[3/6] add ti cpsw driver file part 3
yao0718
29171383 at qq.com
Tue Jul 5 07:30:42 UTC 2016
+ * Init/Shutdown.
+static int
+cpsw_ports_down(struct cpsw_softc *sc)
+ struct cpswp_softc *psc;
+ struct ifnet *ifp1, *ifp2;
+ if (!sc->dualemac)
+ return (1);
+ psc = device_get_softc(sc->port[0].dev);
+ ifp1 = psc->ifp;
+ psc = device_get_softc(sc->port[1].dev);
+ ifp2 = psc->ifp;
+ if ((ifp1->if_flags & IFF_UP) == 0 && (ifp2->if_flags & IFF_UP) == 0)
+ return (1);
+ return (0);
+static void
+cpswp_init(void *arg)
+ struct cpswp_softc *sc = arg;
+ CPSWP_DEBUGF(sc, (""));
+ CPSW_PORT_LOCK(sc);
+ cpswp_init_locked(arg);
+ CPSW_PORT_UNLOCK(sc);
+static void
+cpswp_init_locked(void *arg)
+ struct ifnet *ifp;
+ uint32_t reg;
+ CPSW_PORT_LOCK_ASSERT(sc);
+ ifp = sc->ifp;
+ if ((ifp->if_drv_flags & IFF_DRV_RUNNING) != 0)
+ return;
+ getbinuptime(&sc->init_uptime);
+ if (!sc->swsc->rx.running && !sc->swsc->tx.running) {
+ /* Reset the controller. */
+ cpsw_reset(sc->swsc);
+ cpsw_init(sc->swsc);
+ /* Set Slave Mapping. */
+ cpsw_write_4(sc->swsc, CPSW_SL_RX_PRI_MAP(sc->unit), 0x76543210);
+ cpsw_write_4(sc->swsc, CPSW_PORT_P_TX_PRI_MAP(sc->unit + 1),
+ 0x33221100);
+ cpsw_write_4(sc->swsc, CPSW_SL_RX_MAXLEN(sc->unit), 0x5f2);
+ /* Enable MAC RX/TX modules. */
+ /* TODO: Docs claim that IFCTL_B and IFCTL_A do the same thing? */
+ /* Huh? Docs call bit 0 "Loopback" some places, "FullDuplex" others. */
+ reg = cpsw_read_4(sc->swsc, CPSW_SL_MACCONTROL(sc->unit));
+ reg |= CPSW_SL_MACTL_GMII_ENABLE;
+ cpsw_write_4(sc->swsc, CPSW_SL_MACCONTROL(sc->unit), reg);
+ /* Initialize ALE: set port to forwarding(3), initialize addrs */
+ cpsw_write_4(sc->swsc, CPSW_ALE_PORTCTL(sc->unit + 1), 3);
+ cpswp_ale_update_addresses(sc, 1);
+ if (sc->swsc->dualemac) {
+ cpsw_write_4(sc->swsc, CPSW_PORT_P_VLAN(0),
+ 1 & 0xfff);
+ /* Set Port VID. */
+ cpsw_write_4(sc->swsc, CPSW_PORT_P_VLAN(sc->unit + 1),
+ sc->vlan & 0xfff);
+ cpsw_ale_update_vlan_table(sc->swsc, sc->vlan,
+ (1 << (sc->unit + 1)) | (1 << 0),
+ (1 << (sc->unit + 1)) | (1 << 0));
+ mii_mediachg(sc->mii);
+ callout_reset(&sc->mii_callout, hz, cpswp_tick, sc);
+ ifp->if_drv_flags |= IFF_DRV_RUNNING;
+ ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+static int
+cpsw_shutdown(device_t dev)
+ struct cpsw_softc *sc;
+ int i;
+ sc = device_get_softc(dev);
+ CPSW_DEBUGF(sc, (""));
+ for (i = 0; i < CPSW_PORTS; i++) {
+ if (!sc->dualemac && i != sc->active_slave)
+ continue;
+ psc = device_get_softc(sc->port[i].dev);
+ CPSW_PORT_LOCK(psc);
+ cpswp_stop_locked(psc);
+ CPSW_PORT_UNLOCK(psc);
+ return (0);
+static void
+cpsw_rx_teardown_locked(struct cpsw_softc *sc)
+ struct mbuf *received, *next;
+ int i = 0;
+ CPSW_DEBUGF(sc, ("starting RX teardown"));
+ cpsw_write_4(sc, CPSW_CPDMA_RX_TEARDOWN, 0);
+ for (;;) {
+ received = cpsw_rx_dequeue(sc);
+ CPSW_GLOBAL_UNLOCK(sc);
+ while (received != NULL) {
+ next = received->m_nextpkt;
+ received->m_nextpkt = NULL;
+ ifp = received->m_pkthdr.rcvif;
+ (*ifp->if_input)(ifp, received);
+ received = next;
+ CPSW_GLOBAL_LOCK(sc);
+ if (!sc->rx.running) {
+ CPSW_DEBUGF(sc,
+ ("finished RX teardown (%d retries)", i));
+ return;
+ if (++i > 10) {
+ device_printf(sc->dev,
+ "Unable to cleanly shutdown receiver\n");
+ return;
+ DELAY(10);
+static void
+cpsw_tx_teardown_locked(struct cpsw_softc *sc)
+ int i = 0;
+ CPSW_DEBUGF(sc, ("starting TX teardown"));
+ cpsw_write_4(sc, CPSW_CPDMA_TX_TEARDOWN, 0);
+ cpsw_tx_dequeue(sc);
+ while (sc->tx.running && ++i < 10) {
+ DELAY(10);
+ if (sc->tx.running) {
+ "Unable to cleanly shutdown transmitter\n");
+ CPSW_DEBUGF(sc, ("finished TX teardown (%d retries, %d idle buffers)",
+ i, sc->tx.active_queue_len));
+static void
+cpswp_stop_locked(struct cpswp_softc *sc)
+ uint32_t reg;
+ ifp = sc->ifp;
+ if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0)
+ return;
+ /* Disable interface */
+ ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
+ ifp->if_drv_flags |= IFF_DRV_OACTIVE;
+ /* Stop ticker */
+ callout_stop(&sc->mii_callout);
+ /* Tear down the RX/TX queues. */
+ if (cpsw_ports_down(sc->swsc)) {
+ CPSW_GLOBAL_LOCK(sc->swsc);
+ cpsw_rx_teardown_locked(sc->swsc);
+ cpsw_tx_teardown_locked(sc->swsc);
+ CPSW_GLOBAL_UNLOCK(sc->swsc);
+ /* Stop MAC RX/TX modules. */
+ reg &= ~CPSW_SL_MACTL_GMII_ENABLE;
+ /* Capture stats before we reset controller. */
+#ifndef __rtems__
+ cpsw_stats_collect(sc->swsc);
+#endif
+ * Suspend/Resume.
