[PATCH 02/38] score: Create idle threads via linker set
Tue Jan 26 15:37:28 UTC 2016
This allows a more fine grained rtems_initialize_data_structures().
Update #2408.
 cpukit/sapi/src/exinit.c              | 30 +++++++-------
 cpukit/score/include/rtems/sysinit.h  |  1 +
 cpukit/score/src/threadcreateidle.c   |  3 ++
 testsuites/sptests/spsysinit01/init.c | 76 ++++++++++++++++++++++++++---------
 4 files changed, 75 insertions(+), 35 deletions(-)
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 7c1ffd6..faaf283 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -142,21 +142,6 @@ static void rtems_initialize_data_structures(void)
   _Extension_Manager_initialization();
   _POSIX_API_Initialize();
-  _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
-   *  No threads should be created before this point!!!
-   *  _Thread_Executing and _Thread_Heir are not set.
-   *  At this point all API extensions are in place.  After the call to
-   *  _Thread_Create_idle() _Thread_Executing and _Thread_Heir will be set.
-  _Thread_Create_idle();
-   *  Scheduling can properly occur now as long as we avoid dispatching.
 static void rtems_initialize_before_drivers(void)
@@ -261,6 +246,21 @@ RTEMS_SYSINIT_ITEM(
   RTEMS_SYSINIT_ORDER_MIDDLE
+ *  No threads should be created before this point!!!
+ *  _Thread_Executing and _Thread_Heir are not set.
+ *  At this point all API extensions are in place.  After the call to
+ *  _Thread_Create_idle() _Thread_Executing and _Thread_Heir will be set.
+ *  Scheduling can properly occur afterwards as long as we avoid dispatching.
+RTEMS_SYSINIT_ITEM(
+  _Thread_Create_idle,
+  RTEMS_SYSINIT_IDLE_THREADS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
 RTEMS_SYSINIT_ITEM(
   rtems_initialize_before_drivers,
   RTEMS_SYSINIT_BEFORE_DRIVERS,
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index 855198d..e6fe62f 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -29,6 +29,7 @@ extern "C" {
 #define RTEMS_SYSINIT_BSP_WORK_AREAS             000100
 #define RTEMS_SYSINIT_BSP_START                  000200
 #define RTEMS_SYSINIT_DATA_STRUCTURES            000300
+#define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_BSP_LIBC                   000400
 #define RTEMS_SYSINIT_BEFORE_DRIVERS             000500
 #define RTEMS_SYSINIT_BSP_PRE_DRIVERS            000600
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index 3430881..a07e238 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -21,6 +21,7 @@
 #include <rtems/score/stackimpl.h>
+#include <rtems/score/sysstate.h>
 #include <rtems/score/userextimpl.h>
 #include <rtems/config.h>
@@ -84,6 +85,8 @@ void _Thread_Create_idle( void )
   uint32_t cpu_count = _SMP_Get_processor_count();
   uint32_t cpu_index;
+  _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
   for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
     Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 76f8afd..fd34264 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -24,11 +24,35 @@
 #include <rtems/sysinit.h>
 #include <rtems/test.h>
+#include <rtems/score/apimutex.h>
 const char rtems_test_name[] = "SPSYSINIT 1";
+typedef enum {
+  BSP_WORK_AREAS_PRE,
+  BSP_WORK_AREAS_POST,
+  BSP_START_PRE,
+  BSP_START_POST,
+  DATA_STRUCTURES_PRE,
+  DATA_STRUCTURES_POST,
+  IDLE_THREADS_PRE,
+  IDLE_THREADS_POST,
+  BSP_LIBC_PRE,
+  BSP_LIBC_POST,
+  BEFORE_DRIVERS_PRE,
+  BEFORE_DRIVERS_POST,
+  BSP_PRE_DRIVERS_PRE,
+  BSP_PRE_DRIVERS_POST,
+  DEVICE_DRIVERS_PRE,
+  DEVICE_DRIVERS_POST,
+  BSP_POST_DRIVERS_PRE,
+  BSP_POST_DRIVERS_POST,
+  INIT_TASK,
+  DONE
+} init_step;
 #define FIRST(x) \
   static void x##_first(void); \
   RTEMS_SYSINIT_ITEM( \
@@ -47,9 +71,9 @@ const char rtems_test_name[] = "SPSYSINIT 1";
   static void x##_last(void)
-static int step;
+static init_step step;
-static void next_step(int expected)
+static void next_step(init_step expected)
   assert(step == expected);
   step = expected + 1;
@@ -59,13 +83,13 @@ FIRST(RTEMS_SYSINIT_BSP_WORK_AREAS)
   rtems_test_begink();
   assert(_Workspace_Area.area_begin == 0);
-  next_step(0);
+  next_step(BSP_WORK_AREAS_PRE);
 LAST(RTEMS_SYSINIT_BSP_WORK_AREAS)
   assert(_Workspace_Area.area_begin != 0);
-  next_step(1);
+  next_step(BSP_WORK_AREAS_POST);
 FIRST(RTEMS_SYSINIT_BSP_START)
@@ -74,47 +98,59 @@ FIRST(RTEMS_SYSINIT_BSP_START)
    * Since the work performed here is BSP-specific, there is no way to test pre
    * and post conditions.
