[PATCH 8/8] bsp/atsam: New
Joel Sherrill
joel at rtems.org
Fri Jan 15 13:52:54 UTC 2016
Ditto on a Trac ticket.
On Fri, Jan 15, 2016 at 7:44 AM, Sebastian Huber <
> c/src/lib/libbsp/arm/acinclude.m4 | 2 +
> c/src/lib/libbsp/arm/atsam/Makefile.am | 439 +++++++++
> c/src/lib/libbsp/arm/atsam/README | 56 ++
> c/src/lib/libbsp/arm/atsam/bsp_specs | 13 +
> c/src/lib/libbsp/arm/atsam/clock/systick-freq.c | 31 +
> c/src/lib/libbsp/arm/atsam/configure.ac | 85 ++
> c/src/lib/libbsp/arm/atsam/console/console.c | 531 ++++++++++
> c/src/lib/libbsp/arm/atsam/console/debug-console.c | 55 ++
> c/src/lib/libbsp/arm/atsam/include/bsp.h | 45 +
> c/src/lib/libbsp/arm/atsam/include/irq.h | 30 +
> c/src/lib/libbsp/arm/atsam/include/pin-config.h | 36 +
> c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg | 10 +
> c/src/lib/libbsp/arm/atsam/preinstall.am | 1038
> c/src/lib/libbsp/arm/atsam/startup/bspstart.c | 32 +
> c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c | 53 +
> c/src/lib/libbsp/arm/atsam/startup/linkcmds | 21 +
> .../lib/libbsp/arm/atsam/startup/linkcmds.intsram | 23 +
> .../libbsp/arm/atsam/startup/linkcmds.memory.in | 7 +
> c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram | 21 +
> c/src/lib/libbsp/arm/atsam/startup/pin-config.c | 42 +
> .../lib/libbsp/arm/shared/armv7m/include/cache_.h | 144 +++
> c/src/lib/libbsp/arm/shared/include/start.h | 39 +
> 22 files changed, 2753 insertions(+)
> create mode 100644 c/src/lib/libbsp/arm/atsam/Makefile.am
> create mode 100644 c/src/lib/libbsp/arm/atsam/README
> create mode 100644 c/src/lib/libbsp/arm/atsam/bsp_specs
> create mode 100644 c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
> create mode 100644 c/src/lib/libbsp/arm/atsam/configure.ac
> create mode 100644 c/src/lib/libbsp/arm/atsam/console/console.c
> create mode 100644 c/src/lib/libbsp/arm/atsam/console/debug-console.c
> create mode 100644 c/src/lib/libbsp/arm/atsam/include/bsp.h
> create mode 100644 c/src/lib/libbsp/arm/atsam/include/irq.h
> create mode 100644 c/src/lib/libbsp/arm/atsam/include/pin-config.h
> create mode 100644 c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
> create mode 100644 c/src/lib/libbsp/arm/atsam/preinstall.am
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/bspstart.c
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
> create mode 100644 c/src/lib/libbsp/arm/atsam/startup/pin-config.c
> create mode 100644 c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
> diff --git a/c/src/lib/libbsp/arm/acinclude.m4
> b/c/src/lib/libbsp/arm/acinclude.m4
> index f9c4c2f..f5ca105 100644
> --- a/c/src/lib/libbsp/arm/acinclude.m4
> +++ b/c/src/lib/libbsp/arm/acinclude.m4
> @@ -4,6 +4,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
> case "$1" in
> altera-cyclone-v )
> AC_CONFIG_SUBDIRS([altera-cyclone-v]);;
> + atsam )
> + AC_CONFIG_SUBDIRS([atsam]);;
> beagle )
> AC_CONFIG_SUBDIRS([beagle]);;
> csb336 )
> diff --git a/c/src/lib/libbsp/arm/atsam/Makefile.am
> b/c/src/lib/libbsp/arm/atsam/Makefile.am
> new file mode 100644
> index 0000000..901e851
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/Makefile.am
> @@ -0,0 +1,439 @@
> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
> +include $(top_srcdir)/../../../../automake/compile.am
> +# Data
> +dist_project_lib_DATA = bsp_specs
> +noinst_LIBRARIES = libbspstart.a
> +libbspstart_a_SOURCES = ../shared/start/start.S
> +project_lib_DATA =
> +project_lib_DATA += start.$(OBJEXT)
> +project_lib_DATA += startup/linkcmds
> +project_lib_DATA += startup/linkcmds.memory
> +project_lib_DATA += startup/linkcmds.intsram
> +project_lib_DATA += startup/linkcmds.sdram
> +# Header
> +include_HEADERS =
> +include_HEADERS += ../../shared/include/tm27.h
> +include_HEADERS += ../shared/CMSIS/Include/core_cm7.h
> +include_HEADERS += ../shared/CMSIS/Include/core_cmInstr.h
> +include_HEADERS += ../shared/CMSIS/Include/core_cmFunc.h
> +include_HEADERS += ../shared/CMSIS/Include/core_cmSimd.h
> +include_HEADERS += ../shared/CMSIS/Include/cmsis_gcc.h
> +include_HEADERS += include/bsp.h
> +nodist_include_HEADERS =
> +nodist_include_HEADERS += ../../shared/include/coverhd.h
> +nodist_include_HEADERS += include/bspopts.h
> +include_bspdir = $(includedir)/bsp
> +nodist_include_bsp_HEADERS =
> +nodist_include_bsp_HEADERS += ../../shared/include/bootcard.h
> +include_bsp_HEADERS =
> +include_bsp_HEADERS += ../../shared/include/utility.h
> +include_bsp_HEADERS += ../../shared/include/irq-generic.h
> +include_bsp_HEADERS += ../../shared/include/irq-info.h
> +include_bsp_HEADERS += ../../shared/include/stackalloc.h
> +include_bsp_HEADERS += ../shared/include/start.h
> +include_bsp_HEADERS += ../shared/armv7m/include/armv7m-irq.h
> +include_bsp_HEADERS += include/irq.h
> +include_bsp_HEADERS += include/pin-config.h
> +include_libchipdir = $(includedir)/libchip
> +include_libchip_HEADERS =
> +include_libchip_HEADERS += libraries/libchip/chip.h
> +include_libchip_HEADERS += libraries/libchip/compiler.h
> +include_libchip_includedir = $(includedir)/libchip/include
> +include_libchip_include_HEADERS =
> +include_libchip_include_HEADERS += libraries/libchip/include/acc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/adc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/aes.h
> +include_libchip_include_HEADERS += libraries/libchip/include/afec.h
> +include_libchip_include_HEADERS += libraries/libchip/include/afe_dma.h
> +include_libchip_include_HEADERS += libraries/libchip/include/chip.h
> +include_libchip_include_HEADERS += libraries/libchip/include/dac_dma.h
> +include_libchip_include_HEADERS += libraries/libchip/include/efc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/exceptions.h
> +include_libchip_include_HEADERS += libraries/libchip/include/flashd.h
> +include_libchip_include_HEADERS += libraries/libchip/include/gmacd.h
> +include_libchip_include_HEADERS += libraries/libchip/include/gmac.h
> +include_libchip_include_HEADERS += libraries/libchip/include/hsmci.h
> +include_libchip_include_HEADERS += libraries/libchip/include/icm.h
> +include_libchip_include_HEADERS += libraries/libchip/include/isi.h
> +include_libchip_include_HEADERS += libraries/libchip/include/iso7816_4.h
> +include_libchip_include_HEADERS += libraries/libchip/include/mcan.h
> +include_libchip_include_HEADERS += libraries/libchip/include/mcid.h
> +include_libchip_include_HEADERS += libraries/libchip/include/mediaLB.h
> +include_libchip_include_HEADERS += libraries/libchip/include/mpu.h
> +include_libchip_include_HEADERS += libraries/libchip/include/pio_capture.h
> +include_libchip_include_HEADERS += libraries/libchip/include/pio.h
> +include_libchip_include_HEADERS += libraries/libchip/include/pio_it.h
> +include_libchip_include_HEADERS += libraries/libchip/include/pmc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/pwmc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/qspi_dma.h
> +include_libchip_include_HEADERS += libraries/libchip/include/qspi.h
> +include_libchip_include_HEADERS += libraries/libchip/include/rstc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/rtc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/rtt.h
> +include_libchip_include_HEADERS += libraries/libchip/include/sdramc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/smc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/spi_dma.h
> +include_libchip_include_HEADERS += libraries/libchip/include/spi.h
> +include_libchip_include_HEADERS += libraries/libchip/include/ssc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/supc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/tc.h
> +include_libchip_include_HEADERS += libraries/libchip/include/timetick.h
> +include_libchip_include_HEADERS += libraries/libchip/include/trace.h
> +include_libchip_include_HEADERS += libraries/libchip/include/trng.h
> +include_libchip_include_HEADERS += libraries/libchip/include/twid.h
> +include_libchip_include_HEADERS += libraries/libchip/include/twi.h
> +include_libchip_include_HEADERS += libraries/libchip/include/uart_dma.h
> +include_libchip_include_HEADERS += libraries/libchip/include/uart.h
> +include_libchip_include_HEADERS += libraries/libchip/include/usart_dma.h
> +include_libchip_include_HEADERS += libraries/libchip/include/usart.h
> +include_libchip_include_HEADERS += libraries/libchip/include/usbhs.h
> +include_libchip_include_HEADERS += libraries/libchip/include/video.h
> +include_libchip_include_HEADERS += libraries/libchip/include/wdt.h
> +include_libchip_include_HEADERS += libraries/libchip/include/xdmac.h
> +include_libchip_include_HEADERS += libraries/libchip/include/xdmad.h
