[PATCH 7/8] bsp/atsam: Port SAM Software Package to RTEMS
Fri Jan 15 13:52:18 UTC 2016
Given that Trac generates release reports from tickets and this
seems important, could you file a ticket explaining what this is,
source URL, etc.
FWIW I think we all have to be more conscious of helping Trac
help us in this way. :)
--joel
On Fri, Jan 15, 2016 at 7:44 AM, Sebastian Huber <
>  .../libbsp/arm/atsam/libraries/libboard/board.h    |  3 ++
>  .../arm/atsam/libraries/libboard/board_v71_xult.h  |  4 +++
>  .../libboard/resources_v71/system_samv71.c         | 16 +++++++++--
>  .../libraries/libboard/source/board_lowlevel.c     |  5 ++++
>  .../libraries/libboard/source/board_memories.c     | 11 ++++++++
>  .../atsam/libraries/libboard/source/dbg_console.c  | 19 +++++++++++++
>  .../libbsp/arm/atsam/libraries/libchip/compiler.h  | 33
>  .../arm/atsam/libraries/libchip/include/chip.h     |  1 +
>  .../arm/atsam/libraries/libchip/include/qspi_dma.h |  2 ++
>  .../libraries/libchip/include/same70/same70j19.h   |  2 ++
>  .../libraries/libchip/include/same70/same70j20.h   |  2 ++
>  .../libraries/libchip/include/same70/same70j21.h   |  2 ++
>  .../libraries/libchip/include/same70/same70n19.h   |  2 ++
>  .../libraries/libchip/include/same70/same70n20.h   |  2 ++
>  .../libraries/libchip/include/same70/same70n21.h   |  2 ++
>  .../libraries/libchip/include/same70/same70q19.h   |  2 ++
>  .../libraries/libchip/include/same70/same70q20.h   |  2 ++
>  .../libraries/libchip/include/same70/same70q21.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70j19.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70j20.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70j21.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70n19.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70n20.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70n21.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70q19.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70q20.h   |  2 ++
>  .../libraries/libchip/include/sams70/sams70q21.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71.h      |  3 ++
>  .../libraries/libchip/include/samv71/samv71j19.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71j20.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71j21.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71n19.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71n20.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71n21.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71q19.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71q20.h   |  2 ++
>  .../libraries/libchip/include/samv71/samv71q21.h   |  2 ++
>  .../arm/atsam/libraries/libchip/include/xdmac.h    |  2 ++
>  .../arm/atsam/libraries/libchip/source/mcan.c      |  8 ++++++
>  .../libbsp/arm/atsam/libraries/libchip/source/tc.c |  4 +++
>  40 files changed, 161 insertions(+), 4 deletions(-)
>  create mode 100644
> c/src/lib/libbsp/arm/atsam/libraries/libchip/include/chip.h
> diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libboard/board.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libboard/board.h
> index a77409d..d69d212 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libboard/board.h
