[PATCH 2/2] rtemstoolkit: msys2 compatibility
    Sebastian Huber
    Mon Jan 11 06:45:01 UTC 2016
On 11/01/16 02:03, Chris Johns wrote:
> On 08/01/2016 20:05, Sebastian Huber wrote:
>> I am not sure what you mean with "Check the command wrappers and add '.'
>> tothe system path, eg rtems-tester.".
> The command wrapper is:
> https://git.rtems.org/rtems-tools/tree/tester/rtems-test
> and does adding '.' fix the problem? I am not sure if this a suitable
> or questionable fix.
The basic problem is that waf doesn't even work to build the rtems-tools
on msys2.
>> The cyclic dependency is there in all versions.
> I will need to see this and understand the issue. An imported module
> should be ok to import again and again.
In options.py you import git.py and vice versa. This seems to work on
Linux but not on msys2.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
