[PATCH 4/8] bsps/arm: Use common ARMv7-M bsp_reset()
Fri Jan 15 13:44:21 UTC 2016
 c/src/lib/libbsp/arm/lm3s69xx/Makefile.am          |  2 +-
 c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c   | 35 ------------------
 c/src/lib/libbsp/arm/lpc176x/Makefile.am           |  2 +-
 c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c    | 43 ----------------------
 c/src/lib/libbsp/arm/lpc24xx/Makefile.am           |  1 +
 c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c    | 21 +++++------
 .../libbsp/arm/shared/armv7m/startup/bspreset.c    | 38 +++++++++++++++++++
 7 files changed, 51 insertions(+), 91 deletions(-)
 delete mode 100644 c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c
 delete mode 100644 c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c
 create mode 100644 c/src/lib/libbsp/arm/shared/armv7m/startup/bspreset.c
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am b/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
index 8d97001..9fab35f 100644
--- a/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
@@ -74,9 +74,9 @@ libbsp_a_SOURCES += ../../shared/src/stackalloc.c
 # Startup
 libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
+libbsp_a_SOURCES += ../shared/armv7m/startup/bspreset.c
 libbsp_a_SOURCES += startup/bspstart.c
 libbsp_a_SOURCES += startup/bspstarthook.c
-libbsp_a_SOURCES += startup/bspreset.c
 libbsp_a_SOURCES += startup/io.c
 libbsp_a_SOURCES += startup/syscon.c
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c b/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c
deleted file mode 100644
index 6509f81..0000000
--- a/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c
+++ /dev/null
@@ -1,35 +0,0 @@
- * Copyright © 2013 Eugeniy Meshcheryakov <eugen at debian.org>
- * Copyright (c) 2011 Sebastian Huber.  All rights reserved.
- *  embedded brains GmbH
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <rtems/score/armv7m.h>
-#include <bsp/bootcard.h>
-void bsp_reset(void)
-  rtems_interrupt_level level;
-  (void) level;
-  rtems_interrupt_disable(level);
-  _ARMV7M_SCB->aircr = ARMV7M_SCB_AIRCR_VECTKEY
-    | ARMV7M_SCB_AIRCR_SYSRESETREQ;
-  while (true)
-    /* Do nothing */;
diff --git a/c/src/lib/libbsp/arm/lpc176x/Makefile.am b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
index 352b2d9..659ee49 100644
--- a/c/src/lib/libbsp/arm/lpc176x/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
@@ -102,7 +102,7 @@ libbsp_a_SOURCES += ../../shared/src/uart-output-char.c
 # Startup
 # IRQ
diff --git a/c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c b/c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c
index 09e4d64..0000000
--- a/c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c
+++ /dev/null
@@ -1,43 +0,0 @@
- * @file
- * @ingroup lpc176x
- * @brief Reset code.
- * Copyright (c) 2008-2013 embedded brains GmbH.  All rights reserved.
- *  82178 Puchheim
- *  Germany
-#include <rtems.h>
-#include <bsp/lpc176x.h>
-#include <bsp/start.h>
-BSP_START_TEXT_SECTION __attribute__( ( flatten ) ) void bsp_reset( void )
-  (void) level;
-  rtems_interrupt_disable( level );
-  _ARMV7M_SCB->aircr = ARMV7M_SCB_AIRCR_VECTKEY |
-                       ARMV7M_SCB_AIRCR_SYSRESETREQ;
-  while ( true ) {
-    /* Do nothing */
diff --git a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
index c7fcb86..ef6f595 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
@@ -105,6 +105,7 @@ libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
 # Startup
diff --git a/c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c b/c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c
index cb63431..c53b4e2 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c
+++ b/c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c
@@ -27,6 +27,8 @@
 #include <bsp/lpc24xx.h>
+#ifdef ARM_MULTILIB_ARCH_V4
 BSP_START_TEXT_SECTION __attribute__((flatten)) void bsp_reset(void)
@@ -34,19 +36,16 @@ BSP_START_TEXT_SECTION __attribute__((flatten)) void bsp_reset(void)
   (void) level;
-  #if defined(ARM_MULTILIB_ARCH_V4)
-    /* Trigger watchdog reset */
-    WDCLKSEL = 0;
-    WDTC = 0xff;
-    WDMOD = 0x3;
-    WDFEED = 0xaa;
-    WDFEED = 0x55;
-  #elif defined(ARM_MULTILIB_ARCH_V7M)
-  #endif
+  /* Trigger watchdog reset */
+  WDCLKSEL = 0;
+  WDTC = 0xff;
+  WDMOD = 0x3;
+  WDFEED = 0xaa;
+  WDFEED = 0x55;
   while (true) {
     /* Do nothing */
+#endif /* ARM_MULTILIB_ARCH_V4 */
diff --git a/c/src/lib/libbsp/arm/shared/armv7m/startup/bspreset.c b/c/src/lib/libbsp/arm/shared/armv7m/startup/bspreset.c
new file mode 100644
index 0000000..69b7b85
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/armv7m/startup/bspreset.c
@@ -0,0 +1,38 @@
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#include <rtems.h>
+#include <rtems/score/armv7m.h>
+#include <bsp/bootcard.h>
+#include <bsp/start.h>
+#ifdef ARM_MULTILIB_ARCH_V7M
+BSP_START_TEXT_SECTION __attribute__((flatten)) void bsp_reset(void)
+  rtems_interrupt_level level;
+  rtems_interrupt_local_disable(level);
+  (void) level;
+  _ARMV7M_SCB->aircr = ARMV7M_SCB_AIRCR_VECTKEY
+    | ARMV7M_SCB_AIRCR_SYSRESETREQ;
+  while (true) {
+    /* Do nothing */
+#endif /* ARM_MULTILIB_ARCH_V7M */
1.8.4.5
