[PATCH] libnetworking/rtems_dhcp.c: Fix improper hostname handling in DHCP request
Mon Jan 4 10:42:49 UTC 2016
On 27/12/15 23:43, Aun-Ali Zaidi wrote:
> From: Tim Cussins <timcussins at eml.cc>
> DHCP requests add the hostname option in dhcp_request_req() - this is cool, except that the dhcp
> spec requires that this option has a length >= 1 char.
> Excerpt taken from RFC 2132:
>     3.14. Host Name Option
>     This option specifies the name of the client.  The name may or may
>     not be qualified with the local domain name (see section 3.17 for the
>     preferred way to retrieve the domain name).  See RFC 1035 for
>     character set restrictions.
>     The code for this option is 12, and its minimum length is 1.
>      Code   Len                 Host Name
>     |  12 |  n  |  h1 |  h2 |  h3 |  h4 |  h5 |  h6 |  ...
> At present, the hostname is added regardless. This appears to trigger a bug in a specific Netgear
> router that causes it's dhcp process to lock up.
> closes #1405.
>   cpukit/libnetworking/rtems/rtems_dhcp.c | 16 ++++++++++++----
>   1 file changed, 12 insertions(+), 4 deletions(-)
> diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
> index cb6966d..5b8fe32 100644
> --- a/cpukit/libnetworking/rtems/rtems_dhcp.c
> +++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
> @@ -681,10 +681,18 @@ dhcp_request_req (struct dhcp_packet* call,
>       if (gethostname (hostname, MAXHOSTNAMELEN) == 0)
> -      call->vend[len++] = DHCP_HOST;
> -      call->vend[len++] = strlen (hostname);
> -      strcpy ((char*) &call->vend[len], hostname);
> -      len += strlen (hostname);
> +      /* RFC 2132 Section 3.14 dictates min length for this option is 1 char.
> +         If hostname is zero-length, then let's just not add it */
> +      int hostnamelen = strlen(hostname);
The return type of strlen() is size_t. Incorrect style for this
function, use strlen (hostname).
> +      if ( (hostnamelen > 0) && (hostnamelen < 256) )
Superfluous parenthesis.
> +        call->vend[len++] = DHCP_HOST;
> +	call->vend[len++] = (uint8_t) hostnamelen;
> +	strcpy ((char *) &call->vend[len], hostname);
Better use memcpy() if you already know the length of the string.
> +	len += hostnamelen;
>       free (hostname, 0);
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
