[PATCH 8/8] bsp/atsam: New
Fri Jan 15 13:44:25 UTC 2016
 c/src/lib/libbsp/arm/acinclude.m4                  |    2 +
 c/src/lib/libbsp/arm/atsam/Makefile.am             |  439 +++++++++
 c/src/lib/libbsp/arm/atsam/README                  |   56 ++
 c/src/lib/libbsp/arm/atsam/bsp_specs               |   13 +
 c/src/lib/libbsp/arm/atsam/clock/systick-freq.c    |   31 +
 c/src/lib/libbsp/arm/atsam/configure.ac            |   85 ++
 c/src/lib/libbsp/arm/atsam/console/console.c       |  531 ++++++++++
 c/src/lib/libbsp/arm/atsam/console/debug-console.c |   55 ++
 c/src/lib/libbsp/arm/atsam/include/bsp.h           |   45 +
 c/src/lib/libbsp/arm/atsam/include/irq.h           |   30 +
 c/src/lib/libbsp/arm/atsam/include/pin-config.h    |   36 +
 c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg  |   10 +
 c/src/lib/libbsp/arm/atsam/preinstall.am           | 1038 ++++++++++++++++++++
 c/src/lib/libbsp/arm/atsam/startup/bspstart.c      |   32 +
 c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c |   53 +
 c/src/lib/libbsp/arm/atsam/startup/linkcmds        |   21 +
 .../lib/libbsp/arm/atsam/startup/linkcmds.intsram  |   23 +
 .../libbsp/arm/atsam/startup/linkcmds.memory.in    |    7 +
 c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram  |   21 +
 c/src/lib/libbsp/arm/atsam/startup/pin-config.c    |   42 +
 .../lib/libbsp/arm/shared/armv7m/include/cache_.h  |  144 +++
 c/src/lib/libbsp/arm/shared/include/start.h        |   39 +
 22 files changed, 2753 insertions(+)
 create mode 100644 c/src/lib/libbsp/arm/atsam/Makefile.am
 create mode 100644 c/src/lib/libbsp/arm/atsam/README
 create mode 100644 c/src/lib/libbsp/arm/atsam/bsp_specs
 create mode 100644 c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
 create mode 100644 c/src/lib/libbsp/arm/atsam/configure.ac
 create mode 100644 c/src/lib/libbsp/arm/atsam/console/console.c
 create mode 100644 c/src/lib/libbsp/arm/atsam/console/debug-console.c
 create mode 100644 c/src/lib/libbsp/arm/atsam/include/bsp.h
 create mode 100644 c/src/lib/libbsp/arm/atsam/include/irq.h
 create mode 100644 c/src/lib/libbsp/arm/atsam/include/pin-config.h
 create mode 100644 c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
 create mode 100644 c/src/lib/libbsp/arm/atsam/preinstall.am
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/bspstart.c
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
 create mode 100644 c/src/lib/libbsp/arm/atsam/startup/pin-config.c
 create mode 100644 c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
diff --git a/c/src/lib/libbsp/arm/acinclude.m4 b/c/src/lib/libbsp/arm/acinclude.m4
index f9c4c2f..f5ca105 100644
--- a/c/src/lib/libbsp/arm/acinclude.m4
+++ b/c/src/lib/libbsp/arm/acinclude.m4
@@ -4,6 +4,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
   case "$1" in
   altera-cyclone-v )
     AC_CONFIG_SUBDIRS([altera-cyclone-v]);;
+  atsam )
+    AC_CONFIG_SUBDIRS([atsam]);;
   beagle )
     AC_CONFIG_SUBDIRS([beagle]);;
   csb336 )
diff --git a/c/src/lib/libbsp/arm/atsam/Makefile.am b/c/src/lib/libbsp/arm/atsam/Makefile.am
new file mode 100644
index 0000000..901e851
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/Makefile.am
@@ -0,0 +1,439 @@
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+#                  Data                                                       #
+dist_project_lib_DATA = bsp_specs
+noinst_LIBRARIES = libbspstart.a
+libbspstart_a_SOURCES = ../shared/start/start.S
+project_lib_DATA =
+project_lib_DATA += start.$(OBJEXT)
+project_lib_DATA += startup/linkcmds
+project_lib_DATA += startup/linkcmds.memory
+project_lib_DATA += startup/linkcmds.intsram
+project_lib_DATA += startup/linkcmds.sdram
+#                  Header                                                     #
+include_HEADERS =
+include_HEADERS += ../../shared/include/tm27.h
+include_HEADERS += ../shared/CMSIS/Include/core_cm7.h
+include_HEADERS += ../shared/CMSIS/Include/core_cmInstr.h
+include_HEADERS += ../shared/CMSIS/Include/core_cmFunc.h
+include_HEADERS += ../shared/CMSIS/Include/core_cmSimd.h
+include_HEADERS += ../shared/CMSIS/Include/cmsis_gcc.h
+include_HEADERS += include/bsp.h
+nodist_include_HEADERS =
+nodist_include_HEADERS += ../../shared/include/coverhd.h
+nodist_include_HEADERS += include/bspopts.h
+include_bspdir = $(includedir)/bsp
+nodist_include_bsp_HEADERS =
+nodist_include_bsp_HEADERS += ../../shared/include/bootcard.h
+include_bsp_HEADERS =
+include_bsp_HEADERS += ../../shared/include/utility.h
+include_bsp_HEADERS += ../../shared/include/irq-generic.h
+include_bsp_HEADERS += ../../shared/include/irq-info.h
+include_bsp_HEADERS += ../../shared/include/stackalloc.h
+include_bsp_HEADERS += ../shared/include/start.h
+include_bsp_HEADERS += ../shared/armv7m/include/armv7m-irq.h
+include_bsp_HEADERS += include/irq.h
+include_bsp_HEADERS += include/pin-config.h
+include_libchipdir = $(includedir)/libchip
+include_libchip_HEADERS =
+include_libchip_HEADERS += libraries/libchip/chip.h
+include_libchip_HEADERS += libraries/libchip/compiler.h
+include_libchip_includedir = $(includedir)/libchip/include
+include_libchip_include_HEADERS =
+include_libchip_include_HEADERS += libraries/libchip/include/acc.h
+include_libchip_include_HEADERS += libraries/libchip/include/adc.h
+include_libchip_include_HEADERS += libraries/libchip/include/aes.h
+include_libchip_include_HEADERS += libraries/libchip/include/afec.h
+include_libchip_include_HEADERS += libraries/libchip/include/afe_dma.h
+include_libchip_include_HEADERS += libraries/libchip/include/chip.h
+include_libchip_include_HEADERS += libraries/libchip/include/dac_dma.h
+include_libchip_include_HEADERS += libraries/libchip/include/efc.h
+include_libchip_include_HEADERS += libraries/libchip/include/exceptions.h
+include_libchip_include_HEADERS += libraries/libchip/include/flashd.h
+include_libchip_include_HEADERS += libraries/libchip/include/gmacd.h
+include_libchip_include_HEADERS += libraries/libchip/include/gmac.h
+include_libchip_include_HEADERS += libraries/libchip/include/hsmci.h
+include_libchip_include_HEADERS += libraries/libchip/include/icm.h
+include_libchip_include_HEADERS += libraries/libchip/include/isi.h
+include_libchip_include_HEADERS += libraries/libchip/include/iso7816_4.h
+include_libchip_include_HEADERS += libraries/libchip/include/mcan.h
+include_libchip_include_HEADERS += libraries/libchip/include/mcid.h
+include_libchip_include_HEADERS += libraries/libchip/include/mediaLB.h
+include_libchip_include_HEADERS += libraries/libchip/include/mpu.h
+include_libchip_include_HEADERS += libraries/libchip/include/pio_capture.h
+include_libchip_include_HEADERS += libraries/libchip/include/pio.h
+include_libchip_include_HEADERS += libraries/libchip/include/pio_it.h
+include_libchip_include_HEADERS += libraries/libchip/include/pmc.h
+include_libchip_include_HEADERS += libraries/libchip/include/pwmc.h
+include_libchip_include_HEADERS += libraries/libchip/include/qspi_dma.h
+include_libchip_include_HEADERS += libraries/libchip/include/qspi.h
+include_libchip_include_HEADERS += libraries/libchip/include/rstc.h
+include_libchip_include_HEADERS += libraries/libchip/include/rtc.h
+include_libchip_include_HEADERS += libraries/libchip/include/rtt.h
+include_libchip_include_HEADERS += libraries/libchip/include/sdramc.h
+include_libchip_include_HEADERS += libraries/libchip/include/smc.h
+include_libchip_include_HEADERS += libraries/libchip/include/spi_dma.h
+include_libchip_include_HEADERS += libraries/libchip/include/spi.h
+include_libchip_include_HEADERS += libraries/libchip/include/ssc.h
+include_libchip_include_HEADERS += libraries/libchip/include/supc.h
+include_libchip_include_HEADERS += libraries/libchip/include/tc.h
+include_libchip_include_HEADERS += libraries/libchip/include/timetick.h
+include_libchip_include_HEADERS += libraries/libchip/include/trace.h
+include_libchip_include_HEADERS += libraries/libchip/include/trng.h
+include_libchip_include_HEADERS += libraries/libchip/include/twid.h
+include_libchip_include_HEADERS += libraries/libchip/include/twi.h
+include_libchip_include_HEADERS += libraries/libchip/include/uart_dma.h
+include_libchip_include_HEADERS += libraries/libchip/include/uart.h
+include_libchip_include_HEADERS += libraries/libchip/include/usart_dma.h
+include_libchip_include_HEADERS += libraries/libchip/include/usart.h
+include_libchip_include_HEADERS += libraries/libchip/include/usbhs.h
+include_libchip_include_HEADERS += libraries/libchip/include/video.h
+include_libchip_include_HEADERS += libraries/libchip/include/wdt.h
+include_libchip_include_HEADERS += libraries/libchip/include/xdmac.h
+include_libchip_include_HEADERS += libraries/libchip/include/xdmad.h
+include_libchip_include_HEADERS += libraries/libchip/include/xdma_hardware_interface.h
+include_libchip_include_same70dir = $(includedir)/libchip/include/same70
+include_libchip_include_same70_HEADERS =
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70j19.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70j20.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70j21.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70n19.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70n20.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70n21.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70q19.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70q20.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/same70q21.h
+include_libchip_include_same70_HEADERS += libraries/libchip/include/same70/system_same70.h
+include_libchip_include_same70_componentdir = $(includedir)/libchip/include/same70/component
+include_libchip_include_same70_component_HEADERS =
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_acc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_aes.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_afec.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_chipid.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_dacc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_efc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_gmac.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_gpbr.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_hsmci.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_icm.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_isi.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_matrix.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_mcan.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_pio.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_pmc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_pwm.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_qspi.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_rstc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_rswdt.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_rtc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_rtt.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_sdramc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_smc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_spi.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_ssc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_supc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_tc.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_trng.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_twihs.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_uart.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_usart.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_usbhs.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_utmi.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_wdt.h
+include_libchip_include_same70_component_HEADERS += libraries/libchip/include/same70/component/component_xdmac.h
+include_libchip_include_same70_piodir = $(includedir)/libchip/include/same70/pio
+include_libchip_include_same70_pio_HEADERS =
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70j19.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70j20.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70j21.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70n19.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70n20.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70n21.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70q19.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70q20.h
+include_libchip_include_same70_pio_HEADERS += libraries/libchip/include/same70/pio/pio_same70q21.h
+include_libchip_include_sams70dir = $(includedir)/libchip/include/sams70