> libraries/libchip/include/xdma_hardware_interface.h
> +include_libchip_include_same70dir = $(includedir)/libchip/include/same70
> +include_libchip_include_same70_HEADERS =
> +include_libchip_include_same70_HEADERS +=
> libraries/libchip/include/same70/same70.h
> libraries/libchip/include/same70/same70j19.h
> libraries/libchip/include/same70/same70j20.h
> libraries/libchip/include/same70/same70j21.h
> libraries/libchip/include/same70/same70n19.h
> libraries/libchip/include/same70/same70n20.h
> libraries/libchip/include/same70/same70n21.h
> libraries/libchip/include/same70/same70q19.h
> libraries/libchip/include/same70/same70q20.h
> libraries/libchip/include/same70/same70q21.h
> libraries/libchip/include/same70/system_same70.h
> +include_libchip_include_same70_componentdir =
> $(includedir)/libchip/include/same70/component
> +include_libchip_include_same70_component_HEADERS =
> +include_libchip_include_same70_component_HEADERS +=
> libraries/libchip/include/same70/component/component_acc.h
> libraries/libchip/include/same70/component/component_aes.h
> libraries/libchip/include/same70/component/component_afec.h
> libraries/libchip/include/same70/component/component_chipid.h
> libraries/libchip/include/same70/component/component_dacc.h
> libraries/libchip/include/same70/component/component_efc.h
> libraries/libchip/include/same70/component/component_gmac.h
> libraries/libchip/include/same70/component/component_gpbr.h
> libraries/libchip/include/same70/component/component_hsmci.h
> libraries/libchip/include/same70/component/component_icm.h
> libraries/libchip/include/same70/component/component_isi.h
> libraries/libchip/include/same70/component/component_matrix.h
> libraries/libchip/include/same70/component/component_mcan.h
> libraries/libchip/include/same70/component/component_pio.h
> libraries/libchip/include/same70/component/component_pmc.h
> libraries/libchip/include/same70/component/component_pwm.h
> libraries/libchip/include/same70/component/component_qspi.h
> libraries/libchip/include/same70/component/component_rstc.h
> libraries/libchip/include/same70/component/component_rswdt.h
> libraries/libchip/include/same70/component/component_rtc.h
> libraries/libchip/include/same70/component/component_rtt.h
> libraries/libchip/include/same70/component/component_sdramc.h
> libraries/libchip/include/same70/component/component_smc.h
> libraries/libchip/include/same70/component/component_spi.h
> libraries/libchip/include/same70/component/component_ssc.h
> libraries/libchip/include/same70/component/component_supc.h
> libraries/libchip/include/same70/component/component_tc.h
> libraries/libchip/include/same70/component/component_trng.h
> libraries/libchip/include/same70/component/component_twihs.h
> libraries/libchip/include/same70/component/component_uart.h
> libraries/libchip/include/same70/component/component_usart.h
> libraries/libchip/include/same70/component/component_usbhs.h
> libraries/libchip/include/same70/component/component_utmi.h
> libraries/libchip/include/same70/component/component_wdt.h
> libraries/libchip/include/same70/component/component_xdmac.h
> +include_libchip_include_same70_piodir =
> $(includedir)/libchip/include/same70/pio
> +include_libchip_include_same70_pio_HEADERS =
> +include_libchip_include_same70_pio_HEADERS +=
> libraries/libchip/include/same70/pio/pio_same70j19.h
> libraries/libchip/include/same70/pio/pio_same70j20.h
> libraries/libchip/include/same70/pio/pio_same70j21.h
> libraries/libchip/include/same70/pio/pio_same70n19.h
> libraries/libchip/include/same70/pio/pio_same70n20.h
> libraries/libchip/include/same70/pio/pio_same70n21.h
> libraries/libchip/include/same70/pio/pio_same70q19.h
> libraries/libchip/include/same70/pio/pio_same70q20.h
> libraries/libchip/include/same70/pio/pio_same70q21.h
> +include_libchip_include_sams70dir = $(includedir)/libchip/include/sams70
> +include_libchip_include_sams70_HEADERS =
> +include_libchip_include_sams70_HEADERS +=
> libraries/libchip/include/sams70/sams70.h
> libraries/libchip/include/sams70/sams70j19.h
> libraries/libchip/include/sams70/sams70j20.h
> libraries/libchip/include/sams70/sams70j21.h
> libraries/libchip/include/sams70/sams70n19.h
> libraries/libchip/include/sams70/sams70n20.h
> libraries/libchip/include/sams70/sams70n21.h
> libraries/libchip/include/sams70/sams70q19.h
> libraries/libchip/include/sams70/sams70q20.h
> libraries/libchip/include/sams70/sams70q21.h
> libraries/libchip/include/sams70/system_sams70.h
> +include_libchip_include_sams70_componentdir =
> $(includedir)/libchip/include/sams70/component
> +include_libchip_include_sams70_component_HEADERS =
> +include_libchip_include_sams70_component_HEADERS +=
> libraries/libchip/include/sams70/component/component_acc.h
> libraries/libchip/include/sams70/component/component_aes.h
> libraries/libchip/include/sams70/component/component_afec.h
> libraries/libchip/include/sams70/component/component_chipid.h
> libraries/libchip/include/sams70/component/component_dacc.h
> libraries/libchip/include/sams70/component/component_efc.h
> libraries/libchip/include/sams70/component/component_gpbr.h
> libraries/libchip/include/sams70/component/component_hsmci.h
> libraries/libchip/include/sams70/component/component_icm.h
> libraries/libchip/include/sams70/component/component_isi.h
> libraries/libchip/include/sams70/component/component_matrix.h
> libraries/libchip/include/sams70/component/component_pio.h
> libraries/libchip/include/sams70/component/component_pmc.h
> libraries/libchip/include/sams70/component/component_pwm.h
> libraries/libchip/include/sams70/component/component_qspi.h
> libraries/libchip/include/sams70/component/component_rstc.h
> libraries/libchip/include/sams70/component/component_rswdt.h
> libraries/libchip/include/sams70/component/component_rtc.h
> libraries/libchip/include/sams70/component/component_rtt.h
> libraries/libchip/include/sams70/component/component_sdramc.h
> libraries/libchip/include/sams70/component/component_smc.h
> libraries/libchip/include/sams70/component/component_spi.h
> libraries/libchip/include/sams70/component/component_ssc.h
> libraries/libchip/include/sams70/component/component_supc.h
> libraries/libchip/include/sams70/component/component_tc.h
> libraries/libchip/include/sams70/component/component_trng.h
> libraries/libchip/include/sams70/component/component_twihs.h
> libraries/libchip/include/sams70/component/component_uart.h
> libraries/libchip/include/sams70/component/component_usart.h
> libraries/libchip/include/sams70/component/component_usbhs.h
> libraries/libchip/include/sams70/component/component_utmi.h
> libraries/libchip/include/sams70/component/component_wdt.h
> libraries/libchip/include/sams70/component/component_xdmac.h
> +include_libchip_include_sams70_piodir =
> $(includedir)/libchip/include/sams70/pio
> +include_libchip_include_sams70_pio_HEADERS =
> +include_libchip_include_sams70_pio_HEADERS +=
> libraries/libchip/include/sams70/pio/pio_sams70j19.h
> libraries/libchip/include/sams70/pio/pio_sams70j20.h
> libraries/libchip/include/sams70/pio/pio_sams70j21.h
> libraries/libchip/include/sams70/pio/pio_sams70n19.h
> libraries/libchip/include/sams70/pio/pio_sams70n20.h
> libraries/libchip/include/sams70/pio/pio_sams70n21.h
> libraries/libchip/include/sams70/pio/pio_sams70q19.h
> libraries/libchip/include/sams70/pio/pio_sams70q20.h
> libraries/libchip/include/sams70/pio/pio_sams70q21.h
> +include_libchip_include_samv71dir = $(includedir)/libchip/include/samv71
> +include_libchip_include_samv71_HEADERS =
> +include_libchip_include_samv71_HEADERS +=
> libraries/libchip/include/samv71/samv71.h
> libraries/libchip/include/samv71/samv71j19.h
> libraries/libchip/include/samv71/samv71j20.h
> libraries/libchip/include/samv71/samv71j21.h
> libraries/libchip/include/samv71/samv71n19.h
> libraries/libchip/include/samv71/samv71n20.h
> libraries/libchip/include/samv71/samv71n21.h
> libraries/libchip/include/samv71/samv71q19.h
> libraries/libchip/include/samv71/samv71q20.h
> libraries/libchip/include/samv71/samv71q21.h
> libraries/libchip/include/samv71/system_samv71.h
> +include_libchip_include_samv71_componentdir =
> $(includedir)/libchip/include/samv71/component
> +include_libchip_include_samv71_component_HEADERS =
> +include_libchip_include_samv71_component_HEADERS +=
> libraries/libchip/include/samv71/component/component_acc.h
> libraries/libchip/include/samv71/component/component_aes.h
> libraries/libchip/include/samv71/component/component_afec.h
> libraries/libchip/include/samv71/component/component_chipid.h
> libraries/libchip/include/samv71/component/component_dacc.h
