[PATCH v3] score: Fix simple timecounter support
Sebastian Huber
Tue Jan 12 10:21:19 UTC 2016
Update #2502.
.../arm/shared/armv7m/clock/armv7m-clock-config.c | 51 ++++++++++++++++------
c/src/lib/libbsp/m68k/mcf52235/clock/clock.c | 19 ++++----
c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c | 19 ++++----
c/src/lib/libbsp/m68k/mcf5329/clock/clock.c | 19 ++++----
c/src/lib/libbsp/m68k/uC5282/clock/clock.c | 29 ++++++------
.../libbsp/powerpc/mpc55xxevb/clock/clock-config.c | 34 +++++++++------
c/src/lib/libbsp/shared/clockdrv_shell.h | 16 ++++++-
c/src/lib/libbsp/sparc/erc32/clock/ckinit.c | 10 +++--
c/src/lib/libbsp/sparc/leon2/clock/ckinit.c | 13 ++++--
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 31 +++++++------
c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c | 9 +++-
c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c | 32 ++++++++------
cpukit/rtems/src/clocktick.c | 6 ++-
cpukit/sapi/include/rtems/timecounter.h | 35 ++++++++++++---
cpukit/score/include/rtems/score/timecounter.h | 27 +++++++++++-
cpukit/score/src/kern_tc.c | 16 +++----
doc/bsp_howto/clock.t | 13 +++++-
17 files changed, 256 insertions(+), 123 deletions(-)
diff --git a/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c b/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
index e78684c..d481c44 100644
--- a/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
+++ b/c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c
@@ -23,7 +23,12 @@
/* This is defined in clockdrv_shell.h */
static void Clock_isr(void *arg);
-static rtems_timecounter_simple _ARMV7M_TC;
+typedef struct {
+ rtems_timecounter_simple base;
+ bool countflag;
+} ARMV7M_Timecounter;
+static ARMV7M_Timecounter _ARMV7M_TC;
static uint32_t _ARMV7M_TC_get(rtems_timecounter_simple *tc)
@@ -32,11 +37,25 @@ static uint32_t _ARMV7M_TC_get(rtems_timecounter_simple *tc)
return systick->cvr;
-static bool _ARMV7M_TC_is_pending(rtems_timecounter_simple *tc)
+static bool _ARMV7M_TC_is_pending(rtems_timecounter_simple *base)
- volatile ARMV7M_SCB *scb = _ARMV7M_SCB;
+ ARMV7M_Timecounter *tc = (ARMV7M_Timecounter *) base;
+ rtems_interrupt_level level;
+ bool countflag;
+ rtems_interrupt_disable(level);
+ countflag = tc->countflag;
+ if (!countflag) {
+ volatile ARMV7M_Systick *systick = _ARMV7M_Systick;
+ countflag = ((systick->csr & ARMV7M_SYSTICK_CSR_COUNTFLAG) != 0);
+ tc->countflag = countflag;
+ rtems_interrupt_enable(level);
- return ((scb->icsr & ARMV7M_SCB_ICSR_PENDSTSET) != 0);
+ return countflag;
static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *tc)
@@ -48,19 +67,26 @@ static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *tc)
-static void _ARMV7M_TC_tick(void)
- rtems_timecounter_simple_downcounter_tick(&_ARMV7M_TC, _ARMV7M_TC_get);
-static void _ARMV7M_Systick_at_tick(void)
+static void _ARMV7M_TC_at_tick(rtems_timecounter_simple *base)
+ tc->countflag = false;
/* Clear COUNTFLAG */
