Fwd: [Bug debug/65779] [5/6 Regression] undefined local symbol on powerpc [regression]
Nick Withers nick.withers at anu.edu.au
Mon Jan 25 07:58:50 UTC 2016
This is supposedly resolved (
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65779#c16 ) in
https://gcc.gnu.org/viewcvs?rev=232558&root=gcc&view=rev and included
in the latest GCC 6 20160124 snapshot (at r232780).
I didn't seem to run into the issue building tests for powerpc/psim
powerpc/mvme3100 pre-patch though, so can't currently confirm it's
sorted.
Patch attached to update the 4.12 RSB build set to this GCC snapshot.
On Wed, 2016-01-20 at 07:49 +0100, Sebastian Huber wrote:
> Yes, this bug is still a problem for several PowerPC BSPs. I have no
> time to work on this.
> On 18/01/16 20:38, Joel Sherrill wrote:
> > Hi
> > Didn't this impact us? Did someone have a test case?
> > -------- Forwarded Message --------
> > Subject: [Bug debug/65779] [5/6 Regression] undefined local symbol
> > on
> > Date: Mon, 18 Jan 2016 13:34:58 -0600
> > From: jakub at gcc dot gnu.org <gcc-bugzilla at gcc.gnu.org>
> > To: joel at gcc.gnu.org <joel at gcc.gnu.org>
> > Jakub Jelinek <jakub at gcc dot gnu.org> changed:
> >            What    |Removed                     |Added
> >              Status|NEW                         |ASSIGNED
> >            Assignee|unassigned at gcc dot gnu.org      |jakub at
> > gcc
> > dot gnu.org
> > --- Comment #15 from Jakub Jelinek <jakub at gcc dot gnu.org> ---
> > Created attachment 37389
> > https://gcc.gnu.org/bugzilla/attachment.cgi?id=37389&action=edit
> > gcc6-pr65779.patch
> > Untested fix.
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160125/9beb87cb/attachment-0002.bin>
