Problem with system time in lpc176x bsp
Mon Jan 11 19:18:21 UTC 2016
Hello,
I already created a ticket which blocks the 4.11 release for this bug:
https://devel.rtems.org/ticket/2502
I sent a new version of the patch to one of your previous threads some days ago:
https://lists.rtems.org/pipermail/devel/2016-January/013289.html
There is still a bug in it, since we must disable interrupts in the is pending function, but the general approach should work.
----- Am 11. Jan 2016 um 20:05 schrieb Marcos Díaz marcos.diaz at tallertechnologies.com:
> I made a fast search:
> These BSPs use *rtems_timecounter_simple_downcounter*:
> arm/shared/armv7m
> m68k/mcf52235
> m68k/mcf5225x
> m68k/mcf5329
> m68k/uC5282
> powerpc/mpc55xxevb
> sparc/erc32
> sparc/leon2
> sparc/leon3
> sparc/shared
> These use *rtems_timecounter_simple_upcounter*:
> powerpc/mpc55xxevb
> arm/lpc22xx
> We should search a little more for the other changes but at least these
> BSPs will be affected. Maybe we should wait Sebastian's opinion, since he
> suggested the change in timecounter's signatures.
> On Mon, Jan 11, 2016 at 3:44 PM, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Jan 11, 2016 at 12:28 PM, Marcos Díaz <
>> marcos.diaz at tallertechnologies.com> wrote:
>>> I will issue a ticket. But I noticed that in my patch I include changes
>>> to common code that Sebastian suggested, and this will break any other BSP
>>> that uses rtems timecounter simple downcounter or upcounter, since these
>>> function's signatures changed. Should we update all BSPs? Or make changes
>>> more locally to our BSP?  Meanwhile please do not apply the patch I sent.
>> I would prefer not to ship BSPs with bugs but fixing them comes with risks.
>> So I would lean to the same fix on the master and 4.11 branch fixing it
>> where it needs to be fixed.
>> What BSPs does this change impact?
>> --joel
>>> On Mon, Jan 11, 2016 at 3:16 PM, Joel Sherrill <joel at rtems.org> wrote:
>>>> At this point, a ticket is needed for anything applied to 4.11 that is
>>>> not release
>>>> mechanics related.
>>>> --joel
>>>> On Mon, Jan 11, 2016 at 11:47 AM, Marcos Diaz <
>>>>> Hi Sebastian,
>>>>> we did some more testing and found out what's causing the problem.
>>>>> Based on what
>>>>> I posted at
>>>>> https://lists.rtems.org/pipermail/devel/2015-December/013235.html,
>>>>> the problem arises when the ticker interrupt occurs while a task is
>>>>> executing
>>>>> one of the instructions that make up the following line:
>>>>> is_count_pending = (systick->csr & ARMV7M_SYSTICK_CSR_COUNTFLAG) != 0;
>>>>> which compiling with -O3 are:
>>>>> ldr.w r3, [r9]
>>>>> ubfx r5, r3, #16, #1
>>>>> strb.w r5, [r8, #64]
>>>>> If the SysTick counts to 0 and the ldr executes before the interrupt
>>>>> occurs,
>>>>> R3 will have the CSR.COUNTFLAG bit set. Even though _ARMV7M_TC_at_tick
>>>>> will
>>>>> clear the is_count_pending boolean, the task will still see it as true.
>>>>> The solution we found is to simply disable interrupts while reading
>>>>> that flag.
>>>>> We also use a local variable inside _ARMV7M_TC_is_pending instead of
>>>>> directly
>>>>> returning the current value of the is_count_pending global, just in
>>>>> case.
>>>>> Here's the patch that fixes it; this applies to the 4.11 branch.
>>>>> Do we have to open a new thread for it to be applied to the mainline,
>>>>> or will
>>>>> this suffice? Should we open a ticket for 4.11?