systick->csr;
+static void _ARMV7M_TC_tick(void)
+ rtems_timecounter_simple_downcounter_tick(
+ &_ARMV7M_TC.base,
+ _ARMV7M_TC_get,
+ _ARMV7M_TC_at_tick
static void _ARMV7M_Systick_handler(void)
_ARMV7M_Interrupt_service_enter();
@@ -95,7 +121,7 @@ static void _ARMV7M_Systick_initialize(void)
| ARMV7M_SYSTICK_CSR_CLKSOURCE;
rtems_timecounter_simple_install(
- &_ARMV7M_TC,
+ &_ARMV7M_TC.base,
freq,
interval,
@@ -111,9 +137,6 @@ static void _ARMV7M_Systick_cleanup(void)
#define Clock_driver_timecounter_tick() _ARMV7M_TC_tick()
-#define Clock_driver_support_at_tick() \
- _ARMV7M_Systick_at_tick()
#define Clock_driver_support_initialize_hardware() \
_ARMV7M_Systick_initialize()
diff --git a/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c b/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
index fdc1ed6..4b5f4af 100644
--- a/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
@@ -32,18 +32,19 @@ static uint32_t mcf52235_tc_get_timecount(struct timecounter *tc)
-static void mcf52235_tc_tick(void)
+static void mcf52235_tc_at_tick(rtems_timecounter_simple *tc)
- rtems_timecounter_simple_downcounter_tick(&mcf52235_tc, mcf52235_tc_get);
+ MCF_PIT1_PCSR |= MCF_PIT_PCSR_PIF;
- * Periodic interval timer interrupt handler
- do { \
- MCF_PIT1_PCSR |= MCF_PIT_PCSR_PIF; \
- } while (0) \
+static void mcf52235_tc_tick(void)
+ &mcf52235_tc,
+ mcf52235_tc_get,
+ mcf52235_tc_at_tick
* Attach clock interrupt handler
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c b/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
index 743bd1f..ee97e50 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
@@ -32,18 +32,19 @@ static uint32_t mcf5225x_tc_get_timecount(struct timecounter *tc)
-static void mcf5225x_tc_tick(void)
+static void mcf5225x_tc_at_tick(rtems_timecounter_simple *tc)
- rtems_timecounter_simple_downcounter_tick(&mcf5225x_tc, mcf5225x_tc_get);
- do { \
- } while (0) \
+static void mcf5225x_tc_tick(void)
+ &mcf5225x_tc,
+ mcf5225x_tc_get,
+ mcf5225x_tc_at_tick
diff --git a/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c b/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
index 94c5bb0..5741b30 100644
--- a/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
@@ -32,18 +32,19 @@ static uint32_t mcf5329_tc_get_timecount(struct timecounter *tc)
-static void mcf5329_tc_tick(void)
+static void mcf5329_tc_at_tick(rtems_timecounter_simple *tc)
- rtems_timecounter_simple_downcounter_tick(&mcf5329_tc, mcf5329_tc_get);
+ MCF_PIT3_PCSR |= MCF_PIT_PCSR_PIF;
- do { \
- MCF_PIT3_PCSR |= MCF_PIT_PCSR_PIF; \
- } while (0) \
+static void mcf5329_tc_tick(void)
+ &mcf5329_tc,
+ mcf5329_tc_get,
+ mcf5329_tc_at_tick
diff --git a/c/src/lib/libbsp/m68k/uC5282/clock/clock.c b/c/src/lib/libbsp/m68k/uC5282/clock/clock.c
index 46e045c..68b172a 100644
--- a/c/src/lib/libbsp/m68k/uC5282/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/uC5282/clock/clock.c