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libboard/board.h
> @@ -30,6 +30,9 @@
>  #ifndef _BOARD_H_
>  #define _BOARD_H_
> +#ifdef __rtems__
> +#include <bspopts.h>
> +#endif /* __rtems__ */
>  #if defined(BOARD_SAMV71_XULT)
>         #include "board_v71_xult.h"
>  #elif defined(BOARD_SAME70_XPLD)
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libboard/board_v71_xult.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libboard/board_v71_xult.h
> index c98dbd2..be0c0f2 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libboard/board_v71_xult.h
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libboard/board_v71_xult.h
> @@ -110,9 +110,11 @@
>  #include "include/image_sensor_inf.h"
>  #include "include/iso7816_4.h"
> +#ifndef __rtems__
>  #if defined (__GNUC__)
>         #include "include/syscalls.h"
>  #endif
>   *        Definitions
> @@ -129,6 +131,7 @@
>  /** Name of the board */
>  #define BOARD_NAME "SAM V71 Xplained Ultra"
>  #define NO_PUSHBUTTON
> +#ifndef __rtems__
>   *  \page samv7_Xplained_ultra_opfreq "SAM V71 Xplained Ultra - Operating
> frequencies"
> @@ -150,6 +153,7 @@
>  #else
>         #define BOARD_MCK    150000000
>  #endif
>  #if (BOARD_MCK==123000000)
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libboard/resources_v71/system_samv71.c
> b/c/src/lib/libbsp/arm/atsam/libraries/libboard/resources_v71/system_samv71.c
> index 0dfcc95..9b4bd93 100644
> @@ -27,7 +27,11 @@
>  /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> +#ifndef __rtems__
>  #include "samv71.h"
> +#else /* __rtems__ */
> +#include <chip.h>
>  /* @cond 0 */
>  /**INDENT-OFF**/
> @@ -41,7 +45,7 @@ extern "C" {
>         /* Clock Settings (600MHz PLL VDDIO 3.3V and VDDCORE 1.2V) */
>         /* Clock Settings (300MHz HCLK, 150MHz MCK)=> PRESC = 2, MDIV = 2
>  #define SYS_BOARD_OSCOUNT   (CKGR_MOR_MOSCXTST(0x8U))
> -#ifdef MCK_123MHZ
> +#if BOARD_MCK == 123000000
>         /* For example usb_video, PLLA/HCLK/MCK clock is set to
> 492/246/123MHz to achieve
>            the maximum performance, for other examples the clock is set to
> 300/300/150MHz */
>         #define SYS_BOARD_PLLAR     (CKGR_PLLAR_ONE |
> CKGR_PLLAR_MULA(0x28U) | \
> @@ -50,16 +54,20 @@ extern "C" {
>  #define SYS_BOARD_MCKR_MDIV (PMC_MCKR_MDIV_PCK_DIV2)
>         #define SYS_BOARD_MCKR      (PMC_MCKR_PRES_CLK_2 |
> PMC_MCKR_CSS_PLLA_CLK \
> SYS_BOARD_MCKR_MDIV)
> -#else
> +#elif BOARD_MCK == 150000000
> CKGR_PLLAR_MULA(0x18U) | \
>  CKGR_PLLAR_PLLACOUNT(0x3fU) | CKGR_PLLAR_DIVA(0x1U))
>         #define SYS_BOARD_MCKR      (PMC_MCKR_PRES_CLK_1 |
> +#else
> +       #error "unexpected Main Clock (MCK) frequency"
>  #endif
> +#ifndef __rtems__
>         uint32_t SystemCoreClock = CHIP_FREQ_MAINCK_RC_4MHZ;
>  #define USBCLK_DIV          10
> @@ -131,9 +139,12 @@ extern "C" {
>         while (!(PMC->PMC_SR & PMC_SR_MCKRDY)) {
> +#ifndef __rtems__
>         SystemCoreClock = CHIP_FREQ_CPU_MAX;
> +#ifndef __rtems__
>  void SystemCoreClockUpdate(void)
>         /* Determine clock frequency according to clock register values */
> @@ -213,6 +224,7 @@ void SystemCoreClockUpdate(void)
>         else
>                 SystemCoreClock >>= ((PMC->PMC_MCKR & PMC_MCKR_PRES_Msk)
> >> PMC_MCKR_PRES_Pos);
>   * Initialize flash.
