defined(__H8300S__) || defined(__H8300SX__)
> > - stc.w ccr,@(0:16,er0)
> > - mov.l er7,@(2:16,er0)
> > - mov.l er6,@(6:16,er0)
> > - mov.l er5,@(10:16,er0)
> > - mov.l er4,@(14:16,er0)
> > - mov.l er3,@(18:16,er0)
> > - mov.l er2,@(22:16,er0)
> > - /* Install New context */
> > -restore:
> > - mov.l @(22:16,er1),er2
> > - mov.l @(18:16,er1),er3
> > - mov.l @(14:16,er1),er4
> > - mov.l @(10:16,er1),er5
> > - mov.l @(6:16,er1),er6
> > - mov.l @(2:16,er1),er7
> > - ldc.w @(0:16,er1),ccr
> > -#endif
> > - rts
> > - .align 2
> > - .global SYM(_CPU_Context_restore)
> > -SYM(_CPU_Context_restore):
> > - mov.l er0,er1
> > - jmp @restore:24
> > -#endif
> > - VHandler for Vectored Interrupts
> > - All IRQ's are vectored to routine _ISR_#vector_number
> > - This routine stacks er0 and loads er0 with vector number
> > - before transferring to here
> > - .align 2
> > - .global SYM(_ISR_Handler)
> > - .extern SYM(_Vector_table)
> > -SYM(_ISR_Handler):
> > - mov.l er1, at -er7
> > - mov.l er2, at -er7
> > - mov.l er3, at -er7
> > - mov.l er4, at -er7
> > - mov.l er5, at -er7
> > - mov.l er6, at -er7
> > -/* Set IRQ Stack */
> > - orc #0xc0,ccr
> > - mov.l er7,er6 ; save stack pointer
> > - mov.l @ISR_NEST_LEVEL,er1
> > - bne nested
> > - mov.l @INTERRUPT_STACK_HIGH,er7
> > -nested:
> > - mov.l er6, at -er7 ; save sp so pop regardless of nest level
> > -;; Inc system counters
> > - inc.l #1,er1
> > - mov.l er1, at ISR_NEST_LEVEL
> > - mov.l @THREAD_DISPATCH_DISABLE_LEVEL,er1
> > - inc.l #1,er1
> > - mov.l er1, at THREAD_DISPATCH_DISABLE_LEVEL
> > -/* Vector to ISR */
> > - mov er0,er2 ; copy vector
> > - shll.l er2
> > - shll.l er2 ; vector = vector * 4 (sizeof(int))
> > - mov.l @(SYM(_ISR_Vector_table), er2),er1
> > - jsr @er1 ; er0 = arg1 =vector
> > - orc #0xc0,ccr
> > - dec.l #1,er1
> > - dec.l #1,er1
> > - bne exit
> > - mov.l @DISPATCH_NEEDED,er1
> > - beq exit ; If no then exit
> > - /* Context switch here through ISR_Dispatch */
> > -bframe:
> > - orc #0xc0,ccr
> > -/* Pop Stack */
> > - mov @er7+,er6
> > - mov er6,er7
> > - /* Set up IRQ stack frame and dispatch to _ISR_Dispatch */
> > - mov.l #0xc0000000,er2 /* Disable IRQ */
> > - or.l #SYM(_ISR_Dispatch),er2
> > - rte
> > -/* Inner IRQ Return, pop flags and return */
> > -exit:
> > -/* Pop Stack */
> > - orc #0x80,ccr
> > - mov @er7+,er6
> > - mov er6,er7
> > - mov @er7+,er6
> > - mov @er7+,er5
> > - mov @er7+,er4
> > - mov @er7+,er3
> > - mov @er7+,er2
> > - mov @er7+,er1
> > - mov @er7+,er0
> > -#endif
> > - rte
> > - Called from ISR_Handler as a way of ending IRQ
> > - but allowing dispatch to another task.
> > - Must use RTE as CCR is still on stack but IRQ has been serviced.
> > - CCR and PC occupy same word so rte can be used.
> > - now using task stack
> > - .align 2
> > - .global SYM(_ISR_Dispatch)
> > -SYM(_ISR_Dispatch):
> > - jsr @SYM(_Thread_Dispatch)
> > - mov @er7+,er6
> > - mov @er7+,er5
> > - mov @er7+,er4
> > - mov @er7+,er3
> > - mov @er7+,er2
> > - mov @er7+,er1
> > - mov @er7+,er0
> > -#endif
> > - rte
> > - .align 2
> > - .global SYM(_CPU_Context_save_fp)
> > -SYM(_CPU_Context_save_fp):
> > - rts
> > - .align 2
> > - .global SYM(_CPU_Context_restore_fp)
> > -SYM(_CPU_Context_restore_fp):
> > - rts
> > diff --git a/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
> b/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
> > index 71e7e1c..0000000
> > --- a/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
> > +++ /dev/null
> > @@ -1,24 +0,0 @@
> > - * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
> > - * embedded brains GmbH
> > - * Obere Lagerstr. 30
> > - * 82178 Puchheim
> > - * Germany
> > - * <rtems at embedded-brains.de>
> > - #include "config.h"
> > -#endif
> > -#include <rtems/score/cpu.h>
> > -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> > - /* TODO */
> > diff --git a/cpukit/score/cpu/h8300/preinstall.am
> b/cpukit/score/cpu/h8300/preinstall.am
> > index f3c1681..0000000
> > --- a/cpukit/score/cpu/h8300/preinstall.am
> > +++ /dev/null
> > @@ -1,45 +0,0 @@
> > -## Automatically generated by ampolish3 - Do not edit
> > -if AMPOLISH3
> > -$(srcdir)/preinstall.am: Makefile.am
> > - $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> > -endif
> > -PREINSTALL_DIRS =
> > -DISTCLEANFILES = $(PREINSTALL_DIRS)
> > -all-am: $(PREINSTALL_FILES)
> > -PREINSTALL_FILES =
> > -CLEANFILES = $(PREINSTALL_FILES)
> > -$(PROJECT_INCLUDE)/rtems/$(dirstamp):
> > - @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
> > - @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> > -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> > -$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
> > -$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
> > - @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
> > - @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> > -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> > -$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
> > -$(PROJECT_INCLUDE)/rtems/score/h8300.h: rtems/score/h8300.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/h8300.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/h8300.h
> > -$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
> > -$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h
> > - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> > -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> > diff --git a/cpukit/score/cpu/h8300/rtems/asm.h
> b/cpukit/score/cpu/h8300/rtems/asm.h
> > index 6c1a643..0000000
> > --- a/cpukit/score/cpu/h8300/rtems/asm.h
> > +++ /dev/null
> > @@ -1,118 +0,0 @@
> > - * @file
> > - * @brief Address the Problems Caused by Incompatible Flavor of
> > - * Assemblers and Toolsets
> > - * This include file attempts to address the problems
> > - * caused by incompatible flavors of assemblers and
> > - * toolsets. It primarily addresses variations in the
> > - * use of leading underscores on symbols and the requirement
> > - * that register names be preceded by a %.