@@ -42,9 +42,23 @@ static uint32_t uC5282_tc_get_timecount(struct timecounter *tc)
+static void uC5282_tc_at_tick(rtems_timecounter_simple *tc)
+ unsigned idle = IDLE_COUNTER;
+ IDLE_COUNTER = 0;
+ if (idle > MAX_IDLE_COUNT)
+ MAX_IDLE_COUNT = idle;
+ FILTERED_IDLE = idle + FILTERED_IDLE - (FILTERED_IDLE>>FILTER_SHIFT);
+ MCF5282_PIT3_PCSR |= MCF5282_PIT_PCSR_PIF;
static void uC5282_tc_tick(void)
- rtems_timecounter_simple_downcounter_tick(&uC5282_tc, uC5282_tc_get);
+ &uC5282_tc,
+ uC5282_tc_get,
+ uC5282_tc_at_tick
@@ -59,19 +73,6 @@ static void uC5282_tc_tick(void)
#define FILTER_SHIFT 6
- do { \
- unsigned idle = IDLE_COUNTER; \
- IDLE_COUNTER = 0; \
- if (idle > MAX_IDLE_COUNT) \
- MAX_IDLE_COUNT = idle; \
- FILTERED_IDLE = idle + FILTERED_IDLE - (FILTERED_IDLE>>FILTER_SHIFT);\
- MCF5282_PIT3_PCSR |= MCF5282_PIT_PCSR_PIF; \
- } while (0)
#define Clock_driver_support_install_isr( _new, _old ) \
diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c b/c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c
index 4de9a52..c0b8905 100644
--- a/c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c
+++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c
@@ -55,18 +55,22 @@ static uint32_t mpc55xx_tc_get_timecount(struct timecounter *tc)
-static void mpc55xx_tc_tick(void)
- rtems_timecounter_simple_upcounter_tick(&mpc55xx_tc, mpc55xx_tc_get);
-static void mpc55xx_clock_at_tick(void)
+static void mpc55xx_tc_at_tick(rtems_timecounter_simple *tc)
union EMIOS_CSR_tag csr = MPC55XX_ZERO_FLAGS;
csr.B.FLAG = 1;
EMIOS.CH [MPC55XX_CLOCK_EMIOS_CHANNEL].CSR.R = csr.R;
+static void mpc55xx_tc_tick(void)
+ rtems_timecounter_simple_upcounter_tick(
+ &mpc55xx_tc,
+ mpc55xx_tc_get,
+ mpc55xx_tc_at_tick
static void mpc55xx_clock_handler_install(rtems_isr_entry isr)
rtems_status_code sc = RTEMS_SUCCESSFUL;
@@ -174,12 +178,7 @@ static uint32_t mpc55xx_tc_get_timecount(struct timecounter *tc)
- rtems_timecounter_simple_downcounter_tick(&mpc55xx_tc, mpc55xx_tc_get);
volatile PIT_RTI_CHANNEL_tag *channel =
&PIT_RTI.CHANNEL [MPC55XX_CLOCK_PIT_CHANNEL];
@@ -188,6 +187,15 @@ static void mpc55xx_clock_at_tick(void)
channel->TFLG.R = tflg.R;
+ &mpc55xx_tc,
+ mpc55xx_tc_get,
@@ -238,8 +246,6 @@ static void mpc55xx_clock_cleanup(void)
#endif
#define Clock_driver_timecounter_tick() mpc55xx_tc_tick()
- mpc55xx_clock_at_tick()
mpc55xx_clock_initialize()
#define Clock_driver_support_install_isr(isr, old_isr) \
diff --git a/c/src/lib/libbsp/shared/clockdrv_shell.h b/c/src/lib/libbsp/shared/clockdrv_shell.h
index ee4cf9c..9bf5d9b 100644
--- a/c/src/lib/libbsp/shared/clockdrv_shell.h
+++ b/c/src/lib/libbsp/shared/clockdrv_shell.h
@@ -44,6 +44,13 @@
#define Clock_driver_support_find_timer()
#endif
+ * @brief Do nothing by default.
+#ifndef Clock_driver_support_at_tick
+ #define Clock_driver_support_at_tick()
+#endif
* A specialized clock driver may use for example rtems_timecounter_tick_simple()
* instead of the default.