> libraries/libchip/include/samv71/component/component_efc.h
> libraries/libchip/include/samv71/component/component_gmac.h
> libraries/libchip/include/samv71/component/component_gpbr.h
> libraries/libchip/include/samv71/component/component_hsmci.h
> libraries/libchip/include/samv71/component/component_icm.h
> libraries/libchip/include/samv71/component/component_isi.h
> libraries/libchip/include/samv71/component/component_matrix.h
> libraries/libchip/include/samv71/component/component_mcan.h
> libraries/libchip/include/samv71/component/component_mlb.h
> libraries/libchip/include/samv71/component/component_pio.h
> libraries/libchip/include/samv71/component/component_pmc.h
> libraries/libchip/include/samv71/component/component_pwm.h
> libraries/libchip/include/samv71/component/component_qspi.h
> libraries/libchip/include/samv71/component/component_rstc.h
> libraries/libchip/include/samv71/component/component_rswdt.h
> libraries/libchip/include/samv71/component/component_rtc.h
> libraries/libchip/include/samv71/component/component_rtt.h
> libraries/libchip/include/samv71/component/component_sdramc.h
> libraries/libchip/include/samv71/component/component_smc.h
> libraries/libchip/include/samv71/component/component_spi.h
> libraries/libchip/include/samv71/component/component_ssc.h
> libraries/libchip/include/samv71/component/component_supc.h
> libraries/libchip/include/samv71/component/component_tc.h
> libraries/libchip/include/samv71/component/component_trng.h
> libraries/libchip/include/samv71/component/component_twihs.h
> libraries/libchip/include/samv71/component/component_uart.h
> libraries/libchip/include/samv71/component/component_usart.h
> libraries/libchip/include/samv71/component/component_usbhs.h
> libraries/libchip/include/samv71/component/component_utmi.h
> libraries/libchip/include/samv71/component/component_wdt.h
> libraries/libchip/include/samv71/component/component_xdmac.h
> +include_libchip_include_samv71_piodir =
> $(includedir)/libchip/include/samv71/pio
> +include_libchip_include_samv71_pio_HEADERS =
> +include_libchip_include_samv71_pio_HEADERS +=
> libraries/libchip/include/samv71/pio/pio_samv71j19.h
> libraries/libchip/include/samv71/pio/pio_samv71j20.h
> libraries/libchip/include/samv71/pio/pio_samv71j21.h
> libraries/libchip/include/samv71/pio/pio_samv71n19.h
> libraries/libchip/include/samv71/pio/pio_samv71n20.h
> libraries/libchip/include/samv71/pio/pio_samv71n21.h
> libraries/libchip/include/samv71/pio/pio_samv71q19.h
> libraries/libchip/include/samv71/pio/pio_samv71q20.h
> libraries/libchip/include/samv71/pio/pio_samv71q21.h
> +# LibBSP
> +noinst_LIBRARIES += libbsp.a
> +libbsp_a_SOURCES =
> +libbsp_a_CPPFLAGS =
> +libbsp_a_LIBADD =
> +# Shared
> +libbsp_a_SOURCES += ../../shared/bootcard.c
> +libbsp_a_SOURCES += ../../shared/bspclean.c
> +libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
> +libbsp_a_SOURCES += ../../shared/bsplibc.c
> +libbsp_a_SOURCES += ../../shared/bsppost.c
> +libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
> +libbsp_a_SOURCES += ../../shared/cpucounterread.c
> +libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
> +libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
> +libbsp_a_SOURCES += ../../shared/sbrk.c
> +libbsp_a_SOURCES += ../../shared/src/stackalloc.c
> +# libchip
> +libbsp_a_SOURCES += libraries/libchip/source/acc.c
> +libbsp_a_SOURCES += libraries/libchip/source/aes.c
> +libbsp_a_SOURCES += libraries/libchip/source/afec.c
> +libbsp_a_SOURCES += libraries/libchip/source/afe_dma.c
> +libbsp_a_SOURCES += libraries/libchip/source/dac_dma.c
> +libbsp_a_SOURCES += libraries/libchip/source/efc.c
> +libbsp_a_SOURCES += libraries/libchip/source/exceptions.c
> +libbsp_a_SOURCES += libraries/libchip/source/flashd.c
> +libbsp_a_SOURCES += libraries/libchip/source/gmac.c
> +libbsp_a_SOURCES += libraries/libchip/source/gmacd.c
> +libbsp_a_SOURCES += libraries/libchip/source/hsmci.c
> +libbsp_a_SOURCES += libraries/libchip/source/icm.c
> +libbsp_a_SOURCES += libraries/libchip/source/isi.c
> +libbsp_a_SOURCES += libraries/libchip/source/mcan.c
> +libbsp_a_SOURCES += libraries/libchip/source/mediaLB.c
> +libbsp_a_SOURCES += libraries/libchip/source/mpu.c
> +libbsp_a_SOURCES += libraries/libchip/source/pio.c
> +libbsp_a_SOURCES += libraries/libchip/source/pio_capture.c
> +libbsp_a_SOURCES += libraries/libchip/source/pio_it.c
> +libbsp_a_SOURCES += libraries/libchip/source/pmc.c
> +libbsp_a_SOURCES += libraries/libchip/source/pwmc.c
> +libbsp_a_SOURCES += libraries/libchip/source/qspi.c
> +libbsp_a_SOURCES += libraries/libchip/source/qspi_dma.c
> +libbsp_a_SOURCES += libraries/libchip/source/rstc.c
> +libbsp_a_SOURCES += libraries/libchip/source/rtc.c
> +libbsp_a_SOURCES += libraries/libchip/source/rtt.c
> +libbsp_a_SOURCES += libraries/libchip/source/sdramc.c
> +libbsp_a_SOURCES += libraries/libchip/source/spi.c
> +libbsp_a_SOURCES += libraries/libchip/source/spi_dma.c
> +libbsp_a_SOURCES += libraries/libchip/source/ssc.c
> +libbsp_a_SOURCES += libraries/libchip/source/supc.c
> +libbsp_a_SOURCES += libraries/libchip/source/tc.c
> +libbsp_a_SOURCES += libraries/libchip/source/trng.c
> +libbsp_a_SOURCES += libraries/libchip/source/twi.c
> +libbsp_a_SOURCES += libraries/libchip/source/twid.c
> +libbsp_a_SOURCES += libraries/libchip/source/uart.c
> +libbsp_a_SOURCES += libraries/libchip/source/uart_dma.c
> +libbsp_a_SOURCES += libraries/libchip/source/usart.c
> +libbsp_a_SOURCES += libraries/libchip/source/usart_dma.c
> +libbsp_a_SOURCES += libraries/libchip/source/wdt.c
> +libbsp_a_SOURCES += libraries/libchip/source/xdmac.c
> +libbsp_a_SOURCES += libraries/libchip/source/xdmad.c
> +libbsp_a_SOURCES += libraries/libchip/source/xdma_hardware_interface.c
> +# libboard
> +libbsp_a_SOURCES += libraries/libboard/resources_v71/system_samv71.c
> +libbsp_a_SOURCES += libraries/libboard/source/board_lowlevel.c
> +libbsp_a_SOURCES += libraries/libboard/source/board_memories.c
> +libbsp_a_SOURCES += libraries/libboard/source/dbg_console.c
> +# Startup
> +libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
> +libbsp_a_SOURCES += ../shared/armv7m/startup/bspreset.c
> +libbsp_a_SOURCES += startup/bspstart.c
> +libbsp_a_SOURCES += startup/bspstarthooks.c
> +libbsp_a_SOURCES += startup/pin-config.c
> +# IRQ
> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
> +libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
> +libbsp_a_SOURCES += ../../shared/src/irq-server.c
> +libbsp_a_SOURCES += ../../shared/src/irq-shell.c
> +libbsp_a_SOURCES += ../shared/armv7m/irq/armv7m-irq.c
> +libbsp_a_SOURCES += ../shared/armv7m/irq/armv7m-irq-dispatch.c
> +# Console
> +libbsp_a_SOURCES += ../../shared/console-termios.c
> +libbsp_a_SOURCES += console/console.c
> +libbsp_a_SOURCES += console/debug-console.c
> +# Clock
> +libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
> +libbsp_a_SOURCES += ../shared/armv7m/clock/armv7m-clock-config.c
> +libbsp_a_SOURCES += clock/systick-freq.c
> +# Timer
> +libbsp_a_SOURCES += ../../shared/timerstub.c
> +# Cache
> +libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
> +libbsp_a_SOURCES += ../shared/armv7m/include/cache_.h
> +libbsp_a_CPPFLAGS += -I$(srcdir)/../shared/armv7m/include
> +# Includes
> +libbsp_a_CPPFLAGS += -I$(srcdir)/../shared/CMSIS/Include
> +libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libboard
> +libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libboard/include
> +libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libchip
> +libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libchip/include
> +# Special Rules
> +DISTCLEANFILES = include/bspopts.h
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/../../../../automake/local.am
> diff --git a/c/src/lib/libbsp/arm/atsam/README
> b/c/src/lib/libbsp/arm/atsam/README
> index 0000000..8f96a7f
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/README
> @@ -0,0 +1,56 @@
> +Board support package for the Atmel SAM V71/V70/E70/S70 chip platform.
> +The BSP is customized to a particular board/chip variant by means of
> configure
> +command line options.
> +Use --enable-chip=XYZ to select the chip variant where XYZ is one of
> same70j19,
> +same70j20, same70j21, same70n19, same70n20, same70n21, same70q19,
> same70q20,
> +same70q21, sams70j19, sams70j20, sams70j21, sams70n19, sams70n20,
> sams70n21,
> +sams70q19, sams70q20, sams70q21, samv71j19, samv71j20, samv71j21,
> samv71n19,
> +samv71n20, samv71n21, samv71q19, samv71q20 and samv71q21. By default the
> BSP
> +uses the ATSAMV71Q21 chip. Not all variants are tested.
