[PATCH 20/38] Optional POSIX Condition Variable initialization
Tue Jan 26 15:37:46 UTC 2016
Update #2408.
 cpukit/posix/include/rtems/posix/condimpl.h |  9 +--------
 cpukit/posix/src/cond.c                     | 11 ++++++++++-
 cpukit/sapi/src/posixapi.c                  |  2 --
 cpukit/score/include/rtems/sysinit.h        |  1 +
 testsuites/sptests/spsysinit01/init.c       | 17 +++++++++++++++++
 5 files changed, 29 insertions(+), 11 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/condimpl.h b/cpukit/posix/include/rtems/posix/condimpl.h
index 7def0f8..789d3e8 100644
--- a/cpukit/posix/include/rtems/posix/condimpl.h
+++ b/cpukit/posix/include/rtems/posix/condimpl.h
@@ -36,7 +36,7 @@ extern "C" {
  *  The following defines the information control block used to manage
  *  this class of objects.
-POSIX_EXTERN Objects_Information  _POSIX_Condition_variables_Information;
+extern Objects_Information _POSIX_Condition_variables_Information;
  *  The default condition variable attributes structure.
@@ -44,13 +44,6 @@ POSIX_EXTERN Objects_Information  _POSIX_Condition_variables_Information;
 extern const pthread_condattr_t _POSIX_Condition_variables_Default_attributes;
- *  @brief POSIX Condition Variable Manager Initialization
- *  This routine performs the initialization necessary for this manager.
-void _POSIX_Condition_variables_Manager_initialization(void);
  *  @brief POSIX Condition Variable Allocate
  *  This function allocates a condition variable control block from
diff --git a/cpukit/posix/src/cond.c b/cpukit/posix/src/cond.c
index 5ce12d5..d0ce8a6 100644
--- a/cpukit/posix/src/cond.c
+++ b/cpukit/posix/src/cond.c
@@ -24,10 +24,13 @@
 #include <rtems/config.h>
+#include <rtems/sysinit.h>
 #include <rtems/posix/condimpl.h>
+Objects_Information _POSIX_Condition_variables_Information;
  *  _POSIX_Condition_variables_Manager_initialization
@@ -39,7 +42,7 @@
  *  Output parameters:  NONE
+static void _POSIX_Condition_variables_Manager_initialization(void)
   _Objects_Initialize_information(
     &_POSIX_Condition_variables_Information, /* object information table */
@@ -58,3 +61,9 @@ void _POSIX_Condition_variables_Manager_initialization(void)
 #endif
+RTEMS_SYSINIT_ITEM(
+  _POSIX_Condition_variables_Manager_initialization,
+  RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index 4cf5249..9277c93 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -33,7 +33,6 @@
 #include <rtems/posix/barrierimpl.h>
 #include <rtems/posix/config.h>
-#include <rtems/posix/condimpl.h>
 #include <rtems/posix/mqueueimpl.h>
@@ -63,7 +62,6 @@ void _POSIX_API_Initialize(void)
   _POSIX_Key_Manager_initialization();
   #ifdef RTEMS_POSIX_API
-    _POSIX_Condition_variables_Manager_initialization();
     _POSIX_Mutex_Manager_initialization();
     _POSIX_Message_queue_Manager_initialization();
     _POSIX_Semaphore_Manager_initialization();
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index dcd0e18..9d1e59e 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -44,6 +44,7 @@ extern "C" {
 #define RTEMS_SYSINIT_CLASSIC_BARRIER            00034a
 #define RTEMS_SYSINIT_POSIX_SIGNALS              000360
 #define RTEMS_SYSINIT_POSIX_THREADS              000361
+#define RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE   000362
 #define RTEMS_SYSINIT_POSIX_CLEANUP              00036a
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_BSP_LIBC                   000400
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 8925099..87d0c32 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -28,6 +28,7 @@
 #include <rtems/extensionimpl.h>
+#include <rtems/posix/condimpl.h>
 #include <rtems/posix/psignalimpl.h>
 #endif /* RTEMS_POSIX_API */
@@ -86,6 +87,8 @@ typedef enum {
   POSIX_SIGNALS_POST,
   POSIX_THREADS_PRE,
   POSIX_THREADS_POST,
+  POSIX_CONDITION_VARIABLE_PRE,
+  POSIX_CONDITION_VARIABLE_POST,
   POSIX_CLEANUP_PRE,
   POSIX_CLEANUP_POST,
@@ -362,6 +365,18 @@ LAST(RTEMS_SYSINIT_POSIX_THREADS)
   next_step(POSIX_THREADS_POST);
+FIRST(RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE)
+  assert(_POSIX_Condition_variables_Information.maximum == 0);
+  next_step(POSIX_CONDITION_VARIABLE_PRE);
+LAST(RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE)
+  assert(_POSIX_Condition_variables_Information.maximum != 0);
+  next_step(POSIX_CONDITION_VARIABLE_POST);
 static size_t user_extensions_pre_posix_cleanup;
 FIRST(RTEMS_SYSINIT_POSIX_CLEANUP)
@@ -491,6 +506,8 @@ static void Init(rtems_task_argument arg)
+#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 1
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
1.8.4.5
