[PATCH 3/4] score: Add _Thread_Lock_acquire_critical()
Tue Jul 5 08:33:18 UTC 2016
Keep interrupts disabled during the thread lock acquire sequence.
 cpukit/score/include/rtems/score/threadimpl.h | 31 +++++++++++++++++++--------
 1 file changed, 22 insertions(+), 9 deletions(-)
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 448f38d..182cb3a 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1105,14 +1105,14 @@ RTEMS_INLINE_ROUTINE void _Thread_Lock_release_default(
- * @brief Acquires the thread lock.
+ * @brief Acquires the thread lock inside a critical section (interrupts disabled).
  * @param[in] the_thread The thread.
- * @param[in] lock_context The lock context for _Thread_Lock_release().
+ * @param[in] lock_context The lock context for _Thread_Lock_release_critical().
- * @return The lock required by _Thread_Lock_release().
+ * @return The lock required by _Thread_Lock_release_critical().
-RTEMS_INLINE_ROUTINE void *_Thread_Lock_acquire(
+RTEMS_INLINE_ROUTINE void *_Thread_Lock_acquire_critical(
   Thread_Control   *the_thread,
   ISR_lock_Context *lock_context
@@ -1123,8 +1123,6 @@ RTEMS_INLINE_ROUTINE void *_Thread_Lock_acquire(
   while ( true ) {
     SMP_ticket_lock_Control *lock_1;
-    _ISR_lock_ISR_disable( lock_context );
      * We assume that a normal load of pointer is identical to a relaxed atomic
      * load.  Here, we may read an out-of-date lock.  However, only the owner
@@ -1168,15 +1166,30 @@ RTEMS_INLINE_ROUTINE void *_Thread_Lock_acquire(
       return lock_0;
-    _Thread_Lock_release( lock_0, lock_context );
+    _Thread_Lock_release_critical( lock_0, lock_context );
 #else
-  _ISR_Local_disable( lock_context->isr_level );
   return NULL;
 #endif
+ * @brief Acquires the thread lock.
+ * @param[in] the_thread The thread.
+ * @param[in] lock_context The lock context for _Thread_Lock_release().
+ * @return The lock required by _Thread_Lock_release().
+RTEMS_INLINE_ROUTINE void *_Thread_Lock_acquire(
+  Thread_Control   *the_thread,
+  ISR_lock_Context *lock_context
+  _ISR_lock_ISR_disable( lock_context );
+  return _Thread_Lock_acquire_critical( the_thread, lock_context );
 #if defined(RTEMS_SMP)
  * Internal function, use _Thread_Lock_set() or _Thread_Lock_restore_default()
1.8.4.5