>>>>>  .../arm/shared/armv7m/clock/armv7m-clock-config.c  | 38
>>>>>  c/src/lib/libbsp/shared/clockdrv_shell.h           | 16 ++++++++-
>>>>>  cpukit/rtems/src/clocktick.c                       |  6 +++-
>>>>>  cpukit/sapi/include/rtems/timecounter.h            | 35
>>>>>  cpukit/score/include/rtems/score/timecounter.h     | 37
>>>>>  cpukit/score/src/kern_tc.c                         | 16 ++++-----
>>>>>  doc/bsp_howto/clock.t                              | 13 +++++++-
>>>>>  7 files changed, 130 insertions(+), 31 deletions(-)
>>>>> diff --git
>>>>> a/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
>>>>> b/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
>>>>> index e78684c..53bd7cf 100644
>>>>> --- a/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
>>>>> +++ b/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
>>>>> @@ -25,6 +25,8 @@ static void Clock_isr(void *arg);
>>>>>  static rtems_timecounter_simple _ARMV7M_TC;
>>>>> +static bool is_count_pending = false;
>>>>>  static uint32_t _ARMV7M_TC_get(rtems_timecounter_simple *tc)
>>>>>    volatile ARMV7M_Systick *systick = _ARMV7M_Systick;
>>>>> @@ -34,9 +36,20 @@ static uint32_t
>>>>>  static bool _ARMV7M_TC_is_pending(rtems_timecounter_simple *tc)
>>>>> -  volatile ARMV7M_SCB *scb = _ARMV7M_SCB;
>>>>> +  volatile ARMV7M_Systick *systick = _ARMV7M_Systick;
>>>>> +  ISR_lock_Context lock_context;
>>>>> +  _Timecounter_Acquire( &lock_context );
>>>>> +  /* We use this bool since the hardware flag is reset each time it is
>>>>> read. */
>>>>> +  if (!is_count_pending)
>>>>> +    is_count_pending = ((systick->csr & ARMV7M_SYSTICK_CSR_COUNTFLAG)
>>>>> != 0 );
>>>>> -  return ((scb->icsr & ARMV7M_SCB_ICSR_PENDSTSET) != 0);
>>>>> +  const bool is_pending_local = is_count_pending;
>>>>> +  _Timecounter_Release( &lock_context );
>>>>> +  return is_pending_local;
>>>>>  static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *tc)
>>>>> @@ -48,19 +61,23 @@ static uint32_t _ARMV7M_TC_get_timecount(struct
>>>>> timecounter *tc)
>>>>> -static void _ARMV7M_TC_tick(void)
>>>>> -  rtems_timecounter_simple_downcounter_tick(&_ARMV7M_TC,
>>>>> _ARMV7M_TC_get);
>>>>> -static void _ARMV7M_Systick_at_tick(void)
>>>>> +static void _ARMV7M_TC_at_tick(rtems_timecounter_simple *tc)
>>>>> +  is_count_pending = false;
>>>>>    /* Clear COUNTFLAG */
>>>>>    systick->csr;
>>>>> +static void _ARMV7M_TC_tick(void)
>>>>> +  rtems_timecounter_simple_downcounter_tick(
>>>>> +    &_ARMV7M_TC,
>>>>> +    _ARMV7M_TC_get,
>>>>> +    _ARMV7M_TC_at_tick
>>>>>  static void _ARMV7M_Systick_handler(void)
>>>>>    _ARMV7M_Interrupt_service_enter();
>>>>> @@ -111,9 +128,6 @@ static void _ARMV7M_Systick_cleanup(void)
>>>>>  #define Clock_driver_timecounter_tick() _ARMV7M_TC_tick()
>>>>> -#define Clock_driver_support_at_tick() \
>>>>> -  _ARMV7M_Systick_at_tick()
>>>>>  #define Clock_driver_support_initialize_hardware() \
>>>>>    _ARMV7M_Systick_initialize()
>>>>> diff --git a/c/src/lib/libbsp/shared/clockdrv_shell.h
>>>>> b/c/src/lib/libbsp/shared/clockdrv_shell.h
>>>>> index d546fb8..96b962f 100644
>>>>> --- a/c/src/lib/libbsp/shared/clockdrv_shell.h
>>>>> +++ b/c/src/lib/libbsp/shared/clockdrv_shell.h
>>>>> @@ -44,6 +44,13 @@
>>>>>    #define Clock_driver_support_find_timer()
>>>>>  #endif
>>>>> + * @brief Do nothing by default.
>>>>> +#ifndef Clock_driver_support_at_tick
>>>>> +  #define Clock_driver_support_at_tick()
>>>>> +#endif
>>>>>   * A specialized clock driver may use for example
>>>>> rtems_timecounter_tick_simple()
>>>>>   * instead of the default.