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c
> b/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c
> index a731ba4..254e529 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c
> @@ -37,7 +37,12 @@
>   *        Headers
> +#ifndef __rtems__
>  #include "board.h"
> +#include <chip.h>
> +#include <include/board_lowlevel.h>
>  #if defined(ENABLE_TCM) && defined(__GNUC__)
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_memories.c
> b/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_memories.c
> index e2a1097..01ecd8e 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_memories.c
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_memories.c
> @@ -37,7 +37,12 @@
>   *        Headers
> +#ifndef __rtems__
>  #include "board.h"
> +#include <chip.h>
> +#include <include/board_memories.h>
>   *        Exported functions
> @@ -47,6 +52,7 @@
>  #define SDRAM_BA1 (1 << 21)
> +#ifndef __rtems__
>  uint32_t BOARD_SdramValidation(uint32_t baseAddr, uint32_t size)
>         uint32_t i;
> @@ -135,6 +141,7 @@ uint32_t BOARD_SdramValidation(uint32_t baseAddr,
> uint32_t size)
>         return ret;
> @@ -144,12 +151,16 @@ uint32_t BOARD_SdramValidation(uint32_t baseAddr,
> uint32_t size)
>  void BOARD_ConfigureSdram(void)
> +#ifndef __rtems__
>         const Pin pinsSdram[] = {BOARD_SDRAM_PINS};
>         volatile uint32_t i;
>         volatile uint8_t *pSdram = (uint8_t *) SDRAM_CS_ADDR;
>         /* Configure PIO */
> +#ifndef __rtems__
>         PIO_Configure(pinsSdram, PIO_LISTSIZE(pinsSdram));
>         PMC_EnablePeripheral(ID_SDRAMC);
>         MATRIX->CCFG_SMCNFCS = CCFG_SMCNFCS_SDRAMEN;
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/dbg_console.c
> b/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/dbg_console.c
> index a31dad1..7538054 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/dbg_console.c
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libboard/source/dbg_console.c
> @@ -38,7 +38,12 @@
>   *        Headers
> +#ifndef __rtems__
>  #include "board.h"
> +#include <chip.h>
> +#include <include/dbg_console.h>
>  #include <stdio.h>
>  #include <stdint.h>
> @@ -108,8 +113,12 @@
>   *        Variables
> +#ifndef __rtems__
>  /** Is Console Initialized. */
>  static uint8_t _ucIsConsoleInitialized = 0;
> +#define _ucIsConsoleInitialized 1
>   * \brief Configures an USART peripheral with the specified parameters.
> @@ -120,11 +129,15 @@ static uint8_t _ucIsConsoleInitialized = 0;
>  extern void DBG_Configure(uint32_t baudrate, uint32_t masterClock)
> +#ifndef __rtems__
>         const Pin pPins[] = CONSOLE_PINS;
>  #if defined CONSOLE_ON_UART
>         Uart *pUart = CONSOLE_UART;
>         /* Configure PIO */
> +#ifndef __rtems__
>         PIO_Configure(pPins, PIO_LISTSIZE(pPins));
>         // Reset & disable receiver and transmitter, disable interrupts
>         pUart->UART_CR = UART_CR_RSTRX | UART_CR_RSTTX | UART_CR_RSTSTA;
> @@ -142,10 +155,12 @@ extern void DBG_Configure(uint32_t baudrate,
>  #if defined CONSOLE_ON_USART
>         Usart *pUsart = CONSOLE_Usart;
>         // Disable the MATRIX registers write protection
> +#ifndef __rtems__
>         MATRIX->MATRIX_WPMR  = MATRIX_WPMR_WPKEY_PASSWD;
>         MATRIX->CCFG_SYSIO |= CCFG_SYSIO_SYSIO4;
>         pUsart->US_CR = US_CR_RSTRX | US_CR_RSTTX | US_CR_RSTSTA;
> @@ -161,12 +176,14 @@ extern void DBG_Configure(uint32_t baudrate,
>         // Enable receiver and transmitter
>         pUsart->US_CR = US_CR_RXEN | US_CR_TXEN;
>  #endif
> +#ifndef __rtems__
>         _ucIsConsoleInitialized = 1;
>         /* Disable buffering for printf(). */
>  #if (defined (__GNUC__) && !defined (__SAMBA__))
>         setvbuf(stdout, (char *)NULL, _IONBF, 0);
>  #endif
> @@ -269,6 +286,7 @@ extern uint32_t DBG_IsRxReady(void)
>  #endif
> +#ifndef __rtems__
>   *  Displays the content of the given frame on the UART0.
