[PATCH v3] score: Fix simple timecounter support
Fri Jan 22 06:33:29 UTC 2016
On 21/01/16 14:50, Daniel Gutson wrote:
> El 21/1/2016 10:08, "Sebastian Huber"
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> escribió:
> > On 21/01/16 14:04, Marcos Díaz wrote:
> >> Just a question, isn't this hardware counter used for debugging?
> This won't cause us any problem for debugging?
> > Why should it cause problems?
> Beside any problem, how this affects debugging since this is using
> indeed a dubigging resource?
I don't share your concerns. You can start and stop the cycle counter.
Why should a debugger stop it? You can read the cycle counter. What is
the problem with this? You can reset the cycle counter. Why should a
debugger do this? You can do nothing else with the cycle counter.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