+static int
+cpsw_suspend(device_t dev)
+ int i;
+ continue;
+ return (0);
+static int
+cpsw_resume(device_t dev)
+ CPSW_DEBUGF(sc, ("UNIMPLEMENTED"));
+ return (0);
+ * IOCTL
+static void
+cpsw_set_promisc(struct cpswp_softc *sc, int set)
+ uint32_t reg;
+ * Enabling promiscuous mode requires ALE_BYPASS to be enabled.
+ * That disables the ALE forwarding logic and causes every
+ * packet to be sent only to the host port. In bypass mode,
+ * the ALE processes host port transmit packets the same as in
+ * normal mode.
+ reg = cpsw_read_4(sc->swsc, CPSW_ALE_CONTROL);
+ reg &= ~CPSW_ALE_CTL_BYPASS;
+ if (set)
+ reg |= CPSW_ALE_CTL_BYPASS;
+ cpsw_write_4(sc->swsc, CPSW_ALE_CONTROL, reg);
+static void
+cpsw_set_allmulti(struct cpswp_softc *sc, int set)
+ if (set) {
+ printf("All-multicast mode unimplemented\n");
+static int
+cpswp_ioctl(struct ifnet *ifp, u_long command, caddr_t data)
+ struct cpswp_softc *sc;
+ struct ifreq *ifr;
+ int error;
+ uint32_t changed;
+ error = 0;
+ sc = ifp->if_softc;
+ ifr = (struct ifreq *)data;
+ switch (command) {
+ case SIOCSIFFLAGS:
+ if (ifp->if_flags & IFF_UP) {
+ if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+ changed = ifp->if_flags ^ sc->if_flags;
+ CPSWP_DEBUGF(sc,
+ ("SIOCSIFFLAGS: UP & RUNNING (changed=0x%x)",
+ changed));
+ if (changed & IFF_PROMISC)
+ cpsw_set_promisc(sc,
+ ifp->if_flags & IFF_PROMISC);
+ if (changed & IFF_ALLMULTI)
+ cpsw_set_allmulti(sc,
+ ifp->if_flags & IFF_ALLMULTI);
+ } else {
+ CPSWP_DEBUGF(sc,
+ ("SIOCSIFFLAGS: UP but not RUNNING; starting up"));
+ cpswp_init_locked(sc);
+ } else if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+ CPSWP_DEBUGF(sc,
+ ("SIOCSIFFLAGS: not UP but RUNNING; shutting down"));
+ cpswp_stop_locked(sc);
+ sc->if_flags = ifp->if_flags;
+ break;
+ case SIOCADDMULTI:
+ cpswp_ale_update_addresses(sc, 0);
+ break;
+ case SIOCDELMULTI:
+ /* Ugh. DELMULTI doesn't provide the specific address
+ being removed, so the best we can do is remove
+ everything and rebuild it all. */
+ break;
+ case SIOCGIFMEDIA:
+ case SIOCSIFMEDIA:
+ error = ifmedia_ioctl(ifp, ifr, &sc->mii->mii_media, command);
+ break;
+ default:
+ error = ether_ioctl(ifp, command, data);
+ return (error);
+ * MIIBUS
+static int
+cpswp_miibus_ready(struct cpsw_softc *sc, uint32_t reg)
+ uint32_t r, retries = CPSW_MIIBUS_RETRIES;
+ while (--retries) {
+ r = cpsw_read_4(sc, reg);
+ if ((r & MDIO_PHYACCESS_GO) == 0)
+ return (1);
+ DELAY(CPSW_MIIBUS_DELAY);
+ return (0);
+static int
+cpswp_miibus_readreg(device_t dev, int phy, int reg)
+ uint32_t cmd, r;
+ if (!cpswp_miibus_ready(sc->swsc, sc->phyaccess)) {
+ device_printf(dev, "MDIO not ready to read\n");
+ return (0);
+ /* Set GO, reg, phy */
+ cmd = MDIO_PHYACCESS_GO | (reg & 0x1F) << 21 | (phy & 0x1F) << 16;
+ cpsw_write_4(sc->swsc, sc->phyaccess, cmd);
+ device_printf(dev, "MDIO timed out during read\n");
+ return (0);
+ r = cpsw_read_4(sc->swsc, sc->phyaccess);
+ if ((r & MDIO_PHYACCESS_ACK) == 0) {
+ device_printf(dev, "Failed to read from PHY.\n");
+ r = 0;
+ return (r & 0xFFFF);
+static int
+cpswp_miibus_writereg(device_t dev, int phy, int reg, int value)
+ uint32_t cmd;
+ device_printf(dev, "MDIO not ready to write\n");
+ return (0);
+ /* Set GO, WRITE, reg, phy, and value */
+ cmd = MDIO_PHYACCESS_GO | MDIO_PHYACCESS_WRITE |
+ (reg & 0x1F) << 21 | (phy & 0x1F) << 16 | (value & 0xFFFF);
+ device_printf(dev, "MDIO timed out during write\n");
+ return (0);
+ if ((cpsw_read_4(sc->swsc, sc->phyaccess) & MDIO_PHYACCESS_ACK) == 0)
+ device_printf(dev, "Failed to write to PHY.\n");
+ return (0);
+static void
+cpswp_miibus_statchg(device_t dev)
+ uint32_t mac_control, reg;
+ reg = CPSW_SL_MACCONTROL(sc->unit);
+ mac_control = cpsw_read_4(sc->swsc, reg);
+ mac_control &= ~(CPSW_SL_MACTL_GIG | CPSW_SL_MACTL_IFCTL_A |
+ CPSW_SL_MACTL_IFCTL_B | CPSW_SL_MACTL_FULLDUPLEX);
+ switch(IFM_SUBTYPE(sc->mii->mii_media_active)) {
+ case IFM_1000_SX:
+ case IFM_1000_LX:
+ case IFM_1000_CX:
+ case IFM_1000_T:
+ mac_control |= CPSW_SL_MACTL_GIG;
+ break;
+ case IFM_100_TX:
+ mac_control |= CPSW_SL_MACTL_IFCTL_A;
+ break;
+ if (sc->mii->mii_media_active & IFM_FDX)
+ mac_control |= CPSW_SL_MACTL_FULLDUPLEX;
+ cpsw_write_4(sc->swsc, reg, mac_control);
+ * Transmit/Receive Packets.