> > - * NOTE: The spacing in the use of these macros
> > - * is critical to them working as advertised.
> > - * COPYRIGHT:
> > - * This file is based on similar code found in newlib available
> > - * from ftp.cygnus.com. The file which was used had no copyright
> > - * notice. This file is freely distributable as long as the source
> > - * of the file is noted. This file is:
> > -#ifndef _RTEMS_ASM_H
> > -#define _RTEMS_ASM_H
> > - * Indicate we are in an assembly file and get the basic CPU
> definitions.
> > -#include <rtems/score/h8300.h>
> > - * Recent versions of GNU cpp define variables which indicate the
> > - * need for underscores and percents. If not using GNU cpp or
> > - * the version does not support this, then you will obviously
> > - * have to define these as appropriate.
> > -#ifndef __USER_LABEL_PREFIX__
> > -#define __USER_LABEL_PREFIX__ _
> > -#endif
> > -#ifndef __REGISTER_PREFIX__
> > -#define __REGISTER_PREFIX__
> > -#endif
> > -#include <rtems/concat.h>
> > -/* Use the right prefix for global labels. */
> > -#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
> > -/* Use the right prefix for registers. */
> > -#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
> > - * define macros for all of the registers on this CPU
> > - * EXAMPLE: #define d0 REG (d0)
> > -#define r0 REG(r0)
> > -#define r1 REG(r1)
> > -#define r2 REG(r2)
> > -#define r3 REG(r3)
> > -#define r4 REG(r4)
> > -#define r5 REG(r5)
> > -#define r6 REG(r6)
> > -#define r7 REG(r7)
> > -#define er0 REG(er0)
> > -#define er1 REG(er1)
> > -#define er2 REG(er2)
> > -#define er3 REG(er3)
> > -#define er4 REG(er4)
> > -#define er5 REG(er5)
> > -#define er6 REG(er6)
> > -#define er7 REG(er7)
> > -#define sp REG(sp)
> > - * Define macros to handle section beginning and ends.
> > -#define BEGIN_CODE_DCL .text
> > -#define END_CODE_DCL
> > -#define BEGIN_DATA_DCL .data
> > -#define END_DATA_DCL
> > -#define BEGIN_CODE __asm__ ( ".text
> > -#define END_CODE ");
> > -#define BEGIN_DATA
> > -#define END_DATA
> > -#define BEGIN_BSS
> > -#define END_BSS
> > -#define END
> > - * Following must be tailor for a particular flavor of the C compiler.
> > - * They may need to put underscores in front of the symbols.
> > -#define PUBLIC(sym) .globl SYM (sym)
> > -#define EXTERN(sym) .globl SYM (sym)
> > -#endif
> > diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h
> b/cpukit/score/cpu/h8300/rtems/score/cpu.h
> > index 8b34bb4..0000000
> > --- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
> > +++ /dev/null
> > @@ -1,1176 +0,0 @@
> > - * @file
> > - * @brief Hitachi H8300 CPU Department Source
> > - * This include file contains information pertaining to the H8300
> > - * processor.
> > - * COPYRIGHT (c) 1989-2006.
> > -#ifndef _RTEMS_SCORE_CPU_H
> > -#define _RTEMS_SCORE_CPU_H
> > -#ifdef __cplusplus
> > -extern "C" {
> > -#endif
> > -#include <rtems/score/types.h>
> > -#ifndef ASM
> > - #include <rtems/bspIo.h>
> > -#endif
> > -/* conditional compilation parameters */
> > - * Should the calls to _Thread_Enable_dispatch be inlined?
> > - * If TRUE, then they are inlined.
> > - * If FALSE, then a subroutine call is made.
> > - * Basically this is an example of the classic trade-off of size
> > - * versus speed. Inlining the call (TRUE) typically increases the
> > - * size of RTEMS while speeding up the enabling of dispatching.
> > - * [NOTE: In general, the _Thread_Dispatch_disable_level will
> > - * only be 0 or 1 unless you are in an interrupt handler and that
> > - * interrupt handler invokes the executive.] When not inlined
> > - * something calls _Thread_Enable_dispatch which in turns calls
> > - * _Thread_Dispatch. If the enable dispatch is inlined, then
> > - * one subroutine call is avoided entirely.]
> > - * H8300 Specific Information:
> > - * XXX
> > -#define CPU_INLINE_ENABLE_DISPATCH FALSE
> > - * Should this target use 16 or 32 bit object Ids?
