[PATCH] Add Untar_FromChunk_Print() + Test
Alexander Krutwig
alexander.krutwig at embedded-brains.de
Wed Jul 13 11:59:07 UTC 2016
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
cpukit/libmisc/untar/untar.c | 135 ++++++++++++++++++++++++++++++++++++
cpukit/libmisc/untar/untar.h | 30 ++++++++
testsuites/libtests/tar01/init.c | 44 ++++++++++++
testsuites/libtests/tar01/tar01.doc | 1 +
testsuites/libtests/tar01/tar01.scn | 11 +++
5 files changed, 221 insertions(+)
diff --git a/cpukit/libmisc/untar/untar.c b/cpukit/libmisc/untar/untar.c
index f6f4f0c..5287d5a 100644
--- a/cpukit/libmisc/untar/untar.c
+++ b/cpukit/libmisc/untar/untar.c
@@ -542,6 +542,141 @@ Untar_FromFile_Print(
+ * Function: Untar_ChunkContext_Init
+ * Description:
+ * This is a simple subroutine that initializes the Untar_ChunkContext
+ * files out of a part of a block of memory.
+ * Inputs:
+ * Untar_ChunkContext *context - Pointer to a context structure
+ * Output: None
+void Untar_ChunkContext_Init(Untar_ChunkContext *context)
+ context->state = UNTAR_CHUNK_HEADER;
+ context->done_bytes = 0;
+ context->out_fd = -1;
+ * Function: Untar_FromChunk_Print
+ * Description:
+ * This is a simple subroutine used to rip links, directories, and
+ * Inputs:
+ * void *chunk - Pointer to a chunk of a TAR buffer
+ * size_t chunk_size - Length of the chunk of a TAR buffer
+ * Output:
+ * int - UNTAR_SUCCESSFUL (0) on successful completion.
+ * UNTAR_FAIL for a faulty step within the process
+ * UNTAR_INVALID_CHECKSUM for an invalid header checksum.
+ * UNTAR_INVALID_HEADER for an invalid header.
+int Untar_FromChunk_Print(
+ Untar_ChunkContext *context,
+ void *chunk,
+ size_t chunk_size,
+ const rtems_printer* printer
+ char *buf;
+ size_t done;
+ size_t todo;
+ size_t remaining;
+ size_t consume;
+ int retval;
+ unsigned char linkflag;
+ buf = chunk;
+ done = 0;
+ todo = chunk_size;
+ while (todo > 0) {
+ switch (context->state) {
+ case UNTAR_CHUNK_HEADER:
+ remaining = 512 - context->done_bytes;
+ consume = MIN(remaining, todo);
+ memcpy(&context->header[context->done_bytes], &buf[done], consume);
+ context->done_bytes += consume;
+ if (context->done_bytes == 512) {
+ retval = Untar_ProcessHeader(
+ &context->header[0],
+ &context->fname[0],
+ &context->todo_bytes,
+ &context->todo_blocks,
+ &linkflag,
+ printer
+ if (retval != UNTAR_SUCCESSFUL) {
+ context->state = UNTAR_CHUNK_ERROR;
+ return retval;
+ if (linkflag == REGTYPE) {
+ context->out_fd = creat(&context->fname[0], 0644);
+ if (context->out_fd >= 0) {
+ context->state = UNTAR_CHUNK_WRITE;
+ } else {
+ context->state = UNTAR_CHUNK_SKIP;
+ context->todo_bytes = 512 * context->todo_blocks;
+ } else {
+ break;
+ case UNTAR_CHUNK_SKIP:
+ remaining = context->todo_bytes - context->done_bytes;
+ if (context->done_bytes == context->todo_bytes) {
+ break;
+ case UNTAR_CHUNK_WRITE:
+ write(context->out_fd, &buf[done], consume);
+ close(context->out_fd);
+ context->todo_bytes = 512 * context->todo_blocks - context->todo_bytes;
+ break;
+ default:
+ return UNTAR_FAIL;
+ done += consume;
+ todo -= consume;
+ return UNTAR_SUCCESSFUL;
* Function: Untar_FromFile
* Description:
diff --git a/cpukit/libmisc/untar/untar.h b/cpukit/libmisc/untar/untar.h
index d67c29e..5a74918 100644
--- a/cpukit/libmisc/untar/untar.h
+++ b/cpukit/libmisc/untar/untar.h
@@ -44,6 +44,36 @@ int Untar_FromMemory_Print(void *tar_buf, size_t size, const rtems_printer* prin
int Untar_FromFile(const char *tar_name);
int Untar_FromFile_Print(const char *tar_name, const rtems_printer* printer);
+typedef struct {
+ enum {
+ UNTAR_CHUNK_HEADER,
+ UNTAR_CHUNK_SKIP,
+ UNTAR_CHUNK_WRITE,
+ UNTAR_CHUNK_ERROR
+ } state;
+ char header[512];
+ char fname[100];
+ size_t done_bytes;
+ long unsigned todo_bytes;
+ unsigned long todo_blocks;
+ int out_fd;
+} Untar_ChunkContext;
+void Untar_ChunkContext_Init(Untar_ChunkContext *context);
+ void *chunk,
* This converts octal ASCII number representations into an
* unsigned long. Only support 32-bit numbers for now.
diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
index 54760e9..3977447 100644
--- a/testsuites/libtests/tar01/init.c
+++ b/testsuites/libtests/tar01/init.c
@@ -31,6 +31,7 @@ const char rtems_test_name[] = "TAR 1";
rtems_task Init(rtems_task_argument argument);
void test_untar_from_memory(void);
void test_untar_from_file(void);
+void test_untar_chunks_from_memory(void);
#define TARFILE_START initial_filesystem_tar
#define TARFILE_SIZE initial_filesystem_tar_size
@@ -106,6 +107,47 @@ void test_untar_from_file(void)
test_cat( "/dest/symlink", 0, 0 );
+ rtems_status_code sc;
+ rtems_printer printer;
+ int rv;
+ Untar_ChunkContext ctx;
+ unsigned long counter = 0;
+ char *buffer = (char *)TARFILE_START;
+ size_t buflen = TARFILE_SIZE;
+ rtems_print_printer_printf(&printer);
+ /* make a directory to untar it into */
+ rv = mkdir( "/dest2", 0777 );
+ rtems_test_assert( rv == 0 );
+ rv = chdir( "/dest2" );
+ printf("Untaring chunks from memory - ");
+ Untar_ChunkContext_Init(&ctx);
+ do {
+ sc = Untar_FromChunk_Print(&ctx, &buffer[counter], (size_t)1 , &printer);
+ if (sc != RTEMS_SUCCESSFUL) {
+ printf ("error: untar failed: %s\n", rtems_status_text (sc));
+ exit(1);
+ counter ++;
+ } while (counter < buflen);
+ printf ("successful\n");
+ printf( "========= /home/test_file =========\n" );
+ test_cat( "/home/test_file", 0, 0 );
+ printf( "========= /symlink =========\n" );
+ test_cat( "/symlink", 0, 0 );
rtems_task Init(
rtems_task_argument ignored
@@ -115,6 +157,8 @@ rtems_task Init(
test_untar_from_memory();
puts( "" );
test_untar_from_file();
+ puts( "" );
+ test_untar_chunks_from_memory();
TEST_END();
exit( 0 );
diff --git a/testsuites/libtests/tar01/tar01.doc b/testsuites/libtests/tar01/tar01.doc
index 463d6b3..1a8151c 100644
--- a/testsuites/libtests/tar01/tar01.doc
+++ b/testsuites/libtests/tar01/tar01.doc
@@ -14,6 +14,7 @@ directives:
+ Untar_FromMemory
+ Untar_FromFile
+ + Untar_ChunksFromMemory
concepts:
diff --git a/testsuites/libtests/tar01/tar01.scn b/testsuites/libtests/tar01/tar01.scn
index 2c4d6b0..ae20139 100644
--- a/testsuites/libtests/tar01/tar01.scn
+++ b/testsuites/libtests/tar01/tar01.scn
@@ -19,4 +19,15 @@ initial tar image.
(0)This is a test of loading an RTEMS filesystem from an
initial tar image.
+Untaring chunks from memory - untar: dir: home
+untar: file: home/test_file (73)
+successful
+========= /home/test_file =========
+(0)This is a test of loading an RTEMS filesystem from an
+initial tar image.
+========= /symlink =========
+initial tar image.
*** END OF TAR01 TEST ***
1.8.4.5