+include_libchip_include_sams70_HEADERS =
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70j19.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70j20.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70j21.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70n19.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70n20.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70n21.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70q19.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70q20.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/sams70q21.h
+include_libchip_include_sams70_HEADERS += libraries/libchip/include/sams70/system_sams70.h
+include_libchip_include_sams70_componentdir = $(includedir)/libchip/include/sams70/component
+include_libchip_include_sams70_component_HEADERS =
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_acc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_aes.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_afec.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_chipid.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_dacc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_efc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_gpbr.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_hsmci.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_icm.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_isi.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_matrix.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_pio.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_pmc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_pwm.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_qspi.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_rstc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_rswdt.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_rtc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_rtt.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_sdramc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_smc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_spi.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_ssc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_supc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_tc.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_trng.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_twihs.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_uart.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_usart.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_usbhs.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_utmi.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_wdt.h
+include_libchip_include_sams70_component_HEADERS += libraries/libchip/include/sams70/component/component_xdmac.h
+include_libchip_include_sams70_piodir = $(includedir)/libchip/include/sams70/pio
+include_libchip_include_sams70_pio_HEADERS =
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70j19.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70j20.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70j21.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70n19.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70n20.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70n21.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70q19.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70q20.h
+include_libchip_include_sams70_pio_HEADERS += libraries/libchip/include/sams70/pio/pio_sams70q21.h
+include_libchip_include_samv71dir = $(includedir)/libchip/include/samv71
+include_libchip_include_samv71_HEADERS =
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71j19.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71j20.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71j21.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71n19.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71n20.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71n21.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71q19.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71q20.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/samv71q21.h
+include_libchip_include_samv71_HEADERS += libraries/libchip/include/samv71/system_samv71.h
+include_libchip_include_samv71_componentdir = $(includedir)/libchip/include/samv71/component
+include_libchip_include_samv71_component_HEADERS =
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_acc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_aes.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_afec.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_chipid.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_dacc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_efc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_gmac.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_gpbr.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_hsmci.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_icm.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_isi.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_matrix.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_mcan.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_mlb.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_pio.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_pmc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_pwm.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_qspi.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_rstc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_rswdt.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_rtc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_rtt.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_sdramc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_smc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_spi.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_ssc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_supc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_tc.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_trng.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_twihs.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_uart.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_usart.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_usbhs.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_utmi.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_wdt.h
+include_libchip_include_samv71_component_HEADERS += libraries/libchip/include/samv71/component/component_xdmac.h
+include_libchip_include_samv71_piodir = $(includedir)/libchip/include/samv71/pio
+include_libchip_include_samv71_pio_HEADERS =
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71j19.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71j20.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71j21.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71n19.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71n20.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71n21.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71q19.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71q20.h
+include_libchip_include_samv71_pio_HEADERS += libraries/libchip/include/samv71/pio/pio_samv71q21.h
+#                  LibBSP                                                     #
+noinst_LIBRARIES += libbsp.a
+libbsp_a_SOURCES =
+libbsp_a_CPPFLAGS =
+libbsp_a_LIBADD =
+# Shared
+libbsp_a_SOURCES += ../../shared/bootcard.c
+libbsp_a_SOURCES += ../../shared/bspclean.c
+libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c
+libbsp_a_SOURCES += ../../shared/bsppost.c
+libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += ../../shared/cpucounterread.c
+libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
+libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
+libbsp_a_SOURCES += ../../shared/sbrk.c
+libbsp_a_SOURCES += ../../shared/src/stackalloc.c
+# libchip
+libbsp_a_SOURCES += libraries/libchip/source/acc.c
+libbsp_a_SOURCES += libraries/libchip/source/aes.c
+libbsp_a_SOURCES += libraries/libchip/source/afec.c
+libbsp_a_SOURCES += libraries/libchip/source/afe_dma.c
+libbsp_a_SOURCES += libraries/libchip/source/dac_dma.c
+libbsp_a_SOURCES += libraries/libchip/source/efc.c
+libbsp_a_SOURCES += libraries/libchip/source/exceptions.c
+libbsp_a_SOURCES += libraries/libchip/source/flashd.c
+libbsp_a_SOURCES += libraries/libchip/source/gmac.c
+libbsp_a_SOURCES += libraries/libchip/source/gmacd.c
+libbsp_a_SOURCES += libraries/libchip/source/hsmci.c
+libbsp_a_SOURCES += libraries/libchip/source/icm.c
+libbsp_a_SOURCES += libraries/libchip/source/isi.c
+libbsp_a_SOURCES += libraries/libchip/source/mcan.c
+libbsp_a_SOURCES += libraries/libchip/source/mediaLB.c
+libbsp_a_SOURCES += libraries/libchip/source/mpu.c
+libbsp_a_SOURCES += libraries/libchip/source/pio.c
+libbsp_a_SOURCES += libraries/libchip/source/pio_capture.c
+libbsp_a_SOURCES += libraries/libchip/source/pio_it.c
+libbsp_a_SOURCES += libraries/libchip/source/pmc.c
+libbsp_a_SOURCES += libraries/libchip/source/pwmc.c
+libbsp_a_SOURCES += libraries/libchip/source/qspi.c
+libbsp_a_SOURCES += libraries/libchip/source/qspi_dma.c
+libbsp_a_SOURCES += libraries/libchip/source/rstc.c
+libbsp_a_SOURCES += libraries/libchip/source/rtc.c
+libbsp_a_SOURCES += libraries/libchip/source/rtt.c
+libbsp_a_SOURCES += libraries/libchip/source/sdramc.c
+libbsp_a_SOURCES += libraries/libchip/source/spi.c
+libbsp_a_SOURCES += libraries/libchip/source/spi_dma.c
+libbsp_a_SOURCES += libraries/libchip/source/ssc.c
+libbsp_a_SOURCES += libraries/libchip/source/supc.c
+libbsp_a_SOURCES += libraries/libchip/source/tc.c
+libbsp_a_SOURCES += libraries/libchip/source/trng.c
+libbsp_a_SOURCES += libraries/libchip/source/twi.c
+libbsp_a_SOURCES += libraries/libchip/source/twid.c
+libbsp_a_SOURCES += libraries/libchip/source/uart.c
+libbsp_a_SOURCES += libraries/libchip/source/uart_dma.c
+libbsp_a_SOURCES += libraries/libchip/source/usart.c
+libbsp_a_SOURCES += libraries/libchip/source/usart_dma.c
+libbsp_a_SOURCES += libraries/libchip/source/wdt.c
+libbsp_a_SOURCES += libraries/libchip/source/xdmac.c
+libbsp_a_SOURCES += libraries/libchip/source/xdmad.c
+libbsp_a_SOURCES += libraries/libchip/source/xdma_hardware_interface.c
+# libboard
+libbsp_a_SOURCES += libraries/libboard/resources_v71/system_samv71.c
+libbsp_a_SOURCES += libraries/libboard/source/board_lowlevel.c
+libbsp_a_SOURCES += libraries/libboard/source/board_memories.c
+libbsp_a_SOURCES += libraries/libboard/source/dbg_console.c
+# Startup
+libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
+libbsp_a_SOURCES += ../shared/armv7m/startup/bspreset.c
+libbsp_a_SOURCES += startup/bspstart.c
+libbsp_a_SOURCES += startup/bspstarthooks.c
+libbsp_a_SOURCES += startup/pin-config.c
+# IRQ
+libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
+libbsp_a_SOURCES += ../../shared/src/irq-generic.c
+libbsp_a_SOURCES += ../../shared/src/irq-info.c
+libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
+libbsp_a_SOURCES += ../../shared/src/irq-server.c
+libbsp_a_SOURCES += ../../shared/src/irq-shell.c
+libbsp_a_SOURCES += ../shared/armv7m/irq/armv7m-irq.c
+libbsp_a_SOURCES += ../shared/armv7m/irq/armv7m-irq-dispatch.c
+# Console
+libbsp_a_SOURCES += ../../shared/console-termios.c
+libbsp_a_SOURCES += console/console.c
+libbsp_a_SOURCES += console/debug-console.c
+# Clock
+libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
+libbsp_a_SOURCES += ../shared/armv7m/clock/armv7m-clock-config.c
+libbsp_a_SOURCES += clock/systick-freq.c
+# Timer
+libbsp_a_SOURCES += ../../shared/timerstub.c
+# Cache
+libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
+libbsp_a_SOURCES += ../shared/armv7m/include/cache_.h
+libbsp_a_CPPFLAGS += -I$(srcdir)/../shared/armv7m/include
+# Includes
+libbsp_a_CPPFLAGS += -I$(srcdir)/../shared/CMSIS/Include
+libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libboard
+libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libboard/include
+libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libchip
+libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libchip/include
+#                  Special Rules                                              #
+DISTCLEANFILES = include/bspopts.h
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/arm/atsam/README b/c/src/lib/libbsp/arm/atsam/README
index 0000000..8f96a7f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/README
@@ -0,0 +1,56 @@
+Board support package for the Atmel SAM V71/V70/E70/S70 chip platform.