> > -#define RTEMS_USE_16_BIT_OBJECT
> > - * Does RTEMS manage a dedicated interrupt stack in software?
> > - * If TRUE, then a stack is allocated in _ISR_Handler_initialization.
> > - * If FALSE, nothing is done.
> > - * If the CPU supports a dedicated interrupt stack in hardware,
> > - * then it is generally the responsibility of the BSP to allocate it
> > - * and set it up.
> > - * If the CPU does not support a dedicated interrupt stack, then
> > - * the porter has two options: (1) execute interrupts on the
> > - * stack of the interrupted task, and (2) have RTEMS manage a dedicated
> > - * interrupt stack.
> > - * If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
> > - * Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
> > - * CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE. It is
> > - * possible that both are FALSE for a particular CPU. Although it
> > - * is unclear what that would imply about the interrupt processing
> > - * procedure on that CPU.
> > - * XXX
> > -#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
> > - * Does the CPU follow the simple vectored interrupt model?
> > - * If TRUE, then RTEMS allocates the vector table it internally
> manages.
> > - * If FALSE, then the BSP is assumed to allocate and manage the vector
> > - * table
> > - * XXX document implementation including references if appropriate
> > -#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
> > - * Does this CPU have hardware support for a dedicated interrupt stack?
> > - * If TRUE, then it must be installed during initialization.
> > - * If FALSE, then no installation is performed.
> > - * XXX
> > -#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
> > - * Does RTEMS allocate a dedicated interrupt stack in the Interrupt
> Manager?
> > - * If TRUE, then the memory is allocated during initialization.
> > - * If FALSE, then the memory is allocated during initialization.
> > - * This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
> > - * XXX
> > -#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
> > - * Does the CPU have hardware floating point?
> > - * If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
> > - * If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
> > - * If there is a FP coprocessor such as the i387 or mc68881, then
> > - * the answer is TRUE.
> > - * The macro name "H8300_HAS_FPU" should be made CPU specific.
> > - * It indicates whether or not this CPU model has FP support. For
> > - * example, it would be possible to have an i386_nofp CPU model
> > - * which set this to false to indicate that you have an i386 without
> > - * an i387 and wish to leave floating point support out of RTEMS.
> > - * XXX
> > -#define CPU_HARDWARE_FP FALSE
> > - * Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
> > - * If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
> > - * If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
> > - * If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
> > - * XXX
> > -#define CPU_ALL_TASKS_ARE_FP FALSE
> > - * Should the IDLE task have a floating point context?
> > - * If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT
> task
> > - * and it has a floating point context which is switched in and out.
> > - * If FALSE, then the IDLE task does not have a floating point context.
> > - * Setting this to TRUE negatively impacts the time required to preempt
> > - * the IDLE task from an interrupt because the floating point context
> > - * must be saved as part of the preemption.
> > - * XXX
> > -#define CPU_IDLE_TASK_IS_FP FALSE
> > - * Should the saving of the floating point registers be deferred
> > - * until a context switch is made to another different floating point
> > - * task?
> > - * If TRUE, then the floating point context will not be stored until
> > - * necessary. It will remain in the floating point registers and not
> > - * disturned until another floating point task is switched to.
> > - * If FALSE, then the floating point context is saved when a floating
> > - * point task is switched out and restored when the next floating point
> > - * task is restored. The state of the floating point registers between
> > - * those two operations is not specified.
> > - * If the floating point context does NOT have to be saved as part of
> > - * interrupt dispatching, then it should be safe to set this to TRUE.
> > - * Setting this flag to TRUE results in using a different algorithm
> > - * for deciding when to save and restore the floating point context.
> > - * The deferred FP switch algorithm minimizes the number of times
> > - * the FP context is saved and restored. The FP context is not saved
> > - * until a context switch is made to another, different FP task.
> > - * Thus in a system with only one FP task, the FP context will never
> > - * be saved or restored.
> > - * XXX
> > -#define CPU_USE_DEFERRED_FP_SWITCH TRUE
> > - * Does this port provide a CPU dependent IDLE task implementation?
> > - * If TRUE, then the routine _CPU_Internal_threads_Idle_thread_body
> > - * must be provided and is the default IDLE thread body instead of
> > - * _Internal_threads_Idle_thread_body.
> > - * If FALSE, then use the generic IDLE thread body if the BSP does
> > - * not provide one.
> > - * This is intended to allow for supporting processors which have
> > - * a low power or idle mode. When the IDLE thread is executed, then
> > - * the CPU can be powered down.
> > - * The order of precedence for selecting the IDLE thread body is:
> > - * 1. BSP provided
> > - * 2. CPU dependent (if provided)
> > - * 3. generic (if no BSP and no CPU dependent)
> > - * XXX
> > - * The port initially called a BSP dependent routine called
> > - * IDLE_Monitor. The idle task body can be overridden by
> > - * the BSP in newer versions of RTEMS.
> > -#define CPU_PROVIDES_IDLE_THREAD_BODY FALSE
> > - * Does the stack grow up (toward higher addresses) or down
> > - * (toward lower addresses)?
> > - * If TRUE, then the grows upward.
> > - * If FALSE, then the grows toward smaller addresses.
> > - * XXX
> > -#define CPU_STACK_GROWS_UP FALSE
> > - * The following is the variable attribute used to force alignment
> > - * of critical RTEMS structures. On some processors it may make
> > - * sense to have these aligned on tighter boundaries than
> > - * the minimum requirements of the compiler in order to have as
> > - * much of the critical data area as possible in a cache line.
> > - * The placement of this macro in the declaration of the variables
> > - * is based on the syntactically requirements of the GNU C
> > - * "__attribute__" extension. For example with GNU C, use
> > - * the following to force a structures to a 32 byte boundary.
