RSB rtems-4.12 gcc-6 dependent package version numbers.
Tue Jan 5 09:14:35 UTC 2016
On 5/01/2016 7:48 PM, Sebastian Huber wrote:
> On 05/01/16 09:45, Chris Johns wrote:
>> On 5/01/2016 5:03 PM, Sebastian Huber wrote:
>>> >I used the versions of the contrib/download_prerequisites script of the
>>> >GCC.
>> The pagehttps://gcc.gnu.org/install/prerequisites.html  indicates later
>> versions can be used. I cannot remember the reason these are selected.
>> It may have been partially inherited from the crossrpm scripts and/or
>> some specific host issue.
>> Can they be updated to these version?
> I don't know. I always used the contrib/download_prerequisites script to
> get the dependencies.
Sure. Given 4.11 has been tested on a wide range of hosts I would prefer
to use those versions. I will push a change.