> +Use BOARD_MAINOSC=XYZ to set the main oscillator frequency in Hz (default
> +12MHz).
> +Use BOARD_MCK=XYZ to set the Master Clock (MCK) frequency in Hz (default
> +123MHz). The default value enables operation of an external SDRAM, e.g.
> 150MHz
> +would be too fast.
> +Use ATSAM_CONSOLE_BAUD=XYZ to set the initial baud for console devices
> (default
> +115200).
> +Use ATSAM_CONSOLE_DEVICE_TYPE=XYZ to set the device type for
> /dev/console, use
> +0 for USART and 1 for UART (default USART).
> +Use ATSAM_CONSOLE_DEVICE_INDEX=XYZ to set the device index for
> /dev/console
> +(default 1, e.g. USART1).
> +Use ATSAM_CONSOLE_USE_INTERRUPTS=XYZ to set the use interrupt driven mode
> for
> +console devices (used by default).
> +Use ATSAM_MEMORY_TCM_SIZE=XYZ to set the size of tightly coupled memories
> (TCM)
> +in bytes (default 0x00000000).
> +Use ATSAM_MEMORY_INTFLASH_SIZE=XYZ to set the size of internal flash in
> bytes
> +(default 0x00200000).
> +Use ATSAM_MEMORY_INTSRAM_SIZE=XYZ to set the size of internal SRAM in
> bytes
> +(default 0x00060000).
> +Use ATSAM_MEMORY_SDRAM_SIZE=XYZ to set the size of external SDRAM in bytes
> +The pins may be configured by the application at link-time. See
> +<bsp/pin-config.h>.
> +The clock driver uses the ARMv7-M Systick.
> +The console driver supports the USART and UART devices.
> +The default linker command file places the code into the internal flash.
> Use
> +"LDFLAGS += -qnolinkcmds -T linkcmds.sdram" to place the code into the
> external
> +SDRAM. Use "LDFLAGS += -qnolinkcmds -T linkcmds.intsram" to place the
> code
> +into the internal SRAM.
> +The fast text section uses the ITCM. The fast data section uses the DTCM.
> diff --git a/c/src/lib/libbsp/arm/atsam/bsp_specs
> b/c/src/lib/libbsp/arm/atsam/bsp_specs
> index 0000000..32c105f
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/bsp_specs
> @@ -0,0 +1,13 @@
> +%rename endfile old_endfile
> +%rename startfile old_startfile
> +%rename link old_link
> +*startfile:
> +%{!qrtems: %(old_startfile)} \
> +%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
> +*link:
> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
> +*endfile:
> +%{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
> diff --git a/c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
> b/c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
> index 0000000..060fa17
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/clock/systick-freq.c
> @@ -0,0 +1,31 @@
> + * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <bsp.h>
> +#include <chip.h>
> +uint32_t atsam_systick_frequency(void)
> + uint32_t mdiv = (PMC->PMC_MCKR & PMC_MCKR_MDIV_Msk) >>
> PMC_MCKR_MDIV_Pos;
> + uint32_t fclk;
> + if (mdiv == 3) {
> + fclk = BOARD_MCK * mdiv;
> + } else {
> + fclk = BOARD_MCK * (1 << mdiv);
> + return fclk;
> diff --git a/c/src/lib/libbsp/arm/atsam/configure.ac
> b/c/src/lib/libbsp/arm/atsam/configure.ac
> index 0000000..c459557
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/configure.ac
> @@ -0,0 +1,85 @@
> +AC_PREREQ([2.69])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-atsam],[_RTEMS_VERSION],[
> https://devel.rtems.org/newticket])
> +AC_CONFIG_SRCDIR([bsp_specs])
> +RTEMS_TOP(../../../../../..)
> +RTEMS_CANONICAL_TARGET_CPU
> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> +RTEMS_BSP_CONFIGURE
> +RTEMS_PROG_CC_FOR_TARGET
> +RTEMS_CANONICALIZE_TOOLS
> +RTEMS_PROG_CCAS
> +RTEMS_CHECK_NETWORKING
> +AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
> +RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
> +AC_ARG_ENABLE(
> +[chip],
> +[AS_HELP_STRING([--enable-chip],[select a chip variant (default
> samv71q21)])],
> +[case "${enableval}" in
> + same70j19) AC_DEFINE([__SAME70J19__],[1],[chip variant]) ;;
> + same70j20) AC_DEFINE([__SAME70J20__],[1],[chip variant]) ;;
> + same70j21) AC_DEFINE([__SAME70J21__],[1],[chip variant]) ;;
> + same70n19) AC_DEFINE([__SAME70N19__],[1],[chip variant]) ;;
> + same70n20) AC_DEFINE([__SAME70N20__],[1],[chip variant]) ;;
> + same70n21) AC_DEFINE([__SAME70N21__],[1],[chip variant]) ;;
> + same70q19) AC_DEFINE([__SAME70Q19__],[1],[chip variant]) ;;
> + same70q20) AC_DEFINE([__SAME70Q20__],[1],[chip variant]) ;;
> + same70q21) AC_DEFINE([__SAME70Q21__],[1],[chip variant]) ;;
> + sams70j19) AC_DEFINE([__SAMS70J19__],[1],[chip variant]) ;;
> + sams70j20) AC_DEFINE([__SAMS70J20__],[1],[chip variant]) ;;
> + sams70j21) AC_DEFINE([__SAMS70J21__],[1],[chip variant]) ;;
> + sams70n19) AC_DEFINE([__SAMS70N19__],[1],[chip variant]) ;;
> + sams70n20) AC_DEFINE([__SAMS70N20__],[1],[chip variant]) ;;
> + sams70n21) AC_DEFINE([__SAMS70N21__],[1],[chip variant]) ;;
> + sams70q19) AC_DEFINE([__SAMS70Q19__],[1],[chip variant]) ;;
> + sams70q20) AC_DEFINE([__SAMS70Q20__],[1],[chip variant]) ;;
> + sams70q21) AC_DEFINE([__SAMS70Q21__],[1],[chip variant]) ;;
> + samv71j19) AC_DEFINE([__SAMV71J19__],[1],[chip variant]) ;;
> + samv71j20) AC_DEFINE([__SAMV71J20__],[1],[chip variant]) ;;
> + samv71j21) AC_DEFINE([__SAMV71J21__],[1],[chip variant]) ;;
> + samv71n19) AC_DEFINE([__SAMV71N19__],[1],[chip variant]) ;;
> + samv71n20) AC_DEFINE([__SAMV71N20__],[1],[chip variant]) ;;
> + samv71n21) AC_DEFINE([__SAMV71N21__],[1],[chip variant]) ;;
> + samv71q19) AC_DEFINE([__SAMV71Q19__],[1],[chip variant]) ;;
> + samv71q20) AC_DEFINE([__SAMV71Q20__],[1],[chip variant]) ;;
> + samv71q21) AC_DEFINE([__SAMV71Q21__],[1],[chip variant]) ;;
> + *) AC_MSG_ERROR([bad value ${enableval} for chip variant]) ;;
> +esac],
> +[AC_DEFINE([__SAMV71Q21__],[1],[chip variant])])
> +RTEMS_BSPOPTS_SET([BOARD_MAINOSC],[*],[12000000])
> +RTEMS_BSPOPTS_HELP([BOARD_MAINOSC],[Main oscillator frequency in Hz
> (default 12MHz)])
> +RTEMS_BSPOPTS_SET([BOARD_MCK],[*],[123000000])
> +RTEMS_BSPOPTS_HELP([BOARD_MCK],[Master Clock (MCK) frequency in Hz
> (default 123MHz)])
> +RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_BAUD],[*],[115200])
> +RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_BAUD],[initial baud for console devices
> (default 115200)])
> +RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_DEVICE_TYPE],[*],[0])
> +RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_DEVICE_TYPE],[device type for
> /dev/console, use 0 for USART and 1 for UART (default USART)])
> +RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_DEVICE_INDEX],[*],[1])
> +RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_DEVICE_INDEX],[device index for
> /dev/console (default 1, e.g. USART1)])
> +RTEMS_BSPOPTS_SET([ATSAM_CONSOLE_USE_INTERRUPTS],[*],[1])
> +RTEMS_BSPOPTS_HELP([ATSAM_CONSOLE_USE_INTERRUPTS],[use interrupt driven
> mode for console devices (used by default)])
> +AC_DEFUN([ATSAM_LINKCMD],[
> +AC_ARG_VAR([$1],[$2 (default $3)])dnl
> +[$1]=[$]{[$1]:-[$3]}
> +ATSAM_LINKCMD([ATSAM_MEMORY_TCM_SIZE],[size of tightly coupled memories
> (TCM) in bytes],[0x00000000])
> +ATSAM_LINKCMD([ATSAM_MEMORY_INTFLASH_SIZE],[size of internal flash in
> bytes],[0x00200000])
> +ATSAM_LINKCMD([ATSAM_MEMORY_INTSRAM_SIZE],[size of internal SRAM in
> bytes],[0x00060000])
> +ATSAM_LINKCMD([ATSAM_MEMORY_SDRAM_SIZE],[size of external SDRAM in
> +AC_CONFIG_FILES([
> +Makefile
> +startup/linkcmds.memory
> +AC_OUTPUT
> diff --git a/c/src/lib/libbsp/arm/atsam/console/console.c
> b/c/src/lib/libbsp/arm/atsam/console/console.c
> index 0000000..8ab8526
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/console/console.c
> @@ -0,0 +1,531 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include <bsp.h>
> +#include <bsp/irq.h>
> +#include <bsp/fatal.h>
> +#include <rtems/termiostypes.h>
> +#include <chip.h>
> +typedef struct {
> + rtems_termios_device_context base;
> + Usart *regs;
> + rtems_vector_number irq;
> + uint32_t id;
> + bool console;
> +#ifdef ATSAM_CONSOLE_USE_INTERRUPTS
> + bool transmitting;
> +#endif
> +} atsam_usart_context;
> +static atsam_usart_context atsam_usart_instances[] = {
> + .regs = USART0,
> + .irq = USART0_IRQn,
> + .id = ID_USART0
> +#ifdef USART1
> + .regs = USART1,
> + .irq = USART1_IRQn,
> + .id = ID_USART1
> +#endif
> +#ifdef USART2
> + .regs = USART2,
> + .irq = USART2_IRQn,
> + .id = ID_USART2
> +#endif
> +static void atsam_usart_interrupt(void *arg)
> + rtems_termios_tty *tty = arg;
> + atsam_usart_context *ctx = rtems_termios_get_device_context(tty);
> + Usart *regs = ctx->regs;
> + uint32_t csr = regs->US_CSR;
> + while ((csr & US_CSR_RXRDY) != 0) {
> + char c = (char) regs->US_RHR;
> + rtems_termios_enqueue_raw_characters(tty, &c, 1);
> + csr = regs->US_CSR;
> + if (ctx->transmitting && (csr & US_CSR_TXEMPTY) != 0) {
> + rtems_termios_dequeue_characters(tty, 1);
> +#endif
> +static bool atsam_usart_set_attributes(
> + rtems_termios_device_context *base,
> + const struct termios *term
> + atsam_usart_context *ctx = (atsam_usart_context *) base;
> + rtems_termios_baud_t baud;
> + uint32_t mr;
> + baud = rtems_termios_baud_to_number(term->c_cflag);
> + regs->US_BRGR = (BOARD_MCK / baud) / 16;
> + if ((term->c_cflag & CREAD) != 0) {
> + regs->US_CR = US_CR_RXEN | US_CR_TXEN;
> + } else {
> + regs->US_CR = US_CR_TXEN;
> + mr = US_MR_USART_MODE_NORMAL | US_MR_USCLKS_MCK;
> + switch (term->c_cflag & CSIZE) {
> + case CS5:
> + mr |= US_MR_CHRL_5_BIT;
> + break;
> + case CS6:
> + mr |= US_MR_CHRL_6_BIT;
> + break;
> + case CS7:
> + mr |= US_MR_CHRL_7_BIT;
> + break;
> + default:
> + mr |= US_MR_CHRL_8_BIT;
> + break;
> + if ((term->c_cflag & PARENB) != 0) {
> + if ((term->c_cflag & PARODD) != 0) {
> + mr |= US_MR_PAR_ODD;
> + } else {
> + mr |= US_MR_PAR_EVEN;
> + } else {
> + mr |= US_MR_PAR_NO;
> + if ((term->c_cflag & CSTOPB) != 0) {
> + mr |= US_MR_NBSTOP_2_BIT;
> + } else {
> + mr |= US_MR_NBSTOP_1_BIT;
> + regs->US_MR = mr;
> + return true;
> +static bool atsam_usart_first_open(
> + rtems_termios_tty *tty,
> + struct termios *term,
> + rtems_libio_open_close_args_t *args
> + rtems_status_code sc;
> +#endif
> + regs->US_CR = US_CR_RSTRX | US_CR_RSTTX | US_CR_RSTSTA;
> + regs->US_IDR = 0xffffffff;
> + PMC_EnablePeripheral(ctx->id);
> + rtems_termios_set_initial_baud(tty, ATSAM_CONSOLE_BAUD);
> + atsam_usart_set_attributes(base, term);
> + regs->US_IER = US_IDR_RXRDY;
> + sc = rtems_interrupt_handler_install(
> + ctx->irq,
> + "USART",
> + RTEMS_INTERRUPT_SHARED,
> + atsam_usart_interrupt,
> + tty
> + if (sc != RTEMS_SUCCESSFUL) {
> + return false;
> +#endif
> + return true;
> +static void atsam_usart_last_close(
> + rtems_interrupt_handler_remove(ctx->irq, atsam_usart_interrupt, tty);
> +#endif
> + if (!ctx->console) {
> + PMC_DisablePeripheral(ctx->id);
> +static void atsam_usart_write(
> + const char *buf,
> + size_t len
> + if (len > 0) {
> + ctx->transmitting = true;
> + regs->US_THR = buf[0];
> + regs->US_IER = US_IDR_TXEMPTY;
> + } else {