> > - * __attribute__ ((aligned (32)))
> > - * NOTE: Currently only the Priority Bit Map table uses this feature.
> > - * To benefit from using this, the data must be heavily
> > - * used so it will stay in the cache and used frequently enough
> > - * in the executive to justify turning this on.
> > - * XXX
> > -#define CPU_STRUCTURE_ALIGNMENT
> > -#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
> > - * Define what is required to specify how the network to host
> conversion
> > - * routines are handled.
> > -#define CPU_BIG_ENDIAN TRUE
> > -#define CPU_LITTLE_ENDIAN FALSE
> > - * The following defines the number of bits actually used in the
> > - * interrupt field of the task mode. How those bits map to the
> > - * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
> > - * XXX
> > -#define CPU_MODES_INTERRUPT_MASK 0x00000001
> > -#define CPU_PER_CPU_CONTROL_SIZE 0
> > - * Processor defined structures required for cpukit/score.
> > - * XXX
> > -/* may need to put some structures here. */
> > - * Contexts
> > - * Generally there are 2 types of context to save.
> > - * 1. Interrupt registers to save
> > - * 2. Task level registers to save
> > - * This means we have the following 3 context items:
> > - * 1. task level context stuff:: Context_Control
> > - * 2. floating point task stuff:: Context_Control_fp
> > - * 3. special interrupt level context :: Context_Control_interrupt
> > - * On some processors, it is cost-effective to save only the callee
> > - * preserved registers during a task context switch. This means
> > - * that the ISR code needs to save those registers which do not
> > - * persist across function calls. It is not mandatory to make this
> > - * distinctions between the caller/callee saves registers for the
> > - * purpose of minimizing context saved during task switch and on
> interrupts.
> > - * If the cost of saving extra registers is minimal, simplicity is the
> > - * choice. Save the same context on interrupt entry as for tasks in
> > - * this case.
> > - * Additionally, if gdb is to be made aware of RTEMS tasks for this
> CPU, then
> > - * care should be used in designing the context area.
> > - * On some CPUs with hardware floating point support, the
> Context_Control_fp
> > - * structure will not be used or it simply consist of an array of a
> > - * fixed number of bytes. This is done when the floating point
> context
> > - * is dumped by a "FP save context" type instruction and the format
> > - * is not really defined by the CPU. In this case, there is no need
> > - * to figure out the exact format -- only the size. Of course,
> although
> > - * this is enough information for RTEMS, it is probably not enough for
> > - * a debugger such as gdb. But that is another problem.
> > - * XXX
> > -#ifndef ASM
> > -typedef struct {
> > - /* There is no CPU specific per-CPU state */
> > -} CPU_Per_CPU_control;
> > -#define nogap __attribute__ ((packed))
> > -typedef struct {
> > - uint16_t ccr nogap;
> > - void *er7 nogap;
> > - void *er6 nogap;
> > - uint32_t er5 nogap;
> > - uint32_t er4 nogap;
> > - uint32_t er3 nogap;
> > - uint32_t er2 nogap;
> > - uint32_t er1 nogap;
> > - uint32_t er0 nogap;
> > - uint32_t xxx nogap;
> > -} Context_Control;
> > -#define _CPU_Context_Get_SP( _context ) \
> > - (_context)->er7
> > -typedef struct {
> > - double some_float_register[2];
> > -} Context_Control_fp;
> > -typedef struct {
> > - uint32_t special_interrupt_register;
> > -} CPU_Interrupt_frame;
> > - * This variable is optional. It is used on CPUs on which it is
> difficult
> > - * to generate an "uninitialized" FP context. It is filled in by
> > - * _CPU_Initialize and copied into the task's FP context area during
> > - * _CPU_Context_Initialize.
> > - * XXX
> > -SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
> > - * Nothing prevents the porter from declaring more CPU specific
> variables.
> > - * XXX
> > -/* XXX: if needed, put more variables here */
> > - * The size of the floating point context area. On some CPUs this
> > - * will not be a "sizeof" because the format of the floating point
> > - * area is not defined -- only the size is. This is usually on
> > - * CPUs with a "floating point save context" instruction.
> > - * XXX
> > -#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
> > -#endif /* ASM */
> > - * Amount of extra stack (above minimum stack size) required by
> > - * system initialization thread. Remember that in a multiprocessor
> > - * system the system intialization thread becomes the MP server thread.
> > - * It is highly unlikely the H8300 will get used in a multiprocessor
> system.
> > -#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
> > - * This defines the number of entries in the ISR_Vector_table managed
> > - * by RTEMS.
> > - * XXX
> > -#define CPU_INTERRUPT_NUMBER_OF_VECTORS 64
> > -#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER
> (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
> > - * This is defined if the port has a special way to report the ISR
> nesting
> > - * level. Most ports maintain the variable _ISR_Nest_level.
> > -#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
> > - * Should be large enough to run all RTEMS tests. This ensures
> > - * that a "reasonable" small application should not have any problems.
> > - * XXX
> > -#define CPU_STACK_MINIMUM_SIZE (1536)
> > - #define CPU_SIZEOF_POINTER 4
> > -#else
> > - #define CPU_SIZEOF_POINTER 2
> > -#endif
> > - * CPU's worst alignment requirement for data types on a byte
> boundary. This
> > - * alignment does not take into account the requirements for the stack.
> > - * XXX
> > -#define CPU_ALIGNMENT 8
> > - * This number corresponds to the byte alignment requirement for the
> > - * heap handler. This alignment requirement may be stricter than that
> > - * for the data types alignment specified by CPU_ALIGNMENT. It is
> > - * common for the heap to follow the same alignment requirement as
> > - * CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap,
> > - * then this should be set to CPU_ALIGNMENT.