+static void
+cpsw_intr_rx(void *arg)
+ struct cpsw_softc *sc = arg;
+ //cpsw_ale_dump_table(sc);
+ CPSW_RX_LOCK(sc);
+ cpsw_rx_enqueue(sc);
+ cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 1);
+ CPSW_RX_UNLOCK(sc);
+ received = next;
+static struct mbuf *
+cpsw_rx_dequeue(struct cpsw_softc *sc)
+ struct cpsw_cpdma_bd bd;
+ struct cpsw_slot *slot;
+ struct mbuf *mb_head, *mb_tail;
+ int port, removed = 0;
+ mb_head = mb_tail = NULL;
+ /* Pull completed packets off hardware RX queue. */
+ while ((slot = STAILQ_FIRST(&sc->rx.active)) != NULL) {
+ cpsw_cpdma_read_bd(sc, slot, &bd);
+ if (bd.flags & CPDMA_BD_OWNER)
+ break; /* Still in use by hardware */
+ CPSW_DEBUGF(sc, ("Removing received packet from RX queue"));
+ ++removed;
+ STAILQ_REMOVE_HEAD(&sc->rx.active, next);
+ STAILQ_INSERT_TAIL(&sc->rx.avail, slot, next);
+#ifndef __rtems__
+ bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTREAD);
+ bus_dmamap_unload(sc->mbuf_dtag, slot->dmamap);
+#else
+ rtems_cache_invalidate_multiple_data_lines(slot->mbuf->m_data, slot->mbuf->m_len);
+#endif
+ if (bd.flags & CPDMA_BD_TDOWNCMPLT) {
+ CPSW_DEBUGF(sc, ("RX teardown in progress"));
+ m_freem(slot->mbuf);
+ slot->mbuf = NULL;
+ cpsw_write_cp(sc, &sc->rx, 0xfffffffc);
+ sc->rx.running = 0;
+ break;
+ cpsw_write_cp_slot(sc, &sc->rx, slot);
+ port = (bd.flags & CPDMA_BD_PORT_MASK) - 1;
+ KASSERT(port >= 0 && port <= 1,
+ ("patcket received with invalid port: %d", port));
+ psc = device_get_softc(sc->port[port].dev);
+ /* Set up mbuf */
+ /* TODO: track SOP/EOP bits to assemble a full mbuf
+ out of received fragments. */
+ slot->mbuf->m_data += bd.bufoff;
+ slot->mbuf->m_len = bd.pktlen - 4;
+ slot->mbuf->m_pkthdr.len = bd.pktlen - 4;
+ slot->mbuf->m_flags |= M_PKTHDR;
+ slot->mbuf->m_pkthdr.rcvif = psc->ifp;
+ slot->mbuf->m_nextpkt = NULL;
+ if ((psc->ifp->if_capenable & IFCAP_RXCSUM) != 0) {
+ /* check for valid CRC by looking into pkt_err[5:4] */
+ if ((bd.flags & CPDMA_BD_PKT_ERR_MASK) == 0) {
+ slot->mbuf->m_pkthdr.csum_flags |= CSUM_IP_CHECKED;
+ slot->mbuf->m_pkthdr.csum_flags |= CSUM_IP_VALID;
+ slot->mbuf->m_pkthdr.csum_data = 0xffff;
+ /* Add mbuf to packet list to be returned. */
+ if (mb_tail) {
+ mb_tail->m_nextpkt = slot->mbuf;
+ } else {
+ mb_head = slot->mbuf;
+ mb_tail = slot->mbuf;
+ if (removed != 0) {
+ sc->rx.queue_removes += removed;
+ sc->rx.active_queue_len -= removed;
+ sc->rx.avail_queue_len += removed;
+ if (sc->rx.avail_queue_len > sc->rx.max_avail_queue_len)
+ sc->rx.max_avail_queue_len = sc->rx.avail_queue_len;
+ return (mb_head);
+static void
+cpsw_rx_enqueue(struct cpsw_softc *sc)
+ bus_dma_segment_t seg[1];
+ struct cpsw_slots tmpqueue = STAILQ_HEAD_INITIALIZER(tmpqueue);
+ struct cpsw_slot *slot, *prev_slot = NULL;
+ struct cpsw_slot *last_old_slot, *first_new_slot;
+ int error, nsegs, added = 0;
+ /* Register new mbufs with hardware. */
+ while ((slot = STAILQ_FIRST(&sc->rx.avail)) != NULL) {
+ if (slot->mbuf == NULL) {
+ slot->mbuf = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+ "Unable to fill RX queue\n");
+ break;
+ slot->mbuf->m_ext.ext_size;
+#ifndef __rtems__
+ error = bus_dmamap_load_mbuf_sg(sc->mbuf_dtag, slot->dmamap,
+ slot->mbuf, seg, &nsegs, BUS_DMA_NOWAIT);
+ KASSERT(nsegs == 1, ("More than one segment (nsegs=%d)", nsegs));
+ KASSERT(error == 0, ("DMA error (error=%d)", error));
+ if (error != 0 || nsegs != 1) {
+ "%s: Can't prep RX buf for DMA (nsegs=%d, error=%d)\n",
+ __func__, nsegs, error);
+ break;
+#endif
+#ifndef __rtems__
+ bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_PREREAD);
+#else
+ seg->ds_addr = mtod(slot->mbuf, bus_addr_t);
+#endif
+ /* Create and submit new rx descriptor*/
+ bd.next = 0;
+ bd.bufptr = seg->ds_addr;
+ bd.bufoff = 0;
+ bd.buflen = MCLBYTES - 1;
+ bd.pktlen = bd.buflen;
+ bd.flags = CPDMA_BD_OWNER;
+ cpsw_cpdma_write_bd(sc, slot, &bd);
+ ++added;
+ if (prev_slot != NULL)
+ cpsw_cpdma_write_bd_next(sc, prev_slot, slot);
+ prev_slot = slot;
+ STAILQ_REMOVE_HEAD(&sc->rx.avail, next);
+ sc->rx.avail_queue_len--;
+ STAILQ_INSERT_TAIL(&tmpqueue, slot, next);
+ if (added == 0)
+ return;
+ CPSW_DEBUGF(sc, ("Adding %d buffers to RX queue", added));
+ /* Link new entries to hardware RX queue. */
+ last_old_slot = STAILQ_LAST(&sc->rx.active, cpsw_slot, next);
+ first_new_slot = STAILQ_FIRST(&tmpqueue);
+ STAILQ_CONCAT(&sc->rx.active, &tmpqueue);
+ if (first_new_slot == NULL) {
+ return;
+ } else if (last_old_slot == NULL) {
+ /* Start a fresh queue. */
+ cpsw_write_hdp_slot(sc, &sc->rx, first_new_slot);
+ } else {
+ /* Add buffers to end of current queue. */
+ cpsw_cpdma_write_bd_next(sc, last_old_slot, first_new_slot);
+ /* If underrun, restart queue. */
+ if (cpsw_cpdma_read_bd_flags(sc, last_old_slot) & CPDMA_BD_EOQ) {
+ sc->rx.queue_adds += added;
+ sc->rx.active_queue_len += added;
+ if (sc->rx.active_queue_len > sc->rx.max_active_queue_len) {
+ sc->rx.max_active_queue_len = sc->rx.active_queue_len;
+static void
+cpswp_start(struct ifnet *ifp)
+ struct cpswp_softc *sc = ifp->if_softc;
+ CPSW_TX_LOCK(sc->swsc);
+ if ((ifp->if_drv_flags & IFF_DRV_RUNNING) && sc->swsc->tx.running) {
+ cpswp_tx_enqueue(sc);
+ cpsw_tx_dequeue(sc->swsc);
+ //cpsw_ale_dump_table(sc->swsc);
+ CPSW_TX_UNLOCK(sc->swsc);
------------------ Original ------------------
Date: Tue, Jul 5, 2016 03:17 PM
To: "devel"<devel at rtems.org>;
Subject: Re: [3/6] add ti cpsw driver file part 1
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c 2016-07-05 09:22:41.794327800 +0800
@@ -0,0 +1,2772 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
+ * Copyright (c) 2016 Rubicon Communications, LLC (Netgate)
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * TI Common Platform Ethernet Switch (CPSW) Driver
+ * Found in TI8148 "DaVinci" and AM335x "Sitara" SoCs.
