Switching m68k BSPs to linkcmds.base
Sat Jan 23 23:36:14 UTC 2016
Hi
This file is currently used by only one BSP and it isn't in sync with the
start code that five of the BSPs use.  I looked at the genmcf548x BSP for
guidance but it appears to inherit the stack it starts on and doesn't have
bss clear code in start.S.
The shared start.S needs a starting stack and the following symbols:
_clear_start and _clear_end
What do those symbols map to in the linkcmds.shared?
Any thoughts on the starting stack other than to declare it in the shared
start.S?
Just thinking I can move a few BSPs to shared easily if I can address this
issue.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160123/6b2c3f8d/attachment.html>