+The BSP is customized to a particular board/chip variant by means of configure
+command line options.
+Use --enable-chip=XYZ to select the chip variant where XYZ is one of same70j19,
+same70j20, same70j21, same70n19, same70n20, same70n21, same70q19, same70q20,
+same70q21, sams70j19, sams70j20, sams70j21, sams70n19, sams70n20, sams70n21,
+sams70q19, sams70q20, sams70q21, samv71j19, samv71j20, samv71j21, samv71n19,
+samv71n20, samv71n21, samv71q19, samv71q20 and samv71q21.  By default the BSP
+uses the ATSAMV71Q21 chip.  Not all variants are tested.
+Use BOARD_MAINOSC=XYZ to set the main oscillator frequency in Hz (default
+12MHz).
+Use BOARD_MCK=XYZ to set the Master Clock (MCK) frequency in Hz (default
+123MHz).  The default value enables operation of an external SDRAM, e.g. 150MHz
+would be too fast.
+Use ATSAM_CONSOLE_BAUD=XYZ to set the initial baud for console devices (default
+115200).
+Use ATSAM_CONSOLE_DEVICE_TYPE=XYZ to set the device type for /dev/console, use
+0 for USART and 1 for UART (default USART).
+Use ATSAM_CONSOLE_DEVICE_INDEX=XYZ to set the device index for /dev/console
+(default 1, e.g. USART1).
+Use ATSAM_CONSOLE_USE_INTERRUPTS=XYZ to set the use interrupt driven mode for
+console devices (used by default).
+Use ATSAM_MEMORY_TCM_SIZE=XYZ to set the size of tightly coupled memories (TCM)
+in bytes (default 0x00000000).
+Use ATSAM_MEMORY_INTFLASH_SIZE=XYZ to set the size of internal flash in bytes
+(default 0x00200000).
+Use ATSAM_MEMORY_INTSRAM_SIZE=XYZ to set the size of internal SRAM in bytes
+(default 0x00060000).
+Use ATSAM_MEMORY_SDRAM_SIZE=XYZ to set the size of external SDRAM in bytes
+The pins may be configured by the application at link-time.  See
+<bsp/pin-config.h>.
+The clock driver uses the ARMv7-M Systick.
+The console driver supports the USART and UART devices.
+The default linker command file places the code into the internal flash.  Use
+"LDFLAGS += -qnolinkcmds -T linkcmds.sdram" to place the code into the external
+SDRAM.  Use "LDFLAGS += -qnolinkcmds -T linkcmds.intsram" to place the code
+into the internal SRAM.
+The fast text section uses the ITCM.  The fast data section uses the DTCM.
diff --git a/c/src/lib/libbsp/arm/atsam/bsp_specs b/c/src/lib/libbsp/arm/atsam/bsp_specs
index 0000000..32c105f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/bsp_specs
@@ -0,0 +1,13 @@
+%rename endfile old_endfile
+%rename startfile old_startfile
+%rename link old_link
+*startfile:
+%{!qrtems: %(old_startfile)} \
+%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
+*link:
+%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
+*endfile:
+%{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
diff --git a/c/src/lib/libbsp/arm/atsam/clock/systick-freq.c b/c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
index 0000000..060fa17
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
@@ -0,0 +1,31 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#include <bsp.h>
+#include <chip.h>
+uint32_t atsam_systick_frequency(void)
+  uint32_t mdiv = (PMC->PMC_MCKR & PMC_MCKR_MDIV_Msk) >> PMC_MCKR_MDIV_Pos;
+  uint32_t fclk;
+  if (mdiv == 3) {
+    fclk = BOARD_MCK * mdiv;
+  } else {
+    fclk = BOARD_MCK * (1 << mdiv);
+  return fclk;
diff --git a/c/src/lib/libbsp/arm/atsam/configure.ac b/c/src/lib/libbsp/arm/atsam/configure.ac
index 0000000..c459557
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/configure.ac
@@ -0,0 +1,85 @@
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-arm-atsam],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+AC_CONFIG_SRCDIR([bsp_specs])
+RTEMS_TOP(../../../../../..)
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_PROG_CC_FOR_TARGET
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_PROG_CCAS
+RTEMS_CHECK_NETWORKING
+AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
+RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
+AC_ARG_ENABLE(
+[chip],
+[AS_HELP_STRING([--enable-chip],[select a chip variant (default samv71q21)])],
+[case "${enableval}" in
+  same70j19) AC_DEFINE([__SAME70J19__],[1],[chip variant]) ;;
+  same70j20) AC_DEFINE([__SAME70J20__],[1],[chip variant]) ;;
+  same70j21) AC_DEFINE([__SAME70J21__],[1],[chip variant]) ;;
+  same70n19) AC_DEFINE([__SAME70N19__],[1],[chip variant]) ;;
+  same70n20) AC_DEFINE([__SAME70N20__],[1],[chip variant]) ;;
+  same70n21) AC_DEFINE([__SAME70N21__],[1],[chip variant]) ;;
+  same70q19) AC_DEFINE([__SAME70Q19__],[1],[chip variant]) ;;
+  same70q20) AC_DEFINE([__SAME70Q20__],[1],[chip variant]) ;;
+  same70q21) AC_DEFINE([__SAME70Q21__],[1],[chip variant]) ;;
+  sams70j19) AC_DEFINE([__SAMS70J19__],[1],[chip variant]) ;;
+  sams70j20) AC_DEFINE([__SAMS70J20__],[1],[chip variant]) ;;
+  sams70j21) AC_DEFINE([__SAMS70J21__],[1],[chip variant]) ;;
+  sams70n19) AC_DEFINE([__SAMS70N19__],[1],[chip variant]) ;;
+  sams70n20) AC_DEFINE([__SAMS70N20__],[1],[chip variant]) ;;
+  sams70n21) AC_DEFINE([__SAMS70N21__],[1],[chip variant]) ;;
+  sams70q19) AC_DEFINE([__SAMS70Q19__],[1],[chip variant]) ;;
+  sams70q20) AC_DEFINE([__SAMS70Q20__],[1],[chip variant]) ;;
+  sams70q21) AC_DEFINE([__SAMS70Q21__],[1],[chip variant]) ;;
+  samv71j19) AC_DEFINE([__SAMV71J19__],[1],[chip variant]) ;;
+  samv71j20) AC_DEFINE([__SAMV71J20__],[1],[chip variant]) ;;
+  samv71j21) AC_DEFINE([__SAMV71J21__],[1],[chip variant]) ;;
+  samv71n19) AC_DEFINE([__SAMV71N19__],[1],[chip variant]) ;;
+  samv71n20) AC_DEFINE([__SAMV71N20__],[1],[chip variant]) ;;
+  samv71n21) AC_DEFINE([__SAMV71N21__],[1],[chip variant]) ;;
+  samv71q19) AC_DEFINE([__SAMV71Q19__],[1],[chip variant]) ;;
+  samv71q20) AC_DEFINE([__SAMV71Q20__],[1],[chip variant]) ;;
+  samv71q21) AC_DEFINE([__SAMV71Q21__],[1],[chip variant]) ;;
+  *) AC_MSG_ERROR([bad value ${enableval} for chip variant]) ;;
+esac],
+[AC_DEFINE([__SAMV71Q21__],[1],[chip variant])])
+RTEMS_BSPOPTS_SET([BOARD_MAINOSC],[*],[12000000])
+RTEMS_BSPOPTS_HELP([BOARD_MAINOSC],[Main oscillator frequency in Hz (default 12MHz)])
+RTEMS_BSPOPTS_SET([BOARD_MCK],[*],[123000000])
+RTEMS_BSPOPTS_HELP([BOARD_MCK],[Master Clock (MCK) frequency in Hz (default 123MHz)])
+RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_BAUD],[*],[115200])
+RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_BAUD],[initial baud for console devices (default 115200)])
+RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_DEVICE_TYPE],[*],[0])
+RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_DEVICE_TYPE],[device type for /dev/console, use 0 for USART and 1 for UART (default USART)])
+RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_DEVICE_INDEX],[*],[1])
+RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_DEVICE_INDEX],[device index for /dev/console (default 1, e.g. USART1)])
+RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_USE_INTERRUPTS],[*],[1])
+RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_USE_INTERRUPTS],[use interrupt driven mode for console devices (used by default)])
+AC_DEFUN([ATSAM_LINKCMD],[
+AC_ARG_VAR([$1],[$2 (default $3)])dnl
+[$1]=[$]{[$1]:-[$3]}
+ATSAM_LINKCMD([ATSAM_MEMORY_TCM_SIZE],[size of tightly coupled memories (TCM) in bytes],[0x00000000])
+ATSAM_LINKCMD([ATSAM_MEMORY_INTFLASH_SIZE],[size of internal flash in bytes],[0x00200000])
+ATSAM_LINKCMD([ATSAM_MEMORY_INTSRAM_SIZE],[size of internal SRAM in bytes],[0x00060000])
+ATSAM_LINKCMD([ATSAM_MEMORY_SDRAM_SIZE],[size of external SDRAM in bytes],[0x00200000])
+AC_CONFIG_FILES([
+Makefile
+startup/linkcmds.memory
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/arm/atsam/console/console.c b/c/src/lib/libbsp/arm/atsam/console/console.c
index 0000000..8ab8526
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/console/console.c
@@ -0,0 +1,531 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <bsp/fatal.h>
+#include <rtems/termiostypes.h>
+#include <chip.h>
+typedef struct {
+  rtems_termios_device_context base;
+  Usart *regs;
+  rtems_vector_number irq;
+  uint32_t id;
+  bool console;
+#ifdef ATSAM_CONSOLE_USE_INTERRUPTS
+  bool transmitting;
+#endif
+} atsam_usart_context;
+static atsam_usart_context atsam_usart_instances[] = {
+    .regs = USART0,
+    .irq = USART0_IRQn,
+    .id = ID_USART0
+#ifdef USART1
+    .regs = USART1,
+    .irq = USART1_IRQn,
+    .id = ID_USART1
+#endif
+#ifdef USART2
+    .regs = USART2,
+    .irq = USART2_IRQn,
+    .id = ID_USART2
+#endif
+static void atsam_usart_interrupt(void *arg)
+  rtems_termios_tty *tty = arg;
+  atsam_usart_context *ctx = rtems_termios_get_device_context(tty);
+  Usart *regs = ctx->regs;
+  uint32_t csr = regs->US_CSR;
+  while ((csr & US_CSR_RXRDY) != 0) {
+    char c = (char) regs->US_RHR;
+    rtems_termios_enqueue_raw_characters(tty, &c, 1);
+    csr = regs->US_CSR;
+  if (ctx->transmitting && (csr & US_CSR_TXEMPTY) != 0) {
+    rtems_termios_dequeue_characters(tty, 1);
+#endif
+static bool atsam_usart_set_attributes(
+  rtems_termios_device_context *base,
+  const struct termios *term
+  atsam_usart_context *ctx = (atsam_usart_context *) base;
+  rtems_termios_baud_t baud;
+  uint32_t mr;
+  baud = rtems_termios_baud_to_number(term->c_cflag);
+  regs->US_BRGR = (BOARD_MCK / baud) / 16;
+  if ((term->c_cflag & CREAD) != 0) {
+    regs->US_CR = US_CR_RXEN | US_CR_TXEN;
+  } else {
+    regs->US_CR = US_CR_TXEN;
+  mr = US_MR_USART_MODE_NORMAL | US_MR_USCLKS_MCK;
+  switch (term->c_cflag & CSIZE) {
+    case CS5:
+      mr |= US_MR_CHRL_5_BIT;
+      break;
+    case CS6:
+      mr |= US_MR_CHRL_6_BIT;
+      break;
+    case CS7:
+      mr |= US_MR_CHRL_7_BIT;
+      break;
+    default:
+      mr |= US_MR_CHRL_8_BIT;
+      break;
+  if ((term->c_cflag & PARENB) != 0) {
+    if ((term->c_cflag & PARODD) != 0) {
+      mr |= US_MR_PAR_ODD;
+    } else {
+      mr |= US_MR_PAR_EVEN;
+  } else {
+    mr |= US_MR_PAR_NO;
+  if ((term->c_cflag & CSTOPB) != 0) {
+    mr |= US_MR_NBSTOP_2_BIT;
+  } else {
+    mr |= US_MR_NBSTOP_1_BIT;
+  regs->US_MR = mr;
+  return true;
+static bool atsam_usart_first_open(
+  rtems_termios_tty *tty,
+  struct termios *term,
+  rtems_libio_open_close_args_t *args
+  rtems_status_code sc;
+#endif
+  regs->US_CR = US_CR_RSTRX | US_CR_RSTTX | US_CR_RSTSTA;
+  regs->US_IDR = 0xffffffff;
+  PMC_EnablePeripheral(ctx->id);
+  rtems_termios_set_initial_baud(tty, ATSAM_CONSOLE_BAUD);
+  atsam_usart_set_attributes(base, term);
+  regs->US_IER = US_IDR_RXRDY;
+  sc = rtems_interrupt_handler_install(
+    ctx->irq,
+    "USART",
+    RTEMS_INTERRUPT_SHARED,
+    atsam_usart_interrupt,
+    tty
+  if (sc != RTEMS_SUCCESSFUL) {
+    return false;
+#endif
+  return true;
+static void atsam_usart_last_close(
+  rtems_interrupt_handler_remove(ctx->irq, atsam_usart_interrupt, tty);
+#endif
+  if (!ctx->console) {
+    PMC_DisablePeripheral(ctx->id);
+static void atsam_usart_write(
+  const char *buf,
+  size_t len
+  if (len > 0) {
+    ctx->transmitting = true;
+    regs->US_THR = buf[0];
+    regs->US_IER = US_IDR_TXEMPTY;
+  } else {
+    ctx->transmitting = false;
+    regs->US_IDR = US_IDR_TXEMPTY;
+#else
+  size_t i;
+  for (i = 0; i < len; ++i) {
+    while ((regs->US_CSR & US_CSR_TXEMPTY) == 0) {
+      /* Wait */
+    regs->US_THR = buf[i];
+#endif
+#ifndef ATSAM_CONSOLE_USE_INTERRUPTS
+static int atsam_usart_read(rtems_termios_device_context *base)
+  if ((regs->US_CSR & US_CSR_RXRDY) != 0) {
+    return (char) regs->US_RHR;
+  } else {
+    return -1;
+#endif
+static const rtems_termios_device_handler atsam_usart_handler = {
+  .first_open = atsam_usart_first_open,
+  .last_close = atsam_usart_last_close,
+  .write = atsam_usart_write,
+  .set_attributes = atsam_usart_set_attributes,
+  .mode = TERMIOS_IRQ_DRIVEN
+#else
+  .poll_read = atsam_usart_read,
+  .mode = TERMIOS_POLLED
+#endif
+typedef struct {
+  Uart *regs;
+  uint32_t id;
+  bool console;
+#endif
+} atsam_uart_context;
+static atsam_uart_context atsam_uart_instances[] = {
+    .regs = UART0,
+    .irq = UART0_IRQn,
+    .id = ID_UART0
+#ifdef UART1
+    .regs = UART1,
+    .irq = UART1_IRQn,
+    .id = ID_UART1
+#endif
+#ifdef UART2
+    .regs = UART2,
+    .irq = UART2_IRQn,
+    .id = ID_UART2
+#endif
+#ifdef UART3
+    .regs = UART3,
+    .irq = UART3_IRQn,
+    .id = ID_UART3
+#endif
+#ifdef UART4
+    .regs = UART4,
+    .irq = UART4_IRQn,
+    .id = ID_UART4
+#endif
+static void atsam_uart_interrupt(void *arg)
+  atsam_uart_context *ctx = rtems_termios_get_device_context(tty);
+  Uart *regs = ctx->regs;
+  uint32_t sr = regs->UART_SR;
+  while ((sr & UART_SR_RXRDY) != 0) {
+    char c = (char) regs->UART_RHR;
+    sr = regs->UART_SR;
+  if (ctx->transmitting && (sr & UART_SR_TXEMPTY) != 0) {
+#endif
+static bool atsam_uart_set_attributes(
+  atsam_uart_context *ctx = (atsam_uart_context *) base;
+  uint32_t mr;
+  regs->UART_BRGR = (BOARD_MCK / baud) / 16;
+    regs->UART_CR = UART_CR_RXEN | UART_CR_TXEN;
+  } else {
+    regs->UART_CR = UART_CR_TXEN;
+  mr = UART_MR_FILTER_DISABLED | UART_MR_BRSRCCK_PERIPH_CLK;
+  if ((term->c_cflag & CSIZE) != CS8) {
+    return false;
+      mr |= UART_MR_PAR_ODD;
+    } else {
+      mr |= UART_MR_PAR_EVEN;
+  } else {
+    mr |= UART_MR_PAR_NO;
+    return false;
+  regs->UART_MR = mr;
+  return true;
+static bool atsam_uart_first_open(
+#endif
+  regs->UART_CR = UART_CR_RSTRX | UART_CR_RSTTX | UART_CR_RSTSTA;
+  regs->UART_IDR = 0xffffffff;
+  atsam_uart_set_attributes(base, term);
+  regs->UART_IER = UART_IDR_RXRDY;
+    ctx->irq,
+    "UART",
+    atsam_uart_interrupt,
+    tty
+    return false;
+#endif
+  return true;
+static void atsam_uart_last_close(
+  rtems_interrupt_handler_remove(ctx->irq, atsam_uart_interrupt, tty);
+#endif
+static void atsam_uart_write(
+  const char *buf,