> + ctx->transmitting = false;
> + regs->US_IDR = US_IDR_TXEMPTY;
> +#else
> + size_t i;
> + for (i = 0; i < len; ++i) {
> + while ((regs->US_CSR & US_CSR_TXEMPTY) == 0) {
> + /* Wait */
> + regs->US_THR = buf[i];
> +#endif
> +#ifndef ATSAM_CONSOLE_USE_INTERRUPTS
> +static int atsam_usart_read(rtems_termios_device_context *base)
> + if ((regs->US_CSR & US_CSR_RXRDY) != 0) {
> + return (char) regs->US_RHR;
> + } else {
> + return -1;
> +#endif
> +static const rtems_termios_device_handler atsam_usart_handler = {
> + .first_open = atsam_usart_first_open,
> + .last_close = atsam_usart_last_close,
> + .write = atsam_usart_write,
> + .set_attributes = atsam_usart_set_attributes,
> + .mode = TERMIOS_IRQ_DRIVEN
> +#else
> + .poll_read = atsam_usart_read,
> + .mode = TERMIOS_POLLED
> +#endif
> +typedef struct {
> + Uart *regs;
> + uint32_t id;
> + bool console;
> +#endif
> +} atsam_uart_context;
> +static atsam_uart_context atsam_uart_instances[] = {
> + .regs = UART0,
> + .irq = UART0_IRQn,
> + .id = ID_UART0
> +#ifdef UART1
> + .regs = UART1,
> + .irq = UART1_IRQn,
> + .id = ID_UART1
> +#endif
> +#ifdef UART2
> + .regs = UART2,
> + .irq = UART2_IRQn,
> + .id = ID_UART2
> +#endif
> +#ifdef UART3
> + .regs = UART3,
> + .irq = UART3_IRQn,
> + .id = ID_UART3
> +#endif
> +#ifdef UART4
> + .regs = UART4,
> + .irq = UART4_IRQn,
> + .id = ID_UART4
> +#endif
> +static void atsam_uart_interrupt(void *arg)
> + atsam_uart_context *ctx = rtems_termios_get_device_context(tty);
> + Uart *regs = ctx->regs;
> + uint32_t sr = regs->UART_SR;
> + while ((sr & UART_SR_RXRDY) != 0) {
> + char c = (char) regs->UART_RHR;
> + sr = regs->UART_SR;
> + if (ctx->transmitting && (sr & UART_SR_TXEMPTY) != 0) {
> +#endif
> +static bool atsam_uart_set_attributes(
> + atsam_uart_context *ctx = (atsam_uart_context *) base;
> + uint32_t mr;
> + regs->UART_BRGR = (BOARD_MCK / baud) / 16;
> + regs->UART_CR = UART_CR_RXEN | UART_CR_TXEN;
> + } else {
> + regs->UART_CR = UART_CR_TXEN;
> + mr = UART_MR_FILTER_DISABLED | UART_MR_BRSRCCK_PERIPH_CLK;
> + if ((term->c_cflag & CSIZE) != CS8) {
> + return false;
> + mr |= UART_MR_PAR_ODD;
> + } else {
> + mr |= UART_MR_PAR_EVEN;
> + } else {
> + mr |= UART_MR_PAR_NO;
> + return false;
> + regs->UART_MR = mr;
> + return true;
> +static bool atsam_uart_first_open(
> +#endif
> + regs->UART_CR = UART_CR_RSTRX | UART_CR_RSTTX | UART_CR_RSTSTA;
> + regs->UART_IDR = 0xffffffff;
> + atsam_uart_set_attributes(base, term);
> + regs->UART_IER = UART_IDR_RXRDY;
> + ctx->irq,
> + "UART",
> + atsam_uart_interrupt,
> + tty
> + return false;
> +#endif
> + return true;
> +static void atsam_uart_last_close(
> + rtems_interrupt_handler_remove(ctx->irq, atsam_uart_interrupt, tty);
> +#endif
> +static void atsam_uart_write(
> + const char *buf,
> + size_t len
> + if (len > 0) {
> + regs->UART_THR = buf[0];
> + regs->UART_IER = UART_IDR_TXEMPTY;
> + } else {
> + regs->UART_IDR = UART_IDR_TXEMPTY;
> +#else
> + size_t i;
> + while ((regs->UART_SR & UART_SR_TXEMPTY) == 0) {
> + /* Wait */
> + regs->UART_THR = buf[i];
> +#endif
> +static int atsam_uart_read(rtems_termios_device_context *base)
> + if ((regs->UART_SR & UART_SR_RXRDY) != 0) {
> + return (char) regs->UART_RHR;
> + } else {
> + return -1;
> +#endif
> +static const rtems_termios_device_handler atsam_uart_handler = {
> + .first_open = atsam_uart_first_open,
> + .last_close = atsam_uart_last_close,
> + .write = atsam_uart_write,
> + .set_attributes = atsam_uart_set_attributes,
> +#else
> + .poll_read = atsam_uart_read,
> +#endif
> +rtems_status_code console_initialize(
> + rtems_device_major_number major,
> + rtems_device_minor_number minor,
> + void *arg
> + size_t i;
> + rtems_termios_initialize();
> + for (i = 0; i < RTEMS_ARRAY_SIZE(atsam_usart_instances); ++i) {
> + char usart[] = "/dev/ttyUSARTX";
> + usart[sizeof(usart) - 2] = (char) ('0' + i);
> + rtems_termios_device_install(
> + &usart[0],
> + major,
> + minor,
> + &atsam_usart_handler,
> + NULL,
> + &atsam_usart_instances[i].base
> +#if ATSAM_CONSOLE_DEVICE_TYPE == 0
> + if (i == ATSAM_CONSOLE_DEVICE_INDEX) {
> + atsam_usart_instances[i].console = true;
> + rtems_io_register_name(CONSOLE_DEVICE_NAME, major, minor);
> +#endif
> + ++minor;
> + for (i = 0; i < RTEMS_ARRAY_SIZE(atsam_uart_instances); ++i) {
> + char uart[] = "/dev/ttyUARTX";
> + uart[sizeof(uart) - 2] = (char) ('0' + i);
> + &uart[0],
> + major,
> + minor,
> + &atsam_uart_handler,
> + NULL,
> + &atsam_uart_instances[i].base
> +#if ATSAM_CONSOLE_DEVICE_TYPE == 1
> + atsam_uart_instances[i].console = true;
> +#endif
> + ++minor;
> + return RTEMS_SUCCESSFUL;
> diff --git a/c/src/lib/libbsp/arm/atsam/console/debug-console.c
> b/c/src/lib/libbsp/arm/atsam/console/debug-console.c
> index 0000000..aebc60f
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/console/debug-console.c
> @@ -0,0 +1,55 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include <rtems/bspIo.h>
> +#include <rtems/sysinit.h>
> +#include <chip.h>
> +#include <include/dbg_console.h>
> +static void atsam_debug_console_out(char c)
> + if (c == '\n') {
> + DBG_PutChar('\r');
> + DBG_PutChar((uint8_t) c);
> +static void atsam_debug_console_init(void)
> + DBG_Configure(115200, BOARD_MCK);
> + BSP_output_char = atsam_debug_console_out;
> +static void atsam_debug_console_early_init(char c)
> + atsam_debug_console_init();
> + atsam_debug_console_out(c);
> +static int atsam_debug_console_in(void)
> + return (int) DBG_GetChar();
> +BSP_output_char_function_type BSP_output_char =
> atsam_debug_console_early_init;
> +BSP_polling_getchar_function_type BSP_poll_char = atsam_debug_console_in;
> +RTEMS_SYSINIT_ITEM(
> + atsam_debug_console_init,
> + RTEMS_SYSINIT_BSP_START,
> + RTEMS_SYSINIT_ORDER_LAST
> diff --git a/c/src/lib/libbsp/arm/atsam/include/bsp.h
> b/c/src/lib/libbsp/arm/atsam/include/bsp.h
> index 0000000..974afbd
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/include/bsp.h
> @@ -0,0 +1,45 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef LIBBSP_ARM_ATSAM_BSP_H
> +#define LIBBSP_ARM_ATSAM_BSP_H
> +#include <bspopts.h>
> +#include <bsp/default-initial-extension.h>
> +#include <rtems.h>
> +#include <rtems/console.h>
> +#include <rtems/clockdrv.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +#define BSP_FEATURE_IRQ_EXTENSION
> +#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT (13 << 4)
> +#define BSP_ARMV7M_SYSTICK_PRIORITY (14 << 4)
> +uint32_t atsam_systick_frequency(void);
> +#define BSP_ARMV7M_SYSTICK_FREQUENCY atsam_systick_frequency()
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_ATSAM_BSP_H */
> diff --git a/c/src/lib/libbsp/arm/atsam/include/irq.h
> b/c/src/lib/libbsp/arm/atsam/include/irq.h
> index 0000000..19370e4
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/include/irq.h
> @@ -0,0 +1,30 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef LIBBSP_ARM_ATSAM_ESV_70_IRQ_H
> +#define LIBBSP_ARM_ATSAM_ESV_70_IRQ_H
> +#ifndef ASM
> + #include <rtems.h>
> + #include <rtems/irq.h>
> + #include <rtems/irq-extension.h>
> +#endif
> +#define BSP_INTERRUPT_VECTOR_MIN 0
> +#define BSP_INTERRUPT_VECTOR_MAX 64
> +#endif /* LIBBSP_ARM_ATSAM_ESV_70_IRQ_H */
> diff --git a/c/src/lib/libbsp/arm/atsam/include/pin-config.h
> b/c/src/lib/libbsp/arm/atsam/include/pin-config.h
> index 0000000..8f4a614
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/include/pin-config.h
> @@ -0,0 +1,36 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef LIBBSP_ARM_ATSAM_PIN_CONFIG_H
> +#define LIBBSP_ARM_ATSAM_PIN_CONFIG_H
> +#include <libchip/chip.h>
> +#ifdef __cplusplus
> +extern "C" {
> +extern const Pin atsam_pin_config[];
> +extern const size_t atsam_pin_config_count;
> +extern const uint32_t atsam_matrix_ccfg_sysio;
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_ATSAM_PIN_CONFIG_H */
> diff --git a/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
> b/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
> index 0000000..06892f9
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
> @@ -0,0 +1,10 @@
> +include $(RTEMS_ROOT)/make/custom/default.cfg
> +RTEMS_CPU = arm
> +CPU_CFLAGS = -mthumb -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard
> +CFLAGS_OPTIMIZE_V = -O2 -g
> +CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
> +LDFLAGS = -Wl,--gc-sections
> diff --git a/c/src/lib/libbsp/arm/atsam/preinstall.am
> b/c/src/lib/libbsp/arm/atsam/preinstall.am
> index 0000000..ff0d22f
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/preinstall.am
> @@ -0,0 +1,1038 @@
> +## Automatically generated by ampolish3 - Do not edit
> +if AMPOLISH3
> +$(srcdir)/preinstall.am: Makefile.am
> + $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> +endif
> +PREINSTALL_DIRS =
> +DISTCLEANFILES += $(PREINSTALL_DIRS)
> +all-am: $(PREINSTALL_FILES)
> +PREINSTALL_FILES =
> +CLEANFILES = $(PREINSTALL_FILES)
> +all-local: $(TMPINSTALL_FILES)
> +TMPINSTALL_FILES =
> +CLEANFILES += $(TMPINSTALL_FILES)
> +$(PROJECT_LIB)/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_LIB)
> + @: > $(PROJECT_LIB)/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
> +$(PROJECT_INCLUDE)/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)
> + @: > $(PROJECT_INCLUDE)/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
> +$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
> +PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
> +$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
> +TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
> +$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
> +$(PROJECT_LIB)/linkcmds.memory: startup/linkcmds.memory
> + $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.memory
> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.memory
> +$(PROJECT_LIB)/linkcmds.intsram: startup/linkcmds.intsram
> + $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.intsram
> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.intsram
> +$(PROJECT_LIB)/linkcmds.sdram: startup/linkcmds.sdram
> + $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.sdram
> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.sdram
> +$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
> +$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
> +$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
> +$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
> +$(PROJECT_INCLUDE)/bsp/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
> + @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
> +$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
> +$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
> +$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
> +$(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
> +$(PROJECT_INCLUDE)/bsp/armv7m-irq.h:
> ../shared/armv7m/include/armv7m-irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/armv7m-irq.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/armv7m-irq.h
> +$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
> +$(PROJECT_INCLUDE)/bsp/pin-config.h: include/pin-config.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pin-config.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pin-config.h
> +$(PROJECT_INCLUDE)/libchip/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip
> + @: > $(PROJECT_INCLUDE)/libchip/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/$(dirstamp)
> +$(PROJECT_INCLUDE)/libchip/chip.h: libraries/libchip/chip.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/chip.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/chip.h
> +$(PROJECT_INCLUDE)/libchip/compiler.h: libraries/libchip/compiler.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/compiler.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/compiler.h
> +$(PROJECT_INCLUDE)/libchip/include/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include
> + @: > $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/$(dirstamp)
> +$(PROJECT_INCLUDE)/libchip/include/acc.h: libraries/libchip/include/acc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/acc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/acc.h
> +$(PROJECT_INCLUDE)/libchip/include/adc.h: libraries/libchip/include/adc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/adc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/adc.h
> +$(PROJECT_INCLUDE)/libchip/include/aes.h: libraries/libchip/include/aes.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/aes.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/aes.h
> +$(PROJECT_INCLUDE)/libchip/include/afec.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/afec.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/afec.h
> +$(PROJECT_INCLUDE)/libchip/include/afe_dma.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/afe_dma.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/afe_dma.h
> +$(PROJECT_INCLUDE)/libchip/include/chip.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/chip.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/chip.h
> +$(PROJECT_INCLUDE)/libchip/include/dac_dma.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/dac_dma.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/dac_dma.h
> +$(PROJECT_INCLUDE)/libchip/include/efc.h: libraries/libchip/include/efc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/efc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/efc.h
> +$(PROJECT_INCLUDE)/libchip/include/exceptions.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/exceptions.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/exceptions.h
> +$(PROJECT_INCLUDE)/libchip/include/flashd.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/flashd.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/flashd.h
> +$(PROJECT_INCLUDE)/libchip/include/gmacd.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/gmacd.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/gmacd.h
> +$(PROJECT_INCLUDE)/libchip/include/gmac.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/gmac.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/gmac.h
> +$(PROJECT_INCLUDE)/libchip/include/hsmci.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/hsmci.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/hsmci.h
> +$(PROJECT_INCLUDE)/libchip/include/icm.h: libraries/libchip/include/icm.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/icm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/icm.h
> +$(PROJECT_INCLUDE)/libchip/include/isi.h: libraries/libchip/include/isi.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/isi.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/isi.h
> +$(PROJECT_INCLUDE)/libchip/include/iso7816_4.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/iso7816_4.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/iso7816_4.h
> +$(PROJECT_INCLUDE)/libchip/include/mcan.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mcan.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mcan.h
> +$(PROJECT_INCLUDE)/libchip/include/mcid.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mcid.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mcid.h
> +$(PROJECT_INCLUDE)/libchip/include/mediaLB.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mediaLB.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mediaLB.h
> +$(PROJECT_INCLUDE)/libchip/include/mpu.h: libraries/libchip/include/mpu.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/mpu.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/mpu.h
> +$(PROJECT_INCLUDE)/libchip/include/pio_capture.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pio_capture.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pio_capture.h
> +$(PROJECT_INCLUDE)/libchip/include/pio.h: libraries/libchip/include/pio.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pio.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pio.h
> +$(PROJECT_INCLUDE)/libchip/include/pio_it.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pio_it.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pio_it.h
> +$(PROJECT_INCLUDE)/libchip/include/pmc.h: libraries/libchip/include/pmc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pmc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pmc.h
> +$(PROJECT_INCLUDE)/libchip/include/pwmc.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/pwmc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/pwmc.h
> +$(PROJECT_INCLUDE)/libchip/include/qspi_dma.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/qspi_dma.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/qspi_dma.h
> +$(PROJECT_INCLUDE)/libchip/include/qspi.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/qspi.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/qspi.h
> +$(PROJECT_INCLUDE)/libchip/include/rstc.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/rstc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/rstc.h
> +$(PROJECT_INCLUDE)/libchip/include/rtc.h: libraries/libchip/include/rtc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/rtc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/rtc.h
> +$(PROJECT_INCLUDE)/libchip/include/rtt.h: libraries/libchip/include/rtt.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/rtt.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/rtt.h
> +$(PROJECT_INCLUDE)/libchip/include/sdramc.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/sdramc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sdramc.h
> +$(PROJECT_INCLUDE)/libchip/include/smc.h: libraries/libchip/include/smc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/smc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/smc.h
> +$(PROJECT_INCLUDE)/libchip/include/spi_dma.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/spi_dma.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/spi_dma.h
> +$(PROJECT_INCLUDE)/libchip/include/spi.h: libraries/libchip/include/spi.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/spi.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/spi.h
> +$(PROJECT_INCLUDE)/libchip/include/ssc.h: libraries/libchip/include/ssc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/ssc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/ssc.h
> +$(PROJECT_INCLUDE)/libchip/include/supc.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/supc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/supc.h
> +$(PROJECT_INCLUDE)/libchip/include/tc.h: libraries/libchip/include/tc.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/tc.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/tc.h
> +$(PROJECT_INCLUDE)/libchip/include/timetick.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/timetick.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/timetick.h
> +$(PROJECT_INCLUDE)/libchip/include/trace.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/trace.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/trace.h
> +$(PROJECT_INCLUDE)/libchip/include/trng.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/trng.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/trng.h
> +$(PROJECT_INCLUDE)/libchip/include/twid.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/twid.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/twid.h
> +$(PROJECT_INCLUDE)/libchip/include/twi.h: libraries/libchip/include/twi.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/twi.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/twi.h
> +$(PROJECT_INCLUDE)/libchip/include/uart_dma.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/uart_dma.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/uart_dma.h
> +$(PROJECT_INCLUDE)/libchip/include/uart.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/uart.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/uart.h
> +$(PROJECT_INCLUDE)/libchip/include/usart_dma.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/usart_dma.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/usart_dma.h
> +$(PROJECT_INCLUDE)/libchip/include/usart.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/usart.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/usart.h
> +$(PROJECT_INCLUDE)/libchip/include/usbhs.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/usbhs.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/usbhs.h
> +$(PROJECT_INCLUDE)/libchip/include/video.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/video.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/video.h
> +$(PROJECT_INCLUDE)/libchip/include/wdt.h: libraries/libchip/include/wdt.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/wdt.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/wdt.h
> +$(PROJECT_INCLUDE)/libchip/include/xdmac.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/xdmac.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/xdmac.h
> +$(PROJECT_INCLUDE)/libchip/include/xdmad.h:
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/include/xdmad.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/xdmad.h
> +$(PROJECT_INCLUDE)/libchip/include/xdma_hardware_interface.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/same70
> + @: > $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/same70/$(dirstamp)