>>>>> @@ -108,7 +115,14 @@ rtems_isr Clock_isr(
>>>>>            && _Thread_Executing->Start.entry_point
>>>>>              == (Thread_Entry) rtems_configuration_get_idle_task()
>>>>> -        _Timecounter_Tick_simple(interval,
>>>>> (*tc->tc_get_timecount)(tc));
>>>>> +        _Timecounter_Acquire(&lock_context);
>>>>> +        _Timecounter_Tick_simple(
>>>>> +          interval,
>>>>> +          (*tc->tc_get_timecount)(tc),
>>>>> +          &lock_context
>>>>>        Clock_driver_support_at_tick();
>>>>> diff --git a/cpukit/rtems/src/clocktick.c b/cpukit/rtems/src/clocktick.c
>>>>> index e2cd35f..a6bf26d 100644
>>>>> --- a/cpukit/rtems/src/clocktick.c
>>>>> +++ b/cpukit/rtems/src/clocktick.c
>>>>> @@ -23,9 +23,13 @@
>>>>>  rtems_status_code rtems_clock_tick( void )
>>>>>      rtems_configuration_get_microseconds_per_tick(),
>>>>> -    0
>>>>> +    0,
>>>>> +    &lock_context
>>>>>    return RTEMS_SUCCESSFUL;
>>>>> diff --git a/cpukit/sapi/include/rtems/timecounter.h
>>>>> b/cpukit/sapi/include/rtems/timecounter.h
>>>>> index 04bc534..06b3973 100644
>>>>> --- a/cpukit/sapi/include/rtems/timecounter.h
>>>>> +++ b/cpukit/sapi/include/rtems/timecounter.h
>>>>> @@ -94,6 +94,13 @@ typedef struct {
>>>>>  } rtems_timecounter_simple;
>>>>> + * @brief At tick handling done under protection of the timecounter
>>>>> lock.
>>>>> +typedef uint32_t rtems_timecounter_simple_at_tick(
>>>>> +  rtems_timecounter_simple *tc
>>>>>   * @brief Returns the current value of a simple timecounter.
>>>>>  typedef uint32_t rtems_timecounter_simple_get(
>>>>> @@ -199,20 +206,28 @@ RTEMS_INLINE_ROUTINE uint32_t
>>>>> rtems_timecounter_simple_scale(
>>>>>   * @param[in] tc The simple timecounter.
>>>>>   * @param[in] get The method to get the value of the simple
>>>>> timecounter.
>>>>> + * @param[in] at_tick The method to perform work under timecounter lock
>>>>> + * protection at this tick, e.g. clear a pending flag.
>>>>>  RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick(
>>>>> -  rtems_timecounter_simple     *tc,
>>>>> -  rtems_timecounter_simple_get  get
>>>>> +  rtems_timecounter_simple         *tc,
>>>>> +  rtems_timecounter_simple_get      get,
>>>>> +  rtems_timecounter_simple_at_tick  at_tick
>>>>>    uint32_t current;
>>>>> +  ( *at_tick )( tc );
>>>>>    current = rtems_timecounter_simple_scale(
>>>>>      tc,
>>>>>      tc->real_interval - ( *get )( tc )
>>>>> -  _Timecounter_Tick_simple( tc->binary_interval, current );
>>>>> +  _Timecounter_Tick_simple( tc->binary_interval, current,
>>>>> &lock_context );
>>>>> @@ -220,17 +235,25 @@ RTEMS_INLINE_ROUTINE void
>>>>> timecounter.
>>>>>  RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_upcounter_tick(
>>>>>    uint32_t current;
>>>>>    current = rtems_timecounter_simple_scale( tc, ( *get )( tc ) );
>>>>> &lock_context );
>>>>> diff --git a/cpukit/score/include/rtems/score/timecounter.h
>>>>> b/cpukit/score/include/rtems/score/timecounter.h
>>>>> index 0d17cc7..0e611b5 100644
>>>>> --- a/cpukit/score/include/rtems/score/timecounter.h
>>>>> +++ b/cpukit/score/include/rtems/score/timecounter.h
>>>>> @@ -26,6 +26,8 @@
>>>>>  #include <sys/time.h>
>>>>>  #include <sys/timetc.h>
>>>>> +#include <rtems/score/isrlock.h>
>>>>>  #ifdef __cplusplus
>>>>>  extern "C" {
>>>>>  #endif /* __cplusplus */
>>>>> @@ -161,6 +163,31 @@ void _Timecounter_Install( struct timecounter *tc
>>>>>  void _Timecounter_Tick( void );
>>>>> + * @brief Lock to protect the timecounter mechanic.
>>>>> +ISR_LOCK_DECLARE( extern, _Timecounter_Lock )
>>>>> + * @brief Acquires the timecounter lock.
>>>>> + * @param[in] lock_context The lock context.
>>>>> + * See _Timecounter_Tick_simple().
>>>>> +#define _Timecounter_Acquire( lock_context ) \
>>>>> +  _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
>>>>> + * @brief Releases the timecounter lock.
>>>>> +#define _Timecounter_Release(lock_context) \
>>>>> +  _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
>>>>>   * @brief Performs a simple timecounter tick.
>>>>>   * This is a special purpose tick function for simple timecounter to
>>>>> support
>>>>> @@ -169,8 +196,14 @@ void _Timecounter_Tick( void );
>>>>>   * @param[in] delta The time in timecounter ticks elapsed since the
>>>>> last call
>>>>>   * to _Timecounter_Tick_simple().
