[3/6] add ti cpsw driver file part 5
yao0718
29171383 at qq.com
Tue Jul 5 07:33:35 UTC 2016
+static int
+cpswp_ale_update_addresses(struct cpswp_softc *sc, int purge)
+ uint8_t *mac;
+ uint32_t ale_entry[3], ale_type, portmask;
+ struct ifmultiaddr *ifma;
+ if (sc->swsc->dualemac) {
+ ale_type = ALE_TYPE_VLAN_ADDR << 28 | sc->vlan << 16;
+ portmask = 1 << (sc->unit + 1) | 1 << 0;
+ } else {
+ ale_type = ALE_TYPE_ADDR << 28;
+ portmask = 7;
+ * Route incoming packets for our MAC address to Port 0 (host).
+ * For simplicity, keep this entry at table index 0 for port 1 and
+ * at index 2 for port 2 in the ALE.
+ if_addr_rlock(sc->ifp);
+ mac = LLADDR((struct sockaddr_dl *)sc->ifp->if_addr->ifa_addr);
+ ale_entry[0] = mac[2] << 24 | mac[3] << 16 | mac[4] << 8 | mac[5];
+ ale_entry[1] = ale_type | mac[0] << 8 | mac[1]; /* addr entry + mac */
+ ale_entry[2] = 0; /* port = 0 */
+ cpsw_ale_write_entry(sc->swsc, 0 + 2 * sc->unit, ale_entry);
+ /* Set outgoing MAC Address for slave port. */
+ cpsw_write_4(sc->swsc, CPSW_PORT_P_SA_HI(sc->unit + 1),
+ mac[3] << 24 | mac[2] << 16 | mac[1] << 8 | mac[0]);
+ cpsw_write_4(sc->swsc, CPSW_PORT_P_SA_LO(sc->unit + 1),
+ mac[5] << 8 | mac[4]);
+ if_addr_runlock(sc->ifp);
+ /* Keep the broadcast address at table entry 1 (or 3). */
+ ale_entry[0] = 0xffffffff; /* Lower 32 bits of MAC */
+ /* ALE_MCAST_FWD, Addr type, upper 16 bits of Mac */
+ ale_entry[1] = ALE_MCAST_FWD | ale_type | 0xffff;
+ ale_entry[2] = portmask << 2;
+ cpsw_ale_write_entry(sc->swsc, 1 + 2 * sc->unit, ale_entry);
+ /* SIOCDELMULTI doesn't specify the particular address
+ being removed, so we have to remove all and rebuild. */
+ if (purge)
+ cpsw_ale_remove_all_mc_entries(sc->swsc);
+ /* Set other multicast addrs desired. */
+ if_maddr_rlock(sc->ifp);
+ TAILQ_FOREACH(ifma, &sc->ifp->if_multiaddrs, ifma_link) {
+ if (ifma->ifma_addr->sa_family != AF_LINK)
+ continue;
+ cpsw_ale_mc_entry_set(sc->swsc, portmask, sc->vlan,
+ LLADDR((struct sockaddr_dl *)ifma->ifma_addr));
+ if_maddr_runlock(sc->ifp);
+ return (0);
+static int
+cpsw_ale_update_vlan_table(struct cpsw_softc *sc, int vlan, int ports, int untag)
+ int free_index, i, matching_index;
+ uint32_t ale_entry[3];
+ free_index = matching_index = -1;
+ /* Find a matching entry or a free entry. */
+ for (i = 5; i < CPSW_MAX_ALE_ENTRIES; i++) {
+ cpsw_ale_read_entry(sc, i, ale_entry);
+ /* Entry Type[61:60] is 0 for free entry */
+ if (free_index < 0 && ALE_TYPE(ale_entry) == 0)
+ free_index = i;
+ if (ALE_VLAN(ale_entry) == vlan) {
+ matching_index = i;
+ break;
+ if (matching_index < 0) {
+ if (free_index < 0)
+ return (-1);
+ i = free_index;
+ ale_entry[0] = ((untag & 7) << 24)|((untag & 7) << 16)|((0) << 8) | (ports & 7);
+ ale_entry[1] = ALE_TYPE_VLAN << 28 | vlan << 16;
+ ale_entry[2] = 0;
+ cpsw_ale_write_entry(sc, i, ale_entry);
+ return (0);
+ * Statistics and Sysctls.