+ * This controller is documented in the AM335x Technical Reference
+ * Manual, in the TMS320DM814x DaVinci Digital Video Processors TRM
+ * and in the TMS320C6452 3 Port Switch Ethernet Subsystem TRM.
+ * It is basically a single Ethernet port (port 0) wired internally to
+ * a 3-port store-and-forward switch connected to two independent
+ * "sliver" controllers (port 1 and port 2). You can operate the
+ * controller in a variety of different ways by suitably configuring
+ * the slivers and the Address Lookup Engine (ALE) that routes packets
+ * between the ports.
+ * This code was developed and tested on a BeagleBone with
+ * an AM335x SoC.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/systm.h>
+#include <sys/endian.h>
+#include <sys/mbuf.h>
+#ifndef __rtems__
+#include <sys/lock.h>
+#else
+#include <rtems/bsd/sys/lock.h>
+#endif
+#include <sys/mutex.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/socket.h>
+#include <sys/sysctl.h>
+#include <net/ethernet.h>
+#include <net/bpf.h>
+#include <net/if.h>
+#include <net/if_arp.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <net/if_vlan_var.h>
+#include <netinet/in_systm.h>
+#include <netinet/in.h>
+#include <netinet/ip.h>
+#include <sys/sockio.h>
+#include <sys/bus.h>
+#include <machine/bus.h>
+#include <sys/rman.h>
+#include <machine/resource.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#ifndef __rtems__
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#endif
+#include "if_cpswreg.h"
+#include "if_cpswvar.h"
+#ifndef __rtems__
+#include <arm/ti/ti_scm.h>
+#endif
+#include <rtems/bsd/local/miibus_if.h>
+#include <sys/malloc.h>
+/* Device probe/attach/detach. */
+static int cpsw_probe(device_t);
+static void cpsw_init_slots(struct cpsw_softc *);
+static int cpsw_attach(device_t);
+static void cpsw_free_slot(struct cpsw_softc *, struct cpsw_slot *);
+static int cpsw_detach(device_t);
+static int cpswp_probe(device_t);
+static int cpswp_attach(device_t);
+static int cpswp_detach(device_t);
+#ifndef __rtems__
+static phandle_t cpsw_get_node(device_t, device_t);
+#endif
+/* Device Init/shutdown. */
+static int cpsw_shutdown(device_t);
+static void cpswp_init(void *);
+static void cpswp_init_locked(void *);
+static void cpswp_stop_locked(struct cpswp_softc *);
+/* Device Suspend/Resume. */
+static int cpsw_suspend(device_t);
+static int cpsw_resume(device_t);
+/* Ioctl. */
+static int cpswp_ioctl(struct ifnet *, u_long command, caddr_t data);
+static int cpswp_miibus_readreg(device_t, int phy, int reg);
+static int cpswp_miibus_writereg(device_t, int phy, int reg, int value);
+static void cpswp_miibus_statchg(device_t);
+/* Send/Receive packets. */
+static void cpsw_intr_rx(void *arg);
+static struct mbuf *cpsw_rx_dequeue(struct cpsw_softc *);
+static void cpsw_rx_enqueue(struct cpsw_softc *);
+static void cpswp_start(struct ifnet *);
+static void cpswp_tx_enqueue(struct cpswp_softc *);
+static int cpsw_tx_dequeue(struct cpsw_softc *);
+/* Misc interrupts and watchdog. */
+static void cpsw_intr_rx_thresh(void *);
+static void cpsw_intr_misc(void *);
+static void cpswp_tick(void *);
+static void cpswp_ifmedia_sts(struct ifnet *, struct ifmediareq *);
+static int cpswp_ifmedia_upd(struct ifnet *);
+static void cpsw_tx_watchdog(void *);
+/* ALE support */
+static void cpsw_ale_read_entry(struct cpsw_softc *, uint16_t, uint32_t *);
+static void cpsw_ale_write_entry(struct cpsw_softc *, uint16_t, uint32_t *);
+static int cpsw_ale_mc_entry_set(struct cpsw_softc *, uint8_t, int, uint8_t *);
+static void cpsw_ale_dump_table(struct cpsw_softc *);
+static int cpsw_ale_update_vlan_table(struct cpsw_softc *, int, int, int);
+static int cpswp_ale_update_addresses(struct cpswp_softc *, int);
+/* Statistics and sysctls. */
+#ifndef __rtems__
+static void cpsw_add_sysctls(struct cpsw_softc *);
+static void cpsw_stats_collect(struct cpsw_softc *);
+static int cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS);
+#endif
+ * Arbitrary limit on number of segments in an mbuf to be transmitted.
+ * Packets with more segments than this will be defragmented before
+ * they are queued.