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70j19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70j19.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70j20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70j20.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70j21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70j21.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70n19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70n19.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70n20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70n20.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70n21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70n21.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70q19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70q19.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70q20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70q20.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/same70q21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/same70/same70q21.h
> +$(PROJECT_INCLUDE)/libchip/include/same70/system_same70.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/same70/component
> +PREINSTALL_DIRS +=
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_acc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_aes.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_afec.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_chipid.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_dacc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_efc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_gmac.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_gpbr.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_hsmci.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_icm.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_isi.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_matrix.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_mcan.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_pio.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_pmc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_pwm.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_qspi.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rstc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rswdt.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_rtt.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_sdramc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_smc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_spi.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_ssc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_supc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_tc.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_trng.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_twihs.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_uart.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_usart.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_usbhs.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_utmi.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_wdt.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/component/component_xdmac.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/same70/pio
> + @: > $(PROJECT_INCLUDE)/libchip/include/same70/pio/$(dirstamp)
> +PREINSTALL_DIRS +=
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j19.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j20.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70j21.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n19.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n20.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70n21.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q19.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q20.h:
> +$(PROJECT_INCLUDE)/libchip/include/same70/pio/pio_same70q21.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/sams70
> + @: > $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/sams70/$(dirstamp)
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70j19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j19.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70j20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j20.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70j21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70j21.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70n19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n19.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70n20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n20.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70n21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70n21.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70q19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q19.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70q20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q20.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/sams70q21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/sams70/sams70q21.h
> +$(PROJECT_INCLUDE)/libchip/include/sams70/system_sams70.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/sams70/component
> +PREINSTALL_DIRS +=
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_acc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_aes.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_afec.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_chipid.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_dacc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_efc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_gpbr.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_hsmci.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_icm.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_isi.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_matrix.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pio.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pmc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_pwm.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_qspi.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rstc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rswdt.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_rtt.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_sdramc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_smc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_spi.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_ssc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_supc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_tc.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_trng.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_twihs.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_uart.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usart.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_usbhs.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_utmi.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_wdt.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/component/component_xdmac.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/sams70/pio
> + @: > $(PROJECT_INCLUDE)/libchip/include/sams70/pio/$(dirstamp)
> +PREINSTALL_DIRS +=
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j19.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j20.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70j21.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n19.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n20.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70n21.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q19.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q20.h:
> +$(PROJECT_INCLUDE)/libchip/include/sams70/pio/pio_sams70q21.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/samv71
> + @: > $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/include/samv71/$(dirstamp)
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71j19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j19.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71j20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j20.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71j21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71j21.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71n19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n19.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71n20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n20.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71n21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71n21.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71q19.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q19.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71q20.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q20.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/samv71q21.h:
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/include/samv71/samv71q21.h
> +$(PROJECT_INCLUDE)/libchip/include/samv71/system_samv71.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/samv71/component
> +PREINSTALL_DIRS +=
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_acc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_aes.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_afec.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_chipid.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_dacc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_efc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gmac.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_gpbr.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_hsmci.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_icm.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_isi.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_matrix.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mcan.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_mlb.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pio.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pmc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_pwm.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_qspi.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rstc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rswdt.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_rtt.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_sdramc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_smc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_spi.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_ssc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_supc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_tc.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_trng.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_twihs.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_uart.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usart.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_usbhs.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_utmi.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_wdt.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/component/component_xdmac.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip/include/samv71/pio