+#if 0
+static void
+cpsw_stats_dump(struct cpsw_softc *sc)
+ int i;
+ uint32_t r;
+ for (i = 0; i < CPSW_SYSCTL_COUNT; ++i) {
+ r = cpsw_read_4(sc, CPSW_STATS_OFFSET +
+ cpsw_stat_sysctls[i].reg);
+ CPSW_DEBUGF(sc, ("%s: %ju + %u = %ju", cpsw_stat_sysctls[i].oid,
+ (intmax_t)sc->shadow_stats[i], r,
+ (intmax_t)sc->shadow_stats[i] + r));
+#endif
+#ifndef __rtems__
+static void
+cpsw_stats_collect(struct cpsw_softc *sc)
+ int i;
+ uint32_t r;
+ CPSW_DEBUGF(sc, ("Controller shadow statistics updated."));
+ sc->shadow_stats[i] += r;
+ cpsw_write_4(sc, CPSW_STATS_OFFSET + cpsw_stat_sysctls[i].reg,
+ r);
+static int
+cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS)
+ struct cpsw_softc *sc;
+ struct cpsw_stat *stat;
+ uint64_t result;
+ sc = (struct cpsw_softc *)arg1;
+ stat = &cpsw_stat_sysctls[oidp->oid_number];
+ result = sc->shadow_stats[oidp->oid_number];
+ result += cpsw_read_4(sc, CPSW_STATS_OFFSET + stat->reg);
+ return (sysctl_handle_64(oidp, &result, 0, req));
+static int
+cpsw_stat_attached(SYSCTL_HANDLER_ARGS)
+ struct bintime t;
+ unsigned result;
+ getbinuptime(&t);
+ bintime_sub(&t, &sc->attach_uptime);
+ result = t.sec;
+ return (sysctl_handle_int(oidp, &result, 0, req));
+static int
+cpsw_stat_uptime(SYSCTL_HANDLER_ARGS)
+ struct cpsw_softc *swsc;
+ struct cpswp_softc *sc;
+ struct bintime t;
+ unsigned result;
+ swsc = arg1;
+ sc = device_get_softc(swsc->port[arg2].dev);
+ if (sc->ifp->if_drv_flags & IFF_DRV_RUNNING) {
+ getbinuptime(&t);
+ bintime_sub(&t, &sc->init_uptime);
+ result = t.sec;
+ } else
+ result = 0;
+static void
+cpsw_add_queue_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node,
+ struct cpsw_queue *queue)
+ struct sysctl_oid_list *parent;
+ parent = SYSCTL_CHILDREN(node);
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "totalBuffers",
+ CTLFLAG_RD, &queue->queue_slots, 0,
+ "Total buffers currently assigned to this queue");
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "activeBuffers",
+ CTLFLAG_RD, &queue->active_queue_len, 0,
+ "Buffers currently registered with hardware controller");
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxActiveBuffers",
+ CTLFLAG_RD, &queue->max_active_queue_len, 0,
+ "Max value of activeBuffers since last driver reset");
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "availBuffers",
+ CTLFLAG_RD, &queue->avail_queue_len, 0,
+ "Buffers allocated to this queue but not currently "
+ "registered with hardware controller");
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxAvailBuffers",
+ CTLFLAG_RD, &queue->max_avail_queue_len, 0,
+ "Max value of availBuffers since last driver reset");
+ SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalEnqueued",
+ CTLFLAG_RD, &queue->queue_adds, 0,
+ "Total buffers added to queue");
+ SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalDequeued",
+ CTLFLAG_RD, &queue->queue_removes, 0,
+ "Total buffers removed from queue");
+ SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "longestChain",
+ CTLFLAG_RD, &queue->longest_chain, 0,
+ "Max buffers used for a single packet");
+static void
+cpsw_add_watchdog_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node,
+ struct cpsw_softc *sc)
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "resets",
+ CTLFLAG_RD, &sc->watchdog.resets, 0,
+ "Total number of watchdog resets");
+static void
+cpsw_add_sysctls(struct cpsw_softc *sc)
+ struct sysctl_ctx_list *ctx;
+ struct sysctl_oid *stats_node, *queue_node, *node;
+ struct sysctl_oid_list *parent, *stats_parent, *queue_parent;
+ struct sysctl_oid_list *ports_parent, *port_parent;
+ char port[16];
+ int i;
+ ctx = device_get_sysctl_ctx(sc->dev);
+ parent = SYSCTL_CHILDREN(device_get_sysctl_tree(sc->dev));
+ SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "debug",
+ CTLFLAG_RW, &sc->debug, 0, "Enable switch debug messages");
+ SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "attachedSecs",
+ CTLTYPE_UINT | CTLFLAG_RD, sc, 0, cpsw_stat_attached, "IU",
+ "Time since driver attach");
+ node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "ports",
+ CTLFLAG_RD, NULL, "CPSW Ports Statistics");
+ ports_parent = SYSCTL_CHILDREN(node);
+ for (i = 0; i < CPSW_PORTS; i++) {
+ if (!sc->dualemac && i != sc->active_slave)
+ continue;
+ port[0] = '0' + i;
+ port[1] = '\0';
+ node = SYSCTL_ADD_NODE(ctx, ports_parent, OID_AUTO,
+ port, CTLFLAG_RD, NULL, "CPSW Port Statistics");
+ port_parent = SYSCTL_CHILDREN(node);
+ SYSCTL_ADD_PROC(ctx, port_parent, OID_AUTO, "uptime",
+ CTLTYPE_UINT | CTLFLAG_RD, sc, i,
+ cpsw_stat_uptime, "IU", "Seconds since driver init");
+ stats_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "stats",
+ CTLFLAG_RD, NULL, "CPSW Statistics");
+ stats_parent = SYSCTL_CHILDREN(stats_node);
+ SYSCTL_ADD_PROC(ctx, stats_parent, i,
+ cpsw_stat_sysctls[i].oid,
+ CTLTYPE_U64 | CTLFLAG_RD, sc, 0,
+ cpsw_stats_sysctl, "IU",
+ cpsw_stat_sysctls[i].oid);
+ queue_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "queue",
+ CTLFLAG_RD, NULL, "CPSW Queue Statistics");
+ queue_parent = SYSCTL_CHILDREN(queue_node);
+ node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "tx",
+ CTLFLAG_RD, NULL, "TX Queue Statistics");
+ cpsw_add_queue_sysctls(ctx, node, &sc->tx);
+ node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "rx",
+ CTLFLAG_RD, NULL, "RX Queue Statistics");
+ cpsw_add_queue_sysctls(ctx, node, &sc->rx);
+ node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "watchdog",
+ CTLFLAG_RD, NULL, "Watchdog Statistics");
+ cpsw_add_watchdog_sysctls(ctx, node, sc);
+#endif
------------------ Original ------------------
Date: Tue, Jul 5, 2016 03:17 PM
To: "devel"<devel at rtems.org>;
Subject: Re: [3/6] add ti cpsw driver file part 1
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpsw.c 2016-07-05 09:22:41.794327800 +0800
@@ -0,0 +1,2772 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
+ * Copyright (c) 2016 Rubicon Communications, LLC (Netgate)
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * TI Common Platform Ethernet Switch (CPSW) Driver
+ * Found in TI8148 "DaVinci" and AM335x "Sitara" SoCs.