-  next_step(2);
+  next_step(BSP_START_PRE);
 LAST(RTEMS_SYSINIT_BSP_START)
-  next_step(3);
+  next_step(BSP_START_POST);
 FIRST(RTEMS_SYSINIT_DATA_STRUCTURES)
-  assert(_System_state_Is_before_initialization(_System_state_Get()));
-  next_step(4);
+  assert(_RTEMS_Allocator_Mutex == NULL);
+  next_step(DATA_STRUCTURES_PRE);
 LAST(RTEMS_SYSINIT_DATA_STRUCTURES)
+  assert(_RTEMS_Allocator_Mutex != NULL);
+  next_step(DATA_STRUCTURES_POST);
+FIRST(RTEMS_SYSINIT_IDLE_THREADS)
+  assert(_System_state_Is_before_initialization(_System_state_Get()));
+  next_step(IDLE_THREADS_PRE);
+LAST(RTEMS_SYSINIT_IDLE_THREADS)
   assert(_System_state_Is_before_multitasking(_System_state_Get()));
-  next_step(5);
+  next_step(IDLE_THREADS_POST);
 FIRST(RTEMS_SYSINIT_BSP_LIBC)
   assert(rtems_libio_semaphore == 0);
-  next_step(6);
+  next_step(BSP_LIBC_PRE);
 LAST(RTEMS_SYSINIT_BSP_LIBC)
   assert(rtems_libio_semaphore != 0);
-  next_step(7);
+  next_step(BSP_LIBC_POST);
 FIRST(RTEMS_SYSINIT_BEFORE_DRIVERS)
   /* Omit test of build configuration specific pre and post conditions */
-  next_step(8);
+  next_step(BEFORE_DRIVERS_PRE);
 LAST(RTEMS_SYSINIT_BEFORE_DRIVERS)
-  next_step(9);
+  next_step(BEFORE_DRIVERS_POST);
 FIRST(RTEMS_SYSINIT_BSP_PRE_DRIVERS)
@@ -123,41 +159,41 @@ FIRST(RTEMS_SYSINIT_BSP_PRE_DRIVERS)
-  next_step(10);
+  next_step(BSP_PRE_DRIVERS_PRE);
 LAST(RTEMS_SYSINIT_BSP_PRE_DRIVERS)
-  next_step(11);
+  next_step(BSP_PRE_DRIVERS_POST);
 FIRST(RTEMS_SYSINIT_DEVICE_DRIVERS)
   assert(!_IO_All_drivers_initialized);
-  next_step(12);
+  next_step(DEVICE_DRIVERS_PRE);
 LAST(RTEMS_SYSINIT_DEVICE_DRIVERS)
   assert(_IO_All_drivers_initialized);
-  next_step(13);
+  next_step(DEVICE_DRIVERS_POST);
 FIRST(RTEMS_SYSINIT_BSP_POST_DRIVERS)
   assert(rtems_libio_iop_freelist != NULL);
-  next_step(14);
+  next_step(BSP_POST_DRIVERS_PRE);
 LAST(RTEMS_SYSINIT_BSP_POST_DRIVERS)
   assert(rtems_libio_iop_freelist == NULL);
-  next_step(15);
+  next_step(BSP_POST_DRIVERS_POST);
 static void Init(rtems_task_argument arg)
-  next_step(16);
+  next_step(INIT_TASK);
   rtems_test_endk();
   exit(0);
1.8.4.5