> @@ -502,3 +520,4 @@ extern WEAK char *gets(char *ptr)
> diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libchip/compiler.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/compiler.h
> index 874ecae..f36013a 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/compiler.h
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/compiler.h
> @@ -30,12 +30,41 @@
>  #ifndef _COMPILER_H_
>  #define _COMPILER_H_
> +#ifdef __rtems__
>   * Peripherals registers definitions
> -#if defined(__SAMV71Q21__)
> +#if defined __SAMV71J19__ \
> +       || defined __SAMV71J20__ \
> +       || defined __SAMV71J21__ \
> +       || defined __SAMV71N19__ \
> +       || defined __SAMV71N20__ \
> +       || defined __SAMV71N21__ \
> +       || defined __SAMV71Q19__ \
> +       || defined __SAMV71Q20__ \
> +       || defined __SAMV71Q21__
>         #include "include/samv71/samv71.h"
> -#elif defined(__SAME70Q21__)
> +#elif defined __SAMS70J19__ \
> +       || defined __SAMS70J20__ \
> +       || defined __SAMS70J21__ \
> +       || defined __SAMS70N19__ \
> +       || defined __SAMS70N20__ \
> +       || defined __SAMS70N21__ \
> +       || defined __SAMS70Q19__ \
> +       || defined __SAMS70Q20__ \
> +       || defined __SAMS70Q21__
> +       #include "include/sams70/sams70.h"
> +#elif defined __SAME70J19__ \
> +       || defined __SAME70J20__ \
> +       || defined __SAME70J21__ \
> +       || defined __SAME70N19__ \
> +       || defined __SAME70N20__ \
> +       || defined __SAME70N21__ \
> +       || defined __SAME70Q19__ \
> +       || defined __SAME70Q20__ \
> +       || defined __SAME70Q21__
>         #include "include/same70/same70.h"
>  #else
>         #error "please define correct macro for the chip first!"
> diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/chip.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/chip.h
> new file mode 100644
> index 0000000..a9f1f01
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/chip.h
> @@ -0,0 +1 @@
> +#include "../chip.h"
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi_dma.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi_dma.h
> index b51c58e..8ee274e 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi_dma.h
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi_dma.h
> @@ -42,7 +42,9 @@
>  #include "chip.h"
> +#ifndef __rtems__
>  #include "../../../../utils/utility.h"
>   *        Definitions
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j19.h
> index 602621f..a82d7c1 100644
> @@ -333,6 +333,7 @@ void XDMAC_Handler      ( void );
>  #include "component/component_xdmac.h"
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70J19 */
> @@ -386,6 +387,7 @@ void XDMAC_Handler      ( void );
>  #include "instance/instance_uart3.h"
>  #include "instance/instance_uart4.h"
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70J19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j20.h
> index 89af94b..a877891 100644
> @@ -336,6 +336,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70J20 */
> @@ -390,6 +391,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70J20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j21.h
> index 88bad12..812c28c 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70J21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70J21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n19.h
> index 0afe214..ed565d4 100644
> @@ -338,6 +338,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70N19 */
> @@ -393,6 +394,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70N19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n20.h
> index 1b0ac6a..84b1265 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70N20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70N20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n21.h
> index f3889a5..ceaeef3 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70N21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70N21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q19.h
> index 2fb2e85..136ac0e 100644
> @@ -358,6 +358,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70Q19 */
> @@ -419,6 +420,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70Q19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q20.h
> index 2310461..dc5858c 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70Q20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70Q20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q21.h
> index 06adb73..3cd174e 100644
> @@ -362,6 +362,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAME70Q21 */
> @@ -423,6 +424,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAME70Q21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j19.h
> index fe9c2b8..82e2d7f 100644
> @@ -328,6 +328,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70J19 */
> @@ -379,6 +380,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70J19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j20.h
> index 8aa106a..e9f40dd 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70J20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70J20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j21.h
> index 30720a2..db2dbb9 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70J21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70J21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n19.h
> index 3da562a..8a810f1 100644
> @@ -330,6 +330,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70N19 */
> @@ -382,6 +383,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70N19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n20.h
> index 716cb4b..f95b970 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70N20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70N20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n21.h