+  size_t len
+  if (len > 0) {
+    regs->UART_THR = buf[0];
+    regs->UART_IER = UART_IDR_TXEMPTY;
+  } else {
+    regs->UART_IDR = UART_IDR_TXEMPTY;
+#else
+  size_t i;
+    while ((regs->UART_SR & UART_SR_TXEMPTY) == 0) {
+      /* Wait */
+    regs->UART_THR = buf[i];
+#endif
+static int atsam_uart_read(rtems_termios_device_context *base)
+  if ((regs->UART_SR & UART_SR_RXRDY) != 0) {
+    return (char) regs->UART_RHR;
+  } else {
+    return -1;
+#endif
+static const rtems_termios_device_handler atsam_uart_handler = {
+  .first_open = atsam_uart_first_open,
+  .last_close = atsam_uart_last_close,
+  .write = atsam_uart_write,
+  .set_attributes = atsam_uart_set_attributes,
+#else
+  .poll_read = atsam_uart_read,
+#endif
+rtems_status_code console_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *arg
+  size_t i;
+  rtems_termios_initialize();
+  for (i = 0; i < RTEMS_ARRAY_SIZE(atsam_usart_instances); ++i) {
+    char usart[] = "/dev/ttyUSARTX";
+    usart[sizeof(usart) - 2] = (char) ('0' + i);
+    rtems_termios_device_install(
+      &usart[0],
+      major,
+      minor,
+      &atsam_usart_handler,
+      NULL,
+      &atsam_usart_instances[i].base
+#if ATSAM_CONSOLE_DEVICE_TYPE == 0
+    if (i == ATSAM_CONSOLE_DEVICE_INDEX) {
+      atsam_usart_instances[i].console = true;
+      rtems_io_register_name(CONSOLE_DEVICE_NAME, major, minor);
+#endif
+    ++minor;
+  for (i = 0; i < RTEMS_ARRAY_SIZE(atsam_uart_instances); ++i) {
+    char uart[] = "/dev/ttyUARTX";
+    uart[sizeof(uart) - 2] = (char) ('0' + i);
+      &uart[0],
+      major,
+      minor,
+      &atsam_uart_handler,
+      NULL,
+      &atsam_uart_instances[i].base
+#if ATSAM_CONSOLE_DEVICE_TYPE == 1
+      atsam_uart_instances[i].console = true;
+#endif
+    ++minor;
+  return RTEMS_SUCCESSFUL;
diff --git a/c/src/lib/libbsp/arm/atsam/console/debug-console.c b/c/src/lib/libbsp/arm/atsam/console/debug-console.c
index 0000000..aebc60f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/console/debug-console.c
@@ -0,0 +1,55 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <rtems/bspIo.h>
+#include <rtems/sysinit.h>
+#include <chip.h>
+#include <include/dbg_console.h>
+static void atsam_debug_console_out(char c)
+  if (c == '\n') {
+    DBG_PutChar('\r');
+  DBG_PutChar((uint8_t) c);
+static void atsam_debug_console_init(void)
+  DBG_Configure(115200, BOARD_MCK);
+  BSP_output_char = atsam_debug_console_out;
+static void atsam_debug_console_early_init(char c)
+  atsam_debug_console_init();
+  atsam_debug_console_out(c);
+static int atsam_debug_console_in(void)
+  return (int) DBG_GetChar();
+BSP_output_char_function_type BSP_output_char = atsam_debug_console_early_init;
+BSP_polling_getchar_function_type BSP_poll_char = atsam_debug_console_in;
+RTEMS_SYSINIT_ITEM(
+  atsam_debug_console_init,
+  RTEMS_SYSINIT_BSP_START,
+  RTEMS_SYSINIT_ORDER_LAST
diff --git a/c/src/lib/libbsp/arm/atsam/include/bsp.h b/c/src/lib/libbsp/arm/atsam/include/bsp.h
index 0000000..974afbd
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/include/bsp.h
@@ -0,0 +1,45 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef LIBBSP_ARM_ATSAM_BSP_H
+#define LIBBSP_ARM_ATSAM_BSP_H
+#include <bspopts.h>
+#include <bsp/default-initial-extension.h>
+#include <rtems.h>
+#include <rtems/console.h>
+#include <rtems/clockdrv.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_FEATURE_IRQ_EXTENSION
+#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT (13 << 4)
+#define BSP_ARMV7M_SYSTICK_PRIORITY (14 << 4)
+uint32_t atsam_systick_frequency(void);
+#define BSP_ARMV7M_SYSTICK_FREQUENCY atsam_systick_frequency()
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_ATSAM_BSP_H */
diff --git a/c/src/lib/libbsp/arm/atsam/include/irq.h b/c/src/lib/libbsp/arm/atsam/include/irq.h
index 0000000..19370e4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/include/irq.h
@@ -0,0 +1,30 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef LIBBSP_ARM_ATSAM_ESV_70_IRQ_H
+#define LIBBSP_ARM_ATSAM_ESV_70_IRQ_H
+#ifndef ASM
+  #include <rtems.h>
+  #include <rtems/irq.h>
+  #include <rtems/irq-extension.h>
+#endif
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 64
+#endif /* LIBBSP_ARM_ATSAM_ESV_70_IRQ_H */
diff --git a/c/src/lib/libbsp/arm/atsam/include/pin-config.h b/c/src/lib/libbsp/arm/atsam/include/pin-config.h
index 0000000..8f4a614
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/include/pin-config.h
@@ -0,0 +1,36 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef LIBBSP_ARM_ATSAM_PIN_CONFIG_H
+#define LIBBSP_ARM_ATSAM_PIN_CONFIG_H
+#include <libchip/chip.h>
+#ifdef __cplusplus
+extern "C" {
+extern const Pin atsam_pin_config[];
+extern const size_t atsam_pin_config_count;
+extern const uint32_t atsam_matrix_ccfg_sysio;
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_ATSAM_PIN_CONFIG_H */
diff --git a/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg b/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
index 0000000..06892f9
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
@@ -0,0 +1,10 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -mthumb -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard
+CFLAGS_OPTIMIZE_V = -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/c/src/lib/libbsp/arm/atsam/preinstall.am b/c/src/lib/libbsp/arm/atsam/preinstall.am
index 0000000..ff0d22f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/preinstall.am
@@ -0,0 +1,1038 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES = $(PREINSTALL_FILES)
+all-local: $(TMPINSTALL_FILES)
+TMPINSTALL_FILES =
+CLEANFILES += $(TMPINSTALL_FILES)
+$(PROJECT_LIB)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_LIB)
+	@: > $(PROJECT_LIB)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
+$(PROJECT_INCLUDE)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)
+	@: > $(PROJECT_INCLUDE)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
+PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
+$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
+TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
+$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
+$(PROJECT_LIB)/linkcmds.memory: startup/linkcmds.memory $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.memory
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.memory
+$(PROJECT_LIB)/linkcmds.intsram: startup/linkcmds.intsram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.intsram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.intsram
+$(PROJECT_LIB)/linkcmds.sdram: startup/linkcmds.sdram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.sdram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.sdram
+$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
+$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
+$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
+$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
+$(PROJECT_INCLUDE)/bsp/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
+	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
+$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
+$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
+$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
+$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
+$(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
+$(PROJECT_INCLUDE)/bsp/armv7m-irq.h: ../shared/armv7m/include/armv7m-irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/armv7m-irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/armv7m-irq.h
+$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
+$(PROJECT_INCLUDE)/bsp/pin-config.h: include/pin-config.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pin-config.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pin-config.h
+$(PROJECT_INCLUDE)/libchip/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip
+	@: > $(PROJECT_INCLUDE)/libchip/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/chip.h: libraries/libchip/chip.h $(PROJECT_INCLUDE)/libchip/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/chip.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/chip.h
+$(PROJECT_INCLUDE)/libchip/compiler.h: libraries/libchip/compiler.h $(PROJECT_INCLUDE)/libchip/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/compiler.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/compiler.h
+$(PROJECT_INCLUDE)/libchip/include/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include
+	@: > $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/acc.h: libraries/libchip/include/acc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/acc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/acc.h
+$(PROJECT_INCLUDE)/libchip/include/adc.h: libraries/libchip/include/adc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/adc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/adc.h
+$(PROJECT_INCLUDE)/libchip/include/aes.h: libraries/libchip/include/aes.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/aes.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/aes.h
+$(PROJECT_INCLUDE)/libchip/include/afec.h: libraries/libchip/include/afec.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/afec.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/afec.h
+$(PROJECT_INCLUDE)/libchip/include/afe_dma.h: libraries/libchip/include/afe_dma.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/afe_dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/afe_dma.h
+$(PROJECT_INCLUDE)/libchip/include/chip.h: libraries/libchip/include/chip.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/chip.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/chip.h
+$(PROJECT_INCLUDE)/libchip/include/dac_dma.h: libraries/libchip/include/dac_dma.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/dac_dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/dac_dma.h
+$(PROJECT_INCLUDE)/libchip/include/efc.h: libraries/libchip/include/efc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/efc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/efc.h
+$(PROJECT_INCLUDE)/libchip/include/exceptions.h: libraries/libchip/include/exceptions.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/exceptions.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/exceptions.h
+$(PROJECT_INCLUDE)/libchip/include/flashd.h: libraries/libchip/include/flashd.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/flashd.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/flashd.h
+$(PROJECT_INCLUDE)/libchip/include/gmacd.h: libraries/libchip/include/gmacd.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/gmacd.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/gmacd.h
+$(PROJECT_INCLUDE)/libchip/include/gmac.h: libraries/libchip/include/gmac.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/gmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/gmac.h
+$(PROJECT_INCLUDE)/libchip/include/hsmci.h: libraries/libchip/include/hsmci.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/hsmci.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/hsmci.h
+$(PROJECT_INCLUDE)/libchip/include/icm.h: libraries/libchip/include/icm.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/icm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/icm.h
+$(PROJECT_INCLUDE)/libchip/include/isi.h: libraries/libchip/include/isi.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/isi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/isi.h
+$(PROJECT_INCLUDE)/libchip/include/iso7816_4.h: libraries/libchip/include/iso7816_4.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/iso7816_4.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/iso7816_4.h
+$(PROJECT_INCLUDE)/libchip/include/mcan.h: libraries/libchip/include/mcan.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mcan.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mcan.h
+$(PROJECT_INCLUDE)/libchip/include/mcid.h: libraries/libchip/include/mcid.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mcid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mcid.h
+$(PROJECT_INCLUDE)/libchip/include/mediaLB.h: libraries/libchip/include/mediaLB.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mediaLB.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mediaLB.h
+$(PROJECT_INCLUDE)/libchip/include/mpu.h: libraries/libchip/include/mpu.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mpu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mpu.h
+$(PROJECT_INCLUDE)/libchip/include/pio_capture.h: libraries/libchip/include/pio_capture.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pio_capture.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pio_capture.h
+$(PROJECT_INCLUDE)/libchip/include/pio.h: libraries/libchip/include/pio.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pio.h
+$(PROJECT_INCLUDE)/libchip/include/pio_it.h: libraries/libchip/include/pio_it.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pio_it.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pio_it.h
+$(PROJECT_INCLUDE)/libchip/include/pmc.h: libraries/libchip/include/pmc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pmc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pmc.h
+$(PROJECT_INCLUDE)/libchip/include/pwmc.h: libraries/libchip/include/pwmc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pwmc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pwmc.h
+$(PROJECT_INCLUDE)/libchip/include/qspi_dma.h: libraries/libchip/include/qspi_dma.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/qspi_dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/qspi_dma.h
+$(PROJECT_INCLUDE)/libchip/include/qspi.h: libraries/libchip/include/qspi.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/qspi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/qspi.h