> > - * NOTE: This does not have to be a power of 2. It does have to
> > - * be greater or equal to than CPU_ALIGNMENT.
> > - * XXX
> > -#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
> > - * This number corresponds to the byte alignment requirement for memory
> > - * buffers allocated by the partition manager. This alignment
> requirement
> > - * may be stricter than that for the data types alignment specified by
> > - * CPU_ALIGNMENT. It is common for the partition to follow the same
> > - * alignment requirement as CPU_ALIGNMENT. If the CPU_ALIGNMENT is
> strict
> > - * enough for the partition, then this should be set to CPU_ALIGNMENT.
> > - * XXX
> > -#define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT
> > - * stack. This alignment requirement may be stricter than that for the
> > - * data types alignment specified by CPU_ALIGNMENT. If the
> CPU_ALIGNMENT
> > - * is strict enough for the stack, then this should be set to 0.
> > - * NOTE: This must be a power of 2 either 0 or greater than
> CPU_ALIGNMENT.
> > - * XXX
> > -#define CPU_STACK_ALIGNMENT 2
> > - * ISR handler macros
> > - * Support routine to initialize the RTEMS vector table after it is
> allocated.
> > -#define _CPU_Initialize_vectors()
> > -/* COPE With Brain dead version of GCC distributed with Hitachi HIView
> Tools.
> > - Note requires ISR_Level be uint16_t or assembler croaks.
> > -#if (__GNUC__ == 2 && __GNUC_MINOR__ == 7 )
> > - * Disable all interrupts for an RTEMS critical section. The previous
> > - * level is returned in _level.
> > -#define _CPU_ISR_Disable( _isr_cookie ) \
> > - do { \
> > - __asm__ volatile( "stc.w ccr, @-er7 ;\n orc #0xC0,ccr ;\n mov.w
> @er7+,%0" : : "r" (_isr_cookie) ); \
> > - } while (0)
> > - * Enable interrupts to the previous level (returned by
> _CPU_ISR_Disable).
> > - * This indicates the end of an RTEMS critical section. The parameter
> > - * _level is not modified.
> > -#define _CPU_ISR_Enable( _isr_cookie ) \
> > - do { \
> > - __asm__ volatile( "mov.w %0, at -er7 ;\n ldc.w @er7+, ccr" : : "r"
> (_isr_cookie) ); \
> > - } while (0)
> > - * This temporarily restores the interrupt to _level before immediately
> > - * disabling them again. This is used to divide long RTEMS critical
> > - * sections into two or more parts. The parameter _level is not
> > - * modified.
> > -#define _CPU_ISR_Flash( _isr_cookie ) \
> > - do { \
> > - __asm__ volatile( "mov.w %0, at -er7 ;\n ldc.w @er7+, ccr ;\n orc
> #0xC0,ccr" : : "r" (_isr_cookie) ); \
> > - } while (0)
> > -/* end of ISR handler macros */
> > -#else /* modern gcc version */
> > - * TODO: As of 8 October 2014, this method is not implemented for the
> SX.
> > - do { \
> > - unsigned char __ccr; \
> > - __asm__ volatile( "stc ccr, %0 ; orc #0x80,ccr " \
> > - : "=m" (__ccr) /* : "0" (__ccr) */ ); \
> > - (_isr_cookie) = __ccr; \
> > - } while (0)
> > -#else
> > - do { \
> > - (_isr_cookie) = 0; \
> > - } while (0)
> > -#endif
> _CPU_ISR_Disable).
> SX.
> > - do { \
> > - unsigned char __ccr = (unsigned char) (_isr_cookie); \
> > - __asm__ volatile( "ldc %0, ccr" : : "m" (__ccr) ); \
> > - } while (0)
> > -#else
> > - do { \
> > - (_isr_cookie) = (_isr_cookie); \
> > - } while (0)
> > -#endif
> > - * modified.
> SX.
> > - do { \
> > - __asm__ volatile( "ldc %0, ccr ; orc #0x80,ccr " : : "m" (__ccr)
> > - } while (0)
> > -#else
> > - do { \
> > - _CPU_ISR_Enable( _isr_cookie ); \
> > - _CPU_ISR_Disable( _isr_cookie ); \
> > - } while (0)
> > -#endif
> > -#endif /* end of old gcc */
> > - * Map interrupt level in task mode onto the hardware that the CPU
> > - * actually provides. Currently, interrupt levels which do not
> > - * map onto the CPU in a generic fashion are undefined. Someday,
> > - * it would be nice if these were "mapped" by the application
> > - * via a callout. For example, m68k has 8 levels 0 - 7, levels
> > - * 8 - 255 would be available for bsp/application specific meaning.
> > - * This could be used to manage a programmable interrupt controller
> > - * via the rtems_task_mode directive.
> > - * XXX
> > -#define _CPU_ISR_Set_level( _new_level ) \
> > - if ( _new_level ) __asm__ volatile ( "orc #0x80,ccr\n" ); \
> > - else __asm__ volatile ( "andc #0x7f,ccr\n" ); \
> > -#ifndef ASM
> > -uint32_t _CPU_ISR_Get_level( void );
> > -/* Context handler macros */
> > - * Initialize the context to a state suitable for starting a
> > - * task after a context restore operation. Generally, this
> > - * involves:
> > - * - setting a starting address
> > - * - preparing the stack
> > - * - preparing the stack and frame pointers
> > - * - setting the proper interrupt level in the context
> > - * - initializing the floating point context
> > - * This routine generally does not set any unnecessary register
> > - * in the context. The state of the "general data" registers is
> > - * undefined at task start time.
> > - * NOTE: This is_fp parameter is TRUE if the thread is to be a floating
> > - * point thread. This is typically only used on CPUs where the
> > - * FPU may be easily disabled by software such as on the SPARC
> > - * where the PSR contains an enable FPU bit.