+#define CPSW_TXFRAGS 8
+/* Shared resources. */
+static device_method_t cpsw_methods[] = {
+ /* Device interface */
+ DEVMETHOD(device_probe, cpsw_probe),
+ DEVMETHOD(device_attach, cpsw_attach),
+ DEVMETHOD(device_detach, cpsw_detach),
+ DEVMETHOD(device_shutdown, cpsw_shutdown),
+ DEVMETHOD(device_suspend, cpsw_suspend),
+ DEVMETHOD(device_resume, cpsw_resume),
+ /* OFW methods */
+#ifndef __rtems__
+ DEVMETHOD(ofw_bus_get_node, cpsw_get_node),
+#endif
+ DEVMETHOD_END
+static driver_t cpsw_driver = {
+ "cpsw",
+ cpsw_methods,
+ sizeof(struct cpsw_softc),
+static devclass_t cpsw_devclass;
+#ifndef __rtems__
+DRIVER_MODULE(cpsw, simplebus, cpsw_driver, cpsw_devclass, 0, 0);
+#else
+DRIVER_MODULE(cpsw, nexus, cpsw_driver, cpsw_devclass, 0, 0);
+#endif
+/* Port/Slave resources. */
+static device_method_t cpswp_methods[] = {
+ DEVMETHOD(device_probe, cpswp_probe),
+ DEVMETHOD(device_attach, cpswp_attach),
+ DEVMETHOD(device_detach, cpswp_detach),
+ /* MII interface */
+ DEVMETHOD(miibus_readreg, cpswp_miibus_readreg),
+ DEVMETHOD(miibus_writereg, cpswp_miibus_writereg),
+ DEVMETHOD(miibus_statchg, cpswp_miibus_statchg),
+ DEVMETHOD_END
+static driver_t cpswp_driver = {
+ "cpswp",
+ cpswp_methods,
+ sizeof(struct cpswp_softc),
+static devclass_t cpswp_devclass;
+DRIVER_MODULE(cpswp, cpsw, cpswp_driver, cpswp_devclass, 0, 0);
+DRIVER_MODULE(miibus, cpswp, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(cpsw, ether, 1, 1, 1);
+MODULE_DEPEND(cpswp, miibus, 1, 1, 1);
+static uint32_t slave_mdio_addr[] = { 0x4a100200, 0x4a100300 };
+static struct resource_spec irq_res_spec[] = {
+#ifdef __rtems__
+ { SYS_RES_MEMORY, 0, RF_ACTIVE },
+#endif
+ { SYS_RES_IRQ, 0, RF_ACTIVE | RF_SHAREABLE },
+ { SYS_RES_IRQ, 1, RF_ACTIVE | RF_SHAREABLE },
+ { SYS_RES_IRQ, 2, RF_ACTIVE | RF_SHAREABLE },
+ { SYS_RES_IRQ, 3, RF_ACTIVE | RF_SHAREABLE },
+ { -1, 0 }
+/* Number of entries here must match size of stats
+ * array in struct cpswp_softc. */
+static struct cpsw_stat {
+ int reg;
+ char *oid;
+} cpsw_stat_sysctls[CPSW_SYSCTL_COUNT] = {
+ {0x00, "GoodRxFrames"},
+ {0x04, "BroadcastRxFrames"},
+ {0x08, "MulticastRxFrames"},
+ {0x0C, "PauseRxFrames"},
+ {0x10, "RxCrcErrors"},
+ {0x14, "RxAlignErrors"},
+ {0x18, "OversizeRxFrames"},
+ {0x1c, "RxJabbers"},
+ {0x20, "ShortRxFrames"},
+ {0x24, "RxFragments"},
+ {0x30, "RxOctets"},
+ {0x34, "GoodTxFrames"},
+ {0x38, "BroadcastTxFrames"},
+ {0x3c, "MulticastTxFrames"},
+ {0x40, "PauseTxFrames"},
+ {0x44, "DeferredTxFrames"},
+ {0x48, "CollisionsTxFrames"},
+ {0x4c, "SingleCollisionTxFrames"},
+ {0x50, "MultipleCollisionTxFrames"},
+ {0x54, "ExcessiveCollisions"},
+ {0x58, "LateCollisions"},
+ {0x5c, "TxUnderrun"},
+ {0x60, "CarrierSenseErrors"},
+ {0x64, "TxOctets"},
+ {0x68, "RxTx64OctetFrames"},
+ {0x6c, "RxTx65to127OctetFrames"},
+ {0x70, "RxTx128to255OctetFrames"},
+ {0x74, "RxTx256to511OctetFrames"},
+ {0x78, "RxTx512to1024OctetFrames"},
+ {0x7c, "RxTx1024upOctetFrames"},
+ {0x80, "NetOctets"},
+ {0x84, "RxStartOfFrameOverruns"},
+ {0x88, "RxMiddleOfFrameOverruns"},
+ {0x8c, "RxDmaOverruns"}
+ * Basic debug support.
+#define IF_DEBUG(_sc) if ((_sc)->if_flags & IFF_DEBUG)
+static void
+cpsw_debugf_head(const char *funcname)
+ int t = (int)(time_second % (24 * 60 * 60));
+ printf("%02d:%02d:%02d %s ", t / (60 * 60), (t / 60) % 60, t % 60, funcname);
+#include <machine/stdarg.h>
+static void
+cpsw_debugf(const char *fmt, ...)
+ va_list ap;
+ va_start(ap, fmt);
+ vprintf(fmt, ap);
+ va_end(ap);
+ printf("\n");
+#define CPSW_DEBUGF(_sc, a) do { \
+ if (sc->debug) { \
+ cpsw_debugf_head(__func__); \
+ cpsw_debugf a; \
+} while (0)
+#define CPSWP_DEBUGF(_sc, a) do { \
+ IF_DEBUG((_sc)) { \
+ cpsw_debugf a; \
+} while (0)
+ * Locking macros
+#define CPSW_TX_LOCK(sc) do { \
+ mtx_assert(&(sc)->rx.lock, MA_NOTOWNED); \
+ mtx_lock(&(sc)->tx.lock); \
+} while (0)
+#define CPSW_TX_UNLOCK(sc) mtx_unlock(&(sc)->tx.lock)
+#define CPSW_TX_LOCK_ASSERT(sc) mtx_assert(&(sc)->tx.lock, MA_OWNED)
+#define CPSW_RX_LOCK(sc) do { \
+ mtx_assert(&(sc)->tx.lock, MA_NOTOWNED); \
+ mtx_lock(&(sc)->rx.lock); \
+} while (0)
+#define CPSW_RX_UNLOCK(sc) mtx_unlock(&(sc)->rx.lock)
+#define CPSW_RX_LOCK_ASSERT(sc) mtx_assert(&(sc)->rx.lock, MA_OWNED)
+#define CPSW_GLOBAL_LOCK(sc) do { \
+ if ((mtx_owned(&(sc)->tx.lock) ? 1 : 0) != \
+ (mtx_owned(&(sc)->rx.lock) ? 1 : 0)) { \
+ panic("cpsw deadlock possibility detection!"); \
+} while (0)
+#define CPSW_GLOBAL_UNLOCK(sc) do { \
+ CPSW_RX_UNLOCK(sc); \
+ CPSW_TX_UNLOCK(sc); \
+} while (0)
+#define CPSW_GLOBAL_LOCK_ASSERT(sc) do { \
+ CPSW_TX_LOCK_ASSERT(sc); \
+ CPSW_RX_LOCK_ASSERT(sc); \
+} while (0)
+#define CPSW_PORT_LOCK(_sc) do { \
+ mtx_assert(&(_sc)->lock, MA_NOTOWNED); \
+ mtx_lock(&(_sc)->lock); \
+} while (0)
