[PATCH] Fix RTEMS Tools source symlink generation.
Patrick Gauvin pggauvin at gmail.com
Mon Jan 25 00:10:01 UTC 2016
This patch is against the 4.11 branch, I will send the patch for
master in a few minutes.
On Sun, Jan 24, 2016 at 7:07 PM, Patrick Gauvin <pggauvin at gmail.com> wrote:
> Updates #2495.
>  rtems/config/tools/rtems-tools-common-1.cfg | 3 +--
>  1 file changed, 1 insertion(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-common-1.cfg b/rtems/config/tools/rtems-tools-common-1.cfg
> index 0de16ba..eecd121 100644
> --- a/rtems/config/tools/rtems-tools-common-1.cfg
> +++ b/rtems/config/tools/rtems-tools-common-1.cfg
> @@ -22,12 +22,11 @@ License:   BSD-2-Caluse + GPL-2.0
>    build_top=$(pwd)
>    rtems_tools_source="rtems-tools-%{rtems_tools_version}"
> +  source_dir_rtems_tools=${rtems_tools_source}
>    %source setup rtems-tools -q -n ${rtems_tools_source}
>    %patch setup rtems-tools -p1
> -  source_dir_rtems_tools=${rtems_tools_source}
>    cd ${build_top}
>  %build
> 2.7.0
