Fwd: [rtems commit] Merge branch 'master' of ssh://dispatch.rtems.org/data/git/ rtems
Mon Jan 18 06:33:32 UTC 2016
Looks all right.
You can avoid this problem in the future if you add something like this
to your .git/config:
[branch "abc"]
rebase = true
On 16/01/16 21:36, Joel Sherrill wrote:
> Please check that I did not screw the master up.
> I was at a library for an authors' day with Michele. I was committing
> a GCI patch and accidentally did this.
> Double check and revert if needed.
> Thanks.
> ---------- Forwarded message ----------
> From: "Joel Sherrill" <joel at rtems.org <mailto:joel at rtems.org>>
> Date: Jan 16, 2016 11:18 AM
> Subject: [rtems commit] Merge branch 'master' of
> <http://dispatch.rtems.org/data/git/> rtems
> To: <vc at rtems.org <mailto:vc at rtems.org>>
> Cc:
> Module:    rtems
> Branch:    master
> Commit:    c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
> Changeset:
> http://git.rtems.org/rtems/commit/?id=c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
> Author:    Joel Sherrill <joel at rtems.org <mailto:joel at rtems.org>>
> Date:      Sat Jan 16 11:17:43 2016 -0600
> Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems
> <http://dispatch.rtems.org/data/git/rtems>
> vc mailing list
> http://lists.rtems.org/mailman/listinfo/vc
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