@@ -108,7 +115,14 @@ rtems_isr Clock_isr(
&& _Thread_Executing->Start.Entry.Kinds.Idle.entry
== rtems_configuration_get_idle_task()
- _Timecounter_Tick_simple(interval, (*tc->tc_get_timecount)(tc));
+ ISR_lock_Context lock_context;
+ _Timecounter_Acquire(&lock_context);
+ _Timecounter_Tick_simple(
+ interval,
+ (*tc->tc_get_timecount)(tc),
+ &lock_context
Clock_driver_support_at_tick();
diff --git a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
index 46f99a5..f2d493e 100644
--- a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
@@ -36,8 +36,6 @@
#define CLOCK_VECTOR ERC32_TRAP_TYPE( ERC32_INTERRUPT_REAL_TIME_CLOCK )
do { \
_old = set_vector( _new, CLOCK_VECTOR, 1 ); \
@@ -66,11 +64,17 @@ static uint32_t erc32_tc_get_timecount( struct timecounter *tc )
+static void erc32_tc_at_tick( rtems_timecounter_simple *tc )
+ /* Nothing to do */
static void erc32_tc_tick( void )
&erc32_tc,
- erc32_tc_get
+ erc32_tc_get,
+ erc32_tc_at_tick
diff --git a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
index 3dd68e0..6c2cf98 100644
--- a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
@@ -51,9 +51,18 @@ static uint32_t leon2_tc_get_timecount( struct timecounter *tc )
+static void leon2_tc_at_tick( rtems_timecounter_simple *tc )
static void leon2_tc_tick( void )
- rtems_timecounter_simple_downcounter_tick( &leon2_tc, leon2_tc_get );
+ &leon2_tc,
+ leon2_tc_get,
+ leon2_tc_at_tick
@@ -62,8 +71,6 @@ static void leon2_tc_tick( void )
#define CLOCK_VECTOR LEON_TRAP_TYPE( LEON_INTERRUPT_TIMER1 )
do { \
diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
index b82b457..5d645dc 100644
--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
@@ -69,15 +69,6 @@ static uint32_t leon3_tc_get_timecount_irqmp(struct timecounter *tc)
return LEON3_IrqCtrl_Regs->timestamp[0].counter;
-static void leon3_tc_tick(void)
- if (leon3_tc_use_irqmp) {
- rtems_timecounter_tick();
- } else {
- rtems_timecounter_simple_downcounter_tick(&leon3_tc, leon3_tc_get);
static void leon3_clock_profiling_interrupt_delay(void)
#ifdef RTEMS_PROFILING
@@ -111,10 +102,24 @@ static void leon3_clock_profiling_interrupt_delay(void)
#endif
- do { \
- leon3_clock_profiling_interrupt_delay(); \
- } while (0)
+static void leon3_tc_at_tick( rtems_timecounter_simple *tc )
+ leon3_clock_profiling_interrupt_delay();
+static void leon3_tc_tick(void)
+ if (leon3_tc_use_irqmp) {
+ rtems_timecounter_tick();
+ } else {
+ &leon3_tc,
+ leon3_tc_get,
+ leon3_tc_at_tick
#define Adjust_clkirq_for_node() do { clkirq += LEON3_CLOCK_INDEX; } while(0)
diff --git a/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c b/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
index b29f140..d84c037 100644
--- a/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
+++ b/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
@@ -29,7 +29,6 @@
#undef CLOCK_DRIVER_ISRS_PER_TICK
#undef CLOCK_DRIVER_USE_FAST_IDLE
* Number of Clock ticks since initialization
@@ -87,11 +86,17 @@ static uint32_t tlib_tc_get_timecount(struct timecounter *tc)
+static void tlib_tc_at_tick(rtems_timecounter_simple *tc)
+ /* Nothing to do? */
static void tlib_tc_tick(void)
&tlib_tc,
- tlib_tc_get
+ tlib_tc_get,
+ tlib_tc_at_tick
diff --git a/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c b/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c
index 4887d2a..463125b 100644
--- a/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c
+++ b/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c
@@ -45,9 +45,26 @@ static uint32_t lpc22xx_tc_get_timecount(struct timecounter *tc)
+ * When we get the clock interrupt
+ * - clear the interrupt bit?