+ * This controller is documented in the AM335x Technical Reference
+ * Manual, in the TMS320DM814x DaVinci Digital Video Processors TRM
+ * and in the TMS320C6452 3 Port Switch Ethernet Subsystem TRM.
+ * It is basically a single Ethernet port (port 0) wired internally to
+ * a 3-port store-and-forward switch connected to two independent
+ * "sliver" controllers (port 1 and port 2). You can operate the
+ * controller in a variety of different ways by suitably configuring
+ * the slivers and the Address Lookup Engine (ALE) that routes packets
+ * between the ports.
+ * This code was developed and tested on a BeagleBone with
+ * an AM335x SoC.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/systm.h>
+#include <sys/endian.h>
+#include <sys/mbuf.h>
+#ifndef __rtems__
+#include <sys/lock.h>
+#else
+#include <rtems/bsd/sys/lock.h>
+#endif
+#include <sys/mutex.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/socket.h>
+#include <sys/sysctl.h>
+#include <net/ethernet.h>
+#include <net/bpf.h>
+#include <net/if.h>
+#include <net/if_arp.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <net/if_vlan_var.h>
+#include <netinet/in_systm.h>
+#include <netinet/in.h>
+#include <netinet/ip.h>
+#include <sys/sockio.h>
+#include <sys/bus.h>
+#include <machine/bus.h>
+#include <sys/rman.h>
+#include <machine/resource.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#ifndef __rtems__
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#endif
+#include "if_cpswreg.h"
+#include "if_cpswvar.h"
+#ifndef __rtems__
+#include <arm/ti/ti_scm.h>
+#endif
+#include <rtems/bsd/local/miibus_if.h>
+#include <sys/malloc.h>
+/* Device probe/attach/detach. */
+static int cpsw_probe(device_t);
+static void cpsw_init_slots(struct cpsw_softc *);
+static int cpsw_attach(device_t);
+static void cpsw_free_slot(struct cpsw_softc *, struct cpsw_slot *);
+static int cpsw_detach(device_t);
+static int cpswp_probe(device_t);
+static int cpswp_attach(device_t);
+static int cpswp_detach(device_t);
+#ifndef __rtems__
+static phandle_t cpsw_get_node(device_t, device_t);
+#endif
+/* Device Init/shutdown. */
+static int cpsw_shutdown(device_t);
+static void cpswp_init(void *);
+static void cpswp_init_locked(void *);
+static void cpswp_stop_locked(struct cpswp_softc *);
+/* Device Suspend/Resume. */
+static int cpsw_suspend(device_t);
+static int cpsw_resume(device_t);
+/* Ioctl. */
+static int cpswp_ioctl(struct ifnet *, u_long command, caddr_t data);
+static int cpswp_miibus_readreg(device_t, int phy, int reg);
+static int cpswp_miibus_writereg(device_t, int phy, int reg, int value);
+static void cpswp_miibus_statchg(device_t);
+/* Send/Receive packets. */
+static void cpsw_intr_rx(void *arg);
+static struct mbuf *cpsw_rx_dequeue(struct cpsw_softc *);
+static void cpsw_rx_enqueue(struct cpsw_softc *);
+static void cpswp_start(struct ifnet *);
+static void cpswp_tx_enqueue(struct cpswp_softc *);
+static int cpsw_tx_dequeue(struct cpsw_softc *);
+/* Misc interrupts and watchdog. */
+static void cpsw_intr_rx_thresh(void *);
+static void cpsw_intr_misc(void *);
+static void cpswp_tick(void *);
+static void cpswp_ifmedia_sts(struct ifnet *, struct ifmediareq *);
+static int cpswp_ifmedia_upd(struct ifnet *);
+static void cpsw_tx_watchdog(void *);
+/* ALE support */
+static void cpsw_ale_read_entry(struct cpsw_softc *, uint16_t, uint32_t *);
+static void cpsw_ale_write_entry(struct cpsw_softc *, uint16_t, uint32_t *);
+static int cpsw_ale_mc_entry_set(struct cpsw_softc *, uint8_t, int, uint8_t *);
+static void cpsw_ale_dump_table(struct cpsw_softc *);
+static int cpsw_ale_update_vlan_table(struct cpsw_softc *, int, int, int);
+static int cpswp_ale_update_addresses(struct cpswp_softc *, int);
+/* Statistics and sysctls. */
+#ifndef __rtems__
+static void cpsw_add_sysctls(struct cpsw_softc *);
+static void cpsw_stats_collect(struct cpsw_softc *);
+static int cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS);
+#endif
+ * Arbitrary limit on number of segments in an mbuf to be transmitted.
+ * Packets with more segments than this will be defragmented before
+ * they are queued.