+$(PROJECT_INCLUDE)/libchip/include/rstc.h: libraries/libchip/include/rstc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/rstc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/rstc.h
+$(PROJECT_INCLUDE)/libchip/include/rtc.h: libraries/libchip/include/rtc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/rtc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/rtc.h
+$(PROJECT_INCLUDE)/libchip/include/rtt.h: libraries/libchip/include/rtt.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/rtt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/rtt.h
+$(PROJECT_INCLUDE)/libchip/include/sdramc.h: libraries/libchip/include/sdramc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sdramc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sdramc.h
+$(PROJECT_INCLUDE)/libchip/include/smc.h: libraries/libchip/include/smc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/smc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/smc.h
+$(PROJECT_INCLUDE)/libchip/include/spi_dma.h: libraries/libchip/include/spi_dma.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/spi_dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/spi_dma.h
+$(PROJECT_INCLUDE)/libchip/include/spi.h: libraries/libchip/include/spi.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/spi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/spi.h
+$(PROJECT_INCLUDE)/libchip/include/ssc.h: libraries/libchip/include/ssc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/ssc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/ssc.h
+$(PROJECT_INCLUDE)/libchip/include/supc.h: libraries/libchip/include/supc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/supc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/supc.h
+$(PROJECT_INCLUDE)/libchip/include/tc.h: libraries/libchip/include/tc.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/tc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/tc.h
+$(PROJECT_INCLUDE)/libchip/include/timetick.h: libraries/libchip/include/timetick.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/timetick.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/timetick.h
+$(PROJECT_INCLUDE)/libchip/include/trace.h: libraries/libchip/include/trace.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/trace.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/trace.h
+$(PROJECT_INCLUDE)/libchip/include/trng.h: libraries/libchip/include/trng.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/trng.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/trng.h
+$(PROJECT_INCLUDE)/libchip/include/twid.h: libraries/libchip/include/twid.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/twid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/twid.h
+$(PROJECT_INCLUDE)/libchip/include/twi.h: libraries/libchip/include/twi.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/twi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/twi.h
+$(PROJECT_INCLUDE)/libchip/include/uart_dma.h: libraries/libchip/include/uart_dma.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/uart_dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/uart_dma.h
+$(PROJECT_INCLUDE)/libchip/include/uart.h: libraries/libchip/include/uart.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/uart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/uart.h
+$(PROJECT_INCLUDE)/libchip/include/usart_dma.h: libraries/libchip/include/usart_dma.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/usart_dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/usart_dma.h
+$(PROJECT_INCLUDE)/libchip/include/usart.h: libraries/libchip/include/usart.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/usart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/usart.h
+$(PROJECT_INCLUDE)/libchip/include/usbhs.h: libraries/libchip/include/usbhs.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/usbhs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/usbhs.h
+$(PROJECT_INCLUDE)/libchip/include/video.h: libraries/libchip/include/video.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/video.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/video.h
+$(PROJECT_INCLUDE)/libchip/include/wdt.h: libraries/libchip/include/wdt.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/wdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/wdt.h
+$(PROJECT_INCLUDE)/libchip/include/xdmac.h: libraries/libchip/include/xdmac.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/xdmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/xdmac.h
+$(PROJECT_INCLUDE)/libchip/include/xdmad.h: libraries/libchip/include/xdmad.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/xdmad.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/xdmad.h
+$(PROJECT_INCLUDE)/libchip/include/xdma_hardware_interface.h: libraries/libchip/include/xdma_hardware_interface.h $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/xdma_hardware_interface.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/xdma_hardware_interface.h
+$(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/same70
+	@: > $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/same70/same70.h: libraries/libchip/include/same70/same70.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70j19.h: libraries/libchip/include/same70/same70j19.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70j19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70j19.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70j20.h: libraries/libchip/include/same70/same70j20.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70j20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70j20.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70j21.h: libraries/libchip/include/same70/same70j21.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70j21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70j21.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70n19.h: libraries/libchip/include/same70/same70n19.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70n19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70n19.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70n20.h: libraries/libchip/include/same70/same70n20.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70n20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70n20.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70n21.h: libraries/libchip/include/same70/same70n21.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70n21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70n21.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70q19.h: libraries/libchip/include/same70/same70q19.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70q19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70q19.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70q20.h: libraries/libchip/include/same70/same70q20.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70q20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70q20.h
+$(PROJECT_INCLUDE)/libchip/include/same70/same70q21.h: libraries/libchip/include/same70/same70q21.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/same70q21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70q21.h
+$(PROJECT_INCLUDE)/libchip/include/same70/system_same70.h: libraries/libchip/include/same70/system_same70.h $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/system_same70.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/system_same70.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/same70/component
+	@: > $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_acc.h: libraries/libchip/include/same70/component/component_acc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_acc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_acc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_aes.h: libraries/libchip/include/same70/component/component_aes.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_aes.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_aes.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_afec.h: libraries/libchip/include/same70/component/component_afec.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_afec.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_afec.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_chipid.h: libraries/libchip/include/same70/component/component_chipid.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_chipid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_chipid.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_dacc.h: libraries/libchip/include/same70/component/component_dacc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_dacc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_dacc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_efc.h: libraries/libchip/include/same70/component/component_efc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_efc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_efc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_gmac.h: libraries/libchip/include/same70/component/component_gmac.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_gmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_gmac.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_gpbr.h: libraries/libchip/include/same70/component/component_gpbr.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_gpbr.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_gpbr.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_hsmci.h: libraries/libchip/include/same70/component/component_hsmci.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_hsmci.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_hsmci.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_icm.h: libraries/libchip/include/same70/component/component_icm.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_icm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_icm.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_isi.h: libraries/libchip/include/same70/component/component_isi.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_isi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_isi.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_matrix.h: libraries/libchip/include/same70/component/component_matrix.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_matrix.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_matrix.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_mcan.h: libraries/libchip/include/same70/component/component_mcan.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_mcan.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_mcan.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_pio.h: libraries/libchip/include/same70/component/component_pio.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_pio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_pio.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_pmc.h: libraries/libchip/include/same70/component/component_pmc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_pmc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_pmc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_pwm.h: libraries/libchip/include/same70/component/component_pwm.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_pwm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_pwm.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_qspi.h: libraries/libchip/include/same70/component/component_qspi.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_qspi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_qspi.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rstc.h: libraries/libchip/include/same70/component/component_rstc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rstc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rstc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rswdt.h: libraries/libchip/include/same70/component/component_rswdt.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rswdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rswdt.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtc.h: libraries/libchip/include/same70/component/component_rtc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtt.h: libraries/libchip/include/same70/component/component_rtt.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtt.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_sdramc.h: libraries/libchip/include/same70/component/component_sdramc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_sdramc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_sdramc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_smc.h: libraries/libchip/include/same70/component/component_smc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_smc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_smc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_spi.h: libraries/libchip/include/same70/component/component_spi.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_spi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_spi.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_ssc.h: libraries/libchip/include/same70/component/component_ssc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_ssc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_ssc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_supc.h: libraries/libchip/include/same70/component/component_supc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_supc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_supc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_tc.h: libraries/libchip/include/same70/component/component_tc.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_tc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_tc.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_trng.h: libraries/libchip/include/same70/component/component_trng.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_trng.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_trng.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_twihs.h: libraries/libchip/include/same70/component/component_twihs.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_twihs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_twihs.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_uart.h: libraries/libchip/include/same70/component/component_uart.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_uart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_uart.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_usart.h: libraries/libchip/include/same70/component/component_usart.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_usart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_usart.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_usbhs.h: libraries/libchip/include/same70/component/component_usbhs.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_usbhs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_usbhs.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_utmi.h: libraries/libchip/include/same70/component/component_utmi.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_utmi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_utmi.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_wdt.h: libraries/libchip/include/same70/component/component_wdt.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_wdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_wdt.h