> > - * XXX
> > -#define CPU_CCR_INTERRUPTS_ON 0x80
> > -#define CPU_CCR_INTERRUPTS_OFF 0x00
> > -#define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
> > - _isr, _entry_point, _is_fp,
> _tls_area ) \
> > - /* Locate Me */ \
> > - do { \
> > - uintptr_t _stack; \
> > - if ( (_isr) ) (_the_context)->ccr = CPU_CCR_INTERRUPTS_OFF; \
> > - else (_the_context)->ccr = CPU_CCR_INTERRUPTS_ON; \
> > - (void) _is_fp; /* to eliminate set but not used warning */ \
> > - _stack = ((uintptr_t)(_stack_base)) + (_size) - 4; \
> > - *((proc_ptr *)(_stack)) = (_entry_point); \
> > - (_the_context)->er7 = (void *) _stack; \
> > - (_the_context)->er6 = (void *) _stack; \
> > - (_the_context)->er5 = 0; \
> > - (_the_context)->er4 = 1; \
> > - (_the_context)->er3 = 2; \
> > - } while (0)
> > - * This routine is responsible for somehow restarting the currently
> > - * executing task. If you are lucky, then all that is necessary
> > - * is restoring the context. Otherwise, there will need to be
> > - * a special assembly routine which does something special in this
> > - * case. Context_Restore should work most of the time. It will
> > - * not work if restarting self conflicts with the stack frame
> > - * assumptions of restoring a context.
> > - * XXX
> > -#define _CPU_Context_Restart_self( _the_context ) \
> > - _CPU_Context_restore( (_the_context) );
> > - * The purpose of this macro is to allow the initial pointer into
> > - * a floating point context area (used to save the floating point
> > - * context) to be at an arbitrary place in the floating point
> > - * context area.
> > - * This is necessary because some FP units are designed to have
> > - * their context saved as a stack which grows into lower addresses.
> > - * Other FP units can be saved by simply moving registers into offsets
> > - * from the base of the context area. Finally some FP units provide
> > - * a "dump context" instruction which could fill in from high to low
> > - * or low to high based on the whim of the CPU designers.
> > - * XXX
> > -#define _CPU_Context_Fp_start( _base, _offset ) \
> > - ( (void *) (_base) + (_offset) )
> > - * This routine initializes the FP context area passed to it to.
> > - * There are a few standard ways in which to initialize the
> > - * floating point context. The code included for this macro assumes
> > - * that this is a CPU in which a "initial" FP context was saved into
> > - * _CPU_Null_fp_context and it simply copies it to the destination
> > - * context passed to it.
> > - * Other models include (1) not doing anything, and (2) putting
> > - * a "null FP status word" in the correct place in the FP context.
> > - * XXX
> > -#define _CPU_Context_Initialize_fp( _destination ) \
> > - *(*(_destination)) = _CPU_Null_fp_context; \
> > -/* end of Context handler macros */
> > -/* Fatal Error manager macros */
> > - * This routine copies _error into a known place -- typically a stack
> > - * location or a register, optionally disables interrupts, and
> > - * halts/stops the CPU.
> > - * XXX
> > -#define _CPU_Fatal_halt( _source, _error ) \
> > - printk("Fatal Error %d.%d Halted\n",_source, _error); \
> > - for(;;)
> > -/* end of Fatal Error manager macros */
> > -/* Bitfield handler macros */
> > - * This routine sets _output to the bit number of the first bit
> > - * set in _value. _value is of CPU dependent type
> Priority_bit_map_Word.
> > - * This type may be either 16 or 32 bits wide although only the 16
> > - * least significant bits will be used.
> > - * There are a number of variables in using a "find first bit" type
> > - * instruction.
> > - * (1) What happens when run on a value of zero?
> > - * (2) Bits may be numbered from MSB to LSB or vice-versa.
> > - * (3) The numbering may be zero or one based.
> > - * (4) The "find first bit" instruction may search from MSB or LSB.
> > - * RTEMS guarantees that (1) will never happen so it is not a concern.
> > - * (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
> > - * _CPU_Priority_bits_index(). These three form a set of routines
> > - * which must logically operate together. Bits in the _value are
> > - * set and cleared based on masks built by _CPU_Priority_mask().
> > - * The basic major and minor values calculated by _Priority_Major()
> > - * and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
> > - * to properly range between the values returned by the "find first
> bit"
> > - * instruction. This makes it possible for _Priority_Get_highest() to
> > - * calculate the major and directly index into the minor table.
> > - * This mapping is necessary to ensure that 0 (a high priority
> major/minor)
> > - * is the first bit found.
> > - * This entire "find first bit" and mapping process depends heavily
> > - * on the manner in which a priority is broken into a major and minor
> > - * components with the major being the 4 MSB of a priority and minor
> > - * the 4 LSB. Thus (0 << 4) + 0 corresponds to priority 0 -- the
> highest
> > - * priority. And (15 << 4) + 14 corresponds to priority 254 -- the
> next
> > - * to the lowest priority.
> > - * If your CPU does not have a "find first bit" instruction, then
> > - * there are ways to make do without it. Here are a handful of ways
> > - * to implement this in software:
> > - * - a series of 16 bit test instructions
> > - * - a "binary search using if's"
> > - * - _number = 0
> > - * if _value > 0x00ff
> > - * _value >>=8
> > - * _number = 8;
> > - * if _value > 0x0000f
> > - * _value >=8
> > - * _number += 4
> > - * _number += bit_set_table[ _value ]
> > - * where bit_set_table[ 16 ] has values which indicate the first
> > - * bit set
> > - * XXX
> > -#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> > -#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> > -#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
> > -#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> > - (_output) = 0; /* do something to prevent warnings */ \
> > -#endif
> > -/* end of Bitfield handler macros */
> > - * This routine builds the mask which corresponds to the bit fields
> > - * as searched by _CPU_Bitfield_Find_first_bit(). See the discussion
> > - * for that routine.
