Fwd: [rtems commit] Merge branch 'master' of ssh://dispatch.rtems.org/data/git/ rtems
Tue Jan 19 01:45:39 UTC 2016
Hey Joel,
Merge commits 1 out of every 100 pushes is too many, so you might want
to increase your number of '9's ;-)
On Mon, Jan 18, 2016 at 3:42 PM, Joel Sherrill <joel at rtems.org> wrote:
> Thanks.
> Since I tend to do commits from others on the same
> branch name, this should be easy to avoid 99% of the
> time in the future.
> --joel
> On Mon, Jan 18, 2016 at 12:33 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Looks all right.
>> You can avoid this problem in the future if you add something like this to
>> your .git/config:
>> [branch "abc"]
>> rebase = true
>> On 16/01/16 21:36, Joel Sherrill wrote:
>>> Please check that I did not screw the master up.
>>> I was at a library for an authors' day with Michele. I was committing a
>>> GCI patch and accidentally did this.
>>> Double check and revert if needed.
>>> Thanks.
>>> ---------- Forwarded message ----------
>>> From: "Joel Sherrill" <joel at rtems.org <mailto:joel at rtems.org>>
>>> Date: Jan 16, 2016 11:18 AM
>>> Subject: [rtems commit] Merge branch 'master' of
>>> ssh://dispatch.rtems.org/data/git/ <http://dispatch.rtems.org/data/git/>
>>> rtems
>>> To: <vc at rtems.org <mailto:vc at rtems.org>>
>>> Cc:
>>> Module:    rtems
>>> Branch:    master
>>> Commit:    c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
>>> Changeset:
>>> http://git.rtems.org/rtems/commit/?id=c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
>>> Author:    Joel Sherrill <joel at rtems.org <mailto:joel at rtems.org>>
>>> Date:      Sat Jan 16 11:17:43 2016 -0600
>>> Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems
>>> <http://dispatch.rtems.org/data/git/rtems>
>>> vc mailing list
>>> http://lists.rtems.org/mailman/listinfo/vc
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