+#define CPSW_PORT_UNLOCK(_sc) mtx_unlock(&(_sc)->lock)
+#define CPSW_PORT_LOCK_ASSERT(_sc) mtx_assert(&(_sc)->lock, MA_OWNED)
+ * Read/Write macros
+#define cpsw_read_4(_sc, _reg) bus_read_4((_sc)->irq_res[0], (_reg))
+#define cpsw_write_4(_sc, _reg, _val) \
+ bus_write_4((_sc)->irq_res[0], (_reg), (_val))
+#define BUS_SPACE_PHYSADDR(res, offs) \
+ ((u_int)(rman_get_start(res)+(offs)))
+#define CONTROL_MOD_BASE 0x44E10000
+#define CPSW_GMII_SEL (0x0650)
+/* GMII_SEL Register Field */
+#define GMIISEL_RMII2_IO_CLK_EN (1UL<<(7))
+#define GMIISEL_RMII1_IO_CLK_EN (1UL<<(6))
+#define GMIISEL_RGMII2_IDMODE (1UL<<(5))
+#define GMIISEL_RGMII1_IDMODE (1UL<<(4))
+#define GMIISEL_GMII2_SEL(val) ((0x3 & (val)) << 2)
+#define GMIISEL_GMII1_SEL(val) ((0x3 & (val)) << 0)
+#define GMII_MODE 0
+#define RMII_MODE 1
+#define RGMII_MODE 2
+#define cm_read(a) (*(volatile uint32_t *)(a))
+#define cm_write(a,v) (*(volatile uint32_t *)(a) = (v))
+#define cpsw_cpdma_bd_offset(i) (CPSW_CPPI_RAM_OFFSET + ((i)*16))
+#define cpsw_cpdma_bd_paddr(sc, slot) \
+ BUS_SPACE_PHYSADDR(sc->irq_res[0], slot->bd_offset)
+#define cpsw_cpdma_read_bd(sc, slot, val) \
+ bus_read_region_4(sc->irq_res[0], slot->bd_offset, (uint32_t *) val, 4)
+#define cpsw_cpdma_write_bd(sc, slot, val) \
+ bus_write_region_4(sc->irq_res[0], slot->bd_offset, (uint32_t *) val, 4)
+#define cpsw_cpdma_write_bd_next(sc, slot, next_slot) \
+ cpsw_write_4(sc, slot->bd_offset, cpsw_cpdma_bd_paddr(sc, next_slot))
+#define cpsw_cpdma_read_bd_flags(sc, slot) \
+ bus_read_2(sc->irq_res[0], slot->bd_offset + 14)
+#define cpsw_write_hdp_slot(sc, queue, slot) \
+ cpsw_write_4(sc, (queue)->hdp_offset, cpsw_cpdma_bd_paddr(sc, slot))
+#define CP_OFFSET (CPSW_CPDMA_TX_CP(0) - CPSW_CPDMA_TX_HDP(0))
+#define cpsw_read_cp(sc, queue) \
+ cpsw_read_4(sc, (queue)->hdp_offset + CP_OFFSET)
+#define cpsw_write_cp(sc, queue, val) \
+ cpsw_write_4(sc, (queue)->hdp_offset + CP_OFFSET, (val))
+#define cpsw_write_cp_slot(sc, queue, slot) \
+ cpsw_write_cp(sc, queue, cpsw_cpdma_bd_paddr(sc, slot))
+#if 0
+/* XXX temporary function versions for debugging. */
+static void
+cpsw_write_hdp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+ uint32_t reg = queue->hdp_offset;
+ uint32_t v = cpsw_cpdma_bd_paddr(sc, slot);
+ CPSW_DEBUGF(("HDP <=== 0x%08x (was 0x%08x)", v, cpsw_read_4(sc, reg)));
+ cpsw_write_4(sc, reg, v);
+static void
+cpsw_write_cp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+ CPSW_DEBUGF(("CP <=== 0x%08x (expecting 0x%08x)", v, cpsw_read_cp(sc, queue)));
+ cpsw_write_cp(sc, queue, v);
+#endif
+ * Expanded dump routines for verbose debugging.
+static void
+cpsw_dump_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
+ static const char *flags[] = {"SOP", "EOP", "Owner", "EOQ",
+ "TDownCmplt", "PassCRC", "Long", "Short", "MacCtl", "Overrun",
+ "PktErr1", "PortEn/PktErr0", "RxVlanEncap", "Port2", "Port1",
+ "Port0"};
+ const char *sep;
+ int i;
+ printf("BD Addr: 0x%08x Next: 0x%08x\n", cpsw_cpdma_bd_paddr(sc, slot), bd.next);
+ printf(" BufPtr: 0x%08x BufLen: 0x%08x\n", bd.bufptr, bd.buflen);
+ printf(" BufOff: 0x%08x PktLen: 0x%08x\n", bd.bufoff, bd.pktlen);
+ printf(" Flags: ");
+ sep = "";
+ for (i = 0; i < 16; ++i) {
+ if (bd.flags & (1 << (15 - i))) {
+ printf("%s%s", sep, flags[i]);
+ sep = ",";
+ printf("\n");
+ if (slot->mbuf) {
+ printf(" Ether: %14D\n",
+ (char *)(slot->mbuf->m_data), " ");
+ printf(" Packet: %16D\n",
+ (char *)(slot->mbuf->m_data) + 14, " ");
+#define CPSW_DUMP_SLOT(cs, slot) do { \
+ IF_DEBUG(sc) { \
+ cpsw_dump_slot(sc, slot); \
+} while (0)
+static void
+cpsw_dump_queue(struct cpsw_softc *sc, struct cpsw_slots *q)
+ int i = 0;
+ int others = 0;
+ STAILQ_FOREACH(slot, q, next) {
+ if (i > 4)
+ ++others;
+ else
+ ++i;
+ if (others)
+ printf(" ... and %d more.\n", others);
+ printf("\n");
Date: Tue, Jul 5, 2016 03:15 PM
Subject: Re: [2/6] add ti cpsw head file
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h 2016-03-18 11:38:45.324075400 +0800
@@ -0,0 +1,178 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _IF_CPSWREG_H
+#define _IF_CPSWREG_H
+#define CPSW_SS_OFFSET 0x0000
+#define CPSW_SS_IDVER (CPSW_SS_OFFSET + 0x00)
+#define CPSW_SS_SOFT_RESET (CPSW_SS_OFFSET + 0x08)
+#define CPSW_SS_STAT_PORT_EN (CPSW_SS_OFFSET + 0x0C)
+#define CPSW_SS_PTYPE (CPSW_SS_OFFSET + 0x10)
+#define CPSW_SS_FLOW_CONTROL (CPSW_SS_OFFSET + 0x24)
+#define CPSW_PORT_OFFSET 0x0100
+#define CPSW_PORT_P_MAX_BLKS(p) (CPSW_PORT_OFFSET + 0x08 + ((p) * 0x100))
+#define CPSW_PORT_P_BLK_CNT(p) (CPSW_PORT_OFFSET + 0x0C + ((p) * 0x100))
+#define CPSW_PORT_P_VLAN(p) (CPSW_PORT_OFFSET + 0x14 + ((p) * 0x100))
+#define CPSW_PORT_P_TX_PRI_MAP(p) (CPSW_PORT_OFFSET + 0x118 + ((p-1) * 0x100))
+#define CPSW_PORT_P0_CPDMA_TX_PRI_MAP (CPSW_PORT_OFFSET + 0x01C)
