Updates and Problems on "Raspberry Pi USB and Ethernet Support" Project
Tue Jul 12 10:37:52 UTC 2016
On 12/07/2016 7:13 PM, Deval Shah wrote:
> On Tue, Jul 12, 2016 at 11:07 AM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 12/07/2016 14:41, Deval Shah wrote:
>         The problem with the RaspberryPi_USB was that due to some other
>         updates
>         in mainline, I was not getting the device_printfs. So I switched
>         back to
>         the old repo of mine.
>     It would help if you could please debug this. It is easy to do. Just
>     add a printf in the syslog function and see if it is bring called.
>     If it is being called please check the values and logic for the
>     priority, again some simple prints should show this.
> I added the print statements in the file
> rtems-libbsd/rtemsbsd/rtems/syslog.c in the "void syslog" function.
Thanks.
> It is not being called.
OK.
> Also I checked the same, with the repo which gives
> me the printfs, it turns out that "void syslog" is not being called
> there too.
This must mean the prints have stopped for another reason. I am not sure
what this could be.
