[PATCH 1/2] score: Add fatal errors for NULL entry init tasks
Sebastian Huber
Thu Jan 7 09:11:47 UTC 2016
This simplifies the global construction.
Update #2514.
cpukit/posix/src/pthreadinitthreads.c | 13 ++++++++++---
cpukit/rtems/src/taskinitusers.c | 14 +++++++++++---
cpukit/sapi/src/interrtext.c | 6 ++++--
cpukit/score/include/rtems/score/interr.h | 4 +++-
testsuites/psxtests/psxfatal01/testcase.h | 5 +++--
testsuites/sptests/spfatal02/testcase.h | 7 ++++---
testsuites/sptests/spinternalerror02/init.c | 6 ++++--
testsuites/sptests/spinternalerror02/spinternalerror02.scn | 5 ++++-
8 files changed, 43 insertions(+), 17 deletions(-)
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index 3379b79..9842316 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -44,7 +44,7 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
pthread_t thread_id;
pthread_attr_t attr;
bool register_global_construction;
- void *(*thread_entry)(void *);
+ Thread_Entry_pointer thread_entry;
user_threads = Configuration_POSIX_API.User_initialization_threads_table;
maximum = Configuration_POSIX_API.number_of_initialization_threads;
@@ -74,10 +74,17 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
_Assert( eno == 0 );
thread_entry = user_threads[ index ].thread_entry;
+ if ( thread_entry == NULL ) {
+ _Terminate(
+ INTERNAL_ERROR_CORE,
+ false,
+ INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
- if ( register_global_construction && thread_entry != NULL ) {
+ if ( register_global_construction ) {
register_global_construction = false;
- thread_entry = (void *(*)(void *)) _Thread_Global_construction;
+ thread_entry = (Thread_Entry_pointer) _Thread_Global_construction;
eno = pthread_create(
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 490ddc7..46d0af3 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -24,6 +24,7 @@
#include <rtems/rtems/modes.h>
#include <rtems/rtems/rtemsapi.h>
+#include <rtems/score/assert.h>
#include <rtems/score/stack.h>
@@ -81,8 +82,15 @@ void _RTEMS_tasks_Initialize_user_tasks_body( void )
_Terminate( INTERNAL_ERROR_RTEMS_API, true, return_value );
entry_point = user_tasks[ index ].entry_point;
+ if ( entry_point == NULL ) {
+ _Terminate(
+ false,
+ INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
- if ( register_global_construction && entry_point != NULL ) {
entry_point = (rtems_task_entry) _Thread_Global_construction;
@@ -92,7 +100,7 @@ void _RTEMS_tasks_Initialize_user_tasks_body( void )
entry_point,
user_tasks[ index ].argument
- if ( !rtems_is_status_successful( return_value ) )
- _Terminate( INTERNAL_ERROR_RTEMS_API, true, return_value );
+ _Assert( rtems_is_status_successful( return_value ) );
+ (void) return_value;
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 09bc215..3a0681d 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -7,7 +7,7 @@
- * Copyright (c) 2012-2014 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2012-2015 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
* Dornierstr. 4
@@ -52,7 +52,9 @@ static const char *const internal_error_text[] = {
"INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
"INTERNAL_ERROR_NO_MEMORY_FOR_HEAP",
"INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR",
- "INTERNAL_ERROR_RESOURCE_IN_USE"
+ "INTERNAL_ERROR_RESOURCE_IN_USE",
+ "INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL",
+ "INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL"
const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index f09d6e9..ea468e0 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -161,7 +161,9 @@ typedef enum {
INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED,
INTERNAL_ERROR_NO_MEMORY_FOR_HEAP,
INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR,
- INTERNAL_ERROR_RESOURCE_IN_USE
+ INTERNAL_ERROR_RESOURCE_IN_USE,
+ INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL,
} Internal_errors_Core_list;
typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/testsuites/psxtests/psxfatal01/testcase.h b/testsuites/psxtests/psxfatal01/testcase.h
index 2426e7b..b400fa6 100644
--- a/testsuites/psxtests/psxfatal01/testcase.h
+++ b/testsuites/psxtests/psxfatal01/testcase.h
@@ -27,9 +27,10 @@ posix_initialization_threads_table POSIX_Initialization_threads[] = {
#define FATAL_ERROR_TEST_NAME "1"
#define FATAL_ERROR_DESCRIPTION \
"POSIX API Init thread create failure - NULL entry"
-#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_POSIX_API
+#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
-#define FATAL_ERROR_EXPECTED_ERROR ((POSIX_FD_PTHREAD << 8) | EFAULT)
+#define FATAL_ERROR_EXPECTED_ERROR \
void force_error(void)
diff --git a/testsuites/sptests/spfatal02/testcase.h b/testsuites/sptests/spfatal02/testcase.h
index 9043701..bd9ac67 100644
--- a/testsuites/sptests/spfatal02/testcase.h
+++ b/testsuites/sptests/spfatal02/testcase.h
@@ -24,9 +24,10 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
#define FATAL_ERROR_TEST_NAME "2"
#define FATAL_ERROR_DESCRIPTION "Classic API Init task start failure"
-#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_RTEMS_API
-#define FATAL_ERROR_EXPECTED_IS_INTERNAL TRUE
-#define FATAL_ERROR_EXPECTED_ERROR RTEMS_INVALID_ADDRESS
+#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
void force_error()
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 5d1d26f..cbc81a5 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -1,5 +1,5 @@
* Donierstr. 4
@@ -35,7 +35,9 @@ static void test_internal_error_text(void)
puts( text );
} while ( text != text_last );
- rtems_test_assert( error - 3 == INTERNAL_ERROR_RESOURCE_IN_USE );
+ rtems_test_assert(
+ error - 3 == INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
static void test_fatal_source_text(void)
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.scn b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
index 1159654..c6e85b1 100644
--- a/testsuites/sptests/spinternalerror02/spinternalerror02.scn
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
@@ -1,4 +1,4 @@
-*** TEST SPINTERNALERROR 2 ***
+*** BEGIN OF TEST SPINTERNALERROR 2 ***
INTERNAL_ERROR_NO_CONFIGURATION_TABLE
INTERNAL_ERROR_NO_CPU_TABLE
INTERNAL_ERROR_TOO_LITTLE_WORKSPACE
@@ -24,6 +24,9 @@ INTERNAL_ERROR_GXX_KEY_ADD_FAILED
+INTERNAL_ERROR_RESOURCE_IN_USE
+INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
+INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
INTERNAL_ERROR_CORE
1.8.4.5
