[PATCH 34/38] Use linker set for driver manager initialization
Tue Jan 26 15:38:00 UTC 2016
Update #2408.
 cpukit/libdrvmgr/drvmgr.c            | 90 ++++++++++++++++++++++++++++++++++++
 cpukit/sapi/src/exinit.c             | 58 -----------------------
 cpukit/score/include/rtems/sysinit.h |  9 +++-
 3 files changed, 97 insertions(+), 60 deletions(-)
diff --git a/cpukit/libdrvmgr/drvmgr.c b/cpukit/libdrvmgr/drvmgr.c
index 7c37afd..03af390 100644
--- a/cpukit/libdrvmgr/drvmgr.c
+++ b/cpukit/libdrvmgr/drvmgr.c
@@ -14,6 +14,8 @@
 #include <drvmgr/drvmgr.h>
 #include <drvmgr/drvmgr_confdefs.h>
+#include <rtems/sysinit.h>
 #include "drvmgr_internal.h"
 /* Enable debugging */
@@ -642,3 +644,91 @@ void drvmgr_bus_res_add(struct drvmgr_bus *bus,
 	bres->next = bus->reslist;
 	bus->reslist = bres;
+#ifdef RTEMS_DRVMGR_STARTUP
+RTEMS_SYSINIT_ITEM(
+  _DRV_Manager_initialization,
+  RTEMS_SYSINIT_DRVMGR,
+  RTEMS_SYSINIT_ORDER_MIDDLE
+/* BSPs has already registered their "root bus" driver in the
+ * bsp_predriver hook or so.
+ * Init Drivers to Level 1, constraints:
+ *   - Interrupts and system clock timer does not work.
+ *   - malloc() work, however other memory services may not
+ *     have been initialized yet.
+ *   - initializes most basic stuff
+ * Typical setup in Level 1:
+ *   - Find most devices in system, do PCI scan and configuration.
+ *   - Reset hardware if needed.
+ *   - Install IRQ driver
+ *   - Install Timer driver
+ *   - Install console driver and debug printk()
+ *   - Install extra memory.
+static void _DRV_Manager_init_level_1(void)
+  _DRV_Manager_init_level(1);
+  _DRV_Manager_init_level_1,
+  RTEMS_SYSINIT_DRVMGR_LEVEL_1,
+/* Init Drivers to Level 2, constraints:
+ *  - Interrupts can be registered and enabled.
+ *  - System Clock is running
+ *  - Console may be used.
+ * This is typically where drivers are initialized
+ * for the first time.
+static void _DRV_Manager_init_level_2(void)
+  _DRV_Manager_init_level(2);
+  _DRV_Manager_init_level_2,
+  RTEMS_SYSINIT_DRVMGR_LEVEL_2,
+/* Init Drivers to Level 3
+ * This is typically where normal drivers are initialized
+ * for the second time, they may depend on other drivers
+ * API inited in level 2
+static void _DRV_Manager_init_level_3(void)
+  _DRV_Manager_init_level(3);
+  _DRV_Manager_init_level_3,
+  RTEMS_SYSINIT_DRVMGR_LEVEL_3,
+/* Init Drivers to Level 4,
+ * Init drivers that depend on services initialized in Level 3
+static void _DRV_Manager_init_level_4(void)
+  _DRV_Manager_init_level(4);
+  _DRV_Manager_init_level_4,
+  RTEMS_SYSINIT_DRVMGR_LEVEL_4,
+#endif /* RTEMS_DRVMGR_STARTUP */
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 1482689..dca42d6 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -51,10 +51,6 @@
 #include <rtems/sptables.h>
-#ifdef RTEMS_DRVMGR_STARTUP
-  #include <drvmgr/drvmgr.h>
-#endif
 static Objects_Information *
 _Internal_Objects[ OBJECTS_INTERNAL_CLASSES_LAST + 1 ];
@@ -129,10 +125,6 @@ static void rtems_initialize_data_structures(void)
 static void rtems_initialize_before_drivers(void)
-  #ifdef RTEMS_DRVMGR_STARTUP
-  _DRV_Manager_initialization();
-  #endif
   #if defined(RTEMS_MULTIPROCESSING)
     _MPCI_Create_server();
   #endif
@@ -146,28 +138,6 @@ static void rtems_initialize_device_drivers(void)
    *  NOTE:  The MPCI may be build upon a device driver.
-  /* BSPs has already registered their "root bus" driver in the
-   * bsp_predriver hook or so.
-   * Init Drivers to Level 1, constraints:
-   *   - Interrupts and system clock timer does not work.
-   *   - malloc() work, however other memory services may not
-   *     have been initialized yet.
-   *   - initializes most basic stuff
-   * Typical setup in Level 1:
-   *   - Find most devices in system, do PCI scan and configuration.
-   *   - Reset hardware if needed.
-   *   - Install IRQ driver
-   *   - Install Timer driver
-   *   - Install console driver and debug printk()
-   *   - Install extra memory.
-  _DRV_Manager_init_level(1);
-  bsp_driver_level_hook(1);
-  #endif
   /* Initialize I/O drivers.
    * Driver Manager note:
@@ -176,34 +146,6 @@ static void rtems_initialize_device_drivers(void)
   _IO_Initialize_all_drivers();
-  /* Init Drivers to Level 2, constraints:
-   *  - Interrupts can be registered and enabled.
-   *  - System Clock is running
-   *  - Console may be used.
-   * This is typically where drivers are initialized
-   * for the first time.
-  _DRV_Manager_init_level(2);
-  bsp_driver_level_hook(2);
-  /* Init Drivers to Level 3
-   * This is typically where normal drivers are initialized
-   * for the second time, they may depend on other drivers
-   * API inited in level 2
-  _DRV_Manager_init_level(3);
-  bsp_driver_level_hook(3);
-  /* Init Drivers to Level 4,
-   * Init drivers that depend on services initialized in Level 3
-  _DRV_Manager_init_level(4);
-  bsp_driver_level_hook(4);
-  #endif
     if ( _System_state_Is_multiprocessing ) {
       _MPCI_Initialization();
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index 178afd8..925593d 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -58,9 +58,14 @@ extern "C" {
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_LIBIO                      000400
 #define RTEMS_SYSINIT_ROOT_FILESYSTEM            000401
-#define RTEMS_SYSINIT_BEFORE_DRIVERS             000500
+#define RTEMS_SYSINIT_DRVMGR                     000500
+#define RTEMS_SYSINIT_BEFORE_DRIVERS             000501
 #define RTEMS_SYSINIT_BSP_PRE_DRIVERS            000600
-#define RTEMS_SYSINIT_DEVICE_DRIVERS             000700
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_1             000700
+#define RTEMS_SYSINIT_DEVICE_DRIVERS             000701
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_2             000702
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_3             000703
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_4             000704
 #define RTEMS_SYSINIT_STD_FILE_DESCRIPTORS       000800
1.8.4.5
