[PATCH 30/38] posix: Delete empty _POSIX_API_Initialize()
Tue Jan 26 15:37:56 UTC 2016
 cpukit/posix/include/rtems/posix/posixapi.h |  8 --------
 cpukit/sapi/src/exinit.c                    |  7 -------
 cpukit/sapi/src/posixapi.c                  | 24 ------------------------
 cpukit/score/include/rtems/score/basedefs.h | 14 --------------
 4 files changed, 53 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/posixapi.h b/cpukit/posix/include/rtems/posix/posixapi.h
index ec8b845..8fee7a4 100644
--- a/cpukit/posix/include/rtems/posix/posixapi.h
+++ b/cpukit/posix/include/rtems/posix/posixapi.h
@@ -49,14 +49,6 @@ typedef enum {
 void _POSIX_Fatal_error( POSIX_Fatal_domain domain, int eno );
- * @brief Initialize POSIX API.
- * This method is responsible for initializing each of the POSIX
- * API managers.
-void _POSIX_API_Initialize(void);
  * @brief Queries the object identifier @a id for a @a name.
  * @param[in] information Object information.
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index edd8a5c..1482689 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -51,9 +51,6 @@
 #include <rtems/sptables.h>
-#include <rtems/posix/posixapi.h>
 #ifdef RTEMS_DRVMGR_STARTUP
   #include <drvmgr/drvmgr.h>
 #endif
@@ -128,10 +125,6 @@ static void rtems_initialize_data_structures(void)
   #endif
   _SMP_Handler_initialize();
-/* MANAGERS */
-  _POSIX_API_Initialize();
 static void rtems_initialize_before_drivers(void)
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index b3839dd..d1de103 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -19,35 +19,11 @@
 #include "config.h"
 #endif
-#define POSIX_API_INIT
-#include <rtems/system.h>    /* include this before checking RTEMS_POSIX_API */
-#include <rtems/config.h>
-#ifdef RTEMS_POSIX_API
-#include <sys/types.h>
-#include <mqueue.h>
-#include <rtems/posix/config.h>
-#include <rtems/posix/priorityimpl.h>
-#include <rtems/posix/psignalimpl.h>
-#endif
   uint32_t code = ( domain << 8 ) | ( ( uint32_t ) eno & 0xffU );
   _Terminate( INTERNAL_ERROR_POSIX_API, false, code );
-   * If there are any type size assumptions in the POSIX API, this is
-   * the appropriate place to place them.
-   * Currently, there are no none type size assumptions.
diff --git a/cpukit/score/include/rtems/score/basedefs.h b/cpukit/score/include/rtems/score/basedefs.h
index 34e021a..ea7d8c7 100644
--- a/cpukit/score/include/rtems/score/basedefs.h
+++ b/cpukit/score/include/rtems/score/basedefs.h
@@ -96,20 +96,6 @@
 #endif
- *  The following ensures that all data is declared in the space
- *  of the initialization routine for either the Initialization Manager
- *  or the initialization file for the appropriate API.  It is
- *  referenced as "external" in every other file.
-#ifdef POSIX_API_INIT
-  #undef  POSIX_EXTERN
-  #define POSIX_EXTERN
-#else
-  #define POSIX_EXTERN  extern
-#endif
  *  The following (in conjunction with compiler arguments) are used
  *  to choose between the use of static inline functions and macro
  *  functions.   The static inline implementation allows better
1.8.4.5
