Rtems-test cortex-m3
Mon Jan 11 06:47:41 UTC 2016
On 08/01/16 17:41, Aurelio Remonda wrote:
> Thanks for your answers! I am running the tests for
> realview_pbx_a9_qemu for the moment.
> I have a few questions if you don't mind
> With the git repository version of rtems
> ./rtems-test --log=realview_pbx_a9_qemu
> --rtems-bsp=realview_pbx_a9_qemu
> --rtems-tools=/home/aurelio-remonda/rtems_a9/install
> /home/aurelio-remonda/rtems_a9/build/arm-rtems4.11/c/realview_pbx_a9_qemu/testsuites/
> The result is:
> Passed:   523
> Failed:     4
> Timeouts:   6
> Invalid:    0
> Total:    533
> Failures:
>   sp69.exe
>   psxcleanup02.exe
>   sptimecounter02.exe
>   psxcancel.exe
> Timeouts:
>   psxintrcritical01.exe
>   spintrcritical11.exe
>   spintrcritical07.exe
>   spintrcritical12.exe
>   spintrcritical06.exe
>   spintrcritical15.exe
> Average test time: 0:00:01.244372
> Testing time     : 0:11:03.250308
> Are those expected fails?
Yes, one issue is that timing related tests work bad on Qemu.
> On the other hand:
> When i try to run with the version of rtems we use:
> --rtems-tools=/home/aurelio-remonda/rtems_gnc/install
> /home/aurelio-remonda/rtems_gnc/build/arm-rtems4.11/c/realview_pbx_a9_qemu/testsuites/
> I get:
> error: unknown application load error.
> Any hints of what is the problem?
I would run Qemu in the debugger to figure out the exact error.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
