[PATCH 1/2] score: Introduce Thread_Entry_information
Fri Jan 8 14:56:48 UTC 2016
On Fri, Jan 8, 2016 at 9:39 AM, Sebastian Huber
> On 08/01/16 15:37, Sebastian Huber wrote:
>> diff --git a/cpukit/score/include/rtems/score/thread.h
>> b/cpukit/score/include/rtems/score/thread.h
>> index 6e937e3..37f9f4b 100644
>> --- a/cpukit/score/include/rtems/score/thread.h
>> +++ b/cpukit/score/include/rtems/score/thread.h
>> @@ -89,16 +89,6 @@ extern "C" {
>>   typedef Timestamp_Control Thread_CPU_usage_t;
>> - *  The following defines the "return type" of a thread.
>> - *  @note  This cannot always be right.  Some APIs have void
>> - *         tasks/threads, others return pointers, others may
>> - *         return a numeric value.  Hopefully a pointer is
>> - *         always at least as big as an uint32_t  .:)
>> -typedef void *Thread;
>>    *  @brief Type of the numeric argument of a thread entry function with
>> at
>>    *  least one numeric argument.
> I am not sure if we should keep this supposed to be internal type for
> backward compatibility. It was used in idle thread prototypes.
I think the elimination is fine. Maybe needs to be clearly documented
in release notes if there is a breakage implied in some user BSPs that
might have used it.
If i understood the patch correctly you are separating out the 3 cases
of kinds of thread entry arguments and providing explicit struct for
each one so they can be type-checked? Looks good to me.
> devel mailing list
> devel at rtems.org