+ * - restart the timer?
+static void lpc22xx_tc_at_tick(rtems_timecounter_simple *tc)
+ if (!(T0IR & 0x01))
+ return;
+ T0IR = 0x01;
+ VICVectAddr = 0x00;
static void lpc22xx_tc_tick(void)
- rtems_timecounter_simple_upcounter_tick(&lpc22xx_tc, lpc22xx_tc_get);
+ &lpc22xx_tc,
+ lpc22xx_tc_get,
+ lpc22xx_tc_at_tick
/* Replace the first value with the clock's interrupt name. */
@@ -63,19 +80,6 @@ rtems_irq_connect_data clock_isr_data = {
/* use the /shared/clockdrv_shell.h code template */
- * When we get the clock interrupt
- * - clear the interrupt bit?
- * - restart the timer?
- do { \
- if (!(T0IR & 0x01)) \
- return; \
- T0IR = 0x01; \
- VICVectAddr = 0x00; \
- } while(0)
* Installs the clock ISR. You shouldn't need to change this.
diff --git a/cpukit/rtems/src/clocktick.c b/cpukit/rtems/src/clocktick.c
index e2cd35f..a6bf26d 100644
--- a/cpukit/rtems/src/clocktick.c
+++ b/cpukit/rtems/src/clocktick.c
@@ -23,9 +23,13 @@
rtems_status_code rtems_clock_tick( void )
+ _Timecounter_Acquire( &lock_context );
rtems_configuration_get_microseconds_per_tick(),
- 0
+ 0,
+ &lock_context
return RTEMS_SUCCESSFUL;
diff --git a/cpukit/sapi/include/rtems/timecounter.h b/cpukit/sapi/include/rtems/timecounter.h
index 04bc534..db0a7ee 100644
--- a/cpukit/sapi/include/rtems/timecounter.h
+++ b/cpukit/sapi/include/rtems/timecounter.h
@@ -94,6 +94,13 @@ typedef struct {
} rtems_timecounter_simple;
+ * @brief At tick handling done under protection of the timecounter lock.
+typedef void rtems_timecounter_simple_at_tick(
+ rtems_timecounter_simple *tc
* @brief Returns the current value of a simple timecounter.
typedef uint32_t rtems_timecounter_simple_get(
@@ -199,20 +206,28 @@ RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_scale(
* @param[in] tc The simple timecounter.
* @param[in] get The method to get the value of the simple timecounter.
+ * @param[in] at_tick The method to perform work under timecounter lock
+ * protection at this tick, e.g. clear a pending flag.
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick(
- rtems_timecounter_simple *tc,
- rtems_timecounter_simple_get get
+ rtems_timecounter_simple *tc,
+ rtems_timecounter_simple_get get,
+ rtems_timecounter_simple_at_tick at_tick
uint32_t current;
+ ( *at_tick )( tc );
current = rtems_timecounter_simple_scale(
tc,
tc->real_interval - ( *get )( tc )
- _Timecounter_Tick_simple( tc->binary_interval, current );
+ _Timecounter_Tick_simple( tc->binary_interval, current, &lock_context );
@@ -220,17 +235,25 @@ RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick(
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_upcounter_tick(
uint32_t current;
current = rtems_timecounter_simple_scale( tc, ( *get )( tc ) );
diff --git a/cpukit/score/include/rtems/score/timecounter.h b/cpukit/score/include/rtems/score/timecounter.h
index 0d17cc7..33de269 100644
--- a/cpukit/score/include/rtems/score/timecounter.h
+++ b/cpukit/score/include/rtems/score/timecounter.h
@@ -26,6 +26,8 @@
#include <sys/time.h>
#include <sys/timetc.h>
+#include <rtems/score/isrlock.h>
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
@@ -161,6 +163,21 @@ void _Timecounter_Install( struct timecounter *tc );
void _Timecounter_Tick( void );
+ * @brief Lock to protect the timecounter mechanic.