> > - * XXX
> > -#define _CPU_Priority_Mask( _bit_number ) \
> > - ( 1 << (_bit_number) )
> > -#endif
> > - * This routine translates the bit numbers returned by
> > - * _CPU_Bitfield_Find_first_bit() into something suitable for use as
> > - * a major or minor component of a priority. See the discussion
> > - * XXX
> > -#define _CPU_Priority_bits_index( _priority ) \
> > - (_priority)
> > -#endif
> > -/* end of Priority handler macros */
> > -/* functions */
> > - * _CPU_Initialize
> > - * This routine performs CPU dependent initialization.
> > - * XXX
> > -void _CPU_Initialize(void);
> > - * This routine installs a "raw" interrupt handler directly into the
> > - * processor's vector table.
> > - * XXX
> > - uint32_t vector,
> > - * _CPU_ISR_install_vector
> > - * This routine installs an interrupt vector.
> > - * XXX
> > - uint32_t vector,
> > - * This routine installs the hardware interrupt stack pointer.
> > - * NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
> > - * is TRUE.
> > - * XXX
> > -void _CPU_Install_interrupt_stack( void );
> > - * _CPU_Internal_threads_Idle_thread_body
> > - * This routine is the CPU dependent IDLE thread body.
> > - * NOTE: It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
> > - * is TRUE.
> > - * XXX
> > -void *_CPU_Thread_Idle_body( uint32_t );
> > - * _CPU_Context_switch
> > - * This routine switches from the run context to the heir context.
> > - * XXX
> > -void _CPU_Context_switch(
> > - Context_Control *run,
> > - Context_Control *heir
> > - * _CPU_Context_restore
> > - * This routine is generallu used only to restart self in an
> > - * efficient manner. It may simply be a label in _CPU_Context_switch.
> > - * NOTE: May be unnecessary to reload some registers.
> > - * XXX
> > -void _CPU_Context_restore(
> > - Context_Control *new_context
> > -) RTEMS_NO_RETURN;
> > - * _CPU_Context_save_fp
> > - * This routine saves the floating point context passed to it.
> > - * XXX
> > -void _CPU_Context_save_fp(
> > - Context_Control_fp **fp_context_ptr
> > - * _CPU_Context_restore_fp
> > - * This routine restores the floating point context passed to it.
> > - * XXX
> > -void _CPU_Context_restore_fp(
> > -static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
> > - /* TODO */
> > -static inline void _CPU_Context_validate( uintptr_t pattern )
> > - while (1) {
> > - /* TODO */
> > -/* FIXME */
> > -typedef CPU_Interrupt_frame CPU_Exception_frame;
> > -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> > -/* The following routine swaps the endian format of an unsigned int.
> > - * It must be static because it is referenced indirectly.
> > - * This version will work on any processor, but if there is a better
> > - * way for your CPU PLEASE use it. The most common way to do this is
> to:
> > - * swap least significant two bytes with 16-bit rotate
> > - * swap upper and lower 16-bits
> > - * swap most significant two bytes with 16-bit rotate
> > - * Some CPUs have special instructions which swap a 32-bit quantity in
> > - * a single instruction (e.g. i486). It is probably best to avoid
> > - * an "endian swapping control bit" in the CPU. One good reason is
> > - * that interrupts would probably have to be disabled to ensure that
> > - * an interrupt does not try to access the same "chunk" with the wrong
> > - * endian. Another good reason is that on some CPUs, the endian bit
> > - * endianness for ALL fetches -- both code and data -- so the code
> > - * will be fetched incorrectly.
> > - * This is the generic implementation.
> > -static inline uint32_t CPU_swap_u32(
> > - uint32_t value
> > - uint32_t byte1, byte2, byte3, byte4, swapped;
> > - byte4 = (value >> 24) & 0xff;
> > - byte3 = (value >> 16) & 0xff;
> > - byte2 = (value >> 8) & 0xff;
> > - byte1 = value & 0xff;
> > - swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
> > - return( swapped );
> > -#define CPU_swap_u16( value ) \
> > - (((value&0xff) << 8) | ((value >> 8)&0xff))
> > -typedef uint32_t CPU_Counter_ticks;
> > -CPU_Counter_ticks _CPU_Counter_read( void );
> > -static inline CPU_Counter_ticks _CPU_Counter_difference(
> > - CPU_Counter_ticks second,
> > - CPU_Counter_ticks first
> > - return second - first;
> > -/* to be provided by the BSP */
> > -extern void H8BD_Install_IRQ(
> > - uint32_t vector,
> > - proc_ptr *old_handler );
> > -#endif /* ASM */
> > -#ifdef __cplusplus
> > -#endif
> > -#endif
> > diff --git a/cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
> b/cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
> > index 598ee76..0000000
> > --- a/cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
> > +++ /dev/null
> > @@ -1,14 +0,0 @@
> > - * COPYRIGHT (c) 2012-2013 Deng Hengyi.
> > -#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
> > -#define _RTEMS_SCORE_ATOMIC_CPU_H
> > -#include <rtems/score/cpustdatomic.h>
> > -#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
> > diff --git a/cpukit/score/cpu/h8300/rtems/score/h8300.h
> b/cpukit/score/cpu/h8300/rtems/score/h8300.h
> > index e30343c..0000000
> > --- a/cpukit/score/cpu/h8300/rtems/score/h8300.h
> > +++ /dev/null
> > @@ -1,44 +0,0 @@
> > - * @file
> > - * @brief Information Required to Build RTEMS for a Particular Member
> > - * of the Hitachi H8/300 Family
> > - * This file contains information pertaining to the Hitachi H8/300
> > - * processor family.