+#define CPSW_TXFRAGS 8
+/* Shared resources. */
+static device_method_t cpsw_methods[] = {
+ /* Device interface */
+ DEVMETHOD(device_probe, cpsw_probe),
+ DEVMETHOD(device_attach, cpsw_attach),
+ DEVMETHOD(device_detach, cpsw_detach),
+ DEVMETHOD(device_shutdown, cpsw_shutdown),
+ DEVMETHOD(device_suspend, cpsw_suspend),
+ DEVMETHOD(device_resume, cpsw_resume),
+ /* OFW methods */
+#ifndef __rtems__
+ DEVMETHOD(ofw_bus_get_node, cpsw_get_node),
+#endif
+ DEVMETHOD_END
+static driver_t cpsw_driver = {
+ "cpsw",
+ cpsw_methods,
+ sizeof(struct cpsw_softc),
+static devclass_t cpsw_devclass;
+#ifndef __rtems__
+DRIVER_MODULE(cpsw, simplebus, cpsw_driver, cpsw_devclass, 0, 0);
+#else
+DRIVER_MODULE(cpsw, nexus, cpsw_driver, cpsw_devclass, 0, 0);
+#endif
+/* Port/Slave resources. */
+static device_method_t cpswp_methods[] = {
+ DEVMETHOD(device_probe, cpswp_probe),
+ DEVMETHOD(device_attach, cpswp_attach),
+ DEVMETHOD(device_detach, cpswp_detach),
+ /* MII interface */
+ DEVMETHOD(miibus_readreg, cpswp_miibus_readreg),
+ DEVMETHOD(miibus_writereg, cpswp_miibus_writereg),
+ DEVMETHOD(miibus_statchg, cpswp_miibus_statchg),
+ DEVMETHOD_END
+static driver_t cpswp_driver = {
+ "cpswp",
+ cpswp_methods,
+ sizeof(struct cpswp_softc),
+static devclass_t cpswp_devclass;
+DRIVER_MODULE(cpswp, cpsw, cpswp_driver, cpswp_devclass, 0, 0);
+DRIVER_MODULE(miibus, cpswp, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(cpsw, ether, 1, 1, 1);
+MODULE_DEPEND(cpswp, miibus, 1, 1, 1);
+static uint32_t slave_mdio_addr[] = { 0x4a100200, 0x4a100300 };
+static struct resource_spec irq_res_spec[] = {
+#ifdef __rtems__
+ { SYS_RES_MEMORY, 0, RF_ACTIVE },
+#endif
+ { SYS_RES_IRQ, 0, RF_ACTIVE | RF_SHAREABLE },
+ { SYS_RES_IRQ, 1, RF_ACTIVE | RF_SHAREABLE },
+ { SYS_RES_IRQ, 2, RF_ACTIVE | RF_SHAREABLE },
+ { SYS_RES_IRQ, 3, RF_ACTIVE | RF_SHAREABLE },
+ { -1, 0 }
+/* Number of entries here must match size of stats
+ * array in struct cpswp_softc. */
+static struct cpsw_stat {
+ int reg;
+ char *oid;
+} cpsw_stat_sysctls[CPSW_SYSCTL_COUNT] = {
+ {0x00, "GoodRxFrames"},
+ {0x04, "BroadcastRxFrames"},
+ {0x08, "MulticastRxFrames"},
+ {0x0C, "PauseRxFrames"},
+ {0x10, "RxCrcErrors"},
+ {0x14, "RxAlignErrors"},
+ {0x18, "OversizeRxFrames"},
+ {0x1c, "RxJabbers"},
+ {0x20, "ShortRxFrames"},
+ {0x24, "RxFragments"},
+ {0x30, "RxOctets"},
+ {0x34, "GoodTxFrames"},
+ {0x38, "BroadcastTxFrames"},
+ {0x3c, "MulticastTxFrames"},
+ {0x40, "PauseTxFrames"},
+ {0x44, "DeferredTxFrames"},
+ {0x48, "CollisionsTxFrames"},
+ {0x4c, "SingleCollisionTxFrames"},
+ {0x50, "MultipleCollisionTxFrames"},
+ {0x54, "ExcessiveCollisions"},
+ {0x58, "LateCollisions"},
+ {0x5c, "TxUnderrun"},
+ {0x60, "CarrierSenseErrors"},
+ {0x64, "TxOctets"},
+ {0x68, "RxTx64OctetFrames"},
+ {0x6c, "RxTx65to127OctetFrames"},
+ {0x70, "RxTx128to255OctetFrames"},
+ {0x74, "RxTx256to511OctetFrames"},
+ {0x78, "RxTx512to1024OctetFrames"},
+ {0x7c, "RxTx1024upOctetFrames"},
+ {0x80, "NetOctets"},
+ {0x84, "RxStartOfFrameOverruns"},
+ {0x88, "RxMiddleOfFrameOverruns"},
+ {0x8c, "RxDmaOverruns"}
+ * Basic debug support.
+#define IF_DEBUG(_sc) if ((_sc)->if_flags & IFF_DEBUG)
+static void
+cpsw_debugf_head(const char *funcname)
+ int t = (int)(time_second % (24 * 60 * 60));
+ printf("%02d:%02d:%02d %s ", t / (60 * 60), (t / 60) % 60, t % 60, funcname);
+#include <machine/stdarg.h>
+static void
+cpsw_debugf(const char *fmt, ...)