>>>>>   * @param[in] offset The current value of the timecounter.
>>>>> -void _Timecounter_Tick_simple( uint32_t delta, uint32_t offset );
>>>>> + * @param[in] lock_context The lock context of the corresponding
>>>>> + * _Timecounter_Acquire().
>>>>> +void _Timecounter_Tick_simple(
>>>>> +  uint32_t delta,
>>>>> +  uint32_t offset,
>>>>> +  ISR_lock_Context *lock_context
>>>>>   * @brief The wall clock time in seconds.
>>>>> diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
>>>>> index f6a1136..4257533 100644
>>>>> --- a/cpukit/score/src/kern_tc.c
>>>>> +++ b/cpukit/score/src/kern_tc.c
>>>>> @@ -64,7 +64,9 @@ __FBSDID("$FreeBSD r284178 2015-06-09T11:49:56Z$");
>>>>>  #ifdef __rtems__
>>>>>  #include <limits.h>
>>>>>  #include <rtems.h>
>>>>> -ISR_LOCK_DEFINE(static, _Timecounter_Lock, "Timecounter");
>>>>> +ISR_LOCK_DEFINE(, _Timecounter_Lock, "Timecounter")
>>>>>  #define hz rtems_clock_get_ticks_per_second()
>>>>>  #define printf(...)
>>>>>  #define log(...)
>>>>> @@ -1383,7 +1385,7 @@ tc_windup(void)
>>>>>  #ifdef __rtems__
>>>>> -       _ISR_lock_ISR_disable_and_acquire(&_Timecounter_Lock,
>>>>> &lock_context);
>>>>>  #endif /* __rtems__ */
>>>>> @@ -1538,7 +1540,7 @@ tc_windup(void)
>>>>>         timekeep_push_vdso();
>>>>>  #ifdef __rtems__
>>>>> -       _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock,
>>>>> &lock_context);
>>>>> +       _Timecounter_Release(&lock_context);
>>>>> @@ -1963,14 +1965,12 @@ _Timecounter_Tick(void)
>>>>>  #ifdef __rtems__
>>>>>  void
>>>>> -_Timecounter_Tick_simple(uint32_t delta, uint32_t offset)
>>>>> +_Timecounter_Tick_simple(uint32_t delta, uint32_t offset,
>>>>> +    ISR_lock_Context *lock_context)
>>>>>         struct bintime bt;
>>>>>         struct timehands *th;
>>>>>         uint32_t ogen;
>>>>> -       ISR_lock_Context lock_context;
>>>>> &lock_context);
>>>>>         th = timehands;
>>>>>         ogen = th->th_generation;
>>>>> @@ -1997,7 +1997,7 @@ _Timecounter_Tick_simple(uint32_t delta, uint32_t
>>>>> offset)
>>>>>         time_second = th->th_microtime.tv_sec;
>>>>>         time_uptime = th->th_offset.sec;
>>>>> &lock_context);
>>>>> +       _Timecounter_Release(lock_context);
>>>>>         _Watchdog_Tick();
>>>>> diff --git a/doc/bsp_howto/clock.t b/doc/bsp_howto/clock.t
>>>>> index f58b898..2891bb2 100644
>>>>> --- a/doc/bsp_howto/clock.t
>>>>> +++ b/doc/bsp_howto/clock.t
>>>>> @@ -89,6 +89,13 @@ static uint32_t some_tc_get(
>>>>> rtems_timecounter_simple *tc )
>>>>>    return some.counter;
>>>>> +static void some_tc_at_tick( rtems_timecounter_simple *tc )
>>>>> +   * Do work necessary at the clock tick interrupt, e.g. clear a
>>>>> pending flag.
>>>>>  static bool some_tc_is_pending( rtems_timecounter_simple *tc )
>>>>>    return some.is_pending;
>>>>> @@ -105,7 +112,11 @@ static uint32_t some_tc_get_timecount( struct
>>>>> timecounter *tc )
>>>>>  static void some_tc_tick( void )
>>>>> -  rtems_timecounter_simple_downcounter_tick( &some_tc, some_tc_get );
>>>>> +    &some_tc,
>>>>> +    some_tc_get,
>>>>> +    some_tc_at_tick
>>>>>  static void some_support_initialize_hardware( void )
>>>>> 2.7.0
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> <http://www.tallertechnologies.com>
>>> Marcos Díaz
>>> Software Engineer
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Córdoba, Argentina
>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>> Skype: markdiaz22
> Marcos Díaz
> Software Engineer
> Córdoba, Argentina
> Skype: markdiaz22