> > -#ifndef _RTEMS_SCORE_H8300_H
> > -#define _RTEMS_SCORE_H8300_H
> > -#ifdef __cplusplus
> > -extern "C" {
> > -#endif
> > - * This file contains the information required to build
> > - * RTEMS for a particular member of the "h8300"
> > - * family when executing in protected mode. It does
> > - * this by setting variables to indicate which implementation
> > - * dependent features are present in a particular member
> > - * of the family.
> > -#define CPU_NAME "Hitachi H8300"
> > -#define CPU_MODEL_NAME "h8300"
> > -#define H8300_HAS_FPU 0
> > -#ifdef __cplusplus
> > -#endif
> > -#endif
> > diff --git a/cpukit/score/cpu/h8300/rtems/score/types.h
> b/cpukit/score/cpu/h8300/rtems/score/types.h
> > index 7fcac8b..0000000
> > --- a/cpukit/score/cpu/h8300/rtems/score/types.h
> > +++ /dev/null
> > @@ -1,47 +0,0 @@
> > - * @file
> > - * @brief Hitachi H8300 CPU Type Definitions
> > - * This include file contains type definitions pertaining to the Hitachi
> > - * h8300 processor family.
> > -#ifndef _RTEMS_SCORE_TYPES_H
> > -#define _RTEMS_SCORE_TYPES_H
> > -#include <rtems/score/basedefs.h>
> > -#ifndef ASM
> > -#ifdef __cplusplus
> > -extern "C" {
> > -#endif
> > - * This section defines the basic types for this processor.
> > -/** Type that can store a 32-bit integer or a pointer. */
> > -typedef unsigned long CPU_Uint32ptr;
> > -typedef uint16_t Priority_bit_map_Word;
> > -typedef void h8300_isr;
> > -typedef void ( *h8300_isr_entry )( void );
> > -#ifdef __cplusplus
> > -#endif
> > -#endif /* !ASM */
> > -#endif
> > diff --git a/doc/cpu_supplement/Makefile.am
> b/doc/cpu_supplement/Makefile.am
> > index f27cc6a..4d8ac98 100644
> > --- a/doc/cpu_supplement/Makefile.am
> > +++ b/doc/cpu_supplement/Makefile.am
> > @@ -16,7 +16,6 @@ GENERATED_FILES += arm.texi
> > GENERATED_FILES += avr.texi
> > GENERATED_FILES += bfin.texi
> > GENERATED_FILES += epiphany.texi
> > -GENERATED_FILES += h8300.texi
> > GENERATED_FILES += i386.texi
> > GENERATED_FILES += lm32.texi
> > GENERATED_FILES += m32c.texi
> > @@ -67,11 +66,6 @@ epiphany.texi: epiphany.t
> > -u "Top" \
> > -n "" < $< > $@
> > -h8300.texi: h8300.t
> > - $(BMENU2) -p "" \
> > - -u "Top" \
> > - -n "" < $< > $@
> > i386.texi: i386.t
> > $(BMENU2) -p "" \
> > -u "Top" \
> > diff --git a/doc/cpu_supplement/cpu_supplement.texi
> b/doc/cpu_supplement/cpu_supplement.texi
> > index 2fcdfa0..52c1a6f 100644
> > --- a/doc/cpu_supplement/cpu_supplement.texi
> > +++ b/doc/cpu_supplement/cpu_supplement.texi
> > @@ -66,7 +66,6 @@
> > * Atmel AVR Specific Information::
> > * Blackfin Specific Information::
> > * Epiphany Specific Information::
> > -* Renesas H8/300 Specific Information::
> > * Intel/AMD x86 Specific Information::
> > * Lattice Mico32 Specific Information::
> > * Renesas M32C Specific Information::
> > @@ -90,7 +89,6 @@
> > @include avr.texi
> > @include bfin.texi
> > @include epiphany.texi
> > - at include h8300.texi
> > @include i386.texi
> > @include lm32.texi
> > @include m32c.texi
> > diff --git a/doc/cpu_supplement/h8300.t b/doc/cpu_supplement/h8300.t
> > index 8c50ffb..0000000
> > --- a/doc/cpu_supplement/h8300.t
> > +++ /dev/null
> > @@ -1,11 +0,0 @@
> > - at c Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> > - at chapter Renesas H8/300 Specific Information
> > - at section Symmetric Multiprocessing
> > -SMP is not supported.
> > - at section Thread-Local Storage
> > -Thread-local storage is not implemented.
> > diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/
> configure.ac
> > index 4941c51..5ac2dfd 100644
> > --- a/testsuites/libtests/configure.ac
> > +++ b/testsuites/libtests/configure.ac
> > @@ -53,9 +53,6 @@ case $RTEMS_CPU in
> > bfin)
> > HAVE_LIBDL=no ;;
> > - h8300)
> > - HAVE_LIBDL=no ;;
> > lm32)
> > HAVE_LIBDL=no ;;
> > diff --git a/testsuites/psxtests/psx04/task3.c
> b/testsuites/psxtests/psx04/task3.c
> > index 71ac39f..5d4172c 100644
> > --- a/testsuites/psxtests/psx04/task3.c
> > +++ b/testsuites/psxtests/psx04/task3.c
> > @@ -29,7 +29,7 @@ void *Task_3(
> > unsigned int remaining;
> > int status;
> > int sig;
> > - volatile union sigval value; /* should be removed once the H8300
> target is fixed */
> > + volatile union sigval value;
> > sigset_t mask;
> > siginfo_t info;
> > 1.7.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160103/f8dda16a/attachment-0001.html>