+ va_list ap;
+ va_start(ap, fmt);
+ vprintf(fmt, ap);
+ va_end(ap);
+ printf("\n");
+#define CPSW_DEBUGF(_sc, a) do { \
+ if (sc->debug) { \
+ cpsw_debugf_head(__func__); \
+ cpsw_debugf a; \
+} while (0)
+#define CPSWP_DEBUGF(_sc, a) do { \
+ IF_DEBUG((_sc)) { \
+ cpsw_debugf a; \
+} while (0)
+ * Locking macros
+#define CPSW_TX_LOCK(sc) do { \
+ mtx_assert(&(sc)->rx.lock, MA_NOTOWNED); \
+ mtx_lock(&(sc)->tx.lock); \
+} while (0)
+#define CPSW_TX_UNLOCK(sc) mtx_unlock(&(sc)->tx.lock)
+#define CPSW_TX_LOCK_ASSERT(sc) mtx_assert(&(sc)->tx.lock, MA_OWNED)
+#define CPSW_RX_LOCK(sc) do { \
+ mtx_assert(&(sc)->tx.lock, MA_NOTOWNED); \
+ mtx_lock(&(sc)->rx.lock); \
+} while (0)
+#define CPSW_RX_UNLOCK(sc) mtx_unlock(&(sc)->rx.lock)
+#define CPSW_RX_LOCK_ASSERT(sc) mtx_assert(&(sc)->rx.lock, MA_OWNED)
+#define CPSW_GLOBAL_LOCK(sc) do { \
+ if ((mtx_owned(&(sc)->tx.lock) ? 1 : 0) != \
+ (mtx_owned(&(sc)->rx.lock) ? 1 : 0)) { \
+ panic("cpsw deadlock possibility detection!"); \
+} while (0)
+#define CPSW_GLOBAL_UNLOCK(sc) do { \
+ CPSW_RX_UNLOCK(sc); \
+ CPSW_TX_UNLOCK(sc); \
+} while (0)
+#define CPSW_GLOBAL_LOCK_ASSERT(sc) do { \
+ CPSW_TX_LOCK_ASSERT(sc); \
+ CPSW_RX_LOCK_ASSERT(sc); \
+} while (0)
+#define CPSW_PORT_LOCK(_sc) do { \
+ mtx_assert(&(_sc)->lock, MA_NOTOWNED); \
+ mtx_lock(&(_sc)->lock); \
+} while (0)
+#define CPSW_PORT_UNLOCK(_sc) mtx_unlock(&(_sc)->lock)
+#define CPSW_PORT_LOCK_ASSERT(_sc) mtx_assert(&(_sc)->lock, MA_OWNED)
+ * Read/Write macros
+#define cpsw_read_4(_sc, _reg) bus_read_4((_sc)->irq_res[0], (_reg))
+#define cpsw_write_4(_sc, _reg, _val) \
+ bus_write_4((_sc)->irq_res[0], (_reg), (_val))
+#define BUS_SPACE_PHYSADDR(res, offs) \
+ ((u_int)(rman_get_start(res)+(offs)))
+#define CONTROL_MOD_BASE 0x44E10000
+#define CPSW_GMII_SEL (0x0650)
+/* GMII_SEL Register Field */
+#define GMIISEL_RMII2_IO_CLK_EN (1UL<<(7))
+#define GMIISEL_RMII1_IO_CLK_EN (1UL<<(6))
+#define GMIISEL_RGMII2_IDMODE (1UL<<(5))
+#define GMIISEL_RGMII1_IDMODE (1UL<<(4))
+#define GMIISEL_GMII2_SEL(val) ((0x3 & (val)) << 2)
+#define GMIISEL_GMII1_SEL(val) ((0x3 & (val)) << 0)
+#define GMII_MODE 0
+#define RMII_MODE 1
+#define RGMII_MODE 2
+#define cm_read(a) (*(volatile uint32_t *)(a))
+#define cm_write(a,v) (*(volatile uint32_t *)(a) = (v))
+#define cpsw_cpdma_bd_offset(i) (CPSW_CPPI_RAM_OFFSET + ((i)*16))
+#define cpsw_cpdma_bd_paddr(sc, slot) \
+ BUS_SPACE_PHYSADDR(sc->irq_res[0], slot->bd_offset)
+#define cpsw_cpdma_read_bd(sc, slot, val) \
+ bus_read_region_4(sc->irq_res[0], slot->bd_offset, (uint32_t *) val, 4)
+#define cpsw_cpdma_write_bd(sc, slot, val) \
+ bus_write_region_4(sc->irq_res[0], slot->bd_offset, (uint32_t *) val, 4)
+#define cpsw_cpdma_write_bd_next(sc, slot, next_slot) \
+ cpsw_write_4(sc, slot->bd_offset, cpsw_cpdma_bd_paddr(sc, next_slot))
+#define cpsw_cpdma_read_bd_flags(sc, slot) \
+ bus_read_2(sc->irq_res[0], slot->bd_offset + 14)
+#define cpsw_write_hdp_slot(sc, queue, slot) \
+ cpsw_write_4(sc, (queue)->hdp_offset, cpsw_cpdma_bd_paddr(sc, slot))
+#define CP_OFFSET (CPSW_CPDMA_TX_CP(0) - CPSW_CPDMA_TX_HDP(0))
+#define cpsw_read_cp(sc, queue) \
+ cpsw_read_4(sc, (queue)->hdp_offset + CP_OFFSET)
+#define cpsw_write_cp(sc, queue, val) \
+ cpsw_write_4(sc, (queue)->hdp_offset + CP_OFFSET, (val))
+#define cpsw_write_cp_slot(sc, queue, slot) \
+ cpsw_write_cp(sc, queue, cpsw_cpdma_bd_paddr(sc, slot))
+#if 0
+/* XXX temporary function versions for debugging. */
+static void
+cpsw_write_hdp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+ uint32_t reg = queue->hdp_offset;
+ uint32_t v = cpsw_cpdma_bd_paddr(sc, slot);
+ CPSW_DEBUGF(("HDP <=== 0x%08x (was 0x%08x)", v, cpsw_read_4(sc, reg)));
+ cpsw_write_4(sc, reg, v);
+static void
+cpsw_write_cp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+ CPSW_DEBUGF(("CP <=== 0x%08x (expecting 0x%08x)", v, cpsw_read_cp(sc, queue)));
+ cpsw_write_cp(sc, queue, v);
+#endif
+ * Expanded dump routines for verbose debugging.