+$(PROJECT_INCLUDE)/libchip/include/same70/component/component_xdmac.h: libraries/libchip/include/same70/component/component_xdmac.h $(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/component/component_xdmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/component/component_xdmac.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/same70/pio
+	@: > $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j19.h: libraries/libchip/include/same70/pio/pio_same70j19.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j19.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j20.h: libraries/libchip/include/same70/pio/pio_same70j20.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j20.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j21.h: libraries/libchip/include/same70/pio/pio_same70j21.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j21.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n19.h: libraries/libchip/include/same70/pio/pio_same70n19.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n19.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n20.h: libraries/libchip/include/same70/pio/pio_same70n20.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n20.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n21.h: libraries/libchip/include/same70/pio/pio_same70n21.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n21.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q19.h: libraries/libchip/include/same70/pio/pio_same70q19.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q19.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q20.h: libraries/libchip/include/same70/pio/pio_same70q20.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q20.h
+$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q21.h: libraries/libchip/include/same70/pio/pio_same70q21.h $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q21.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/sams70
+	@: > $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70.h: libraries/libchip/include/sams70/sams70.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70j19.h: libraries/libchip/include/sams70/sams70j19.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j19.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70j20.h: libraries/libchip/include/sams70/sams70j20.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j20.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70j21.h: libraries/libchip/include/sams70/sams70j21.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j21.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70n19.h: libraries/libchip/include/sams70/sams70n19.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n19.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70n20.h: libraries/libchip/include/sams70/sams70n20.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n20.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70n21.h: libraries/libchip/include/sams70/sams70n21.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n21.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70q19.h: libraries/libchip/include/sams70/sams70q19.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q19.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70q20.h: libraries/libchip/include/sams70/sams70q20.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q20.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/sams70q21.h: libraries/libchip/include/sams70/sams70q21.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q21.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/system_sams70.h: libraries/libchip/include/sams70/system_sams70.h $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/system_sams70.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/system_sams70.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/sams70/component
+	@: > $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_acc.h: libraries/libchip/include/sams70/component/component_acc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_acc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_acc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_aes.h: libraries/libchip/include/sams70/component/component_aes.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_aes.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_aes.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_afec.h: libraries/libchip/include/sams70/component/component_afec.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_afec.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_afec.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_chipid.h: libraries/libchip/include/sams70/component/component_chipid.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_chipid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_chipid.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_dacc.h: libraries/libchip/include/sams70/component/component_dacc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_dacc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_dacc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_efc.h: libraries/libchip/include/sams70/component/component_efc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_efc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_efc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_gpbr.h: libraries/libchip/include/sams70/component/component_gpbr.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_gpbr.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_gpbr.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_hsmci.h: libraries/libchip/include/sams70/component/component_hsmci.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_hsmci.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_hsmci.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_icm.h: libraries/libchip/include/sams70/component/component_icm.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_icm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_icm.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_isi.h: libraries/libchip/include/sams70/component/component_isi.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_isi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_isi.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_matrix.h: libraries/libchip/include/sams70/component/component_matrix.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_matrix.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_matrix.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pio.h: libraries/libchip/include/sams70/component/component_pio.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pio.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pmc.h: libraries/libchip/include/sams70/component/component_pmc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pmc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pmc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pwm.h: libraries/libchip/include/sams70/component/component_pwm.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pwm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pwm.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_qspi.h: libraries/libchip/include/sams70/component/component_qspi.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_qspi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_qspi.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rstc.h: libraries/libchip/include/sams70/component/component_rstc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rstc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rstc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rswdt.h: libraries/libchip/include/sams70/component/component_rswdt.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rswdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rswdt.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtc.h: libraries/libchip/include/sams70/component/component_rtc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtt.h: libraries/libchip/include/sams70/component/component_rtt.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtt.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_sdramc.h: libraries/libchip/include/sams70/component/component_sdramc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_sdramc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_sdramc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_smc.h: libraries/libchip/include/sams70/component/component_smc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_smc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_smc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_spi.h: libraries/libchip/include/sams70/component/component_spi.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_spi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_spi.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_ssc.h: libraries/libchip/include/sams70/component/component_ssc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_ssc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_ssc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_supc.h: libraries/libchip/include/sams70/component/component_supc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_supc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_supc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_tc.h: libraries/libchip/include/sams70/component/component_tc.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_tc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_tc.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_trng.h: libraries/libchip/include/sams70/component/component_trng.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_trng.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_trng.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_twihs.h: libraries/libchip/include/sams70/component/component_twihs.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_twihs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_twihs.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_uart.h: libraries/libchip/include/sams70/component/component_uart.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_uart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_uart.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usart.h: libraries/libchip/include/sams70/component/component_usart.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usart.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usbhs.h: libraries/libchip/include/sams70/component/component_usbhs.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usbhs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usbhs.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_utmi.h: libraries/libchip/include/sams70/component/component_utmi.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_utmi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_utmi.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_wdt.h: libraries/libchip/include/sams70/component/component_wdt.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_wdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_wdt.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_xdmac.h: libraries/libchip/include/sams70/component/component_xdmac.h $(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_xdmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/component/component_xdmac.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/sams70/pio