+ISR_LOCK_DECLARE( extern, _Timecounter_Lock )
+ * @brief Acquires the timecounter lock.
+ * @param[in] lock_context The lock context.
+ * See _Timecounter_Tick_simple().
+#define _Timecounter_Acquire( lock_context ) \
+ _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
* @brief Performs a simple timecounter tick.
* This is a special purpose tick function for simple timecounter to support
@@ -169,8 +186,14 @@ void _Timecounter_Tick( void );
* @param[in] delta The time in timecounter ticks elapsed since the last call
* to _Timecounter_Tick_simple().
* @param[in] offset The current value of the timecounter.
-void _Timecounter_Tick_simple( uint32_t delta, uint32_t offset );
+ * @param[in] lock_context The lock context of the corresponding
+ * _Timecounter_Acquire().
+void _Timecounter_Tick_simple(
+ uint32_t delta,
+ uint32_t offset,
+ ISR_lock_Context *lock_context
* @brief The wall clock time in seconds.
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 9533e77..16d76a1 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -65,7 +65,9 @@ __FBSDID("$FreeBSD r284178 2015-06-09T11:49:56Z$");
#ifdef __rtems__
#include <limits.h>
-ISR_LOCK_DEFINE(static, _Timecounter_Lock, "Timecounter");
+ISR_LOCK_DEFINE(, _Timecounter_Lock, "Timecounter")
+#define _Timecounter_Release(lock_context) \
+ _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
#define hz rtems_clock_get_ticks_per_second()
#define printf(...)
#define bcopy(x, y, z) memcpy(y, x, z);
@@ -1400,7 +1402,7 @@ tc_windup(void)
#ifdef __rtems__
- _ISR_lock_ISR_disable_and_acquire(&_Timecounter_Lock, &lock_context);
#endif /* __rtems__ */
@@ -1555,7 +1557,7 @@ tc_windup(void)
timekeep_push_vdso();
#ifdef __rtems__
- _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, &lock_context);
+ _Timecounter_Release(&lock_context);
@@ -1980,14 +1982,12 @@ _Timecounter_Tick(void)
#ifdef __rtems__
void
-_Timecounter_Tick_simple(uint32_t delta, uint32_t offset)
+_Timecounter_Tick_simple(uint32_t delta, uint32_t offset,
+ ISR_lock_Context *lock_context)
struct bintime bt;
struct timehands *th;
uint32_t ogen;
- ISR_lock_Context lock_context;
th = timehands;
ogen = th->th_generation;
@@ -2014,7 +2014,7 @@ _Timecounter_Tick_simple(uint32_t delta, uint32_t offset)
time_second = th->th_microtime.tv_sec;
time_uptime = th->th_offset.sec;
+ _Timecounter_Release(lock_context);
_Watchdog_Tick();
diff --git a/doc/bsp_howto/clock.t b/doc/bsp_howto/clock.t
index f58b898..2891bb2 100644
--- a/doc/bsp_howto/clock.t
+++ b/doc/bsp_howto/clock.t
@@ -89,6 +89,13 @@ static uint32_t some_tc_get( rtems_timecounter_simple *tc )
return some.counter;
+static void some_tc_at_tick( rtems_timecounter_simple *tc )
+ * Do work necessary at the clock tick interrupt, e.g. clear a pending flag.
static bool some_tc_is_pending( rtems_timecounter_simple *tc )
return some.is_pending;
@@ -105,7 +112,11 @@ static uint32_t some_tc_get_timecount( struct timecounter *tc )
static void some_tc_tick( void )
- rtems_timecounter_simple_downcounter_tick( &some_tc, some_tc_get );
+ &some_tc,
+ some_tc_get,
+ some_tc_at_tick
static void some_support_initialize_hardware( void )
1.8.4.5