+static void
+cpsw_dump_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
+ static const char *flags[] = {"SOP", "EOP", "Owner", "EOQ",
+ "TDownCmplt", "PassCRC", "Long", "Short", "MacCtl", "Overrun",
+ "PktErr1", "PortEn/PktErr0", "RxVlanEncap", "Port2", "Port1",
+ "Port0"};
+ struct cpsw_cpdma_bd bd;
+ const char *sep;
+ int i;
+ cpsw_cpdma_read_bd(sc, slot, &bd);
+ printf("BD Addr: 0x%08x Next: 0x%08x\n", cpsw_cpdma_bd_paddr(sc, slot), bd.next);
+ printf(" BufPtr: 0x%08x BufLen: 0x%08x\n", bd.bufptr, bd.buflen);
+ printf(" BufOff: 0x%08x PktLen: 0x%08x\n", bd.bufoff, bd.pktlen);
+ printf(" Flags: ");
+ sep = "";
+ for (i = 0; i < 16; ++i) {
+ if (bd.flags & (1 << (15 - i))) {
+ printf("%s%s", sep, flags[i]);
+ sep = ",";
+ printf("\n");
+ if (slot->mbuf) {
+ printf(" Ether: %14D\n",
+ (char *)(slot->mbuf->m_data), " ");
+ printf(" Packet: %16D\n",
+ (char *)(slot->mbuf->m_data) + 14, " ");
+#define CPSW_DUMP_SLOT(cs, slot) do { \
+ IF_DEBUG(sc) { \
+ cpsw_dump_slot(sc, slot); \
+} while (0)
+static void
+cpsw_dump_queue(struct cpsw_softc *sc, struct cpsw_slots *q)
+ struct cpsw_slot *slot;
+ int i = 0;
+ int others = 0;
+ STAILQ_FOREACH(slot, q, next) {
+ if (i > 4)
+ ++others;
+ else
+ ++i;
+ if (others)
+ printf(" ... and %d more.\n", others);
+ printf("\n");
Date: Tue, Jul 5, 2016 03:15 PM
Subject: Re: [2/6] add ti cpsw head file
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h 2016-03-18 11:38:45.324075400 +0800
@@ -0,0 +1,178 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _IF_CPSWREG_H
+#define _IF_CPSWREG_H
+#define CPSW_SS_OFFSET 0x0000
+#define CPSW_SS_IDVER (CPSW_SS_OFFSET + 0x00)
+#define CPSW_SS_SOFT_RESET (CPSW_SS_OFFSET + 0x08)
+#define CPSW_SS_STAT_PORT_EN (CPSW_SS_OFFSET + 0x0C)
+#define CPSW_SS_PTYPE (CPSW_SS_OFFSET + 0x10)
+#define CPSW_SS_FLOW_CONTROL (CPSW_SS_OFFSET + 0x24)
+#define CPSW_PORT_OFFSET 0x0100
+#define CPSW_PORT_P_MAX_BLKS(p) (CPSW_PORT_OFFSET + 0x08 + ((p) * 0x100))
+#define CPSW_PORT_P_BLK_CNT(p) (CPSW_PORT_OFFSET + 0x0C + ((p) * 0x100))
+#define CPSW_PORT_P_VLAN(p) (CPSW_PORT_OFFSET + 0x14 + ((p) * 0x100))
+#define CPSW_PORT_P_TX_PRI_MAP(p) (CPSW_PORT_OFFSET + 0x118 + ((p-1) * 0x100))
+#define CPSW_PORT_P0_CPDMA_TX_PRI_MAP (CPSW_PORT_OFFSET + 0x01C)
+#define CPSW_PORT_P0_CPDMA_RX_CH_MAP (CPSW_PORT_OFFSET + 0x020)
+#define CPSW_PORT_P_SA_LO(p) (CPSW_PORT_OFFSET + 0x120 + ((p-1) * 0x100))
+#define CPSW_PORT_P_SA_HI(p) (CPSW_PORT_OFFSET + 0x124 + ((p-1) * 0x100))
+#define CPSW_CPDMA_OFFSET 0x0800
+#define CPSW_CPDMA_TX_CONTROL (CPSW_CPDMA_OFFSET + 0x04)
+#define CPSW_CPDMA_TX_TEARDOWN (CPSW_CPDMA_OFFSET + 0x08)
+#define CPSW_CPDMA_RX_CONTROL (CPSW_CPDMA_OFFSET + 0x14)
+#define CPSW_CPDMA_RX_TEARDOWN (CPSW_CPDMA_OFFSET + 0x18)
+#define CPSW_CPDMA_SOFT_RESET (CPSW_CPDMA_OFFSET + 0x1c)
+#define CPSW_CPDMA_DMACONTROL (CPSW_CPDMA_OFFSET + 0x20)
+#define CPSW_CPDMA_DMASTATUS (CPSW_CPDMA_OFFSET + 0x24)
+#define CPSW_CPDMA_RX_BUFFER_OFFSET (CPSW_CPDMA_OFFSET + 0x28)
+#define CPSW_CPDMA_TX_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0x80)
+#define CPSW_CPDMA_TX_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0x84)
+#define CPSW_CPDMA_TX_INTMASK_SET (CPSW_CPDMA_OFFSET + 0x88)
+#define CPSW_CPDMA_TX_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0x8C)
+#define CPSW_CPDMA_CPDMA_EOI_VECTOR (CPSW_CPDMA_OFFSET + 0x94)
+#define CPSW_CPDMA_RX_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0xA0)
+#define CPSW_CPDMA_RX_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0xA4)
+#define CPSW_CPDMA_RX_INTMASK_SET (CPSW_CPDMA_OFFSET + 0xA8)
+#define CPSW_CPDMA_RX_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0xAc)
+#define CPSW_CPDMA_DMA_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0xB0)
+#define CPSW_CPDMA_DMA_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0xB4)
+#define CPSW_CPDMA_DMA_INTMASK_SET (CPSW_CPDMA_OFFSET + 0xB8)
+#define CPSW_CPDMA_DMA_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0xBC)