+	@: > $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j19.h: libraries/libchip/include/sams70/pio/pio_sams70j19.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j19.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j20.h: libraries/libchip/include/sams70/pio/pio_sams70j20.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j20.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j21.h: libraries/libchip/include/sams70/pio/pio_sams70j21.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j21.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n19.h: libraries/libchip/include/sams70/pio/pio_sams70n19.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n19.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n20.h: libraries/libchip/include/sams70/pio/pio_sams70n20.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n20.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n21.h: libraries/libchip/include/sams70/pio/pio_sams70n21.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n21.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q19.h: libraries/libchip/include/sams70/pio/pio_sams70q19.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q19.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q20.h: libraries/libchip/include/sams70/pio/pio_sams70q20.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q20.h
+$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q21.h: libraries/libchip/include/sams70/pio/pio_sams70q21.h $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q21.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/samv71
+	@: > $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71.h: libraries/libchip/include/samv71/samv71.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71j19.h: libraries/libchip/include/samv71/samv71j19.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j19.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71j20.h: libraries/libchip/include/samv71/samv71j20.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j20.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71j21.h: libraries/libchip/include/samv71/samv71j21.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j21.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71n19.h: libraries/libchip/include/samv71/samv71n19.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n19.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71n20.h: libraries/libchip/include/samv71/samv71n20.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n20.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71n21.h: libraries/libchip/include/samv71/samv71n21.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n21.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71q19.h: libraries/libchip/include/samv71/samv71q19.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q19.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71q20.h: libraries/libchip/include/samv71/samv71q20.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q20.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/samv71q21.h: libraries/libchip/include/samv71/samv71q21.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q21.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/system_samv71.h: libraries/libchip/include/samv71/system_samv71.h $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/system_samv71.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/system_samv71.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/samv71/component
+	@: > $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_acc.h: libraries/libchip/include/samv71/component/component_acc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_acc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_acc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_aes.h: libraries/libchip/include/samv71/component/component_aes.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_aes.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_aes.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_afec.h: libraries/libchip/include/samv71/component/component_afec.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_afec.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_afec.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_chipid.h: libraries/libchip/include/samv71/component/component_chipid.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_chipid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_chipid.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_dacc.h: libraries/libchip/include/samv71/component/component_dacc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_dacc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_dacc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_efc.h: libraries/libchip/include/samv71/component/component_efc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_efc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_efc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gmac.h: libraries/libchip/include/samv71/component/component_gmac.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gmac.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gpbr.h: libraries/libchip/include/samv71/component/component_gpbr.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gpbr.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gpbr.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_hsmci.h: libraries/libchip/include/samv71/component/component_hsmci.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_hsmci.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_hsmci.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_icm.h: libraries/libchip/include/samv71/component/component_icm.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_icm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_icm.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_isi.h: libraries/libchip/include/samv71/component/component_isi.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_isi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_isi.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_matrix.h: libraries/libchip/include/samv71/component/component_matrix.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_matrix.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_matrix.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mcan.h: libraries/libchip/include/samv71/component/component_mcan.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mcan.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mcan.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mlb.h: libraries/libchip/include/samv71/component/component_mlb.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mlb.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mlb.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pio.h: libraries/libchip/include/samv71/component/component_pio.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pio.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pmc.h: libraries/libchip/include/samv71/component/component_pmc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pmc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pmc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pwm.h: libraries/libchip/include/samv71/component/component_pwm.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pwm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pwm.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_qspi.h: libraries/libchip/include/samv71/component/component_qspi.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_qspi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_qspi.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rstc.h: libraries/libchip/include/samv71/component/component_rstc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rstc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rstc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rswdt.h: libraries/libchip/include/samv71/component/component_rswdt.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rswdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rswdt.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtc.h: libraries/libchip/include/samv71/component/component_rtc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtt.h: libraries/libchip/include/samv71/component/component_rtt.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtt.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_sdramc.h: libraries/libchip/include/samv71/component/component_sdramc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_sdramc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_sdramc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_smc.h: libraries/libchip/include/samv71/component/component_smc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_smc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_smc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_spi.h: libraries/libchip/include/samv71/component/component_spi.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_spi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_spi.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_ssc.h: libraries/libchip/include/samv71/component/component_ssc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_ssc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_ssc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_supc.h: libraries/libchip/include/samv71/component/component_supc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_supc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_supc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_tc.h: libraries/libchip/include/samv71/component/component_tc.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_tc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_tc.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_trng.h: libraries/libchip/include/samv71/component/component_trng.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_trng.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_trng.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_twihs.h: libraries/libchip/include/samv71/component/component_twihs.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_twihs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_twihs.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_uart.h: libraries/libchip/include/samv71/component/component_uart.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_uart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_uart.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usart.h: libraries/libchip/include/samv71/component/component_usart.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usart.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usbhs.h: libraries/libchip/include/samv71/component/component_usbhs.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usbhs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usbhs.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_utmi.h: libraries/libchip/include/samv71/component/component_utmi.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_utmi.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_utmi.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_wdt.h: libraries/libchip/include/samv71/component/component_wdt.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_wdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_wdt.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_xdmac.h: libraries/libchip/include/samv71/component/component_xdmac.h $(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_xdmac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/component/component_xdmac.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/samv71/pio
+	@: > $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j19.h: libraries/libchip/include/samv71/pio/pio_samv71j19.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j19.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j20.h: libraries/libchip/include/samv71/pio/pio_samv71j20.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j20.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j21.h: libraries/libchip/include/samv71/pio/pio_samv71j21.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j21.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n19.h: libraries/libchip/include/samv71/pio/pio_samv71n19.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n19.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n20.h: libraries/libchip/include/samv71/pio/pio_samv71n20.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n20.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n21.h: libraries/libchip/include/samv71/pio/pio_samv71n21.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n21.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q19.h: libraries/libchip/include/samv71/pio/pio_samv71q19.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q19.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q19.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q20.h: libraries/libchip/include/samv71/pio/pio_samv71q20.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q20.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q20.h
+$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q21.h: libraries/libchip/include/samv71/pio/pio_samv71q21.h $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q21.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q21.h
diff --git a/c/src/lib/libbsp/arm/atsam/startup/bspstart.c b/c/src/lib/libbsp/arm/atsam/startup/bspstart.c
new file mode 100644
index 0000000..55b16cf
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/bspstart.c
@@ -0,0 +1,32 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq.h>
+#include <bsp/irq-generic.h>
+#include <chip.h>
+RTEMS_STATIC_ASSERT(
+  PERIPH_COUNT_IRQn <= BSP_INTERRUPT_VECTOR_MAX,
+  PERIPH_COUNT_IRQn
+void bsp_start(void)
+  bsp_interrupt_initialize();
+  SCB_CleanDCache();
+  SCB_InvalidateICache();
diff --git a/c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
index 0000000..718a262
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
@@ -0,0 +1,53 @@
+ * Copyright (c) 2016 embedded brains GmbH Huber.  All rights reserved.