+#define CPSW_PORT_P0_CPDMA_RX_CH_MAP (CPSW_PORT_OFFSET + 0x020)
+#define CPSW_PORT_P_SA_LO(p) (CPSW_PORT_OFFSET + 0x120 + ((p-1) * 0x100))
+#define CPSW_PORT_P_SA_HI(p) (CPSW_PORT_OFFSET + 0x124 + ((p-1) * 0x100))
+#define CPSW_CPDMA_OFFSET 0x0800
+#define CPSW_CPDMA_TX_CONTROL (CPSW_CPDMA_OFFSET + 0x04)
+#define CPSW_CPDMA_TX_TEARDOWN (CPSW_CPDMA_OFFSET + 0x08)
+#define CPSW_CPDMA_RX_CONTROL (CPSW_CPDMA_OFFSET + 0x14)
+#define CPSW_CPDMA_RX_TEARDOWN (CPSW_CPDMA_OFFSET + 0x18)
+#define CPSW_CPDMA_SOFT_RESET (CPSW_CPDMA_OFFSET + 0x1c)
+#define CPSW_CPDMA_DMACONTROL (CPSW_CPDMA_OFFSET + 0x20)
+#define CPSW_CPDMA_DMASTATUS (CPSW_CPDMA_OFFSET + 0x24)
+#define CPSW_CPDMA_RX_BUFFER_OFFSET (CPSW_CPDMA_OFFSET + 0x28)
+#define CPSW_CPDMA_TX_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0x80)
+#define CPSW_CPDMA_TX_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0x84)
+#define CPSW_CPDMA_TX_INTMASK_SET (CPSW_CPDMA_OFFSET + 0x88)
+#define CPSW_CPDMA_TX_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0x8C)
+#define CPSW_CPDMA_CPDMA_EOI_VECTOR (CPSW_CPDMA_OFFSET + 0x94)
+#define CPSW_CPDMA_RX_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0xA0)
+#define CPSW_CPDMA_RX_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0xA4)
+#define CPSW_CPDMA_RX_INTMASK_SET (CPSW_CPDMA_OFFSET + 0xA8)
+#define CPSW_CPDMA_RX_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0xAc)
+#define CPSW_CPDMA_DMA_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0xB0)
+#define CPSW_CPDMA_DMA_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0xB4)
+#define CPSW_CPDMA_DMA_INTMASK_SET (CPSW_CPDMA_OFFSET + 0xB8)
+#define CPSW_CPDMA_DMA_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0xBC)
+#define CPSW_CPDMA_RX_FREEBUFFER(p) (CPSW_CPDMA_OFFSET + 0x0e0 + ((p) * 0x04))
+#define CPSW_STATS_OFFSET 0x0900
+#define CPSW_STATERAM_OFFSET 0x0A00
+#define CPSW_CPDMA_TX_HDP(p) (CPSW_STATERAM_OFFSET + 0x00 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_HDP(p) (CPSW_STATERAM_OFFSET + 0x20 + ((p) * 0x04))
+#define CPSW_CPDMA_TX_CP(p) (CPSW_STATERAM_OFFSET + 0x40 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_CP(p) (CPSW_STATERAM_OFFSET + 0x60 + ((p) * 0x04))
+#define CPSW_CPTS_OFFSET 0x0C00
+#define CPSW_ALE_OFFSET 0x0D00
+#define CPSW_ALE_CONTROL (CPSW_ALE_OFFSET + 0x08)
+#define CPSW_ALE_CTL_ENABLE (1U << 31)
+#define CPSW_ALE_CTL_CLEAR_TBL (1 << 30)
+#define CPSW_ALE_CTL_BYPASS (1 << 4)
+#define CPSW_ALE_CTL_VLAN_AWARE (1 << 2)
+#define CPSW_ALE_TBLCTL (CPSW_ALE_OFFSET + 0x20)
+#define CPSW_ALE_TBLW2 (CPSW_ALE_OFFSET + 0x34)
+#define CPSW_ALE_TBLW1 (CPSW_ALE_OFFSET + 0x38)
+#define CPSW_ALE_TBLW0 (CPSW_ALE_OFFSET + 0x3C)
+#define ALE_MCAST(_a) ((_a[1] >> 8) & 1)
+#define ALE_MCAST_FWD (3 << 30)
+#define ALE_PORTS(_a) ((_a[2] >> 2) & 7)
+#define ALE_TYPE(_a) ((_a[1] >> 28) & 3)
+#define ALE_TYPE_ADDR 1
+#define ALE_TYPE_VLAN 2
+#define ALE_TYPE_VLAN_ADDR 3
+#define ALE_VLAN(_a) ((_a[1] >> 16) & 0xfff)
+#define ALE_VLAN_REGFLOOD(_a) ((_a[0] >> 8) & 7)
+#define ALE_VLAN_UNREGFLOOD(_a) ((_a[0] >> 16) & 7)
+#define ALE_VLAN_UNTAG(_a) ((_a[0] >> 24) & 7)
+#define ALE_VLAN_MEMBERS(_a) (_a[0] & 7)
+#define CPSW_ALE_PORTCTL(p) (CPSW_ALE_OFFSET + 0x40 + ((p) * 0x04))
+/* SL1 is at 0x0D80, SL2 is at 0x0DC0 */
+#define CPSW_SL_OFFSET 0x0D80
+#define CPSW_SL_MACCONTROL(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x04)
+#define CPSW_SL_MACTL_IFCTL_B (1 << 16)
+#define CPSW_SL_MACTL_IFCTL_A (1 << 15)
+#define CPSW_SL_MACTL_GIG (1 << 7)
+#define CPSW_SL_MACTL_GMII_ENABLE (1 << 5)
+#define CPSW_SL_MACTL_FULLDUPLEX (1 << 0)
+#define CPSW_SL_MACSTATUS(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x08)
+#define CPSW_SL_SOFT_RESET(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x0C)
+#define CPSW_SL_RX_MAXLEN(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x10)
+#define CPSW_SL_RX_PAUSE(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x18)
+#define CPSW_SL_TX_PAUSE(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x1C)
+#define CPSW_SL_RX_PRI_MAP(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x24)
+#define MDIO_OFFSET 0x1000
+#define MDIOCONTROL (MDIO_OFFSET + 0x04)
+#define MDIOCTL_ENABLE (1 << 30)
+#define MDIOCTL_FAULTENB (1 << 18)
+#define MDIOLINKINTRAW (MDIO_OFFSET + 0x10)
+#define MDIOLINKINTMASKED (MDIO_OFFSET + 0x14)
+#define MDIOUSERACCESS0 (MDIO_OFFSET + 0x80)
+#define MDIOUSERPHYSEL0 (MDIO_OFFSET + 0x84)
+#define MDIOUSERACCESS1 (MDIO_OFFSET + 0x88)
+#define MDIOUSERPHYSEL1 (MDIO_OFFSET + 0x8C)
+#define MDIO_PHYSEL_LINKINTENB (1 << 6)
+#define MDIO_PHYACCESS_GO (1U << 31)
+#define MDIO_PHYACCESS_WRITE (1 << 30)
+#define MDIO_PHYACCESS_ACK (1 << 29)
+#define CPSW_WR_OFFSET 0x1200
+#define CPSW_WR_SOFT_RESET (CPSW_WR_OFFSET + 0x04)