+#define CPSW_CPDMA_RX_FREEBUFFER(p) (CPSW_CPDMA_OFFSET + 0x0e0 + ((p) * 0x04))
+#define CPSW_STATS_OFFSET 0x0900
+#define CPSW_STATERAM_OFFSET 0x0A00
+#define CPSW_CPDMA_TX_HDP(p) (CPSW_STATERAM_OFFSET + 0x00 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_HDP(p) (CPSW_STATERAM_OFFSET + 0x20 + ((p) * 0x04))
+#define CPSW_CPDMA_TX_CP(p) (CPSW_STATERAM_OFFSET + 0x40 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_CP(p) (CPSW_STATERAM_OFFSET + 0x60 + ((p) * 0x04))
+#define CPSW_CPTS_OFFSET 0x0C00
+#define CPSW_ALE_OFFSET 0x0D00
+#define CPSW_ALE_CONTROL (CPSW_ALE_OFFSET + 0x08)
+#define CPSW_ALE_CTL_ENABLE (1U << 31)
+#define CPSW_ALE_CTL_CLEAR_TBL (1 << 30)
+#define CPSW_ALE_CTL_BYPASS (1 << 4)
+#define CPSW_ALE_CTL_VLAN_AWARE (1 << 2)
+#define CPSW_ALE_TBLCTL (CPSW_ALE_OFFSET + 0x20)
+#define CPSW_ALE_TBLW2 (CPSW_ALE_OFFSET + 0x34)
+#define CPSW_ALE_TBLW1 (CPSW_ALE_OFFSET + 0x38)
+#define CPSW_ALE_TBLW0 (CPSW_ALE_OFFSET + 0x3C)
+#define ALE_MCAST(_a) ((_a[1] >> 8) & 1)
+#define ALE_MCAST_FWD (3 << 30)
+#define ALE_PORTS(_a) ((_a[2] >> 2) & 7)
+#define ALE_TYPE(_a) ((_a[1] >> 28) & 3)
+#define ALE_TYPE_ADDR 1
+#define ALE_TYPE_VLAN 2
+#define ALE_TYPE_VLAN_ADDR 3
+#define ALE_VLAN(_a) ((_a[1] >> 16) & 0xfff)
+#define ALE_VLAN_REGFLOOD(_a) ((_a[0] >> 8) & 7)
+#define ALE_VLAN_UNREGFLOOD(_a) ((_a[0] >> 16) & 7)
+#define ALE_VLAN_UNTAG(_a) ((_a[0] >> 24) & 7)
+#define ALE_VLAN_MEMBERS(_a) (_a[0] & 7)
+#define CPSW_ALE_PORTCTL(p) (CPSW_ALE_OFFSET + 0x40 + ((p) * 0x04))
+/* SL1 is at 0x0D80, SL2 is at 0x0DC0 */
+#define CPSW_SL_OFFSET 0x0D80
+#define CPSW_SL_MACCONTROL(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x04)
+#define CPSW_SL_MACTL_IFCTL_B (1 << 16)
+#define CPSW_SL_MACTL_IFCTL_A (1 << 15)
+#define CPSW_SL_MACTL_GIG (1 << 7)
+#define CPSW_SL_MACTL_GMII_ENABLE (1 << 5)
+#define CPSW_SL_MACTL_FULLDUPLEX (1 << 0)
+#define CPSW_SL_MACSTATUS(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x08)
+#define CPSW_SL_SOFT_RESET(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x0C)
+#define CPSW_SL_RX_MAXLEN(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x10)
+#define CPSW_SL_RX_PAUSE(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x18)
+#define CPSW_SL_TX_PAUSE(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x1C)
+#define CPSW_SL_RX_PRI_MAP(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x24)
+#define MDIO_OFFSET 0x1000
+#define MDIOCONTROL (MDIO_OFFSET + 0x04)
+#define MDIOCTL_ENABLE (1 << 30)
+#define MDIOCTL_FAULTENB (1 << 18)
+#define MDIOLINKINTRAW (MDIO_OFFSET + 0x10)
+#define MDIOLINKINTMASKED (MDIO_OFFSET + 0x14)
+#define MDIOUSERACCESS0 (MDIO_OFFSET + 0x80)
+#define MDIOUSERPHYSEL0 (MDIO_OFFSET + 0x84)
+#define MDIOUSERACCESS1 (MDIO_OFFSET + 0x88)
+#define MDIOUSERPHYSEL1 (MDIO_OFFSET + 0x8C)
+#define MDIO_PHYSEL_LINKINTENB (1 << 6)
+#define MDIO_PHYACCESS_GO (1U << 31)
+#define MDIO_PHYACCESS_WRITE (1 << 30)
+#define MDIO_PHYACCESS_ACK (1 << 29)
+#define CPSW_WR_OFFSET 0x1200
+#define CPSW_WR_SOFT_RESET (CPSW_WR_OFFSET + 0x04)
+#define CPSW_WR_CONTROL (CPSW_WR_OFFSET + 0x08)
+#define CPSW_WR_INT_CONTROL (CPSW_WR_OFFSET + 0x0c)
+#define CPSW_WR_C_RX_THRESH_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x10)
+#define CPSW_WR_C_RX_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x14)
+#define CPSW_WR_C_TX_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x18)
+#define CPSW_WR_C_MISC_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x1C)
+#define CPSW_WR_C_RX_THRESH_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x40)
+#define CPSW_WR_C_RX_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x44)
+#define CPSW_WR_C_TX_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x48)
+#define CPSW_WR_C_MISC_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x4C)
+#define CPSW_WR_C_MISC_EVNT_PEND (1 << 4)
+#define CPSW_WR_C_MISC_STAT_PEND (1 << 3)
