Error while adding usb ethernet driver
Deval Shah deval.maker at gmail.com
Wed Jul 6 06:46:30 UTC 2016
I couldn't find rc.conf file. And I added the following. Is this the
correct place ? Because I am still not getting the debug printfs.
diff --git a/testsuite/include/rtems/bsd/test/default-init.h
b/testsuite/include/rtems/bsd/test/default-init.h
index ab2ab3a..873c01a 100644
--- a/testsuite/include/rtems/bsd/test/default-init.h
+++ b/testsuite/include/rtems/bsd/test/default-init.h
@@ -39,6 +39,7 @@ rtems_task Init(
   rtems_status_code sc;
+  rtems_bsd_setlogpriority("debug");
   puts( "*** " TEST_NAME " TEST ***" );
On Tue, Jul 5, 2016 at 1:52 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 05/07/2016 16:54, Deval Shah wrote:
>> 1. I updated the rtems-libbsd to the latest version, and it looks like
>> all the device_printf are closed in one of the update. I am not able to
>> see any log coming from them. Is there any way to switch that on ?
> You can either add:
>  syslog_priority="debug"
> to your rc.conf file or add a call in your init() to:
> The default state of debug is only suitable for developers and not users.
> As a result I have changed the default to suite users. Developers just need
> to enable a suitable priority.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160706/5b7db0c4/attachment.html>
