[PATCH 4/4] score: Introduce CPU_CACHE_LINE_BYTES
Mon Jan 25 11:05:56 UTC 2016
Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes.  The
actual processor may use no cache or a smaller cache line size.
 cpukit/score/cpu/arm/rtems/score/cpu.h      |  6 ++++--
 cpukit/score/cpu/bfin/rtems/score/cpu.h     | 26 +++-----------------------
 cpukit/score/cpu/epiphany/rtems/score/cpu.h | 24 +++---------------------
 cpukit/score/cpu/i386/rtems/score/cpu.h     |  4 ++++
 cpukit/score/cpu/lm32/rtems/score/cpu.h     | 28 ++++------------------------
 cpukit/score/cpu/m32c/rtems/score/cpu.h     | 28 ++++------------------------
 cpukit/score/cpu/m68k/rtems/score/cpu.h     |  6 +++++-
 cpukit/score/cpu/mips/rtems/score/cpu.h     | 28 +++-------------------------
 cpukit/score/cpu/moxie/rtems/score/cpu.h    | 26 +++-----------------------
 cpukit/score/cpu/nios2/rtems/score/cpu.h    |  6 +++++-
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h   | 21 ++++++++-------------
 cpukit/score/cpu/or1k/rtems/score/cpu.h     | 24 +++---------------------
 cpukit/score/cpu/powerpc/rtems/score/cpu.h  | 23 ++---------------------
 cpukit/score/cpu/sh/rtems/score/cpu.h       | 23 +++--------------------
 cpukit/score/cpu/sparc/rtems/score/cpu.h    | 15 ++++-----------
 cpukit/score/cpu/sparc64/rtems/score/cpu.h  |  5 ++++-
 cpukit/score/cpu/v850/rtems/score/cpu.h     | 26 +++-----------------------
 17 files changed, 65 insertions(+), 254 deletions(-)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 089d4293..89b7609 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -144,8 +144,10 @@
 #define CPU_STACK_GROWS_UP FALSE
-/* XXX Why 32? */
-#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (32)))
+/* FIXME: Is this the right value? */
+#define CPU_CACHE_LINE_BYTES 32
+#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
  * The interrupt mask disables only normal interrupts (IRQ).
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 8257383..f4da07d 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -295,29 +295,9 @@ extern "C" {
- * The following is the variable attribute used to force alignment
- * of critical RTEMS structures.  On some processors it may make
- * sense to have these aligned on tighter boundaries than
- * the minimum requirements of the compiler in order to have as
- * much of the critical data area as possible in a cache line.
- * The placement of this macro in the declaration of the variables
- * is based on the syntactically requirements of the GNU C
- * "__attribute__" extension.  For example with GNU C, use
- * the following to force a structures to a 32 byte boundary.
- *     __attribute__ ((aligned (32)))
- * @note Currently only the Priority Bit Map table uses this feature.
- *       To benefit from using this, the data must be heavily
- *       used so it will stay in the cache and used frequently enough
- *       in the executive to justify turning this on.
- * Port Specific Information:
- * XXX document implementation including references if appropriate
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index 967b802..aa786cd 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -260,28 +260,10 @@ extern "C" {
- *  NOTE:  Currently only the Priority Bit Map table uses this feature.
+#define CPU_CACHE_LINE_BYTES 64
-#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
  *  Define what is required to specify how the network to host conversion
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 8a49597..5a8e5d6 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -100,6 +100,10 @@ extern "C" {
 #endif /* __SSE__ */
+/* FIXME: The Pentium 4 used 128 bytes, it this processor still relevant? */
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 1a61475..dd0ec47 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -289,30 +289,10 @@ extern "C" {
- * L2 cache lines are 32 bytes in Milkymist SoC
+/* L2 cache lines are 32 bytes in Milkymist SoC */
  * @defgroup CPUEndian Processor Dependent Endianness Support
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 6819c82..59e9b4e 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -311,30 +311,10 @@ extern "C" {
 #define CPU_STACK_GROWS_UP               TRUE
-#define CPU_STRUCTURE_ALIGNMENT          __attribute__ ((aligned (2)))
+#define CPU_CACHE_LINE_BYTES 2
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 47a2d8e..8e0efa1 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -99,7 +99,11 @@ extern "C" {
 #define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
-#define CPU_STRUCTURE_ALIGNMENT          __attribute__ ((aligned (4)))
+#define CPU_CACHE_LINE_BYTES 16
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index bb897e1..01bd29a 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -280,32 +280,10 @@ extern "C" {
 /* our stack grows down */
-/* our cache line size is 16 bytes */
-#if __GNUC__
-#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (16)))
-#else
-#endif
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index 8348d48..4e4bbad 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -260,29 +260,9 @@ extern "C" {
- *  MOXIE Specific Information:
- *  XXX
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 4bd1fe7..1008865 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -64,7 +64,11 @@ extern "C" {
-#define CPU_STRUCTURE_ALIGNMENT __attribute__((section(".sdata"), aligned(32)))
+#define CPU_STRUCTURE_ALIGNMENT \
+  RTEMS_SECTION( ".sdata" ) RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
 #define CPU_BIG_ENDIAN FALSE
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index ab81e64..67a725c 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -311,29 +311,24 @@ extern "C" {
+ * The maximum cache line size in bytes.
+ * The actual processor may use no cache or a smaller cache line size.
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index c9b833c..2405844 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -252,28 +252,10 @@ extern "C" {
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 5e822e4..f988f8a 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -101,28 +101,9 @@ extern "C" {
+#define CPU_CACHE_LINE_BYTES PPC_STRUCTURE_ALIGNMENT
-#define CPU_STRUCTURE_ALIGNMENT \
-  __attribute__ ((aligned (PPC_STRUCTURE_ALIGNMENT)))
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index bf12220..43d1915 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -229,27 +229,10 @@ extern "C" {
-#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned(16)))
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 9b4db13..4170cb9 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -210,17 +210,10 @@ extern "C" {
- * of critical data structures.  On some processors it may make
- * The SPARC does not appear to have particularly strict alignment
- * requirements.  This value was chosen to take advantages of caches.
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index 4838cac..80c3466 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -170,6 +170,9 @@ extern "C" {
@@ -184,7 +187,7 @@ extern "C" {
  *  and is 16 if quad-word fp instructions are available (e.g. LDQF).
+#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( 16 )
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index b2b9fc1..e910ae1 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -289,29 +289,9 @@ extern "C" {
- * Until proven otherwise, use the compiler default.
1.8.4.5