+#define CPSW_WR_C_MISC_HOST_PEND (1 << 2)
+#define CPSW_WR_C_MISC_MDIOLINK (1 << 1)
+#define CPSW_WR_C_MISC_MDIOUSER (1 << 0)
+#define CPSW_CPPI_RAM_OFFSET 0x2000
+#define CPSW_CPPI_RAM_SIZE 0x2000
+#define CPSW_MEMWINDOW_SIZE 0x4000
+#define CPDMA_BD_SOP (1 << 15)
+#define CPDMA_BD_EOP (1 << 14)
+#define CPDMA_BD_OWNER (1 << 13)
+#define CPDMA_BD_EOQ (1 << 12)
+#define CPDMA_BD_TDOWNCMPLT (1 << 11)
+#define CPDMA_BD_PKT_ERR_MASK (3 << 4)
+#define CPDMA_BD_TO_PORT (1 << 4)
+#define CPDMA_BD_PORT_MASK 3
+struct cpsw_cpdma_bd {
+ volatile uint32_t next;
+ volatile uint32_t bufptr;
+ volatile uint16_t buflen;
+ volatile uint16_t bufoff;
+ volatile uint16_t pktlen;
+ volatile uint16_t flags;
+#endif /*_IF_CPSWREG_H */
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h 2016-07-02 21:43:26.205209800 +0800
@@ -0,0 +1,147 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _IF_CPSWVAR_H
+#define _IF_CPSWVAR_H
+#define CPSW_PORTS 2
+#define CPSW_INTR_COUNT 4
+/* MII BUS */
+#define CPSW_MIIBUS_RETRIES 10
+#define CPSW_MIIBUS_DELAY 2000
+#define CPSW_MAX_ALE_ENTRIES 1024
+#define CPSW_SYSCTL_COUNT 34
+#define CPSW_RESEMBLE_BUFFER_LEN 2048
+#define CPSW_RESEMBLE_BUFFER_ALIGN 4
+struct cpsw_slot {
+ uint32_t bd_offset; /* Offset of corresponding BD within CPPI RAM. */
+ bus_dmamap_t dmamap;
+ struct mbuf *mbuf;
+/* yao0718 add why cppi dma can not send when address misalign 32 bits*/
+ uint8_t *resemble;
+ uint8_t *align_res;
+ STAILQ_ENTRY(cpsw_slot) next;
+STAILQ_HEAD(cpsw_slots, cpsw_slot);
+struct cpsw_queue {
+ struct mtx lock;
+ int running;
+ struct cpsw_slots active;
+ struct cpsw_slots avail;
+ uint32_t queue_adds; /* total bufs added */
+ uint32_t queue_removes; /* total bufs removed */
+ uint32_t queue_removes_at_last_tick; /* Used by watchdog */
+ int queue_slots;
+ int active_queue_len;
+ int max_active_queue_len;
+ int avail_queue_len;
+ int max_avail_queue_len;
+ int longest_chain; /* Largest # segments in a single packet. */
+ int hdp_offset;
+struct cpsw_port {
+ device_t dev;
+ int phy;
+ int vlan;
+struct cpsw_softc {
+ device_t dev;
+ int active_slave;
+ int debug;
+ int dualemac;
+#ifndef __rtems__
+ phandle_t node;
+#endif
+ struct bintime attach_uptime; /* system uptime when attach happened. */
+ struct cpsw_port port[2];
+ /* RX and TX buffer tracking */
+ struct cpsw_queue rx, tx;
+ /* We expect 1 memory resource and 4 interrupts from the device tree. */
+ void *ih_cookie[CPSW_INTR_COUNT];
+#ifndef __rtems__
+ int mem_rid;
+ struct resource *mem_res;
+ struct resource *irq_res[CPSW_INTR_COUNT];
+#else
+ struct resource *irq_res[1+CPSW_INTR_COUNT];
+#endif
+ /* An mbuf full of nulls for TX padding. */
+ bus_dmamap_t null_mbuf_dmamap;
+ struct mbuf *null_mbuf;
+ bus_addr_t null_mbuf_paddr;
+ bus_dma_tag_t mbuf_dtag;
+ struct {
+ int resets;
+ int timer;
+ struct callout callout;
+ } watchdog;
+ /* 64-bit versions of 32-bit hardware statistics counters */
+ uint64_t shadow_stats[CPSW_SYSCTL_COUNT];
+ /* CPPI STATERAM has 512 slots for building TX/RX queues. */
+ /* TODO: Size here supposedly varies with different versions
+ of the controller. Check DaVinci specs and find a good
+ way to adjust this. One option is to have a separate
+ Device Tree parameter for number slots; another option
+ is to calculate it from the memory size in the device tree. */
+ struct cpsw_slot _slots[CPSW_CPPI_RAM_SIZE / sizeof(struct cpsw_cpdma_bd)];
+struct cpswp_softc {
+ device_t dev;
+ device_t miibus;
+ device_t pdev;
+ int media_status;
+ int unit;
+ int vlan;
+ struct bintime init_uptime; /* system uptime when init happened. */
+ struct callout mii_callout;
+ struct ifnet *ifp;
+ struct mii_data *mii;
+ struct mtx lock;
+ uint32_t if_flags;
+ uint32_t phy;
+ uint32_t phyaccess;
+ uint32_t physel;
+#endif /*_IF_CPSWVAR_H */
Date: Tue, Jul 5, 2016 03:11 PM
Subject: [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/8f17451a/attachment-0001.html>