+#define CPSW_WR_CONTROL (CPSW_WR_OFFSET + 0x08)
+#define CPSW_WR_INT_CONTROL (CPSW_WR_OFFSET + 0x0c)
+#define CPSW_WR_C_RX_THRESH_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x10)
+#define CPSW_WR_C_RX_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x14)
+#define CPSW_WR_C_TX_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x18)
+#define CPSW_WR_C_MISC_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x1C)
+#define CPSW_WR_C_RX_THRESH_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x40)
+#define CPSW_WR_C_RX_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x44)
+#define CPSW_WR_C_TX_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x48)
+#define CPSW_WR_C_MISC_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x4C)
+#define CPSW_WR_C_MISC_EVNT_PEND (1 << 4)
+#define CPSW_WR_C_MISC_STAT_PEND (1 << 3)
+#define CPSW_WR_C_MISC_HOST_PEND (1 << 2)
+#define CPSW_WR_C_MISC_MDIOLINK (1 << 1)
+#define CPSW_WR_C_MISC_MDIOUSER (1 << 0)
+#define CPSW_CPPI_RAM_OFFSET 0x2000
+#define CPSW_CPPI_RAM_SIZE 0x2000
+#define CPSW_MEMWINDOW_SIZE 0x4000
+#define CPDMA_BD_SOP (1 << 15)
+#define CPDMA_BD_EOP (1 << 14)
+#define CPDMA_BD_OWNER (1 << 13)
+#define CPDMA_BD_EOQ (1 << 12)
+#define CPDMA_BD_TDOWNCMPLT (1 << 11)
+#define CPDMA_BD_PKT_ERR_MASK (3 << 4)
+#define CPDMA_BD_TO_PORT (1 << 4)
+#define CPDMA_BD_PORT_MASK 3
+struct cpsw_cpdma_bd {
+ volatile uint32_t next;
+ volatile uint32_t bufptr;
+ volatile uint16_t buflen;
+ volatile uint16_t bufoff;
+ volatile uint16_t pktlen;
+ volatile uint16_t flags;
+#endif /*_IF_CPSWREG_H */
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h 2016-07-02 21:43:26.205209800 +0800
@@ -0,0 +1,147 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _IF_CPSWVAR_H
+#define _IF_CPSWVAR_H
+#define CPSW_PORTS 2
+#define CPSW_INTR_COUNT 4
+/* MII BUS */
+#define CPSW_MIIBUS_RETRIES 10
+#define CPSW_MIIBUS_DELAY 2000
+#define CPSW_MAX_ALE_ENTRIES 1024
+#define CPSW_SYSCTL_COUNT 34
+#define CPSW_RESEMBLE_BUFFER_LEN 2048
+#define CPSW_RESEMBLE_BUFFER_ALIGN 4
+struct cpsw_slot {
+ uint32_t bd_offset; /* Offset of corresponding BD within CPPI RAM. */
+ bus_dmamap_t dmamap;
+ struct mbuf *mbuf;
+/* yao0718 add why cppi dma can not send when address misalign 32 bits*/
+ uint8_t *resemble;
+ uint8_t *align_res;
+ STAILQ_ENTRY(cpsw_slot) next;
+STAILQ_HEAD(cpsw_slots, cpsw_slot);
+struct cpsw_queue {
+ struct mtx lock;
+ int running;
+ struct cpsw_slots active;
+ struct cpsw_slots avail;
+ uint32_t queue_adds; /* total bufs added */
+ uint32_t queue_removes; /* total bufs removed */
+ uint32_t queue_removes_at_last_tick; /* Used by watchdog */
+ int queue_slots;
+ int active_queue_len;
+ int max_active_queue_len;
+ int avail_queue_len;
+ int max_avail_queue_len;
+ int longest_chain; /* Largest # segments in a single packet. */
+ int hdp_offset;
+struct cpsw_port {
+ device_t dev;
+ int phy;
+ int vlan;
+struct cpsw_softc {
+ device_t dev;
+ int active_slave;
+ int debug;
+ int dualemac;
+#ifndef __rtems__
+ phandle_t node;
+#endif
+ struct bintime attach_uptime; /* system uptime when attach happened. */
+ struct cpsw_port port[2];
+ /* RX and TX buffer tracking */
+ struct cpsw_queue rx, tx;
+ /* We expect 1 memory resource and 4 interrupts from the device tree. */
+ void *ih_cookie[CPSW_INTR_COUNT];
+#ifndef __rtems__
+ int mem_rid;
+ struct resource *mem_res;
+ struct resource *irq_res[CPSW_INTR_COUNT];
+#else
+ struct resource *irq_res[1+CPSW_INTR_COUNT];
+#endif
+ /* An mbuf full of nulls for TX padding. */
+ bus_dmamap_t null_mbuf_dmamap;
+ struct mbuf *null_mbuf;
+ bus_addr_t null_mbuf_paddr;
+ bus_dma_tag_t mbuf_dtag;
+ struct {
+ int resets;
+ int timer;
+ struct callout callout;
+ } watchdog;
+ /* 64-bit versions of 32-bit hardware statistics counters */
+ uint64_t shadow_stats[CPSW_SYSCTL_COUNT];
+ /* CPPI STATERAM has 512 slots for building TX/RX queues. */
+ /* TODO: Size here supposedly varies with different versions
+ of the controller. Check DaVinci specs and find a good
+ way to adjust this. One option is to have a separate
+ Device Tree parameter for number slots; another option
+ is to calculate it from the memory size in the device tree. */
+ struct cpsw_slot _slots[CPSW_CPPI_RAM_SIZE / sizeof(struct cpsw_cpdma_bd)];
+struct cpswp_softc {
+ device_t dev;
+ device_t miibus;
+ device_t pdev;
+ int media_status;
+ int unit;
+ int vlan;
+ struct bintime init_uptime; /* system uptime when init happened. */
+ struct callout mii_callout;
+ struct cpsw_softc *swsc;
+ struct mii_data *mii;
+ struct mtx lock;
+ uint32_t if_flags;
+ uint32_t phy;
+ uint32_t phyaccess;
+ uint32_t physel;
+#endif /*_IF_CPSWVAR_H */
Date: Tue, Jul 5, 2016 03:11 PM
Subject: [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/4dd7be78/attachment-0001.html>
