[PATCH 1/2] rtemstoolkit: Python 3 compatibility
Fri Jan 8 09:03:43 UTC 2016
On 8/01/2016 7:50 PM, Sebastian Huber wrote:
> On 08/01/16 08:00, Sebastian Huber wrote:
>>   rtemstoolkit/execute.py | 2 +-
>>   1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
>> index 4125182..0344e51 100755
>> --- a/rtemstoolkit/execute.py
>> +++ b/rtemstoolkit/execute.py
>> @@ -177,7 +177,7 @@ class execute(object):
>>                           break
>>                       #print '))))) %02x "%s"' % (ord(data), data)
>>                       for c in data:
>> -                        line += c
>> +                        line += str(c)
>>                           if c == '\n':
>>                               count += 1
>>                               _output_line(line, exe, prefix, out, count)
> I am not sure if this fix is correct. Python 3 refuses to accept the
> previous code since implicit int to str conversions are forbidden.
The code looks fine to me.
What is the error?
Can you print the type of 'c'?
