Fwd: [rtems commit] Merge branch 'master' of ssh://dispatch.rtems.org/data/git/ rtems
Tue Jan 19 15:10:41 UTC 2016
On Mon, Jan 18, 2016 at 7:45 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hey Joel,
> Merge commits 1 out of every 100 pushes is too many, so you might want
> to increase your number of '9's ;-)
> +1
> On Mon, Jan 18, 2016 at 3:42 PM, Joel Sherrill <joel at rtems.org> wrote:
> > Thanks.
> > Since I tend to do commits from others on the same
> > branch name, this should be easy to avoid 99% of the
> > time in the future.
> > --joel
> > On Mon, Jan 18, 2016 at 12:33 AM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> Looks all right.
> >> You can avoid this problem in the future if you add something like this
> to
> >> your .git/config:
> >> [branch "abc"]
> >> rebase = true
> >> On 16/01/16 21:36, Joel Sherrill wrote:
> >>> Please check that I did not screw the master up.
> >>> I was at a library for an authors' day with Michele. I was committing a
> >>> GCI patch and accidentally did this.
> >>> Double check and revert if needed.
> >>> Thanks.
> >>> ---------- Forwarded message ----------
> >>> From: "Joel Sherrill" <joel at rtems.org <mailto:joel at rtems.org>>
> >>> Date: Jan 16, 2016 11:18 AM
> >>> Subject: [rtems commit] Merge branch 'master' of
> >>> ssh://dispatch.rtems.org/data/git/ <
> http://dispatch.rtems.org/data/git/>
> >>> rtems
> >>> To: <vc at rtems.org <mailto:vc at rtems.org>>
> >>> Cc:
> >>> Module:    rtems
> >>> Branch:    master
> >>> Commit:    c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
> >>> Changeset:
> http://git.rtems.org/rtems/commit/?id=c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
> >>> Author:    Joel Sherrill <joel at rtems.org <mailto:joel at rtems.org>>
> >>> Date:      Sat Jan 16 11:17:43 2016 -0600
> >>> Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems
> >>> <http://dispatch.rtems.org/data/git/rtems>
> >>> _______________________________________________
> >>> vc mailing list
> >>> http://lists.rtems.org/mailman/listinfo/vc
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone   : +49 89 189 47 41-16
> >> Fax     : +49 89 189 47 41-09
> >> E-Mail  : sebastian.huber at embedded-brains.de
> >> PGP     : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160119/f4e8c4b9/attachment-0002.html>
