Many BSPs Fail to link CXX tests
Tue Jan 5 17:29:22 UTC 2016
On Mon, Jan 4, 2016 at 1:23 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Jan 3, 2016 at 11:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Sun, Jan 3, 2016 at 9:47 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > On Sun, Jan 3, 2016 at 8:26 PM, Chris Johns <chrisj at rtems.org> wrote:
>> >> Can you get a suitable list of functions that must be present in the
>> >> executable and check they are present with nm?
>> > It should be simple if the breakage is between the entry point and the
>> > rest
>> > of the BSP. If hello does not include bsp_start() or
>> > rtems_initialize_data_structures(), then it is known to be broken. This
>> > is
>> > what broke on sis -- the first 16 instructions of the start code had no
>> > dependency on anything else. So the linkages were satisfied and nothing
>> > else
>> > pulled in. :)
>> Such a list should be easy enough to create by building every BSP and
>> creating a list of functions appearing in every one (known to run).
> The scripts in rtems-testing/rtems keep a copy of ticker.ralf named
> CPU-BSP-ticker.ralf. For the ones I had laying around that were actually
> in ELF format with symbols still, there were 362 symbols which showed
> up in 68 files (that appears to be the magic maximum number).
> file *.ralf | grep ELF | cut -d':' -f1 | while read f
> do
>   target=`echo $f | cut -d'-' -f1`
>   mynm=${target}rtems4.12-nm
>   nm -g ${f} | grep " T " | cut -d' ' -f3
> done | sort | uniq -c | sort -n
https://codein.withgoogle.com/dashboard/tasks/4928162941108224/
Perhaps a GCI student will write something suitable to use for sanity checking.