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <bsp.h>
+#include <bsp/start.h>
+#include <bsp/pin-config.h>
+#include <chip.h>
+#include <include/board_lowlevel.h>
+#include <include/board_memories.h>
+void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
+  system_init_flash(BOARD_MCK);
+  SystemInit();
+  PIO_Configure(&atsam_pin_config[0], atsam_pin_config_count);
+  MATRIX->CCFG_SYSIO = atsam_matrix_ccfg_sysio;
+  if (!PMC_IsPeriphEnabled(ID_SDRAMC)) {
+    BOARD_ConfigureSdram();
+  if ((SCB->CCR & SCB_CCR_IC_Msk) == 0) {
+    SCB_EnableICache();
+  if ((SCB->CCR & SCB_CCR_DC_Msk) == 0) {
+    SCB_EnableDCache();
+  _SetupMemoryRegion();
+void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
+  bsp_start_copy_sections_compact();
+  bsp_start_clear_bss();
+  WDT_Disable(WDT);
diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds b/c/src/lib/libbsp/arm/atsam/startup/linkcmds
index 0000000..61aff87
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds
@@ -0,0 +1,21 @@
+INCLUDE linkcmds.memory
+REGION_ALIAS ("REGION_START", INTFLASH);
+REGION_ALIAS ("REGION_VECTOR", INTSRAM);
+REGION_ALIAS ("REGION_TEXT", INTFLASH);
+REGION_ALIAS ("REGION_TEXT_LOAD", INTFLASH);
+REGION_ALIAS ("REGION_RODATA", INTFLASH);
+REGION_ALIAS ("REGION_RODATA_LOAD", INTFLASH);
+REGION_ALIAS ("REGION_DATA", INTSRAM);
+REGION_ALIAS ("REGION_DATA_LOAD", INTFLASH);
+REGION_ALIAS ("REGION_FAST_TEXT", ITCM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", INTFLASH);
+REGION_ALIAS ("REGION_FAST_DATA", DTCM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", INTFLASH);
+REGION_ALIAS ("REGION_BSS", INTSRAM);
+REGION_ALIAS ("REGION_WORK", INTSRAM);
+REGION_ALIAS ("REGION_STACK", INTSRAM);
+REGION_ALIAS ("REGION_NOCACHE", INTSRAM);
+REGION_ALIAS ("REGION_NOCACHE_LOAD", INTFLASH);
+INCLUDE linkcmds.armv7m
diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
index 0000000..1a17ed3
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
@@ -0,0 +1,23 @@
+bsp_vector_table_in_start_section = 1;
+REGION_ALIAS ("REGION_START", INTSRAM);
+REGION_ALIAS ("REGION_TEXT", INTSRAM);
+REGION_ALIAS ("REGION_TEXT_LOAD", INTSRAM);
+REGION_ALIAS ("REGION_RODATA", INTSRAM);
+REGION_ALIAS ("REGION_RODATA_LOAD", INTSRAM);
+REGION_ALIAS ("REGION_DATA_LOAD", INTSRAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", INTSRAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", INTSRAM);
+REGION_ALIAS ("REGION_NOCACHE_LOAD", INTSRAM);
diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
index 0000000..5eb14dc
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
@@ -0,0 +1,7 @@
+MEMORY {
+	ITCM      : ORIGIN = 0x00000000, LENGTH = @ATSAM_MEMORY_TCM_SIZE@
+	INTFLASH  : ORIGIN = 0x00400000, LENGTH = @ATSAM_MEMORY_INTFLASH_SIZE@
+	DTCM      : ORIGIN = 0x20000000, LENGTH = @ATSAM_MEMORY_TCM_SIZE@
+	INTSRAM   : ORIGIN = 0x20400000, LENGTH = @ATSAM_MEMORY_INTSRAM_SIZE@
+	SDRAM     : ORIGIN = 0x70000000, LENGTH = @ATSAM_MEMORY_SDRAM_SIZE@
diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
index 0000000..675e837
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
@@ -0,0 +1,21 @@
+REGION_ALIAS ("REGION_START", SDRAM);
+REGION_ALIAS ("REGION_TEXT", SDRAM);
+REGION_ALIAS ("REGION_TEXT_LOAD", SDRAM);
+REGION_ALIAS ("REGION_RODATA", SDRAM);
+REGION_ALIAS ("REGION_RODATA_LOAD", SDRAM);
+REGION_ALIAS ("REGION_DATA", SDRAM);
+REGION_ALIAS ("REGION_DATA_LOAD", SDRAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", SDRAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", SDRAM);
+REGION_ALIAS ("REGION_BSS", SDRAM);
+REGION_ALIAS ("REGION_WORK", SDRAM);
+REGION_ALIAS ("REGION_STACK", SDRAM);
+REGION_ALIAS ("REGION_NOCACHE", SDRAM);
+REGION_ALIAS ("REGION_NOCACHE_LOAD", SDRAM);
diff --git a/c/src/lib/libbsp/arm/atsam/startup/pin-config.c b/c/src/lib/libbsp/arm/atsam/startup/pin-config.c
index 0000000..8a18ae8
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/startup/pin-config.c
@@ -0,0 +1,42 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+const Pin atsam_pin_config[] = {
+  /* Console */
+  {PIO_PA21A_RXD1, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT},
+  {PIO_PB4D_TXD1, PIOB, ID_PIOB, PIO_PERIPH_D, PIO_DEFAULT},
+  /* SDRAM */
+  /* D0_7   */ {0x000000FF, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
+  /* D8_13  */ {0x0000003F, PIOE, ID_PIOE, PIO_PERIPH_A, PIO_DEFAULT},
+  /* D14_15 */ {0x00018000, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT},
+  /* A0_9   */ {0x3FF00000, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
+  /* SDA10  */ {0x00002000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* CAS    */ {0x00020000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* RAS    */ {0x00010000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* SDCKE  */ {0x00004000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* SDCK   */ {0x00800000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* SDSC   */ {0x00008000, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
+  /* NBS0   */ {0x00040000, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
+  /* NBS1   */ {0x00008000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* SDWE   */ {0x20000000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
+  /* BA0    */ {0x00100000, PIOA, ID_PIOA, PIO_PERIPH_C, PIO_DEFAULT}
+const size_t atsam_pin_config_count = PIO_LISTSIZE(atsam_pin_config);
+const uint32_t atsam_matrix_ccfg_sysio = 0x20400010;
diff --git a/c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h b/c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
index 0000000..ef94c11
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
@@ -0,0 +1,144 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef LIBBSP_ARM_ARMV7M_CACHE__H
+#define LIBBSP_ARM_ARMV7M_CACHE__H
+#include <rtems.h>
+#include <chip.h>
+#define CPU_DATA_CACHE_ALIGNMENT 32
+#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
+#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
+static inline void _CPU_cache_flush_data_range(
+  const void *d_addr,
+  size_t n_bytes
+  SCB_CleanInvalidateDCache_by_Addr(
+    RTEMS_DECONST(uint32_t *, (const uint32_t *) d_addr),
+    n_bytes
+static inline void _CPU_cache_invalidate_data_range(
+  size_t n_bytes
+  SCB_InvalidateDCache_by_Addr(
+    n_bytes
+static inline void _CPU_cache_freeze_data(void)
+  /* TODO */
+static inline void _CPU_cache_unfreeze_data(void)
+  /* TODO */
+static inline void _CPU_cache_invalidate_instruction_range(
+  const void *i_addr,
+  size_t n_bytes
+  rtems_interrupt_level level;
+  rtems_interrupt_disable(level);
+  rtems_interrupt_enable(level);
+static inline void _CPU_cache_freeze_instruction(void)
+  /* TODO */
+static inline void _CPU_cache_unfreeze_instruction(void)
+  /* TODO */
+static inline void _CPU_cache_flush_entire_data(void)
+static inline void _CPU_cache_invalidate_entire_data(void)
+  SCB_InvalidateDCache();
+static inline void _CPU_cache_enable_data(void)
+static inline void _CPU_cache_disable_data(void)
+  SCB_DisableDCache();
+static inline void _CPU_cache_invalidate_entire_instruction(void)
+static inline void _CPU_cache_enable_instruction(void)
+static inline void _CPU_cache_disable_instruction(void)
+  SCB_DisableICache();
+#endif /* LIBBSP_ARM_ARMV7M_CACHE__H */
diff --git a/c/src/lib/libbsp/arm/shared/include/start.h b/c/src/lib/libbsp/arm/shared/include/start.h
index 9df6df4..f61eed3 100644
--- a/c/src/lib/libbsp/arm/shared/include/start.h
+++ b/c/src/lib/libbsp/arm/shared/include/start.h
@@ -121,6 +121,45 @@ BSP_START_TEXT_SECTION static inline void bsp_start_copy_sections(void)
+BSP_START_TEXT_SECTION static inline void
+bsp_start_memcpy_libc(void *dest, const void *src, size_t n)
+  if (dest != src) {
+    memcpy(dest, src, n);
+ * @brief Copies the .data, .fast_text and .fast_data sections from the load to
+ * the runtime area using the C library memcpy().
+ * Works only in case the .start, .text and .rodata sections reside in one
+ * memory region.
+BSP_START_TEXT_SECTION static inline void bsp_start_copy_sections_compact(void)
+  /* Copy .data section */
+  bsp_start_memcpy_libc(
+    bsp_section_data_begin,
+    bsp_section_data_load_begin,
+    (size_t) bsp_section_data_size
+  /* Copy .fast_text section */
+    bsp_section_fast_text_begin,
+    bsp_section_fast_text_load_begin,
+    (size_t) bsp_section_fast_text_size
+  /* Copy .fast_data section */
+    bsp_section_fast_data_begin,
+    bsp_section_fast_data_load_begin,
+    (size_t) bsp_section_fast_data_size
 BSP_START_TEXT_SECTION static inline void bsp_start_clear_bss(void)
   memset(bsp_section_bss_begin, 0, (size_t) bsp_section_bss_size);
1.8.4.5