> index e53bfeb..61170b4 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70N21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70N21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q19.h
> index 160fcf9..67d465f 100644
> @@ -350,6 +350,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70Q19 */
> @@ -408,6 +409,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70Q19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q20.h
> index f88973a..46c034c 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70Q20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70Q20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q21.h
> index f59404f..1528f41 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMS70Q21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMS70Q21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71.h
> index 892a020..4bdbce5 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71.h
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71.h
> @@ -30,6 +30,9 @@
>  #ifndef _SAMV71_
>  #define _SAMV71_
> +#ifdef __rtems__
>    #include "samv71j19.h"
>  #elif defined __SAMV71J20__
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j19.h
> index 0707f5f..ad3c38f 100644
> @@ -339,6 +339,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71J19 */
> @@ -394,6 +395,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71J19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j20.h
> index 86e5b8f..9df556c 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71J20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71J20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j21.h
> index 1c01571..4c306b8 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71J21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71J21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n19.h
> index 09d62a5..8f2c0b9 100644
> @@ -341,6 +341,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71N19 */
> @@ -397,6 +398,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71N19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n20.h
> index 2a010bc..e709e5f 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71N20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71N20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n21.h
> index 619f602..dc1ef6e 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71N21 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71N21 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q19.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q19.h
> index 14c0930..e42381c 100644
> @@ -361,6 +361,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71Q19 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71Q19 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q20.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q20.h
> index 57a2f43..cfc1780 100644
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71Q20 */
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71Q20 */
> diff --git
> a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q21.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q21.h
> index 77bebbd..401ee9b 100644
> @@ -365,6 +365,7 @@ void XDMAC_Handler      ( void );
> +#ifndef __rtems__
>  /*   REGISTER ACCESS DEFINITIONS FOR SAMV71Q21 */
> @@ -427,6 +428,7 @@ void XDMAC_Handler      ( void );
>  /*   PERIPHERAL ID DEFINITIONS FOR SAMV71Q21 */
> diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h
> index 1761358..34d4faa 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h
> @@ -74,7 +74,9 @@
>  #include "chip.h"
> +#ifndef __rtems__
>  #include <../../../../utils/utility.h>
>  #include <stdint.h>
> diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mcan.c
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mcan.c
> index 70ae12b..e91f73e 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mcan.c
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mcan.c
> @@ -38,7 +38,9 @@
>   *        Headers
> +#ifndef __rtems__
>  #include "board.h"
>  #include "chip.h"
>  #include "mcan_config.h"
>  #include <assert.h>
> @@ -422,8 +424,10 @@
>   *      Internal variables
> +#ifndef __rtems__
>  static const Pin pinsMcan0[] =  {PIN_MCAN0_TXD, PIN_MCAN0_RXD };
>  static const Pin pinsMcan1[] =  {PIN_MCAN1_TXD, PIN_MCAN1_RXD };
>  static uint32_t can0MsgRam[MCAN0_STD_FLTS_WRDS +
>                                                    MCAN0_EXT_FLTS_WRDS +
> @@ -548,7 +552,9 @@ void MCAN_Init(const MCan_ConfigType *mcanConfig)
>         PMC->PMC_SCER = PMC_SCER_PCK5;
>         if (MCAN0 ==  mcan) {
> +#ifndef __rtems__
>                 PIO_Configure(pinsMcan0, PIO_LISTSIZE(pinsMcan0));
>                 // Enable MCAN peripheral clock
>                 PMC_EnablePeripheral(ID_MCAN0);
>                 // Configure Message RAM Base Address
> @@ -557,7 +563,9 @@ void MCAN_Init(const MCan_ConfigType *mcanConfig)
>                                                         ((uint32_t)
> mcanConfig->msgRam.pStdFilts & 0xFFFF0000);
>                 mCanLine0Irq = MCAN0_IRQn;
>         } else if (MCAN1 ==  mcan) {
> +#ifndef __rtems__
>                 PIO_Configure(pinsMcan1, PIO_LISTSIZE(pinsMcan1));
>                 PMC_EnablePeripheral(ID_MCAN1);
> diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/tc.c
> b/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/tc.c
> index 1263a81..4ef9bd9 100644
> --- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/tc.c
> +++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/tc.c
> @@ -70,7 +70,11 @@
>   *         Headers
> +#ifndef __rtems__
>  #include "board.h"
> +#include <chip.h>
>  #include <assert.h>
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160115/a4c3742a/attachment-0002.html>
