[PATCH 1/2] rtemstoolkit: Python 3 compatibility
    Chris Johns
    chrisj at rtems.org
    Mon Jan 11 00:58:33 UTC 2016
On 08/01/2016 20:10, Sebastian Huber wrote:
>> Can you print the type of 'c'?
> <class 'int'>
This implies the input stream on Windows is binary in this case and not
text and so the stream is ints. I suspect the fix here is more
complicated if the data is some form of unicode format. I suppose the
str() conversion is ok until we get reports it is not.