> + @: > $(PROJECT_INCLUDE)/libchip/include/samv71/pio/$(dirstamp)
> +PREINSTALL_DIRS +=
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j19.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j20.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71j21.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n19.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n20.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71n21.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q19.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q20.h:
> +$(PROJECT_INCLUDE)/libchip/include/samv71/pio/pio_samv71q21.h:
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/bspstart.c
> b/c/src/lib/libbsp/arm/atsam/startup/bspstart.c
> new file mode 100644
> index 0000000..55b16cf
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/bspstart.c
> @@ -0,0 +1,32 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include <bsp.h>
> +#include <bsp/bootcard.h>
> +#include <bsp/irq-generic.h>
> +#include <chip.h>
> +RTEMS_STATIC_ASSERT(
> + PERIPH_COUNT_IRQn <= BSP_INTERRUPT_VECTOR_MAX,
> + PERIPH_COUNT_IRQn
> +void bsp_start(void)
> + bsp_interrupt_initialize();
> + SCB_CleanDCache();
> + SCB_InvalidateICache();
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
> b/c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
> index 0000000..718a262
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c
> @@ -0,0 +1,53 @@
> + * Copyright (c) 2016 embedded brains GmbH Huber. All rights reserved.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include <bsp.h>
> +#include <bsp/start.h>
> +#include <bsp/pin-config.h>
> +#include <chip.h>
> +#include <include/board_lowlevel.h>
> +#include <include/board_memories.h>
> +void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
> + system_init_flash(BOARD_MCK);
> + SystemInit();
> + PIO_Configure(&atsam_pin_config[0], atsam_pin_config_count);
> + MATRIX->CCFG_SYSIO = atsam_matrix_ccfg_sysio;
> + if (!PMC_IsPeriphEnabled(ID_SDRAMC)) {
> + BOARD_ConfigureSdram();
> + if ((SCB->CCR & SCB_CCR_IC_Msk) == 0) {
> + SCB_EnableICache();
> + if ((SCB->CCR & SCB_CCR_DC_Msk) == 0) {
> + SCB_EnableDCache();
> + _SetupMemoryRegion();
> +void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
> + bsp_start_copy_sections_compact();
> + bsp_start_clear_bss();
> + WDT_Disable(WDT);
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds
> b/c/src/lib/libbsp/arm/atsam/startup/linkcmds
> index 0000000..61aff87
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds
> @@ -0,0 +1,21 @@
> +INCLUDE linkcmds.memory
> +REGION_ALIAS ("REGION_START", INTFLASH);
> +REGION_ALIAS ("REGION_VECTOR", INTSRAM);
> +REGION_ALIAS ("REGION_TEXT", INTFLASH);
> +REGION_ALIAS ("REGION_TEXT_LOAD", INTFLASH);
> +REGION_ALIAS ("REGION_RODATA", INTFLASH);
> +REGION_ALIAS ("REGION_RODATA_LOAD", INTFLASH);
> +REGION_ALIAS ("REGION_DATA", INTSRAM);
> +REGION_ALIAS ("REGION_DATA_LOAD", INTFLASH);
> +REGION_ALIAS ("REGION_FAST_TEXT", ITCM);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", INTFLASH);
> +REGION_ALIAS ("REGION_FAST_DATA", DTCM);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", INTFLASH);
> +REGION_ALIAS ("REGION_BSS", INTSRAM);
> +REGION_ALIAS ("REGION_WORK", INTSRAM);
> +REGION_ALIAS ("REGION_STACK", INTSRAM);
> +REGION_ALIAS ("REGION_NOCACHE", INTSRAM);
> +REGION_ALIAS ("REGION_NOCACHE_LOAD", INTFLASH);
> +INCLUDE linkcmds.armv7m
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
> b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
> index 0000000..1a17ed3
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram
> @@ -0,0 +1,23 @@
> +bsp_vector_table_in_start_section = 1;
> +REGION_ALIAS ("REGION_START", INTSRAM);
> +REGION_ALIAS ("REGION_TEXT", INTSRAM);
> +REGION_ALIAS ("REGION_TEXT_LOAD", INTSRAM);
> +REGION_ALIAS ("REGION_RODATA", INTSRAM);
> +REGION_ALIAS ("REGION_RODATA_LOAD", INTSRAM);
> +REGION_ALIAS ("REGION_DATA_LOAD", INTSRAM);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", INTSRAM);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", INTSRAM);
> +REGION_ALIAS ("REGION_NOCACHE_LOAD", INTSRAM);
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
> b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
> index 0000000..5eb14dc
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in
> @@ -0,0 +1,7 @@
> +MEMORY {
> + ITCM : ORIGIN = 0x00000000, LENGTH = @ATSAM_MEMORY_TCM_SIZE@
> + INTFLASH : ORIGIN = 0x00400000, LENGTH =
> @ATSAM_MEMORY_INTFLASH_SIZE@
> + DTCM : ORIGIN = 0x20000000, LENGTH = @ATSAM_MEMORY_TCM_SIZE@
> + INTSRAM : ORIGIN = 0x20400000, LENGTH =
> @ATSAM_MEMORY_INTSRAM_SIZE@
> + SDRAM : ORIGIN = 0x70000000, LENGTH = @ATSAM_MEMORY_SDRAM_SIZE@
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
> b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
> index 0000000..675e837
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram
> @@ -0,0 +1,21 @@
> +REGION_ALIAS ("REGION_START", SDRAM);
> +REGION_ALIAS ("REGION_TEXT", SDRAM);
> +REGION_ALIAS ("REGION_TEXT_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_RODATA", SDRAM);
> +REGION_ALIAS ("REGION_RODATA_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_DATA", SDRAM);
> +REGION_ALIAS ("REGION_DATA_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_BSS", SDRAM);
> +REGION_ALIAS ("REGION_WORK", SDRAM);
> +REGION_ALIAS ("REGION_STACK", SDRAM);
> +REGION_ALIAS ("REGION_NOCACHE", SDRAM);
> +REGION_ALIAS ("REGION_NOCACHE_LOAD", SDRAM);
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/pin-config.c
> b/c/src/lib/libbsp/arm/atsam/startup/pin-config.c
> index 0000000..8a18ae8
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/startup/pin-config.c
> @@ -0,0 +1,42 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +const Pin atsam_pin_config[] = {
> + /* Console */
> + {PIO_PA21A_RXD1, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT},
> + {PIO_PB4D_TXD1, PIOB, ID_PIOB, PIO_PERIPH_D, PIO_DEFAULT},
> + /* SDRAM */
> + /* D0_7 */ {0x000000FF, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
> + /* D8_13 */ {0x0000003F, PIOE, ID_PIOE, PIO_PERIPH_A, PIO_DEFAULT},
> + /* D14_15 */ {0x00018000, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT},
> + /* A0_9 */ {0x3FF00000, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
> + /* SDA10 */ {0x00002000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* CAS */ {0x00020000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* RAS */ {0x00010000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* SDCKE */ {0x00004000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* SDCK */ {0x00800000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* SDSC */ {0x00008000, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
> + /* NBS0 */ {0x00040000, PIOC, ID_PIOC, PIO_PERIPH_A, PIO_DEFAULT},
> + /* NBS1 */ {0x00008000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* SDWE */ {0x20000000, PIOD, ID_PIOD, PIO_PERIPH_C, PIO_DEFAULT},
> + /* BA0 */ {0x00100000, PIOA, ID_PIOA, PIO_PERIPH_C, PIO_DEFAULT}
> +const size_t atsam_pin_config_count = PIO_LISTSIZE(atsam_pin_config);
> +const uint32_t atsam_matrix_ccfg_sysio = 0x20400010;
> diff --git a/c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
> b/c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
> index 0000000..ef94c11
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
> @@ -0,0 +1,144 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef LIBBSP_ARM_ARMV7M_CACHE__H
> +#define LIBBSP_ARM_ARMV7M_CACHE__H
> +#include <rtems.h>
> +#include <chip.h>
> +#define CPU_DATA_CACHE_ALIGNMENT 32
> +#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
> +#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
> +static inline void _CPU_cache_flush_data_range(
> + const void *d_addr,
> + size_t n_bytes
> + SCB_CleanInvalidateDCache_by_Addr(
> + RTEMS_DECONST(uint32_t *, (const uint32_t *) d_addr),
> + n_bytes
> +static inline void _CPU_cache_invalidate_data_range(
> + size_t n_bytes
> + SCB_InvalidateDCache_by_Addr(
> + n_bytes
> +static inline void _CPU_cache_freeze_data(void)
> + /* TODO */
> +static inline void _CPU_cache_unfreeze_data(void)
> + /* TODO */
> +static inline void _CPU_cache_invalidate_instruction_range(
> + const void *i_addr,
> + size_t n_bytes
> + rtems_interrupt_level level;
> + rtems_interrupt_disable(level);
> + rtems_interrupt_enable(level);
> +static inline void _CPU_cache_freeze_instruction(void)
> + /* TODO */
> +static inline void _CPU_cache_unfreeze_instruction(void)
> + /* TODO */
> +static inline void _CPU_cache_flush_entire_data(void)
> +static inline void _CPU_cache_invalidate_entire_data(void)
> + SCB_InvalidateDCache();
> +static inline void _CPU_cache_enable_data(void)
> +static inline void _CPU_cache_disable_data(void)
> + SCB_DisableDCache();
> +static inline void _CPU_cache_invalidate_entire_instruction(void)
> +static inline void _CPU_cache_enable_instruction(void)
> +static inline void _CPU_cache_disable_instruction(void)
> + SCB_DisableICache();
> +#endif /* LIBBSP_ARM_ARMV7M_CACHE__H */
> diff --git a/c/src/lib/libbsp/arm/shared/include/start.h
> b/c/src/lib/libbsp/arm/shared/include/start.h
> index 9df6df4..f61eed3 100644
> --- a/c/src/lib/libbsp/arm/shared/include/start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/start.h
> @@ -121,6 +121,45 @@ BSP_START_TEXT_SECTION static inline void
> bsp_start_copy_sections(void)
> +BSP_START_TEXT_SECTION static inline void
> +bsp_start_memcpy_libc(void *dest, const void *src, size_t n)
> + if (dest != src) {
> + memcpy(dest, src, n);
> + * @brief Copies the .data, .fast_text and .fast_data sections from the
> load to
> + * the runtime area using the C library memcpy().
> + * Works only in case the .start, .text and .rodata sections reside in one
> + * memory region.
> bsp_start_copy_sections_compact(void)
> + /* Copy .data section */
> + bsp_start_memcpy_libc(
> + bsp_section_data_begin,
> + bsp_section_data_load_begin,
> + (size_t) bsp_section_data_size
> + /* Copy .fast_text section */
> + bsp_section_fast_text_begin,
> + bsp_section_fast_text_load_begin,
> + (size_t) bsp_section_fast_text_size
> + /* Copy .fast_data section */
> + bsp_section_fast_data_begin,
> + bsp_section_fast_data_load_begin,
> + (size_t) bsp_section_fast_data_size
> BSP_START_TEXT_SECTION static inline void bsp_start_clear_bss(void)
> memset(bsp_section_bss_begin, 0, (size_t) bsp_section_bss_size);
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160115/71ece4cd/attachment-0001.html>
